- // 添加这个函数+ F# w; S" s* {5 ]: g7 ^
- int fputc(int ch,FILE *f); f) p! M& G" w( v/ T8 n4 a
% W4 ?& ]" w, _0 x, e - uint8_t temp[1]={ch};+ E# ~' }1 O$ d# r* B( x
- HAL_UART_Transmit(&UartHandle,temp,1,2);& ^5 Z9 w% G, S: d
复制代码MDK设置:勾选Use Micro LIB 8 G. \ G& q, x |, b
6 ^' p% X7 {. s& a: o3 o" c
测试板子:STM32F746NG-DISCOVERY main.c文件 - /* Includes ------------------------------------------------------------------*/
& I8 h4 O+ \& e! S4 l3 P$ }# i - #include "main.h"4 U2 O/ R1 p$ j1 }: n3 H' `& e
- #include <stdio.h>- S' p; P0 u& \+ Z# V5 R( K; |
- /** @addtogroup STM32F7xx_HAL_Examples
5 n. m) L& l! Y - * @{
8 i1 P$ {" h* d* ^0 Y' n6 e4 P - */
S- E O O# E# ~1 e6 o0 m7 I - : T8 A0 M8 V* m! p) S& ~
- /** @addtogroup UART_TwoBoards_ComDMA* J. l- D% F; ^) K3 q8 B
/ ^- q% @* A9 J - */ ) `* Y- L/ b6 {- C: s1 j
! u4 N2 {+ I/ k& U. |4 ?- /* Private typedef -----------------------------------------------------------*/
: ~( y8 K K2 Q5 D6 F# e/ ^; y - /* Private define ------------------------------------------------------------*/8 q" x8 v. P* U! @, J) b7 C
- #define TRANSMITTER_BOARD
9 f7 T/ b5 P2 I7 c% F - - q: w4 t: G- C
- /* Private macro -------------------------------------------------------------*/" Q& J" h }3 H5 |! \& x+ X9 y3 B/ A
- /* Private variables ---------------------------------------------------------*/" t! A4 O( H0 Z9 s$ B A9 g2 G+ ~
- /* UART handler declaration */6 O0 S1 t( f5 e7 o
- UART_HandleTypeDef UartHandle;8 P' X( C( P1 I4 e# ]! w& U
- __IO ITStatus UartReady = RESET;7 m' s7 f- a" |1 A/ F# f
- __IO uint32_t UserButtonStatus = 0; /* set to 1 after User Button interrupt */6 H! P; U- Q3 N" i) z
- / |* G8 V9 `# R
- /* Buffer used for transmission */
6 S( _* w1 O8 f - uint8_t aTxBuffer[] = " ****UART_TwoBoards communication based on DMA**** ****UART_TwoBoards communication based on DMA**** ****UART_TwoBoards communication based on DMA**** ";
! P8 L k# s. w* t; x8 k% [8 G3 M - H4 w8 P8 F/ X; Q4 n
- /* Buffer used for reception */
: t8 U2 H! t" g+ G - uint8_t aRxBuffer[RXBUFFERSIZE];+ L1 n$ M, d6 `+ p6 b
) `5 d$ ~; A- f9 ~- a- /* Private function prototypes -----------------------------------------------*/
( f0 l8 w4 E6 Q0 G( l0 E7 T: p - void SystemClock_Config(void);
4 X# M$ x* N" D& P+ _5 X+ V# u3 E - static void Error_Handler(void);7 h$ @6 f" c+ \4 _; Z3 B/ ]
- static uint16_t Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength); X- _/ K/ M& t! c
- static void MPU_Config(void);
2 G& h k& L8 C0 H5 [ - static void CPU_CACHE_Enable(void);/ h, e C1 F+ T h: K
- 9 b6 {3 ]: r, c6 G0 I$ f3 b( v, n( \) F
- /* Private functions ---------------------------------------------------------*/
