一、几个重要的IO口操作函数
, J1 J& T$ [3 w6 c- q2 m- HAL_GPIO_Init(GPIO_TypeDef *GPIOx, GPIO_InitTypeDef *GPIO_Init); // GPIO初始化5 w1 w1 M3 e# N& X& h0 p2 u
( C$ W$ v( A+ e# B! w: `- HAL_GPIO_WritePin(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, GPIO_PinState PinState); // 输出高低电平) E' u, M/ a2 k) {& R' l
- ) ?% w5 H8 Q" b! w. B. O2 B" ~- d
- GPIO_PinState HAL_GPIO_ReadPin(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin); // 读IO口电平
c9 k; S+ S) G/ @: ^
, ~# o c; ?4 g* s- void HAL_GPIO_TogglePin(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin); // 电平取反
复制代码 ( D5 ^6 r5 d9 y$ b1 j4 b
二、几个重要的结构
+ A0 ~% H3 ?, s+ w8 _. \$ R- // GPIO口 GPIOA,GPIOB,GPIOC,GPIOD,GPIOE,GPIOF,GPIOG,GPIOH,GPIOI2 j* W* ]0 x0 ?
- typedef struct
& C; v. e5 @ f( A# n4 [ - {0 {% S& I/ l! w& ]
- __IO uint32_t MODER; /*!< GPIO port mode register, Address offset: 0x00 */
3 m- _' m1 ^* y7 k - __IO uint32_t OTYPER; /*!< GPIO port output type register, Address offset: 0x04 */
9 l/ v& i7 o& l) P( [ - __IO uint32_t OSPEEDR; /*!< GPIO port output speed register, Address offset: 0x08 */) t3 b/ Z3 {- S3 R
- __IO uint32_t PUPDR; /*!< GPIO port pull-up/pull-down register, Address offset: 0x0C */
9 q* n3 ?0 o$ H" i - __IO uint32_t IDR; /*!< GPIO port input data register, Address offset: 0x10 */
$ H$ R) X5 n! S - __IO uint32_t ODR; /*!< GPIO port output data register, Address offset: 0x14 */5 c" V$ E( Z- M% q, M2 Q+ t8 y8 k
- __IO uint32_t BSRR; /*!< GPIO port bit set/reset register, Address offset: 0x18 */
) S0 }2 s1 ?1 J) B0 E$ [7 |2 ^ - __IO uint32_t LCKR; /*!< GPIO port configuration lock register, Address offset: 0x1C */9 @2 p- e _! [9 o6 ~
- __IO uint32_t AFR[2]; /*!< GPIO alternate function registers, Address offset: 0x20-0x24 */* o% h5 X6 u8 E2 X! t
- } GPIO_TypeDef;
复制代码- // GPIO引脚,模式,上下拉,速度,复用等/ b8 B: U9 [9 Q+ e- c
- typedef struct
; F8 f. A" n3 I9 S/ H" T - {# [* c n( U# I! {
- uint32_t Pin; /*!< Specifies the GPIO pins to be configured.
2 \& ^9 Y* [ R* X) ~5 C0 V. Y - This parameter can be any value of @ref GPIO_pins_define */
% i8 D9 K7 @% s' b9 J/ g
7 X0 g9 i& C n. X- uint32_t Mode; /*!< Specifies the operating mode for the selected pins.+ ?- i# {1 V1 Q! e* B
- This parameter can be a value of @ref GPIO_mode_define */* ^/ h9 V9 f( C# W: J
X, Q! E7 n4 E4 ?- uint32_t Pull; /*!< Specifies the Pull-up or Pull-Down activation for the selected pins.; T9 m! F% A: |3 `
- This parameter can be a value of @ref GPIO_pull_define */
$ p* G% h5 `: t) r2 i - |+ [6 |6 u0 z- L
- uint32_t Speed; /*!< Specifies the speed for the selected pins.* u% J T$ ]& ^% n; ]& s& u5 w! o5 k! o
- This parameter can be a value of @ref GPIO_speed_define */
! X$ R5 t9 i( }# o% x6 t - 8 ~, D. j) ~: V0 `5 {. s: d* y
- uint32_t Alternate; /*!< Peripheral to be connected to the selected pins.
