我分别驱动lsm6dsl和lis2mdl时,数据是正常的,但是现在我们产品的方案是使用lsm6dsl的sensor hub模式去驱动lis2mdl,并获取软硬校准之后的数据,但是我按照”an5040-LSM6DSL:始终开启的3D 加速度计和3D 陀螺仪.pdf“的sensor hub的例子去驱动的时候,读取出来的数据一直没有变化,三组数据都没有变化,包括 OUT_MAG_RAW_X_L、SENSORHUB1_REG、 SENSORHUB13_REG这三个寄存器的数据,都没有变化,可以帮我看着是什么问题吗?下面是我的代码 版本1: ``` uint8_t Demo_Config(void) ``` * { uint8_t writeData = 0x80; lsm6dsl_func_src1_t readData = {0}; //1.使能对嵌入功能寄存器的访问(A 区) lsm6dsl_write_reg(LSM6DSL_FUNC_CFG_ACCESS, &writeData, 1); //2.LIS2MDL 从设备地址 = 0011110b writeData = 0x1EU; lsm6dsl_write_reg(LSM6DSL_SLV0_ADD, &writeData, 1); //3.60h 为待写入的 LIS2MDL 寄存器 writeData = 0x60; lsm6dsl_write_reg(LSM6DSL_SLV0_SUBADD, &writeData, 1); //4. 8Ch 为写入到 LIS2MDL 的寄存器 60h 的值, Continue 模式 ODR = 100 Hz writeData = 0x8c; lsm6dsl_write_reg(LSM6DSL_DATAWRITE_SRC_MODE_SUB_SLV0, &writeData, 1); //5.将 Aux_sens_on 位设置为不等于 00b writeData = 0x10; lsm6dsl_write_reg(LSM6DSL_SLAVE0_CONFIG, &writeData, 1); //6.使能 write_once 位 writeData = 0x20; lsm6dsl_write_reg(LSM6DSL_SLAVE1_CONFIG, &writeData, 1); //7.禁用对嵌入功能寄存器的访问(A 区) writeData = 0x00; lsm6dsl_write_reg(LSM6DSL_FUNC_CFG_ACCESS, &writeData, 1); //8.使能嵌入功能 writeData = 0x04; lsm6dsl_write_reg(LSM6DSL_CTRL10_C, &writeData, 1); do{ //9.使能 SDx/SCx 线上的内部上拉 传感器集合(sensor hub)触发信号为 XL 数据准备就绪 writeData = 0x09; lsm6dsl_write_reg(LSM6DSL_MASTER_CONFIG, &writeData, 1); //10.开启加速度计(以获取触发信号) writeData = 0x80; lsm6dsl_write_reg(LSM6DSL_CTRL1_XL, &writeData, 1); //11.等待传感器集合通信结束 //12.SENSORHUB_END_OP = 0,转到 9 lsm6dsl_read_reg(LSM6DSL_FUNC_SRC1, (uint8_t *)&readData, 1); } while(!readData.sensorhub_end_op); //13.禁用嵌入功能 writeData = 0x00; lsm6dsl_write_reg(LSM6DSL_CTRL10_C, &writeData, 1); //14.禁用辅助 I2C 主线 writeData = 0x00; lsm6dsl_write_reg(LSM6DSL_MASTER_CONFIG, &writeData, 1); //15.关闭加速度计 writeData = 0x00; lsm6dsl_write_reg(LSM6DSL_CTRL1_XL, &writeData, 1); //16.使能对嵌入功能寄存器的访问(A 区) writeData = 0x80; lsm6dsl_write_reg(LSM6DSL_FUNC_CFG_ACCESS, &writeData, 1); //17.LIS2MDL 从设备地址 = 0011110b writeData = 0x1EU; lsm6dsl_write_reg(LSM6DSL_SLV0_ADD, &writeData, 1); //18. 68h 为待读取的第一个 LIS2MDL 输出寄存器 writeData = 0x68; lsm6dsl_write_reg(LSM6DSL_SLV0_SUBADD, &writeData, 1); //19. 无抽取;连接了 1 个外部传感器 writeData = 0x06; lsm6dsl_write_reg(LSM6DSL_SLAVE0_CONFIG, &writeData, 1); //20~34 uint8_t mag_off[6] = {0x20, 0xFF, 0x54, 0x00, 0xB4, 0xFF}; uint8_t mag_si[9] = {0x0A, 0x01, 0x00, 0x01, 0x08, 0x81, 0x00, 0x81, 0x0A}; lsm6dsl_write_reg(LSM6DSL_MAG_OFFX_L, mag_off, 6); lsm6dsl_write_reg(LSM6DSL_MAG_SI_XX, mag_si, 9); //35.禁用对嵌入功能寄存器的访问(A 区) writeData = 0x00; lsm6dsl_write_reg(LSM6DSL_FUNC_CFG_ACCESS, &writeData, 1); //36.使能嵌入功能 writeData = 0x04; lsm6dsl_write_reg(LSM6DSL_CTRL10_C, &writeData, 1); //37.使能 SDx/SCx 线上的内部上拉 writeData = 0x0b; lsm6dsl_write_reg(LSM6DSL_MASTER_CONFIG, &writeData, 1); //38.