; n6 h1 \/ E/ f# I+ \ - UART_HandleTypeDef UartHandle;! @$ ?, [* H8 m, q. g$ T
- uint8_t sendbuf[]="send ok ";9 Z v4 R- `6 H% N+ q
Z* _8 v- l9 [5 p) ] }+ n- // 添加这个函数
2 f) K5 g) ^! v0 I/ p - int fputc(int ch,FILE *f)- t( x3 t8 U# m- S! _6 S
) G- A0 s8 ^( O) Y* b - uint8_t temp[1]={ch};# b! N5 v0 y& `" o, Y9 F
& Y d- D# B A. L+ N - }
0 j3 Y7 g( g( U( [8 w- k - 8 ^! \: o6 V* H
5 o. C, e( }, R- c4 S& Z3 C" z - * @brief Main program( X* L) U' m4 C6 t
- * @param None
* }# f4 V9 B3 B! W5 t2 x3 ~ - * @retval None
1 `8 M+ E8 A1 b2 V' ^. o - */2 s2 w/ \4 M4 [9 S
- int main(void)
$ a* c/ C/ r W - {3 n( T2 g% L$ U/ Y' h' a
- /* Configure the MPU attributes as Write Through */
! u9 D* b7 L6 r2 n$ k - MPU_Config();
: y9 e6 J8 d" |4 c' b
0 g" W. c& R4 U- d" n- /* Enable the CPU Cache */) W/ u+ y( p- B- O/ c$ i
- CPU_CACHE_Enable();
* y1 m5 a& k# t9 V8 j; B- c9 I7 b - /* STM32F7xx HAL library initialization:& `+ i- S+ @1 K+ I) k4 i
- - Configure the Flash ART accelerator
7 l: S% d1 {) e% _8 Z - - Systick timer is configured by default as source of time base, but user 7 g7 G7 s- p8 A- O
- can eventually implement his proper time base source (a general purpose 8 {4 w4 B1 p; ?' w: ]
- timer for example or other time source), keeping in mind that Time base 7 m* W- J4 q! [! H- p
- duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and ! o* L9 d! v/ z* r O! B3 S0 {7 \
- handled in milliseconds basis.- O+ c3 S3 H' j
- - Set NVIC Group Priority to 4
- Y% T/ P1 v+ ~$ T' I" @* Y! [( e - - Low Level Initialization. [ y8 F4 E4 n" R" Q
- */: j$ W) D- p+ |5 a
- HAL_Init();
- q6 s6 {- L% A Q- j
9 N- e( J( W0 i4 r- z- o( N- /* Configure the system clock to 216 MHz */
& x5 R+ g! ~/ t' ` - SystemClock_Config();
) w$ @! Y5 w# t: {; [1 p+ S - " c+ D1 \ g2 d& I* g' J# ^
- /* Configure LED1 */. b2 U; S g" x& c
- BSP_LED_Init(LED1);
% N2 v2 n) H |3 X, i" C$ }5 z" f - ! E6 g' R3 ]: ], |$ Z
- UartHandle.Instance = DISCOVERY_COM1;8 g4 x# y8 h5 H( Z: ~. [: k
* K& P& O- G- D: ?4 a- UartHandle.Init.BaudRate = 9600;
. M7 H& h- d0 _, d% n! ], Y - UartHandle.Init.WordLength = UART_WORDLENGTH_8B;
' Z# p; j. X( I9 x, o, d5 E - UartHandle.Init.StopBits = UART_STOPBITS_1;
9 h# ?7 X5 U* L% {7 Q3 q; z - UartHandle.Init.Parity = UART_PARITY_NONE;
; h9 H6 |" C. w* ?" X J - UartHandle.Init.HwFlowCtl = UART_HWCONTROL_NONE;
( I1 U8 ]$ p8 d, T - UartHandle.Init.Mode = UART_MODE_TX_RX;. Y1 ]) a: p- h" h0 Z/ P
- BSP_COM_DeInit(COM1,&UartHandle);6 I9 t0 g: A( M% R) U
- BSP_COM_Init(COM1,&UartHandle);
- t1 b5 }( Q3 K" G4 U -
) i' M- O2 w# j. _: N% J - // HAL_UART_Transmit(&UartHandle,sendbuf,sizeof(sendbuf),10);/ b1 ~9 r( G( y3 r' B* B+ N
- /* Configure User push-button in Interrupt mode */
