设置Timer3 中断0 Z' M3 B7 ]1 x8 T: C- A) k
- void TIM3_INT_Config(void)# ^' k0 d( m% R5 v6 ^
0 Z- Z# m: @! D! S0 g; i4 z; p - NVIC_InitTypeDef NVIC_InitStructure;, v/ {" M3 j& V" h( p& ]
- 0 g) V: R8 U! r7 M; X* R
- /* TIM3 clock enable */+ v: P$ `! ]# X4 I/ `1 X' R3 x
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);: S+ y% Y: j2 s2 t; h' ?- ~* z- c
1 g/ t. t9 i" s- /* TIM3 ÖжÏǶÌ×Éè¼Æ*/) K3 `' W d7 X- A% R$ C
- NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
" S$ l" @! F ?7 q - NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
: ~! [" P- a0 I - NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;0 W0 P! c6 B0 v3 z
- NVIC_Init(&NVIC_InitStructure);
- V' Y& u @$ H1 }2 |" ]4 w - }
复制代码 1 e4 C3 U5 s4 c
) u1 C0 N V4 l7 Y* C设置Timer3 模式3 _3 }) E/ L3 m8 s) ^. A
! j8 v, |% O) C; j" j- void TIM3_OUT_Config(void)
8 Q. E# r# q$ W: Z - {
3 ]) b% }6 V' R) M* n - TIM_TimeBaseInitTypeDef TIM3_TimeBaseStructure;6 M0 D5 C9 L w4 ~( ~ N
- TIM_OCInitTypeDef TIM3_OCInitStructure;
1 x, g5 e$ |: }, _8 _, a$ l5 G( \ - /* ¼ÆËãÔ¤·ÖƵֵ */$ C% T0 @ W0 r
- TM3_PrescalerValue = (uint16_t) (SystemCoreClock / TM3_PRESCALER) - 1;
# S$ y" _# r6 U9 Q6 d- O1 L8 _ - 2 R7 H: N5 o; ^2 L9 q" b/ h0 k
- /* Time ¶¨Ê±Æ÷»ù´¡ÉèÖà */
3 U# N& j+ ?: y; t2 c. t. z - TIM3_TimeBaseStructure.TIM_Period = 65535;* t, ?9 \- M) B/ I3 A- t
- TIM3_TimeBaseStructure.TIM_Prescaler = 0;
& R# n. ^/ ~2 C+ U% \* F0 V9 l - TIM3_TimeBaseStructure.TIM_ClockDivision = 0;
M: @: O. {) G; ?4 l - TIM3_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
# Z3 i4 s8 C, H2 G# k - # e* A% q6 A. q" H, F7 l( B
- TIM_TimeBaseInit(TIM3, &TIM3_TimeBaseStructure);
7 M8 H5 E' a( ?+ m {
6 ^$ U5 s) q; ~2 U) ?- /* Ô¤·ÖƵÆ÷ÅäÖà */! C9 a# L& r$ i8 U: w% Z
- TIM_PrescalerConfig(TIM3, TM3_PrescalerValue, TIM_PSCReloadMode_Immediate);
" t! S, U$ ?9 N& d1 a3 p- |/ w+ e/ I - 6 s, |$ I2 V4 ~; e
- /* Êä³ö±È½ÏʱÐòģʽÅäÖÃÉèÖà */
) M. g: J* j* @/ _4 x% C - TIM3_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
( b" o5 _; @, j8 c - TIM3_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
+ w+ E& G3 ~3 J' X$ N1 W - . `+ ]$ P) B. r( r* q f
- /* Êä³ö±È½ÏʱÐòģʽÅäÖÃ: ƵµÀ3*/
4 ]& L* Q7 X9 }$ g7 D: R, } - TIM3_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
A9 n" b' b! `% L/ a, [ - TIM3_OCInitStructure.TIM_Pulse = TM3_CCR1_Val; //3000
3 E8 U1 w. s9 }* P - TIM_OC3Init(TIM3, &TIM3_OCInitStructure);
9 T2 G% P0 Q# h+ `' U% d' } - TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Disable);( X9 s' d# x; G1 J6 d# K( P1 ?
- * X& b$ `& W! y* N" T
- /* TIM ÖжÏʹÄÜ */0 Q7 U2 ]: R3 r
- TIM_ITConfig(TIM3, TIM_IT_CC3 , ENABLE);7 J I6 w. s S, C& A, L1 ?
- * s& [6 T# {0 A! M, B0 i- V2 ]
- /* TIM3 ʹÄÜ */: \( U& y8 ]1 ^ I9 Q9 R1 J
- TIM_Cmd(TIM3, ENABLE);( W' b; F" ] N: l6 L4 X
( E7 I# J" u( ~$ Q. S# v) |- }
复制代码 . e6 W2 [+ ` k+ @9 \
3. 中断子程序
) }" Z M9 J n3 U5 c, E( z( `) p- l% H* U
- void TIM3_IRQHandler(void)* \% w0 y" C, n
% l0 L- p- x7 L+ E0 ^7 H4 R3 k9 P, @ - if (TIM_GetITStatus(TIM3, TIM_IT_CC3) != RESET)
8 C+ A: F e1 W4 Y; a) | - {
4 s! k! B* O! _0 R3 R0 ~4 O - TIM_ClearITPendingBit(TIM3, TIM_IT_CC3);
9 J4 |( S5 ~( r' k; w* g2 d, k
6 x2 S- }+ C2 Z+ Y# e- Q; z5 R- /* LED3 toggling with frequency = 219.7 Hz */ t# C9 v5 L! d% P5 B/ ?
- // LED1_Toggle();. t1 `( m) m) {+ u4 I) I: Y
- // capture3 = TIM_GetCapture3(TIM3);) R4 H! Z+ S( R! o
- // TIM_SetCompare3(TIM3, capture3 + TM3_CCR1_Val);
3 Q) ~, n" y# B8 @4 ^ - 8 \! Q! O3 h& ^( v
- OutToggle();
9 V6 {0 Z e3 x& u5 x o
4 J5 h! B- s9 P& i' Q0 N0 c- if(TimeRxFlag)
$ P. D* D% {& p - {
- i6 l# g5 u4 q) Z - TimeInterval++;0 [1 d" `$ ?5 V: g7 ~
- if(TimeInterval>4)
) P/ ?6 {# J8 G, X, x$ D - {6 Z9 I1 U" }/ n0 ?' E
- RxFrameEndFlag =1;
- |7 ?$ m$ F! h. ]; M. ^ - }, p- r# _0 v* ^; o1 x- [# G0 Q, |/ t
* O: U1 P+ P9 ] - if(KeyCtrl.bDebunceTime != 0)( s W# t1 _. @ t* ^ B$ w0 X% q
t+ ]# m4 I: V7 e - KeyCtrl.bDebunceTime--;- E) c( p; Y6 F; N4 x
: e/ a% O6 |# X) I - // SevenSegShow(DispBuffer);6 T! ]" P' ^" Q0 a9 [" g' b
- capture3 = TIM_GetCapture3(TIM3);
3 k9 |& Y: a, l5 J' C5 B - TIM_SetCompare3(TIM3, capture3 + TM3_CCR1_Val);3 J' R' [6 J1 L# A- ]
) d0 |5 B1 F4 F - }
: ?" j+ H, f0 a1 y& m4 Q% C* S; M0 k% D( F4 h) d