使能软磁校准 writeData = 0x04; lsm6dsl_write_reg(LSM6DSL_CTRL9_XL, &writeData, 1); //39.开启加速度计(以获取触发信号) writeData = 0x80; lsm6dsl_write_reg(LSM6DSL_CTRL1_XL, &writeData, 1); } 版本2: `` int32_t SensorHub_Init(void) { // 1. 将 80h 写入 FUNC_CFG_ACCESS // 使能对嵌入功能寄存器的访问(A 区) // 2. 将 3Ch 写入 SLV0_ADD // LIS2MDL 从设备地址 = 0011110b // 使能写操作(rw_0=0) // 3. 将 60h 写入 SLV0_SUBADD // 60h 为待写入的 LIS2MDL 寄存器 // 4. 将 8Ch 写入 DATAWRITE_SRC_MODE_SUB_SLV0 // 8Ch 为写入到 LIS2MDL 的寄存器 60h 的值 // 以将其配置为 Continue 模式, // ODR = 100 Hz,温度补偿使能 uint8_t w_data = 0; lsm6dsl_sh_cfg_write_t sh_cfg_write; sh_cfg_write.slv0_add = 0x3C; sh_cfg_write.slv0_subadd = 0x60; sh_cfg_write.slv0_data = 0x8C; if (lsm6dsl_sh_cfg_write(&sh_cfg_write) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 5. 将 10h 写入 SLAVE0_CONFIG // 将 Aux_sens_on 位设置为不等于 00b if (lsm6dsl_sh_num_of_dev_connected_set(LSM6DSL_SLV_0_1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 6. 将 20h 写入 SLAVE1_CONFIG // 使能 write_once 位 // 7. 将 00h 写入 FUNC_CFG_ACCESS // 禁用对嵌入功能寄存器的访问(A 区) if (lsm6dsl_sh_write_mode_set(LSM6DSL_ONLY_FIRST_CYCLE) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 8. 将 04h 写入 CTRL10_C // 使能嵌入功能 if (lsm6dsl_func_en_set(1) != LSM6DSL_OK) // lsm6dsl_func_en_set lsm6dsl_pedo_sens_set { return LSM6DSL_ERROR; } // 9. 将 09h 写入 MASTER_CONFIG // 使能 SDx/SCx 线上的内部上拉 // 传感器集合(sensor hub)触发信号为 XL 数据准备就绪 // 使能辅助 I2C 主线 if (lsm6dsl_sh_pin_mode_set(LSM6DSL_INTERNAL_PULL_UP) != LSM6DSL_OK) { return LSM6DSL_ERROR; } if (lsm6dsl_sh_master_set(1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 10. 将 80h 写入 CTRL1_XL // 开启加速度计(以获取触发信号) if (lsm6dsl_xl_data_rate_set(LSM6DSL_XL_ODR_1k66Hz) != LSM6DSL_OK) { return LSM6DSL_ERROR; } lsm6dsl_func_src1_t func_src1 = {0}; func_src1.sensorhub_end_op = 0; do { // 11. 读取 FUNC_SRC1 // 等待传感器集合通信结束 // 12. 如果 SENSORHUB_END_OP = 0,转到 9 if (lsm6dsl_read_reg(LSM6DSL_FUNC_SRC1, (uint8_t *)&func_src1, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } } while (func_src1.sensorhub_end_op == 0); // 13. 将 00h 写入 CTRL10_C // 禁用嵌入功能 w_data = 0; if (lsm6dsl_write_reg(LSM6DSL_CTRL10_C, &w_data, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 14. 将 00h 写入 MASTER_CONFIG // 禁用辅助 I2C 主线 if (lsm6dsl_write_reg(LSM6DSL_MASTER_CONFIG, &w_data, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 15. 将 00h 写入 CTRL1_XL // 关闭加速度计 if (lsm6dsl_write_reg(LSM6DSL_CTRL1_XL, &w_data, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 16. 将 80h 写入 FUNC_CFG_ACCESS // 使能对嵌入功能寄存器的访问(A 区) // 使能读操作(rw_0=1) // 18. 将 68h 写入 SLV0_SUBADD // 68h 为待读取的第一个 LIS2MDL 输出寄存器 // 19. 