% [( K9 R, B# S0 L# o - BSP_PB_Init(BUTTON_KEY, BUTTON_MODE_EXTI);
& ~; F. A( ^. J9 _# Y1 Y5 s - 0 m; G1 C1 j$ J7 p6 v4 w
- /* Wait for User push-button press before starting the Communication.3 S9 N$ O N' k# t( Z: g
- In the meantime, LED1 is blinking */
- {1 z) V- F5 x: a0 ^8 | - printf("hello");
7 W- f+ x5 j9 S9 h, L4 {1 ~; i/ c - % W+ ?2 C# m& i, x" G1 A
- 6 z* q! ], l6 ]. F$ U7 N' ~$ H8 j
- while(UserButtonStatus == 0)
: C! d* w; p. r% r; d! v, f - {
- v" q6 e1 ^/ s7 u. x7 _8 J- _2 \ - /* Toggle LED1*/+ M- h5 N8 Y2 i, h! A
- BSP_LED_Toggle(LED1);
( u% m8 F$ t' j! | - HAL_Delay(100);# h- S3 ?1 N" p# _4 X& Q# }
$ k) j# [9 h3 v - /* Turn on LED1 if test passes then enter infinite loop */. b6 H3 a; F: s" `
- BSP_LED_On(LED1); 5 S; T! V5 L5 N0 g2 G" L
- /* Infinite loop */
% T( {, |& ?# ^/ p+ p( | - while (1)
% C: B6 R1 m+ c [ P5 z) I( M - {" U1 Z# w6 ^ n5 u* q9 @/ k0 R' f
- }: `4 |" X! ^6 m9 d3 A5 p
- }. a. c3 ?) F! v% Z: A
- # v8 P* K, i7 W$ H; n" n3 `
- /**3 N! R0 h N% [# |; E. q+ r4 X, V2 y5 r
- * @brief System Clock Configuration, J9 N$ R/ r; X. y4 u
- * The system Clock is configured as follow : : V' \$ W+ V, F) ~5 {7 i
- * System Clock source = PLL (HSE)7 h. ^. x& d9 J+ w5 b. `
- * SYSCLK(Hz) = 216000000: n: N: f& J; a) p* N; C7 p
- * HCLK(Hz) = 2160000006 `. e5 |" E) c( _; P
- * AHB Prescaler = 1
7 _' B9 @9 m3 ^1 d4 i( `% U' [ - * APB1 Prescaler = 4
: k" r, B: |8 C; \' z$ l. T5 o - * APB2 Prescaler = 2& a- B6 s; _+ m) B( W# Z5 ]* k
- * HSE Frequency(Hz) = 25000000/ `% T& [7 H: }0 F2 v( u: c1 D4 k3 W# W
- * PLL_M = 25
( v1 ], ^6 P0 X j; j4 j - * PLL_N = 4328 S; L: w( D7 m5 c
- * PLL_P = 2
' R3 g7 v. r+ h0 L& N' _( i6 r+ S - * PLL_Q = 9
$ Z! C* H3 C, c4 {# U" \ - * VDD(V) = 3.3
1 [; ~8 x' s( T* ` `2 K2 ^2 G" @ - * Main regulator output voltage = Scale1 mode3 H9 P, k" P# x% D& T2 l
- * Flash Latency(WS) = 7- [. E5 D- h& w- p8 Q
- * @param None) K/ q: i0 z) v( |9 Y% |; I9 c
- * @retval None
# A5 v6 Q5 H# {, M3 ?: D - */* q" a2 f+ O+ [" O7 w8 W
- void SystemClock_Config(void)) V6 H) I5 H6 e
6 M9 F9 }% j4 l6 m$ f - RCC_ClkInitTypeDef RCC_ClkInitStruct;
, Y, u* ?7 j1 W9 j" Q, D - RCC_OscInitTypeDef RCC_OscInitStruct;. q( P6 ~8 @/ O& o
- HAL_StatusTypeDef ret = HAL_OK;
& R2 M5 N/ D1 Q* E
7 l( \* W/ k7 X5 Z- ~- /* Enable HSE Oscillator and activate PLL with HSE as source */( j' P) i' n1 P
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
+ Z9 e, t$ R- Z8 P2 Q, G* C" A - RCC_OscInitStruct.HSEState = RCC_HSE_ON;9 J# E/ R# L' M# S& Q
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;' R& S/ _# N; y
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
3 `' d* \) F; \! a - RCC_OscInitStruct.PLL.PLLM = 25;