" G7 x/ t: I! X" O1 B. g - This parameter can be a value of @ref GPIO_Alternate_function_selection */
: r5 [/ o& A8 r( S- U7 y - }GPIO_InitTypeDef;
复制代码- // GPIO引脚+ D; t% \& j/ s0 M. H/ y3 H
- #define GPIO_PIN_0 ((uint16_t)0x0001U) /* Pin 0 selected */# c0 M- n7 {; H2 v
- #define GPIO_PIN_1 ((uint16_t)0x0002U) /* Pin 1 selected */
8 \8 }, j8 c! X2 d; S3 ? - #define GPIO_PIN_2 ((uint16_t)0x0004U) /* Pin 2 selected */
1 A0 w7 H$ D& c6 u - #define GPIO_PIN_3 ((uint16_t)0x0008U) /* Pin 3 selected */
% |5 N5 [6 A: D - #define GPIO_PIN_4 ((uint16_t)0x0010U) /* Pin 4 selected */8 Q5 L" C' V9 h% j+ M
- #define GPIO_PIN_5 ((uint16_t)0x0020U) /* Pin 5 selected */. t1 {& N% A+ p7 m
- #define GPIO_PIN_6 ((uint16_t)0x0040U) /* Pin 6 selected */
5 U5 I* ~9 H. j0 N" { - #define GPIO_PIN_7 ((uint16_t)0x0080U) /* Pin 7 selected */0 [6 _6 ?: v4 c$ C
- #define GPIO_PIN_8 ((uint16_t)0x0100U) /* Pin 8 selected */
+ K0 k$ x1 g9 U% ~' L6 x& m - #define GPIO_PIN_9 ((uint16_t)0x0200U) /* Pin 9 selected */1 N! h; J8 G; L; Q/ l
- #define GPIO_PIN_10 ((uint16_t)0x0400U) /* Pin 10 selected */
3 t& L$ E* t/ T - #define GPIO_PIN_11 ((uint16_t)0x0800U) /* Pin 11 selected */
T% W6 x8 P4 r$ {: h: r, P - #define GPIO_PIN_12 ((uint16_t)0x1000U) /* Pin 12 selected */8 c$ N, T0 D h& \# Y% a
- #define GPIO_PIN_13 ((uint16_t)0x2000U) /* Pin 13 selected */2 H. Z/ P c x4 h) P {5 j
- #define GPIO_PIN_14 ((uint16_t)0x4000U) /* Pin 14 selected */
( V6 A: I4 d! C' ^4 y - #define GPIO_PIN_15 ((uint16_t)0x8000U) /* Pin 15 selected */
复制代码- // GPIO模式 输入 推挽输出 开漏输出 推挽复用 开漏复用
: p% }( I* i4 m. G1 ]2 X! U - #define GPIO_MODE_INPUT ((uint32_t)0x00000000U) /*!< Input Floating Mode */3 k% F0 y+ _/ v% A( o9 m
- #define GPIO_MODE_OUTPUT_PP ((uint32_t)0x00000001U) /*!< Output Push Pull Mode */5 f8 k4 m. b& \6 O; m" U
- #define GPIO_MODE_OUTPUT_OD ((uint32_t)0x00000011U) /*!< Output Open Drain Mode */5 l5 b$ g$ D \# h
- #define GPIO_MODE_AF_PP ((uint32_t)0x00000002U) /*!< Alternate Function Push Pull Mode */
$ X6 U6 M% U [8 I% \ - #define GPIO_MODE_AF_OD ((uint32_t)0x00000012U) /*!< Alternate Function Open Drain Mode */
复制代码- // GPIO速度 低速 中速 高速 极速7 |4 B. T! F0 R i, W
- #define GPIO_SPEED_FREQ_LOW ((uint32_t)0x00000000U) /*!< Low speed */
