【经验分享】STM32文档中关于NVIC寄存器说明的位置
STMCU小助手 发布时间:2022-1-17 22:09
下面,我们看看关于NVIC寄存器的描述,都在哪些手册里面有提到
在使用STM32F10x standard peripheral library写有关于stm32中断的程序的时候,需要开启某个特定中断的控制位,除了对应外设的寄存器之外,还需要设置NVIC的相关寄存器的对应位。例如:
  1. /******  STM32 specific Interrupt Numbers *********************************************************/
    ( J3 s# x5 z5 h9 Y1 F$ b$ m6 `# @3 n
  2.   WWDG_IRQn                   = 0,      /*!< Window WatchDog Interrupt                            */
    & ?: o. o& x3 C, Z( d; x( B
  3.   PVD_IRQn                    = 1,      /*!< PVD through EXTI Line detection Interrupt            */$ K2 a+ E# {2 F) |* n& f
  4.   TAMPER_IRQn                 = 2,      /*!< Tamper Interrupt                                     */, Z2 x1 I, V. F" k9 C5 `
  5.   RTC_IRQn                    = 3,      /*!< RTC global Interrupt                                 */4 [1 j) Y1 S: q
  6.   FLASH_IRQn                  = 4,      /*!< FLASH global Interrupt                               */
    4 V4 C7 p( ?, v- C6 i% j& Z6 P
  7.   RCC_IRQn                    = 5,      /*!< RCC global Interrupt                                 */
    - q: m5 T% s, F4 d1 x
  8.   EXTI0_IRQn                  = 6,      /*!< EXTI Line0 Interrupt                                 */: D* [. D4 D' ?1 c" B/ g
  9.   EXTI1_IRQn                  = 7,      /*!< EXTI Line1 Interrupt                                 */
    , t" f; S$ o0 V& [
  10.   EXTI2_IRQn                  = 8,      /*!< EXTI Line2 Interrupt                                 */: [5 M0 K) }- j1 W* h
  11.   EXTI3_IRQn                  = 9,      /*!< EXTI Line3 Interrupt                                 */
    , y* f, B& y8 P( [9 i
  12.   EXTI4_IRQn                  = 10,     /*!< EXTI Line4 Interrupt                                 */. K1 j( B2 j, j+ u1 U
  13.   DMA1_Channel1_IRQn          = 11,     /*!< DMA1 Channel 1 global Interrupt                      */
    9 O7 G4 I  U3 K- [5 d0 ?
  14.   DMA1_Channel2_IRQn          = 12,     /*!< DMA1 Channel 2 global Interrupt                      */
    - {  P9 J9 a9 q( E
  15.   DMA1_Channel3_IRQn          = 13,     /*!< DMA1 Channel 3 global Interrupt                      */) K& c% d8 r( B! z
  16.   DMA1_Channel4_IRQn          = 14,     /*!< DMA1 Channel 4 global Interrupt                      */
    * q" [$ p; R0 O  q0 E1 Y  S
  17.   DMA1_Channel5_IRQn          = 15,     /*!< DMA1 Channel 5 global Interrupt                      */' H6 d; B; e& X. c( Q- q
  18.   DMA1_Channel6_IRQn          = 16,     /*!< DMA1 Channel 6 global Interrupt                      */
    % @/ H( t; Q# H# h, z
  19.   DMA1_Channel7_IRQn          = 17,     /*!< DMA1 Channel 7 global Interrupt                      */: D: i2 I6 j" E8 \3 a# R% V
  20. % N8 s% n' c( [- ~; p6 B
  21.     NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;# D5 r, }( i/ s
  22.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;) x& s, x. i$ z6 B
  23.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    , t* ^; {1 [9 g
  24.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;! q! V% e; P+ r% l) B
  25.     NVIC_Init(&NVIC_InitStructure);
. N3 g4 n: z: b) E0 d
而NVIC_Init()这个函数:
  1. /**/ P3 s# y+ Z% K: l/ Q% C
  2.   * @brief  Initializes the NVIC peripheral according to the specified3 F2 V* O, W1 v6 i# ?+ W4 `
  3.   *         parameters in the NVIC_InitStruct.
    3 `% o. m8 X) a" G7 T; Y4 d
  4.   * @param  NVIC_InitStruct: pointer to a NVIC_InitTypeDef structure that contains" K# `( G' ?4 f# O
  5.   *         the configuration information for the specified NVIC peripheral.