- g; ]! \7 N! C3 X! A" E - RCC_OscInitStruct.PLL.PLLN = 432;" Y, W9 t! o2 G! K9 K# P
- RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;# |& m& @, ]- ~: l5 w
- RCC_OscInitStruct.PLL.PLLQ = 9;
' F; V5 Q! R3 | j -
: s) U; @9 L+ |. o+ }# f8 Y1 {) ` - ret = HAL_RCC_OscConfig(&RCC_OscInitStruct);
2 _. s' s' V& `- i- q( e - if(ret != HAL_OK)
5 G3 _! |6 ]: H: B4 u$ d - {# G( D- `- R' V
- while(1) { ; }6 ^& a- w* `7 H# r
! u* r/ O3 u2 ]' O2 f2 f# c5 Y# Z2 ` -
" m7 Z1 t% [2 L+ o, C$ } - /* Activate the OverDrive to reach the 216 MHz Frequency */
. \- M6 ^, V; \7 d! y! \ - ret = HAL_PWREx_EnableOverDrive();
7 d7 }9 r( r5 E& W, A( p: Z; V - if(ret != HAL_OK)
e2 S& f6 ~; T) s - {
" [5 s, T& _" Y2 m2 b5 e: Y: | - while(1) { ; } V; T a. I5 j
: b' P$ n- D8 N5 F5 N7 V -
" ?. ~' n( \+ x& j3 K0 J! N; t9 S - /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks dividers */
2 ~0 N& A+ u3 b7 A - RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
+ g( s, B/ A) d- I& D7 ` - RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;/ G* X5 l/ O m2 n6 i, c5 W0 M2 X
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; x0 S6 R: \- K# H; X; P) j) U) x" Q
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4; / o( o! j. W8 c" ~
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2; & t: R3 o" F$ O% w# I2 ~! _4 X5 x4 u. s
- 8 e+ H( `) {, y. @2 d g# `
- ret = HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7);8 l% d' E7 x5 G& h6 o( P% Z9 A3 s
- if(ret != HAL_OK)
7 H- H. Z$ \4 ` Y+ T - {
) x( e) n. i4 }) x. x' K. h' r - while(1) { ; }1 y0 m4 |/ s7 X1 x
2 B2 K, G$ L4 j - }
$ Z" t7 ?9 T; P
( ?3 p) o8 S! M+ y; [- x- /**8 ], H4 E: I& Z5 V
- * @brief Tx Transfer completed callback" u: g2 i; q, S: A% l
- * @param UartHandle: UART handle. 5 G. R8 |, Q6 B% T- U$ g
- * @note This example shows a simple way to report end of DMA Tx transfer, and * E0 h1 u- ?/ N) s9 v- t/ D8 O
- * you can add your own implementation. ! \. A# l c, b2 S+ F8 S# b/ q
- * @retval None! O) W# h. X* g5 T0 G1 E
, _. I. k; |0 t; }! |3 g3 q" D - void HAL_UART_TxCpltCallback(UART_HandleTypeDef *UartHandle)
. U7 n9 h/ U5 R8 a - {' R' q! o# x: @: J" F# L: o
- /* Set transmission flag: trasfer complete*/6 I" `- R2 x6 r: ~1 R
- UartReady = SET;
- W- Z- p1 S* u+ O - & h4 n# U' t% u* o
% [) G4 M& a' ?2 L$ b6 V - }7 {, H% t: W' Y8 Q9 `& L8 x
, g" q$ m* f, j- /**
# P9 A$ e$ z6 O# t - * @brief Rx Transfer completed callback
9 C( F! F5 \! }/ |( H0 y - * @param UartHandle: UART handle
- F/ V. [1 E8 s; H: u4 _. e, b - * @note This example shows a simple way to report end of DMA Rx transfer, and
J9 c+ ] w; H+ v4 }+ j' z - * you can add your own implementation.