, p1 Z2 I2 y3 B - #define GPIO_SPEED_FREQ_MEDIUM ((uint32_t)0x00000001U) /*!< Medium speed */" s b0 m* a. _, _
- #define GPIO_SPEED_FREQ_HIGH ((uint32_t)0x00000002U) /*!< Fast speed */
- q" b5 S, c9 L; z; A: L& q+ d - #define GPIO_SPEED_FREQ_VERY_HIGH ((uint32_t)0x00000003U) /*!< High speed */
复制代码- // GPIO上下拉 无上下拉 上拉 下拉& ]. D3 Y, H0 L0 l) g$ ~
- #define GPIO_NOPULL ((uint32_t)0x00000000U) /*!< No Pull-up or Pull-down activation */$ @$ H# c3 K t9 _) }5 X! m6 L
- #define GPIO_PULLUP ((uint32_t)0x00000001U) /*!< Pull-up activation */: v! T* n9 ~7 k$ `" P
- #define GPIO_PULLDOWN ((uint32_t)0x00000002U) /*!< Pull-down activation */
复制代码- // GPIO引脚高低电平: i2 C6 I4 l) h# b4 r8 ?! ~7 Q
- typedef enum
2 {0 A$ d& h* h7 F# s - {
8 d# Y$ [2 {, k - GPIO_PIN_RESET = 0,; U, I" c5 s a7 ~* e( b. [
- GPIO_PIN_SET
: \# k2 s) N2 t - }GPIO_PinState;
复制代码 2 E8 \2 M8 Y Z( E: j3 u& V) y( N
三、封装两个GPIO初始化函数(普通GPIO,复用GPIO)+ L3 L! k+ `2 d' @: m8 F4 K
- // 这里只贴出代码片段,封装两个接口,一个普通GPIO初始化,一个带复用功能。
$ c5 ^, t, ]7 S& ^1 v/ h9 u% x - #define GPIO_CLK_ENABLE() do{ \
# p/ f. S: H( J. p, J. M; x7 r, R8 l - __HAL_RCC_GPIOA_CLK_ENABLE(); \; T7 n. n1 L0 w+ U0 I# |
- __HAL_RCC_GPIOB_CLK_ENABLE(); \1 t; I3 H/ _# O! e/ K
- __HAL_RCC_GPIOC_CLK_ENABLE(); \ d2 l7 }0 m, r( q5 d
- __HAL_RCC_GPIOD_CLK_ENABLE(); \; a! R1 ]$ Q6 H! v3 B* A. S O
- __HAL_RCC_GPIOE_CLK_ENABLE(); \4 ]; J0 e: w! v( Y
- __HAL_RCC_GPIOF_CLK_ENABLE(); \
- e) l9 i$ [8 s$ k4 x* N - __HAL_RCC_GPIOG_CLK_ENABLE(); \
- ?5 s/ [. S8 q# t+ u2 x* C - __HAL_RCC_GPIOH_CLK_ENABLE(); \" p1 b+ T, P# ~, ?% n% A
- __HAL_RCC_GPIOI_CLK_ENABLE(); \0 Z( D! { k4 d8 h" {
- } while(0);: L$ W! D8 e% F i1 ]9 f5 [( \
- + t6 c& P: [! x$ v- }9 P
- void GPIOConfig(GPIO_TypeDef *gpio, uint32_t pin, uint32_t mode, uint32_t pull)
8 u! n3 a: O: B - {
4 } x6 d6 l) w, x! ~ - GPIO_InitTypeDef GPIO_InitStructure;
2 i6 _) L; Y# B9 r( S - ' z! A2 u4 [+ m2 [$ B8 a
- GPIO_CLK_ENABLE();8 h, D3 P! S( j+ J7 u! T
_+ j0 ^' C! O; E; F- GPIO_InitStructure.Pin = pin;
! _2 O1 k' T% h" M - GPIO_InitStructure.Mode = mode;
0 ^: O! W$ z2 P - GPIO_InitStructure.Pull = pull;
$ Y, G3 _! i1 g& m. ^) l+ h - GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
* K1 h! D+ Q7 G, K4 p& B
% U1 _1 E. y1 U& E3 b- HAL_GPIO_Init(gpio, &GPIO_InitStructure);
