【经验分享】STM32F407的BootLoader程序
STMCU小助手 发布时间:2022-4-13 16:00
BootLoader程序介绍
% E: {4 |+ s" x' V4 CBootLoader其实就是一段启动程序,它在芯片启动的时候首先被执行,它可以用来做一些硬件的初始化,当初始化完成之后跳转到对应的应用程序中去。例如,我们可以将Flash分为两个区,一个是启动程序区(0x0800 0000 - 0x0800 2000)大小为8K Bytes,剩下的为应用程序区(0x0800 2000 - 0x0801 0000)。芯片上电时先运行启动程序,然后跳转到应用程序区执行应用程序。0 ~- q) q2 {' a( X2 g  U
- _9 M1 z' [' S1 o  `" J0 M
源码实现
6 R" A) \6 k# J0 B基本的BootLoader程序仅实现了代码跳转的功能,因此全部在main.c文件中实现。
2 H, a7 W/ N  [. I9 D9 h- K/ R' A
' i' d( o' c, k" t0 E2 ?源文件
. k' F3 v+ f$ D2 a
  1. /*
    - |) ~. l( |, P0 o4 q( V6 d" f
  2. ******************************************************************************- \" w/ F2 h& y4 }- \
  3. File:     main.c
    " u2 F% h# }8 b. Y( H7 }7 X% d0 H
  4. Info:     Generated by Atollic TrueSTUDIO(R) 9.3.0   2020-09-07$ Z; @# n6 Q6 j5 ]; _5 v
  5. 7 O9 f4 J7 K5 o. A  b
  6. The MIT License (MIT)
      I2 B: j  `2 L) Q% n
  7. Copyright (c) 2019 STMicroelectronics! p( z. b7 R0 w2 i0 T
  8. * S, Y$ ?& R. ^9 F7 w
  9. Permission is hereby granted, free of charge, to any person obtaining a copy. z0 r, j: a/ X1 ^
  10. of this software and associated documentation files (the "Software"), to deal
    9 S5 r9 f! A. c: `2 r
  11. in the Software without restriction, including without limitation the rights
    9 s$ a$ Z+ J8 Z$ q/ B
  12. to use, copy, modify, merge, publish, distribute, sublicense, and/or sell( d! j# A" J2 }: N7 U
  13. copies of the Software, and to permit persons to whom the Software is0 n  S) k" t7 m
  14. furnished to do so, subject to the following conditions:6 W9 Q4 ~& l/ A0 g7 ^4 O
  15. 2 c0 P) e* o3 ]  {) f
  16. The above copyright notice and this permission notice shall be included in all; x& O8 v2 Y; w6 K
  17. copies or substantial portions of the Software.$ g# r$ R1 A* h/ S) b: m
  18. : p& B/ Z& p0 f; {
  19. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    / i7 o: B' g: b) o7 R