k' F/ K- C; N" r/ X - * @retval None
% j9 _, U( D2 A+ m/ Z( N - */+ d, \* u# y: [# X; H: O
- void HAL_UART_RxCpltCallback(UART_HandleTypeDef *UartHandle)
3 [9 ~. ] N+ ~% J$ j M+ r5 O2 C - {! \# D! K" U4 l; B; t8 F
/ r1 t/ q! q: R ~& O6 a - UartReady = SET;/ t' q' d3 J1 |
3 e" E; Z: e' A8 b0 q- + ]1 w) S5 X& w# y
- }% h6 z g4 N- P7 d' g* t% M) j2 X
- 5 a! e8 F0 D- l' I, J8 H. g
- /**3 I7 U: d% @ X. @+ e' b" o8 T
- * @brief UART error callbacks9 C1 F; i! }5 x4 R b3 H1 J
- * @param UartHandle: UART handle) f# B% e( U- V: x
- * @note This example shows a simple way to report transfer error, and you can
# Q9 o/ r% J" N J, s# E) j; D - * add your own implementation.
( L! X+ a+ g1 ^+ C2 ]5 N - * @retval None
# L' \" Z t- _8 V3 n - */
& v; Y ^, a+ y6 k& J$ P - void HAL_UART_ErrorCallback(UART_HandleTypeDef *UartHandle)$ Z' H4 J* W! t3 S6 ?) ^
- {0 W0 N" ^2 k _3 }1 f
- Error_Handler();' y$ Q# k, e# {( J
' i& M+ G/ r9 M0 g
) ~+ O. u) D& b$ S- ! X2 q) L0 \) |
- /**0 L+ M- T! Q( r6 P" X1 d
- * @brief EXTI line detection callbacks
' a+ y5 U. D, |3 p$ z - * @param GPIO_Pin: Specifies the pins connected EXTI line
5 Z" j1 {& r) \" d; f - * @retval None9 @: e" ?, n' ]; ^
/ X& P% N' ~; A8 ]5 p - void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
" Y9 o3 Y9 z4 K* `% }- w - {1 w' S' \! G" B, B
- if(GPIO_Pin == KEY_BUTTON_PIN)
+ ?! ~3 N8 S* i/ f - {
3 h! u! f0 X, L( ]$ D6 o$ X - UserButtonStatus = 1;' x2 T7 @9 v( h: w/ x- Q
- }- z0 k' ?/ k8 h+ k$ m
- } P- Y6 Y3 `% {& R- ~2 H
- ( C2 u6 t' P+ s( L x
( r4 O; E/ l' I4 C$ w. Z J - * @brief Compares two buffers.
+ k4 R& J$ }; ?" N - * @param pBuffer1, pBuffer2: buffers to be compared.