. \9 [( d3 k9 k4 ^7 }; \% V$ V% o& j6 @ - }
! A7 u0 ^% r7 x' W* c - 2 n# x0 v. O2 Y
- void GPIOConfigExt(GPIO_TypeDef *gpio, uint32_t pin, uint32_t mode, uint32_t pull, uint32_t alternate)
% d0 A; r2 T0 C, d2 Q - {
2 @: p7 \& K# q& K3 T; d - GPIO_InitTypeDef GPIO_InitStructure;9 B, @& a1 c" ~2 `- s* {9 O; }
+ h: P% i5 }5 W) o2 v; Y- GPIO_CLK_ENABLE();6 j4 R5 |! ~: h3 K
- 8 g$ _6 B* Y8 n+ _' v7 j, |2 S
- GPIO_InitStructure.Pin = pin;" z0 N: `! O E' O7 l3 s# G
- GPIO_InitStructure.Mode = mode;4 X8 [2 N9 M5 o
- GPIO_InitStructure.Pull = pull;0 ~0 i2 Z& W" W* x0 |& Z% L
- GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;+ U% a! r* P0 f" `8 q
- GPIO_InitStructure.Alternate = alternate;
! H& R1 d3 r* K; A- C) C# B
8 I" O g5 L# s5 z- HAL_GPIO_Init(gpio, &GPIO_InitStructure);
' ]9 m8 X- n8 [( R - }
: P+ Y: E$ A% R/ O y+ l/ }. H9 i4 Y0 m+ }7 N% Z/ Y
四、输出接口设计
, P b9 U6 B A+ l为了灵活使用,我们将输出的有效电平设置成可配置。% f% N- l# U3 i1 u' f+ q
- R, \: r0 h! X0 D: K& R
- // 配置的有效电平 初始 低电平有效 高电平有效( C/ x1 T+ ~ H, G
- typedef enum, [% K. _' Q* O- l# @5 T
- {6 C; b+ d- b/ X, p6 Y. W V
- OUTPUT_INIT_IS_ACTIVE = 0,7 s1 i+ L5 j8 [
- OUTPUT_LOW_IS_ACTIVE = 1,
- A8 m; A( |1 z, z, ] - OUTPUT_HIGH_IS_ACTIVE = 2,
) `( o c( B; C - } output_active_t;
' j8 Z# v3 _: G& y - ) B, Q/ X* |! E% W
- #define OUTX_CONFIG(gpio, pin) GPIOConfig(gpio, pin, GPIO_MODE_OUTPUT_PP, GPIO_NOPULL)
% a9 E4 d5 E- l - #define OUTX_READ(gpio, pin) HAL_GPIO_ReadPin(gpio, pin)% V3 y( l& f8 } n" y. A
- #define OUTX_ACTIVE(gpio, pin, tag) do{ \
* M8 @! W% E/ N2 N3 x - if(OUTPUT_LOW_IS_ACTIVE == tag) \( H% u( t1 V: w" Z& R: p
) q/ O" w$ B0 |) w* ~+ U1 b - HAL_GPIO_WritePin(gpio, pin, GPIO_PIN_RESET); \6 F8 w/ U6 Z4 p0 H
8 B3 F$ O+ ?5 H6 K4 U0 m; T! V - else \# \2 r$ q. d# n7 C% q4 P
/ N3 o7 p, ?) v. L- K - HAL_GPIO_WritePin(gpio, pin, GPIO_PIN_SET); \5 F7 C- X2 Z1 P9 j! ^) X/ ~. e
5 M. N, w. j: r# c8 _ - } while(0);, C8 O5 V# | j; X ]0 m, }
- #define OUTX_NEGATIVE(gpio, pin, tag) do{ \' i; h. x! @. f# u. R/ h4 d8 W7 }
- if(OUTPUT_LOW_IS_ACTIVE == tag) \: C2 d$ J& w; k# R. v
& } x. v, g: z. i" N - HAL_GPIO_WritePin(gpio, pin, GPIO_PIN_SET); \" F2 D' @% C8 z3 J0 u# D& [) D
- } \/ W( b& N8 }5 o$ g! @! W
- else \
5 M) G" X! q# [, J# S) R8 n Y - { \! [3 G# y& v! k9 M: D
9 r5 \# ]) F8 o; N - } \- p' _2 `" s6 `4 Q