    + M  ?* e- b3 G( p9 j0 T' o% Z
  6.   * @retval None6 H% E# F6 G/ p5 C
  7.   */5 T$ N, d3 ?9 I" Q1 [
  8. void NVIC_Init(NVIC_InitTypeDef* NVIC_InitStruct)& e2 A) _' E4 f) `. E4 ^$ P1 E
  9. {
    * _+ @7 m* f6 ~) G, V
  10.   uint32_t tmppriority = 0x00, tmppre = 0x00, tmpsub = 0x0F;
    & A; P! y" c! z9 j2 O; Z. P
  11.   ; H& |$ d0 Q( z, ]- p% z
  12.   /* Check the parameters */% V3 L9 j. N" x
  13.   assert_param(IS_FUNCTIONAL_STATE(NVIC_InitStruct->NVIC_IRQChannelCmd));
    3 x, J& x$ R% i/ s$ O
  14.   assert_param(IS_NVIC_PREEMPTION_PRIORITY(NVIC_InitStruct->NVIC_IRQChannelPreemptionPriority));
    % S8 M' ^% |/ l& {3 ?% s1 d1 q
  15.   assert_param(IS_NVIC_SUB_PRIORITY(NVIC_InitStruct->NVIC_IRQChannelSubPriority));
    + `! ~- k8 A6 m9 O4 b
  16.     ) @% P3 k% A$ A$ u4 S( J6 t
  17.   if (NVIC_InitStruct->NVIC_IRQChannelCmd != DISABLE)
    ' o, R: w* c9 X$ h5 F( {; W
  18.   {0 _/ ]/ X; ]: Q( p3 ]' z0 _* e
  19.     /* Compute the Corresponding IRQ Priority --------------------------------*/    ! V8 G7 h; ^: d; t# O3 a/ \
  20.     tmppriority = (0x700 - ((SCB->AIRCR) & (uint32_t)0x700))>> 0x08;
    # ]( A- y7 D7 K% }* T8 m; J1 A: g, p
  21.     tmppre = (0x4 - tmppriority);
    0 D- s! @9 O; P# v' y
  22.     tmpsub = tmpsub >> tmppriority;- z( O$ _4 A2 ~3 t# Z4 Q2 x
  23. ( q! g  _8 l- R; |- l0 \3 Y/ |# S# N
  24.     tmppriority = (uint32_t)NVIC_InitStruct->NVIC_IRQChannelPreemptionPriority << tmppre;
    $ N# P6 j( I0 s: M$ ^: Q
  25.     tmppriority |=  NVIC_InitStruct->NVIC_IRQChannelSubPriority & tmpsub;
      V+ k$ X/ U1 b# \* k% y/ ]
  26.     tmppriority = tmppriority << 0x04;' ^4 P* V  O. Q( [4 C
  27.         ' e+ K1 R- e0 i. \0 Q' @' r
  28.     NVIC->IP[NVIC_InitStruct->NVIC_IRQChannel] = tmppriority;
    : f* W# {9 T& M, Y9 K: _. h
  29.     ' P7 F  `6 `- [, u
  30.     /* Enable the Selected IRQ Channels --------------------------------------*/' Z! h# W6 h, e
  31.     NVIC->ISER[NVIC_InitStruct->NVIC_IRQChannel >> 0x05] =
    . M4 O' O4 x7 N- O3 a
  32.       (uint32_t)0x01 << (NVIC_InitStruct->NVIC_IRQChannel & (uint8_t)0x1F);) k+ n1 J" m/ M, |2 F% W! |
  33.   }
    * y# p1 W) ]+ s( f4 p2 h
  34.   else5 f" K  D- S. o% G- b) X3 k
  35.   {
    4 F+ t! r# d+ e$ v) s) C& m
  36.     /* Disable the Selected IRQ Channels -------------------------------------*/. b% H: x  P4 q' M0 Q
  37.     NVIC->ICER[NVIC_InitStruct->NVIC_IRQChannel >> 0x05] =
    1 x( M) O2 Q; t
  38.       (uint32_t)0x01 << (NVIC_InitStruct->NVIC_IRQChannel & (uint8_t)0x1F);
    " ?0 ~' p% g$ b' M
  39.   }. F7 m+ P5 u+ C% ?5 Y- r; {
  40. }
; Q) l7 _3 U4 _! \& f
可以看到,它会去设置几个寄存器:NVIC的IP,ISER,ICER等等,NVIC是基址,为:
  1. #define SCS_BASE            (0xE000E000)                              /*!< System Control Space Base Address */
    $ O$ D" T2 z2 X- E5 \
  2. #define NVIC_BASE           (SCS_BASE +  0x0100)                      /*!< NVIC Base Address                 */
    ! \1 e9 A, a  C: t+ p# Q
  3. #define SCB_BASE            (SCS_BASE +  0x0D00)                      /*!< System Control Block Base Address */  }2 q  E2 C5 J2 c  }1 C% l
  4. 6 C7 J+ n- d! o" T
  5. 2 x" g; U" ?) K  u$ M: z4 s( }) D