5 q# l. K, L3 F, |: K& P - * @param BufferLength: buffer's length
8 d* o* n: ~: J2 V: ?- ~ - * @retval 0 : pBuffer1 identical to pBuffer2
- r! E% \1 D ]& ~1 t1 [( t - * >0 : pBuffer1 differs from pBuffer2
1 B- |4 }( G+ M! r7 ]5 [ - */; ?5 i5 n, t; _
- static uint16_t Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength)* e, [7 f( z. Z( G
8 ]! _6 B! Y# p0 S i: G) L3 h& w7 k - while (BufferLength--)
6 A5 p& p4 n, h - {
C& r6 W) L3 q* m+ [1 F - if ((*pBuffer1) != *pBuffer2)
4 X5 y) W; h# p: I& c3 r - {
8 \' J/ G) ~) d( G - return BufferLength;
" D% w# I; @/ d& r% i8 e, Z - }; S# h5 d, ?) m
- pBuffer1++;
: F! M* K2 o1 h! ~- w - pBuffer2++;
2 _4 |1 `/ Q3 g6 N2 ~. m4 E - }
+ v7 U7 ~% k8 Q# P8 O5 n - 2 E# Z1 w# X) e
- return 0;) @8 K( j1 p3 _% z/ t
t# G8 G ?+ g2 s9 t* i t0 K - , G+ E% V. ]8 L' X6 k
. N. k/ `3 s; A r& s a E - * @brief This function is executed in case of error occurrence.. J, P, B: m$ L5 m! F
- * @param None( Q1 n5 v8 {! U
- * @retval None
) m/ m6 u. P1 z( C! [9 t% X - */5 f% L6 j/ }: T1 p& {/ |
( ^# t3 x+ q! l( v+ b1 n - {
" \# e/ {% _ a* ^/ L - /* Turn LED1 on */9 ~6 e0 w4 ~0 Q7 o6 ~
- BSP_LED_On(LED1);
# @* w$ b# D' {8 ]: o( ^ - while(1)
3 }; W! V3 C5 K& e' C - { n9 x& T1 M5 N+ I z
- /* Error if LED1 is slowly blinking (1 sec. period) */3 M# N: u2 r, _0 F. i/ t
- BSP_LED_Toggle(LED1); 0 o; i4 S! ~; \
- HAL_Delay(1000); ; N- m; h& g0 o/ a% h* _
- } 4 _, o) B1 _+ j E7 I
- }0 ?0 z5 _( D8 O& _2 \6 `% u5 t5 a
- + t' O+ R: C/ q8 q1 N
- #ifdef USE_FULL_ASSERT& h/ v5 [& H; o1 Z" q! ~1 `0 L
- ( P/ S5 a+ d1 D9 E
- /**% h0 O: b' L, I. l, N2 A
- * @brief Reports the name of the source file and the source line number/ \% l: R A) r+ v$ k
- * where the assert_param error has occurred.
$ _- e$ q* u' } - * @param file: pointer to the source file name- @3 k2 v! A4 I) g4 Q# n. m0 V7 ]
- * @param line: assert_param error line source number, p( O& B, O2 p9 s* Y4 t7 s
- * @retval None
3 Z% \" ^$ o* x( Z) B - */4 r! [& W0 @ w9 l% J2 e
- void assert_failed(uint8_t* file, uint32_t line)
" X7 U- |* r# E* Y: k5 m - {
f5 n D* z. c% S - /* User can add his own implementation to report the file name and line number,
7 q% I" ~4 f& }8 S - ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/ k+ f7 w9 Z0 W1 @! U2 j6 V/ c1 e - " {4 k0 a" _( G3 _) T7 v4 U6 H5 V
! s. S7 T! J! Q) v8 B- }/ ~$ x - while (1)
. O, c* L9 H- N6 l+ v) E5 O% f0 ` - {+ v- }! j: `$ ^
- }4 Z4 l. v$ [% N
- }( T" W* k0 K4 \# P& v. Y
- #endif
9 ]4 ^) @$ P! P
9 N4 k/ I. t. K- /**) ^7 P. t4 o) a' E0 e V( i" h
- * @brief Configure the MPU attributes as Write Through for SRAM1/2.