- } while(0);% {% L1 k# P* ~1 w
- + }- A# Z1 c+ ]$ _0 z( m% a
- #define OUT1_PORT GPIOA
, D% ^9 @1 }' R% b" \% G5 z - #define OUT1_PIN GPIO_PIN_0 O, w1 e6 t; P! A8 |1 R( A
- ; p1 F. O9 i. M' X8 A0 b
- #define OUT2_PORT GPIOA! p8 W& a6 r# q. H, X V
- #define OUT2_PIN GPIO_PIN_1
& i* v' |& q8 ^1 V( B2 F! m
4 w8 q9 t' l. o- #define OUT3_PORT GPIOA) a8 x4 Q8 t& P. {
- #define OUT3_PIN GPIO_PIN_2
复制代码- // demo代码 只传递思想 9 X% \2 M9 ]$ q5 J
- // 封装出对外的四个接口 初始化 输出有效 输出无效 输出取反
1 }, t" @7 `5 D: o# X4 I4 S# P - // 以列表的形式封装 方便增加和删除
6 F# A4 z& _ i$ e" B7 [
1 K' k$ d4 ?& ]2 S9 q; s' Q+ X- static void output_config(GPIO_TypeDef *gpio, uint16_t pin)8 `3 Z; s" @3 J1 P( L9 ~# ]
- {6 I9 @; x( |; f
- OUTX_CONFIG(gpio, pin);
- i. y, Y4 [4 o( X6 i - }$ B7 G8 P9 z. d9 @( r% w; D3 {
; e0 r/ m7 g$ a( r0 p* k. q9 p- static uint8_t output_is_enable(uint8_t index)
/ y L! @; @2 `3 A, l - {' m. z/ m c8 Q1 J) } M
- // 输出通道可用 这里也可以变成可配置 可以配置本IO口有效和无效
+ v/ P M/ Y& G/ \% @6 o) i - return 1; n3 X( d/ i0 N- j1 |
; h4 a5 j' u t# |+ q* b
$ n5 D- ]+ E4 U7 e! q A9 L( L/ i- static void output_active(GPIO_TypeDef *gpio, uint16_t pin, uint8_t tag)3 g% t# k/ T" N1 D6 `4 p
- {$ j7 U) T @3 d& m) R* N( ?+ K
- OUTX_ACTIVE(gpio, pin, tag);
; ^6 l Z" P% H, N - }
/ Y" F+ }0 [3 l1 Z* M5 M/ ~
0 E% ^; x4 g+ P) n4 n5 N& d- static void output_negative(GPIO_TypeDef *gpio, uint16_t pin, uint8_t tag)
5 m; F! }- [5 J; n j - {
- ?# w% _% l$ m: J - OUTX_NEGATIVE(gpio, pin, tag);
. k1 A: W: N1 o* t3 q2 w: L - }% ]2 q! p, |4 c' `) F. `
( X/ s; M0 Q% B/ [ O/ s) h @- static void output_toggle(GPIO_TypeDef *gpio, uint16_t pin, uint8_t tag): ^3 ^' n/ H" Y* c1 V5 ~2 N
- {1 e% c: k# [+ |2 C) m. L
- // 这里可以不用这么麻烦,使用HAL_GPIO_TogglePin& I8 v9 R: X( I& C
- if(OUTX_READ(gpio, pin) == 0)
, }9 M n3 Q8 F* ^! ^. g7 ~! X; ?+ v - {
b) L6 W4 l3 v6 [' H+ ` - OUTX_ACTIVE(gpio, pin, tag);
$ W' I4 B& M7 T4 j2 t5 k2 ?5 r: r* p/ s - }( I6 c& g; f4 h
- else
3 T: k4 D3 q8 C1 l" T. ` E - {
4 H9 e, R! J. M2 u% B) ~: [% O - OUTX_NEGATIVE(gpio, pin, tag);& [& S3 U- c4 f" T0 q6 X6 `
- }4 E( s: _7 i% y
' c% O- p; w7 _) y m - * r( H0 }' M7 e {$ {* L! W1 Z9 @5 o
- typedef struct
" N5 G1 _% l5 P6 J9 R% j! @ - {/ ^; h a }% P4 X8 R3 e" n$ J
- GPIO_TypeDef *gpio;