  20. IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,* }! B" z8 B+ G7 d1 N
  21. FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
    8 [& [$ W* V5 a4 l% P- J
  22. AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER$ |0 \' ^4 Z4 n3 R; ~9 ?/ V  Y
  23. LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,7 J2 S/ q7 w4 A/ l  C! [$ @6 d2 F
  24. OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
    + I& ]& o& U. j1 ~& d
  25. SOFTWARE.
    ; A. X( T2 C( o" ?8 q
  26. + S- c. ^. s# q, ^6 E9 s
  27. ******************************************************************************
    0 E% @+ Y1 A/ G0 p
  28. */
    + f/ H2 U- C$ w8 F6 Q) G5 M
  29. ' H% X+ Z& p) o+ B. e
  30. /* Includes */5 ^9 T& I7 ^' E( O3 R4 d5 _1 W- r
  31. #include "stm32f4xx.h"( F& E. ~$ V( F/ K& p7 ]
  32. #include "delay.h"
    % ]2 d. }( p4 X! h# k# x
  33. /* Private macro */& W$ s  N/ j$ j# y
  34. ) R5 h! F& r( Q
  35. //用户扇区从第5扇区的起始位置开始启动8 W; ?! ^- G- C6 o- W
  36. #define FLASH_APP_ADDR                        0x08010000! b4 Y( n2 H. k" Q
  37. ' H7 W5 k) F8 P
  38. #define MCU_LED                                                GPIOA_OUT(15)* G' f7 s$ b1 R$ M& F" C
  39. ( e! p0 `! n! w: g& T
  40. /* Private variables */7 O+ e! f# r  z! j
  41. typedef  void (*UserApplication)(void);                                //定义一个函数类型的参数.5 h# [6 `" G- j! u3 _0 x
  42. ! H2 q! b& L5 W8 P; F
  43. UserApplication userApp;
    - H8 _9 N) i+ m8 L
  44. / n9 G8 s8 g/ z5 _! i& ^
  45. /* Private function prototypes */
    ) @& o' p! \! u/ V1 C0 L
  46. void ConfigLED( );/ C" \, J& g7 E) J
  47. void SystemBooting(uint8_t times, uint16_t msDelay);* w/ p0 S3 u" N; d- `9 l
  48. void IAPLoadApp(u32 appxaddr);
    9 p+ s" f0 H, z. o* L  j" g
  49. 9 p2 @* n- @: @( X2 W* l
  50. /* Private functions */
    ! d! T) ^& m" a0 B5 y
  51. 6 a& O# H9 o6 S
  52. 0 K% O1 C! d: B% j5 K
  53. /**! G6 Q+ C" K2 O* R
  54. **===========================================================================6 M) M5 d) T- K1 x! F3 G
  55. **
    - E4 n- _1 o+ u  E4 ~+ ]6 @
  56. **  Abstract: main program
    , n- _! D. o+ I9 A4 h7 a
  57. **
    ) O; a1 N" L+ q% a8 y5 C0 r
  58. **===========================================================================- Z/ ?6 S" I# @. ^2 `& ^! ~4 d
  59. */
    3 }2 S' ~0 w3 Z% w0 I9 d/ S
  60. int main(void)
    ; J2 F$ e, `" P, ]; L' O7 Q% d
  61. {  {- N2 k1 r  ?6 ]" Z1 I# W
  62. 9 U. s- t' V$ ^$ k# U0 ]0 w( u
  63. - N& d2 N5 p, ?) w+ ^) }4 e6 \) L
  64.         /**
    * R% J  B& v5 T: B  J
  65.          *  IMPORTANT NOTE!
    ) n7 ?* B5 P. d! K
  66.          *  The symbol VECT_TAB_SRAM needs to be defined when building the project
    / v5 O9 t2 E( Z; D$ g5 U
  67.          *  if code has been located to RAM and interrupts are used.% \" W, N0 t3 P' c- g. v
  68.          *  Otherwise the interrupt table located in flash will be used.
    ! Q* Y7 o6 m; ~- J
  69.          *  See also the <system_*.c> file and how the SystemInit() function updates- a: @" C& r& M7 i
  70.          *  SCB->VTOR register.
    % b4 y6 _" K" j% Z/ ?