) _, W! }. M, S# I8 x, C6 S - * @note The Base Address is 0x20010000 since this memory interface is the AXI.
2 Z( P3 F3 F. B9 E ?5 [ - * The Region Size is 256KB, it is related to SRAM1 and SRAM2 memory size.
9 i8 c" q6 d7 n/ R, f0 t+ h! s - * @param None$ d( K' Z* g$ d e t; K' \$ y/ S
- * @retval None! z# `4 n: W- W9 U3 ~; S
- */. D$ T6 Q! S+ C7 S
- static void MPU_Config(void)6 p' f) f5 w/ U! O7 _. r) ~
- {: t5 z! j% w: J- @
- MPU_Region_InitTypeDef MPU_InitStruct;5 Y* `/ E- G o0 A8 g3 b1 |3 i
- ) {6 F8 W* p1 @5 Y0 J Y8 l$ }/ U
- /* Disable the MPU */' d s) a" n& m. s; z" U
- HAL_MPU_Disable();4 J1 l6 @2 A7 ^' w1 P2 ?
3 I5 D u* T0 G( b- /* Configure the MPU attributes as WT for SRAM *// D4 [" v% v9 j9 t m
- MPU_InitStruct.Enable = MPU_REGION_ENABLE;
- ^$ p u0 {/ P- o3 | - MPU_InitStruct.BaseAddress = 0x20010000; t: j; C, @8 @7 }; u; n+ q
- MPU_InitStruct.Size = MPU_REGION_SIZE_256KB;& {9 t6 K1 Q. ~* a$ z2 c; G
- MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
* M9 t( r ^* e [4 K - MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
1 j* y0 W1 z. j7 m) ^ - MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
, H0 q# p' b% U - MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
/ c$ L; [- ?) S$ T - MPU_InitStruct.Number = MPU_REGION_NUMBER0; ?- S: s5 {" F2 O k
- MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
4 i4 d* T7 [ F& J1 | - MPU_InitStruct.SubRegionDisable = 0x00;" R/ C. R8 f8 K8 L1 G- \0 s
- MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
5 \! I' p' `: @8 W D, U4 s - . S) Y" v4 m) b- R; ?5 S
- HAL_MPU_ConfigRegion(&MPU_InitStruct);
" D$ F- V5 k8 K3 u, o - , I: d9 V' Z7 {/ R3 ~
- /* Enable the MPU */
" I; M/ } d5 `3 z" V - HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
2 x! P3 h9 ]/ K - }7 ]1 T# Y3 S+ g) A
- . p0 N3 F9 T7 }
- /**! W3 r3 Q, X7 ?" H
- * @brief CPU L1-Cache enable.