' ] K' t% H+ T6 i) v1 z - uint16_t pin;" N% X" j! G" Y$ W$ e. }/ L, R
- void (* output_config_cb)(GPIO_TypeDef *gpio, uint16_t pin);3 S, z4 @$ t8 F8 }
- uint8_t (* output_is_enable_cb)(uint8_t index);
" Q$ E0 Y, U) E% p7 } - void (* output_active_cb)(GPIO_TypeDef *gpio, uint16_t pin, uint8_t tag);5 e G F C1 D, E" i& E$ a
- void (* output_negative_cb)(GPIO_TypeDef *gpio, uint16_t pin, uint8_t tag);2 P9 V0 H" P0 [" F
- void (* output_toggle_cb)(GPIO_TypeDef *gpio, uint16_t pin, uint8_t tag);' m0 }" C5 V/ ?' H% {) s
- } output_port_t;: U' e% z" i5 V
- 5 o# g& [6 `& t2 H$ v
- static output_port_t output_items[] =
1 c0 r; Z" H6 w5 `8 w. U - {" {/ s7 s+ { l' l$ R1 }
- {OUT1_PORT, OUT1_PIN, output_config, output_is_enable, output_active, output_negative, output_toggle}," N/ T) p! }; l) Z9 _
- {OUT2_PORT, OUT2_PIN, output_config, output_is_enable, output_active, output_negative, output_toggle},: @: X4 H( m* N
- {OUT3_PORT, OUT3_PIN, output_config, output_is_enable, output_active, output_negative, output_toggle},
, u) q. X4 d! q3 d% J( D - };' ?/ p) S$ q$ A, R! I, @# T# _
: O+ a8 ?* h/ M$ n2 E# ]- static void output_init(uint32_t value)
5 t7 k8 }2 q9 I0 o; d3 `$ G4 s# p7 N - {- R# Z. N$ J" }/ [6 a' r( a
- uint32_t i, mask = 1;
' J. C7 ^! j" k/ w
, x( [ n8 y/ l4 Y! K; L- J- for(i = 0; i < ARRAY_SIZE(output_items); ++i)! R% H; c/ i2 K9 O! V" ~: {$ ^
- {; |, e2 X& P; x* B
- if(value & mask)0 D+ q) H, b; b3 e4 G0 {
- {- |3 @/ ^ g! S: y1 s" k7 }# p
- #if(CONFIG_OUTPUT_TEST == 1)
8 d$ j% J; u5 F2 |4 r - config.output.total_switch = OUTPUT_MODE_OPEN;8 x- i4 Y9 R7 p! H& n2 P( h$ T
- config.output.sub_switch<i> = OUTPUT_MODE_OPEN;9 p, V5 d5 @, M" ?
- </i> config.output.active_tag = OUTPUT_HIGH_IS_ACTIVE;% h, o# t+ ?" o9 o i; O2 H5 J
- #endif8 c d7 l7 p. `9 ^
- output_items.output_config_cb(output_items.gpio, output_items.pin);
# t3 r8 | h5 |( a. X" u2 V - output_items.output_negative_cb(output_items.gpio, output_items.pin, config.output.active_tag);
: P8 S- ^( v/ f+ J7 z6 f' s - }1 y {. o! F& C* y" E' ?$ I6 u2 W
- 1 i) x# [. z% B. V
- mask <<= 1;0 h2 x |5 y5 S' L$ n- c8 F
- }5 Q1 t6 G' k1 p( C* s! ~; k
- }$ P2 w j, x5 f# k! V: J
- 0 A) g3 o- R" J- Q+ X
- void OutputHigh(uint32_t value)
6 t& x& ^) h7 v0 _9 N4 d+ ? - {0 z' F+ J, v& d3 X
3 ~$ ~ Y# `; ?