  6. #define NVIC                ((NVIC_Type *)          NVIC_BASE)        /*!< NVIC configuration struct         */
2 n. J: w* P3 C: u5 n/ Y0 m
NVIC_Type为:
  1. /** @addtogroup CMSIS_CM3_NVIC CMSIS CM3 NVIC3 u3 t/ W% c- w! T0 d6 Y5 d
  2.   memory mapped structure for Nested Vectored Interrupt Controller (NVIC)
    : g: A  h6 [( C* d9 p
  3.   @{
    * u' x# ?8 D+ I+ K' d! ]$ p
  4. */
    4 t2 u. I- a1 K$ Z( N) M
  5. typedef struct
    % T9 Q' X) S; U3 _
  6. {
    . h' a. g: f- v2 m1 V
  7.   __IO uint32_t ISER[8];                      /*!< Offset: 0x000  Interrupt Set Enable Register           */
    0 I% Y' I0 v$ ?7 L, y1 n, G  k
  8.        uint32_t RESERVED0[24];
    2 K% A; A+ y2 o- m# a4 U+ t
  9.   __IO uint32_t ICER[8];                      /*!< Offset: 0x080  Interrupt Clear Enable Register         */3 L" m1 Q. s) i" X+ s( T9 f
  10.        uint32_t RSERVED1[24];
    - Z7 I/ T' T3 ^/ N* N. f( o
  11.   __IO uint32_t ISPR[8];                      /*!< Offset: 0x100  Interrupt Set Pending Register          */0 }( a. q# _4 H+ @. x# n: t
  12.        uint32_t RESERVED2[24];
    0 ~/ E3 C- K: Y1 o3 r
  13.   __IO uint32_t ICPR[8];                      /*!< Offset: 0x180  Interrupt Clear Pending Register        */& j1 i2 E$ ^! [; M) ~
  14.        uint32_t RESERVED3[24];                                   : P* @" u- P  Y! @
  15.   __IO uint32_t IABR[8];                      /*!< Offset: 0x200  Interrupt Active bit Register           */
    ( s1 a, a' P# h1 A
  16.        uint32_t RESERVED4[56];                                   # |* D+ e; U4 s8 a' Y
  17.   __IO uint8_t  IP[240];                      /*!< Offset: 0x300  Interrupt Priority Register (8Bit wide) */3 ~9 j0 D# e  `* I% x- l
  18.        uint32_t RESERVED5[644];                                  & L( R2 w; ?8 ]/ ~
  19.   __O  uint32_t STIR;                         /*!< Offset: 0xE00  Software Trigger Interrupt Register     */2 \7 }/ F: \; u1 p; s
  20. }  NVIC_Type;                                               ! i- c" T& T5 k* P8 G
  21. /*@}*/ /* end of group CMSIS_CM3_NVIC */
: X* M, r% n/ @" F- H# K4 v. e
从上面可以了解到的是,NVIC的寄存器的基址是没有错的,《The Definitive Guide to the ARM Cortex-M3》 85页有个比较详细的内存图;或者查看《Cortex-M3 Technical Reference Manual Revision r1p1》3.4 System address map,6.3 NVIC programmers model:
8 W; B( b" a9 X
, u/ V$ Z! g. N) n
以及:
. P: ?! j1 W9 ^3 h6 y) M$ Z
) I7 M6 y1 ]! e. M, U2 o  E
B3.4 Nested Vectored Interrupt Controller (NVIC)的相关说明,例如:
% j. I" k  \" z# J4 L
# E& R* G. `4 s6 H* s  l
当然,你看权威指南也可以的,在其APPENDIX D:NVIC Registers Quick Reference里面也有所描述。
但还有一个问题,我怎么知道这个Interrupt Set-Enable Registers寄存器的哪个位对应哪个中断呢?例如NVIC_ISER0的第0位对应哪个呢,其实,上面的表B3-31的说明已经说了,每一位对应一个中断号,所以我们还得看看stm32F103对应的中断号,可以查阅《RM0008:Reference manual》的第10章,Interrupts and events中的中断向量表,找到对应MD容量的那个表Table 63. Vector table for other STM32F10xxx devices,前面16个M3内核的中断,不可以从这个寄存器里控制,所以不管,我们从WWDG开始,可以看到这个表中的第一列即对应于寄存器中的某位(超过31的自己换算一下即可):
4 t  S1 [3 P' @8 {. ?* d
/ G" e: A; n5 ?( z6 G
可以看到,STM32F10x standard peripheral library文件stm32f10x.h中的中断号的定义是能够与这里对应上的。
另外,stm32F103RB的Datasheet(CD00161566)里面的2.3.5 Nested vectored interrupt controller (NVIC)提到F103仅有43个可屏蔽中断,所以只需用到NVIC_ISER0和NVIC_ISER1来设置启用外设中断。
6 T# Y: U0 q% ^$ W5 L/ S
赞 收藏 评论0 发布时间:2022-1-17 22:09