3 r) b% y; K$ k; _1 E - * @param None5 C! I. y6 j7 O
- * @retval None7 y8 Z1 s( S- K1 S
- */; k: U9 N( t2 s
- static void CPU_CACHE_Enable(void)" e0 \4 r9 t4 _
- {4 \8 W( W+ d2 ? p0 U
- /* Enable I-Cache */
3 t7 t3 x7 k0 o& r ` { - SCB_EnableICache();: h: _7 z/ I# B6 g7 t" s& l
( \* \9 `* o5 ?' E' |) T- /* Enable D-Cache */
& Z/ s K& ?) j: L9 C7 ?! j - SCB_EnableDCache();
+ x' u, G/ G) C! s - }& W+ R% e8 Q0 z
- + g z5 Y. ]% e" W5 \! N, q$ b$ X
- /**. P( D4 B0 Y8 W" ]# N$ i
- * @}! s( k, _) ]0 o/ o0 l
- */; j6 ?! ^4 n# O8 L7 E% n4 @$ N- ?. P
- 3 w7 L i7 @8 f) U6 m( b+ r
% Q m$ A4 E! I* ?. r& }5 b, l - * @}“stdio.h”
$ C3 R2 Y1 Q- B( p1 F& r - */
% P' B* ]. r0 \6 { - & ~9 S' C# n& u" @" P! a* r# z
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
复制代码 - t4 l6 t; M3 }0 B; C! @) Z
今天调试了stm32f407的ADC,一切顺利,然而用串口发送ADC结果时都是16进制数,看着很不爽。于是打算用用牛B的“printf”函数,按照以前的做法,在main文件中添加了“stdio.h”,写好了“printf”函数,沏杯茶,打算边品茶边坐等结果,然而这一坐竟坐了半天也没见结果 。一调试发现程序停在了printf函数处,百思不得其解,百度之,得答案,不敢独享,分享如下:
3 r, C$ k' a; e7 f3 y$ W" {7 V5 |3 T7 a. F5 ^; B* E
STM32串口通信中使用printf发送数据配置方法(开发环境 Keil RVMDK) 标签: STM32 串口通信 printf方法 2011-06-29 23:29 在STM32串口通信程序中使用printf发送数据,非常的方便。可在刚开始使用的时候总是遇到问题,常见的是硬件访真时无法进入main主函数,其实只要简单的配置一下就可以了。
$ H8 k9 c3 @, q* _% U+ C% u3 q下面就说一下使用printf需要做哪些配置。 . m& V5 C, L4 f3 X- K
有两种配置方法: 一、对工程属性进行配置,详细步骤如下 1、首先要在你的main 文件中 包含“stdio.h” (标准输入输出头文件)。 2、在main文件中重定义<fputc>函数 如下: // 发送数据 int fputc(int ch, FILE *f) { USART_SendData(USART1, (unsigned char) ch);// USART1 可以换成 USART2 等 while (!(USART1->SR & USART_FLAG_TXE)); return (ch); } // 接收数据 int GetKey (void) { while (!(USART1->SR & USART_FLAG_RXNE)); return ((int)(USART1->DR & 0x1FF)); } 这样在使用printf时就会调用自定义的fputc函数,来发送字符。 3、在工程属性的 “Target" -> "Code Generation" 选项中勾选 "Use MicroLIB"” MicroLIB 是缺省C的备份库,关于它可以到网上查找详细资料。
' r! S. N7 ^4 ?+ v$ V" J至此完成配置,在工程中可以随意使用printf向串口发送数据了。
* s" q, A/ G! U2 b; @. g二、第二种方法是在工程中添加“Regtarge.c”文件 1、在main文件中包含 “stdio.h” 文件 2、在工程中创建一个文件保存为 Regtarge.c , 然后将其添加工程中 在文件中输入如下内容(直接复制即可) #include <stdio.h> #include <rt_misc.h> #pragma import(__use_no_semihosting_swi) extern int SendChar(int ch); // 声明外部函数,在main文件中定义 extern int GetKey(void); struct __FILE { int handle; // Add whatever you need here }; FILE __stdout; FILE __stdin; int fputc(int ch, FILE *f) { return (SendChar(ch)); } int fgetc(FILE *f) { return (SendChar(GetKey())); } void _ttywrch(int ch) { SendChar (ch); } int ferror(FILE *f) { // Your implementation of ferror return EOF; } void _sys_exit(int return_code) { label: goto label; // endless loop }
4 t( Y/ j, D5 O% ?% s ]3、在main文件中添加定义以下两个函数 int SendChar (int ch) { while (!(USART1->SR & USART_FLAG_TXE)); // USART1 可换成你程序中通信的串口 USART1->DR = (ch & 0x1FF); return (ch); } int GetKey (void) { while (!(USART1->SR & USART_FLAG_RXNE)); return ((int)(USART1->DR & 0x1FF)); }
4 ]1 ^' x3 Q% `8 {$ ~ |