$ m$ c b( Y x4 l$ u- for(i = 0; i < ARRAY_SIZE(output_items); ++i)
g" T( h, g7 P8 b9 G) _. K - {
- V9 u5 H% \ c7 B1 M6 c/ r) s: \ - if(value & mask)
2 R- t. R) }! ^6 z9 u, F - {
5 N: q+ T3 b+ }/ a - if(output_items.output_is_enable_cb(i))- A' m8 F2 n+ {% [
3 N$ g b8 _# O, p8 U - output_items.output_active_cb(output_items.gpio, output_items.pin, config.output.active_tag);
- K+ U o# z( m5 @0 L( E0 W - }
, a& \) S) L2 g7 r e6 R' H ? - }
: U/ B- N# R! @7 [- X5 P
8 x ~; Z- i/ k2 O1 m4 }8 D- mask <<= 1;
$ L& T! K* w5 b6 q) \9 @) m$ v" B - }
2 o7 h5 P0 Q) M4 e5 _ - }
* `. }! r# t( J y
! p: I0 g' E& i% H- void OutputLow(uint32_t value)
& ]" ~. Q5 z0 D9 H+ j, C( _ - {
$ G' a5 l1 B- B3 m2 h0 n - uint32_t i, mask = 1;
* e3 J; f5 s7 o) V& { - 3 s) p8 c- Y' D5 ?+ K
6 g8 x- W& e/ {* ~ ?: w - {* p2 y( S7 n6 T6 q5 R+ @5 X
- if(value & mask)
/ Q" @. L' h/ V& {/ @( M - {$ }! B7 V0 q, R& \3 v7 ~
- if(output_items.output_is_enable_cb(i))! h9 K! g6 g* a8 x p, y
- {3 h" |- X3 {# E4 e1 H
4 m+ }% n5 h) M8 i7 J - }
" o% `4 X j2 D+ u- c- c6 I - } h" t6 i8 b. Y1 P
) c- H! ]0 }/ x- mask <<= 1;
+ U- d" B3 e P2 \7 w6 z - }0 K( f% w r) c- F6 v
- }1 n& d. c k8 ^+ f/ _+ O. E, X; v
, `3 m" z0 p9 A/ E" c# g9 W- void OutputToggle(uint32_t value)
5 I6 I; g* _4 @8 s+ } - {# F$ ^" F9 Q" p5 G$ H5 R
& I$ j9 q# u; x - + q) ?4 u/ E( T: m1 g; N3 l
- for(i = 0; i < ARRAY_SIZE(output_items); ++i)+ T' [/ s; q. g5 g- v
. a" t, C5 [* Y% _* D - if(value & mask)
% V \- \1 _% G4 d! q - {
! f* a* |2 k o' r/ ?, M8 E - if(output_items.output_is_enable_cb(i))
' U: \9 b8 k* Z# @+ J' ~& }7 p - {6 C x4 M* F& V# S6 S
- output_items.output_toggle_cb(output_items.gpio, output_items.pin, config.output.active_tag);
$ P+ [; h# M/ n" ^$ U$ z - }
" I! D2 w4 h1 M' `& j1 x* ]' N7 K b t - }
1 h+ s$ {: d' r9 e4 I1 } d - ^" H* a& g8 C3 ^5 o# Z/ x8 z! }
- mask <<= 1;4 k7 ^& g$ q. Y$ C7 B5 B
- }9 k* S' w) o, F _' F( x |) {- u
- }& l T' d1 U% b, m8 J
- 5 X8 L" l# J4 l' B9 v! B
- void OutputInit(void)( w5 Q5 U& M0 e4 y; L& G [) Z" B$ h
- { P) b8 a* S; L. W6 d m/ R
- output_init(0xFFFFFFFF);
- L. p$ V* w) B7 | - OutputLow(0xFFFFFFFF);
. Y4 K, y0 @9 Q: X - }- |/ J0 P& ` h# N7 G. N, }
- & P* l7 ^2 `9 \% H2 E) J6 h
; F& ^, ?8 x: K/ _! D9 |0 F |