将 06h 写入 SLAVE0_CONFIG // 无抽取 // // 连接了 1 个外部传感器 // // 读取的寄存器数 = 6 if (lsm6dsl_mem_bank_set(LSM6DSL_BANK_A) != LSM6DSL_OK) { return LSM6DSL_ERROR; } w_data = 0x3D; if (lsm6dsl_write_reg(LSM6DSL_SLV0_ADD, &w_data, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } w_data = 0x68; if (lsm6dsl_write_reg(LSM6DSL_SLV0_SUBADD, &w_data, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } w_data = 0x06; if (lsm6dsl_write_reg(LSM6DSL_SLAVE0_CONFIG, &w_data, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 20. 将 FFh 写入 MAG_OFFX_H // X 偏移值初始化 // 21. 将 20h 写入 MAG_OFFX_L // X 偏移值初始化 // 22. 将 00h 写入 MAG_OFFY_H // Y 偏移值初始化 // 23. 将 54h 写入 MAG_OFFY_L // Y 偏移值初始化 // 24. 将 FFh 写入 MAG_OFFZ_H // Z 偏移值初始化 // 25. 将 B4h 写入 MAG_OFFZ_L // Z 偏移值初始化 // 26. 将 0Ah 写入 MAG_SI_XX // XX 软磁参数 // 27. 将 01h 写入 MAG_SI_XY // XY 软磁参数 // 28. 将 00h 写入 MAG_SI_XZ // XZ 软磁参数 // 29. 将 01h 写入 MAG_SI_YX // YX 软磁参数 // 30. 将 08h 写入 MAG_SI_YY // YY 软磁参数 // 31. 将 81h 写入 MAG_SI_YZ // YZ 软磁参数 // 32. 将 00h 写入 MAG_SI_ZX // ZX 软磁参数 // 33. 将 81h 写入 MAG_SI_ZY // ZY 软磁参数 // 34. 将 0Ah 写入 MAG_SI_ZZ // ZZ 软磁参数 // 35. 将 00h 写入 FUNC_CFG_ACCESS // 禁用对嵌入功能寄存器的访问(A 区) uint8_t mag_off[6] = {0x20, 0xFF, 0x54, 0x00, 0xB4, 0xFF}; uint8_t mag_si[9] = {0x0A, 0x01, 0x00, 0x01, 0x08, 0x81, 0x00, 0x81, 0x0A}; if (lsm6dsl_write_reg(LSM6DSL_MAG_OFFX_H, mag_off, 6) != LSM6DSL_OK) { return LSM6DSL_ERROR; } if (lsm6dsl_write_reg(LSM6DSL_MAG_SI_XX, mag_si, 9) != LSM6DSL_OK) { return LSM6DSL_ERROR; } if (lsm6dsl_mem_bank_set(LSM6DSL_USER_BANK) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 36. 将 04h 写入 CTRL10_C // 使能嵌入功能 if (lsm6dsl_func_en_set(1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 37. 将 0Bh 写入 MASTER_CONFIG // 使能 SDx/SCx 线上的内部上拉 // 传感器集合(sensor hub)触发信号为 XL 数据准备就绪 // 使能硬磁校准 // 使能辅助 I2C 主线 w_data = 0x0B; if (lsm6dsl_write_reg(LSM6DSL_MASTER_CONFIG, &w_data, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 38. 将 04h 写入 CTRL9_XL // 使能软磁校准 w_data = 0x04; if (lsm6dsl_write_reg(LSM6DSL_CTRL9_XL, &w_data, 1) != LSM6DSL_OK) { return LSM6DSL_ERROR; } // 39. 将 80h 写入 CTRL1_XL // 开启加速度计(以获取触发信号) if (lsm6dsl_xl_data_rate_set(LSM6DSL_XL_ODR_1k66Hz) != LSM6DSL_OK) { return LSM6DSL_ERROR; } return LSM6DSL_OK; } 经过初始化之后,读取出来的数据并没有什么变化 |
LSM6DS3TR-C器件手册上标注是ROHS 环保器件 但是从供应商买来的实际测试缺铅含量超标?
关于九轴传感器算法(DT0060 与 DT0058)
关于传感器融合库的使用问题(motionfx)
Asm330LHH中活动/静止以及自由落体的检测功能开关
LSM6DS3TR-C静止情况下使用MotionFX固件算出的欧拉角周期性异常跳动
LIS3DHTR在读取xyz三轴加速度值时发现高8位一直都是00,请问这是什么情况导致?
LSM6DS33TR咨询
加速度计lis3dh批量异常
关于LSM6DSV16X的问题,最近调试过程中发现其陀螺的标度会变化,这是否正常?
关于三轴陀螺仪 I3G4250D
可以试试:STMems_Standard_C_drivers/lsm6dsm_STdC/examples at master · STMicroelectronics/STMems_Standard_C_drivers · GitHub
lsm6dsm_STdC/examples里的sens_hub示例
这个地址应该是不对的。如果是0011110b应该是1E,或者七位硬件地址应该是0F。我不确定sh_cfg_write.slv0_add这个参数代码中如何使用的。
[md]0x1e的我也试过了,在单独驱动的时候用的就是0x1e的。sensor hub的也试过
[md]我试试
请问下大佬最终是怎么解决这个问题的