  71.          *  E.g.  SCB->VTOR = 0x20000000;
    3 d. b" v& H4 E" {
  72.          */0 F# X3 F* @* L. t( ~5 \/ g
  73. + b2 e! T! t  t  H& f+ A! }# }" G
  74.         /* TODO - Add your application code here */) i) a2 f( ?. C3 q
  75. # U# w4 j9 {4 W1 }. e, T* T
  76.         delay_init();
    4 R; z) S1 T) w1 N: T
  77.         ConfigLED();) l! `+ E6 M! J7 A! }2 \- @; m
  78.         SystemBooting(5,100);
    ' P+ _6 C( Y" |
  79. % `; f: A  F* M3 E1 c% W% b- i
  80.         //从第五扇区起始位置开始加载应用程序
      k9 t$ y6 l$ C: g
  81.         IAPLoadApp(FLASH_APP_ADDR);0 S! K1 O* O" X) Q; o. V
  82. / U: v+ V: F" ?) N. \7 ^
  83.         while(1);
    " b) e2 K! T0 d+ F4 y: [
  84. }
    + T3 k9 q+ k: k$ b
  85. . ]3 ^0 G8 L. J4 ^3 z* H( k
  86. void ConfigLED( )2 S, B9 J+ F7 ~) ~/ A
  87. {
    ) D5 `- u/ B; ^9 H. m
  88.         GPIO_InitTypeDef GPIO_InitStructure;
    , I7 r! @! M# f( H0 m" P7 f9 _
  89.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
    ! G7 Z$ h4 F5 t& M9 s* U$ m0 P; n
  90.         /**
    . E, n2 z8 v6 s: N
  91.          * System State LED
    ( _$ O1 q, a( _+ r
  92.          */8 ]; u% L4 q& g1 ]9 _: D* m& p
  93.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;% l4 Q8 z, V+ a& H7 v
  94.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;* T1 z6 t1 e9 M$ ]! j
  95.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
    : H; F5 S) v& t$ [6 V, n) ^9 o9 @
  96.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    # s; V/ N$ m, `$ k/ V. F
  97.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;( g" a  Y% \! ]$ \3 s
  98. " ^- [1 {9 x3 r3 F- e
  99.         GPIO_Init(GPIOA, &GPIO_InitStructure);
    ) f# L& L$ R/ i! W0 Q/ N& a7 g7 u
  100. }6 P+ Z; S* [3 z7 I8 b  j4 m' G' e6 U0 l0 L
  101. / ], t) d9 m6 j+ @" D
  102. void SystemBooting(uint8_t times, uint16_t msDelay)% @5 {+ b0 \  C' u, D
  103. {2 }7 E. K& z' Y6 T2 G" f  K
  104.         for (uint8_t i = 0; i < times; i++)
    ( f# p# q, h+ G) _1 }( [2 [
  105.         {& {+ s- V2 r- y/ \
  106.                 MCU_LED = 0;
    5 Y) N% h# f( D/ ?
  107.                 delay_ms(msDelay);( q9 x( H) B6 x) N! B( U* y# P0 [& P" P
  108.                 MCU_LED = 1;, s: J3 {' d5 n$ z5 @
  109.                 delay_ms(msDelay);0 `# T) i4 D2 x0 Q" V7 Y9 L
  110.         }; W$ x* f2 ?$ c7 t$ q
  111. }
    9 `  {$ ^) f3 L2 P$ C8 M
  112. ! ?. N6 p9 B) }' S/ @$ H- A! b6 L
  113. void IAPLoadApp(u32 appxaddr)
    " ~- k1 J3 p' ?( q3 Z0 J* o
  114. {
    7 F! C3 x. F! W$ l3 ~7 g+ p& R% x
  115.         if(((*(vu32*)appxaddr)&0x2FF00000)==0x20000000)                                //检查栈顶地址是否合法." ]- L( L" E& ], m
  116.         {
    5 F- W$ Z6 y3 {* Z7 D
  117.                 userApp=(UserApplication)*(__IO vu32*)(appxaddr+4);        //用户代码区第二个字为程序开始地址(复位地址)3 s6 z6 m  M; S) g2 m8 v
  118.                 __set_MSP(*(__IO uint32_t*) appxaddr);                                                        //初始化APP堆栈指针(用户代码区的第一个字用于存放栈顶地址)
    0 w8 `# X  ?# A
  119.                 userApp();        //跳转到APP.! y$ i# ~7 _- K* g  X+ U
  120.         }+ |' C% P/ g9 h* D( c
  121. }
7 N! |8 F1 V) H3 ?( y
stm32f4_flash.ld
# a+ ~! z5 \9 X" b5 k设置BootLoader程序在flash中的位置为第1~2扇区,共32K空间。在笔者的项目中,第3~4扇区用来实现EEPROM的软件仿真,用户程序将从第5扇区开始启动。  m0 `2 V5 {6 f' ^: `9 r3 F1 Y
8 B: b7 P( q9 @5 k9 ]
  1. /* Specify the memory areas */. Q0 O- T; i$ u9 \% B: ^- g4 g( U5 a
  2. MEMORY: k. `2 H$ Q/ l! f: ~
  3. {
    9 B* Q9 f- w' K
  4.   FLASH (rx)      : ORIGIN = 0x08000000, LENGTH = 32K3 j% ]. W! d4 M1 P' N3 Z
  5.   RAM (xrw)       : ORIGIN = 0x20000000, LENGTH = 128K
    2 X4 }. o7 t( I2 \, ^) M, {
  6.   MEMORY_B1 (rx)  : ORIGIN = 0x60000000, LENGTH = 0K: A1 S. Y# _- F) X
  7.   CCMRAM (rw)     : ORIGIN = 0x10000000, LENGTH = 64K
    / M9 z9 b' h  ^# w$ Q" [
  8. }
/ D, G, G9 [6 \# _+ ]6 o+ [使用指南" K$ s7 Y' V$ w! g
用户程序需要从第5扇区的起始位置开始下载,同时需要设置中断向量的偏移地址。
* \9 [# n9 Y. y; n# {$ x" r9 S' Z" @
6 c2 e2 ^* r1 y! K& X设置用户程序下载位置(stm32f4_flash.ld)
5 G  L% g. ]3 R, l7 o: W) Z$ b9 L在笔者的项目中,设置BootLoader程序在flash中的位置为第1~2扇区,共32K空间。第3~4扇区用来实现EEPROM的软件仿真,共32K空间。用户程序将从第5扇区开始启动。5 y2 y+ ?9 L9 L& ]$ N
# Y9 Y: o2 H5 Q" |2 x
  1. /* Memories definition */8 }. u8 ], }- j
  2. MEMORY: h) C) C3 i6 b  g
  3. {
    ) ]! c7 A, {+ p) n& M2 ~: j
  4.   FLASH (rx)    : ORIGIN = 0x8010000,   LENGTH = 448K
    % }, i7 g% z4 f% S9 c
    , b: c) q3 h* e1 f
  6.   CCMRAM (xrw)  : ORIGIN = 0x10000000,  LENGTH = 64K
    ; Y: Q2 h3 _6 [  K1 c
  7. }
+ i: }3 c( ^) f5 [$ Z; F) W8 P$ ]! G1 f
修改中断向量表偏移量
& B8 B: `8 S$ u' G+ \  S' U在"system_stm32f4xx.c"文件中,修改宏定义:
5 P5 k0 I+ y% x! S
( E6 t) H7 ~" ^! B8 V- S
  1. /*!< Uncomment the following line if you need to relocate your vector Table in3 ~$ w! d% P/ [/ V
  2.      Internal SRAM. */
    3 z) c0 e. o, |: B* V. i
  3. /* #define VECT_TAB_SRAM */4 \7 e+ X2 u: s3 ^4 `" \
  4. #define VECT_TAB_OFFSET  0x10000 /*!< Vector Table base offset field.9 j9 A  M# d9 Q4 Z. ]! [
  5.                                    This value must be a multiple of 0x200. */
% @4 I- {5 ^5 |在void SystemInit(void)中将会根据上述宏定义,设置中断向量表的偏移量:0 f  _# Z4 U) {9 G$ c
& k6 B/ k" X! S! j; @3 |  _
  1. /* Configure the Vector Table location add offset address ------------------*/
    : }2 q- A" H) ~1 r* D
  2. #ifdef VECT_TAB_SRAM& _! e' k$ S9 [9 O
  3.   SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
    0 @! {/ O# A% t+ v' @
  4. #else4 {& G  s% d, F. I0 a* C( Z4 C
  5.   SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
    + a. j0 w; Z; b0 b" \
  6. #endif
! x) C/ z6 |6 }" `
5 A+ L8 n4 ?7 X
6 L1 m3 F3 u8 p3 E( g, E/ |
赞 收藏 评论0 发布时间:2022-4-13 16:00
