发布时间:2022-9-29 18:12
1.实验原理 FS-MP1A开发板蓝牙采用AP6236,WIFI蓝牙二合一芯片。WiFi部分通过SDIO接口与SoC进行数据交互。
在FS-MP1A开发板上sdmmc1用于连接sdcard,sdmmc2用于连接eMMC,sdmmc3则用于连接我们这里所用到的AP6236的WiFi接口。' a7 v& Z! V5 l- h! D9 q1 `/ K( | sdmmc3的设备树配置可参考stm32mp157c-dk2.dts中的相关配置,需要重新调整sdmmc3所使用的管脚,AP_CK32KO管脚配置和BT_WIFI_RST管脚配置。/ M# t7 W0 r8 S5 |% n$ ]
( F! n2 \# r C+ k5 }0 S5 d+ f
; |# y1 c. O# G
& r- \( O! g- Z' H1 d
查看原理图得出AP6236数据管脚与STM32MP157A的管脚对应关系如下:5 K# w I! k. W, V/ ~$ F* Y, O/ v `
1.WiFi设备树节点; |1 p1 V4 K( \2 J 内核中ST对STM32MP15x系列芯片的设备树资源了做了定义,可参见:! }6 U" Z' O' T( l8 g- l4 | " H: K2 f5 D( v! h' g6 U7 Z arch/arm/boot/dts/stm32mp151.dtsi; `# U i/ j/ d% e3 x- U6 ` stm32mp151中sdmmc3定义如下: # s% I3 S5 T2 C6 W2 } sdmmc3: sdmmc@48004000 { compatible = "arm,pl18x", "arm,primecell";9 L+ [5 N8 W! O 7 @/ @: p+ U9 h% l6 K2 z9 Y$ H: i arm,primecell-periphid = <0x00253180>; E) m0 e) e) t- Y' S; u reg = <0x48004000 0x400>, <0x48005000 0x400>; : l* O4 T4 [/ G$ v" `8 s interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "cmd_irq";* l# F; w1 }6 l& }1 D clocks = <&rcc SDMMC3_K>; clock-names = "apb_pclk"; resets = <&rcc SDMMC3_R>;% c! z' y f* h% S8 y! T cap-sd-highspeed;( x" X$ X8 q% }0 Q4 {4 R cap-mmc-highspeed;0 q+ ~. {: e) m D5 r max-frequency = <120000000>; status = "disabled";! T; P, S. l# q, d$ I# `6 \. f- E }; 上述代码只对sdmmc3做了基本的初始化,并没有针对不同的硬件设计做适配,所以需结合硬件补全设备树节点信息。 & M, C" x1 Q4 }* q! n 参考文档或stm32mp157c-dk2.dts对于sdmmc2设备节点的描述,增加sdmmc3内容如下:) ?" ]; Z' g8 t( h7 U5 L/ x$ T4 O9 a &sdmmc3 {( A0 P8 a3 [; H; i' n 6 }% J( n4 l3 Z( _ arm,primecell-periphid = <0x10153180>; $ y. a& B" n) c8 L# |5 u D _3 _ pinctrl-names = "default", "opendrain", "sleep";: H/ f4 @' `# q pinctrl-0 = <&sdmmc3_b4_wifi_pins_a>;4 c' ]1 ]& `4 k" s# G4 m: a 0 o3 o+ r# J3 \; S+ J! |8 T pinctrl-1 = <&sdmmc3_b4_od_wifi_pins_a>;" y8 l5 ?: K, A ) p9 B5 Y2 w& M( | pinctrl-2 = <&sdmmc3_b4_sleep_wifi_pins_a>; non-removable; 3 j2 `4 v; y1 P9 K/ _0 E5 p st,neg-edge; bus-width = <4>;7 \) y( J' k& Q7 D& A4 l% P( g vmmc-supply = <&v3v3>; # U# i, T0 R2 o) S4 b$ D, q2 n mmc-pwrseq = <&wifi_pwrseq>; #address-cells = <1>;+ \& G0 V" p7 E, s 3 r f# E) R& L0 A6 k! m F/ H #size-cells = <0>; - T! L# @. m3 B) F+ F% z9 \ keep-power-in-suspend;- Q( W* z2 ?; |- s$ k( o7 Z9 ` % j# `/ h v0 f% R* f9 C$ U. L status = "okay";" {8 [& v% x6 X' L4 K: \4 c brcmf: bcrmf@1 {0 ~7 u: T" i# e5 g# s3 a 7 n5 H* p3 @; h; k) O reg = <1>;# R5 c) C( m# {; z compatible = "brcm,bcm4329-fmac"; ' n; }: b2 ^+ E2 w u) B };) b. T! F: V ?. l }; 这里用到了一个mmc-pwrseq管脚用于控制AP6236的电源,可以stm32mp157c-dk2.dts对于wifi_pwrseq设备节点的描述,增加wifi_pwrseq内容如下:9 e9 i' n" x8 K/ D) Y/ ~8 _, g 5 D: u6 O- t! `1 Y) U% P wifi_pwrseq: wifi-pwrseq { # c. G8 }9 f* p compatible = "mmc-pwrseq-simple";/ ?) H* } g" T( J. b: A# R 9 k2 i# }' E0 R7 c: c9 v1 a reset-gpios = <&gpiod 4 GPIO_ACTIVE_LOW>;+ E! n7 |7 F' z3 l! \ }; 2 S E* h7 @7 Z3 z4 Z9 X- ~6 Z stm32mp15-pinctrl.dtsi对于sdmmc3的描述与FS-MP1A所使用管脚不一致,所以无法直接使用,需参考其增加如下内容: sdmmc3_b4_wifi_pins_a: sdmmc3-b4-wifi-0 { % [( ^# f: U' T1 T4 a pins1 {' `8 C q ~3 ^) I" \5 C( E# J pinmux = <STM32_PINMUX('F', 0, AF9)>, /* SDMMC3_D0 */ ' W. V+ j( ~( `; x$ X <STM32_PINMUX('F', 4, AF9)>, /* SDMMC3_D1 */ <STM32_PINMUX('D', 5, AF10)>, /* SDMMC3_D2 */ 4 f4 c l+ I! u( m2 y <STM32_PINMUX('D', 7, AF10)>, /* SDMMC3_D3 */9 s% h. w; m* k) A" E: ` <STM32_PINMUX('D', 0, AF10)>; /* SDMMC3_CMD */ ; Z5 l' p" m5 d2 ] slew-rate = <1>;. m% S* A. z0 p drive-push-pull;: g$ @9 F1 s/ e7 l bias-pull-up; };8 V% T- R4 @% l$ ]2 W: X5 ] pins2 { pinmux = <STM32_PINMUX('G', 15, AF10)>; /* SDMMC3_CK */ 9 o1 q4 B1 u7 Z4 N9 |( q+ f slew-rate = <2>; drive-push-pull;% s3 j) g) @8 D! l: |% J bias-pull-up; ) Q4 ]1 @! t5 ^- [ };0 ]4 z/ D& E [ }; sdmmc3_b4_od_wifi_pins_a: sdmmc3-b4-od-wifi-0 {9 e" @, k H4 B6 D. O' w pins1 { 5 I+ C. K0 B' ^* n% A& w: G pinmux = <STM32_PINMUX('F', 0, AF9)>, /* SDMMC3_D0 */. _( B0 D z# e8 | * Q" e7 r5 p" g( c$ H9 \9 I <STM32_PINMUX('F', 4, AF9)>, /* SDMMC3_D1 */( ~/ T+ C6 l( n$ G <STM32_PINMUX('D', 5, AF10)>, /* SDMMC3_D2 *// }" N+ H7 @6 m % f! E" B5 {5 w <STM32_PINMUX('D', 7, AF10)>; /* SDMMC3_D3 */ slew-rate = <1>; drive-push-pull; bias-pull-up; }; v; M3 f& Y4 s9 r pins2 { pinmux = <STM32_PINMUX('G', 15, AF10)>; /* SDMMC3_CK */ slew-rate = <2>; 6 X {' o( z! y% O: s8 v drive-push-pull; . v' g9 |6 Y, l' H/ } } bias-pull-up;6 j) a- v; U2 O& b }; 6 R8 o- I( N/ B) J pins3 { pinmux = <STM32_PINMUX('D', 0, AF10)>; /* SDMMC2_CMD */ 7 D# u/ N% F( ]5 A7 O. ~) E slew-rate = <1>;5 s% r8 ]( E( v S" D drive-open-drain; # k+ D; d! W) D0 J( P, ~- A bias-pull-up; }; + I) @9 H; d- t: ] };8 @( u) O# ]0 `$ a% m : M& u! H6 l7 ?( d" j sdmmc3_b4_sleep_wifi_pins_a: sdmmc3-b4-sleep-wifi-0 {5 ]% G g- H G9 o1 q 4 F; l( r5 t" ?3 p pins { 9 K' j; |. |% L$ U/ X3 n pinmux = <STM32_PINMUX('F', 0, ANALOG)>, /* SDMMC3_D0 */7 G' A2 K: }. ^ m, ` + L% B% T* t5 S0 B" Y <STM32_PINMUX('F', 4, ANALOG)>, /* SDMMC3_D1 */ * j& A/ v( s. |1 i <STM32_PINMUX('D', 5, ANALOG)>, /* SDMMC3_D2 */ <STM32_PINMUX('D', 7, ANALOG)>, /* SDMMC3_D3 */$ u4 o4 u0 q3 i& z7 C <STM32_PINMUX('G', 15, ANALOG)>, /* SDMMC3_CK */ <STM32_PINMUX('D', 0, ANALOG)>; /* SDMMC3_CMD */% }. A$ F5 K) K$ L% f - u! I1 z, ?9 A. [ };5 r1 @2 a3 b7 p X, }: A 3 i7 ~" V# R% v$ }2 x5 n) | };( M0 S/ O' n% k; o: p% v - ]4 |* Z7 N& t' t( A4 ^9 X5 M RTC节点1 M3 E) X: |9 a- T AP6236需要使用一个外部输入的32.768KHz的时钟源,因此我们需要使能RTC的外部32.768KHz功能 i/ ?" w& G, }) A& v3 k/ F" y 内核中ST对STM32MP15x系列芯片的设备树资源了做了定义,可参见: arch/arm/boot/dts/stm32mp151.dtsi% @ Q b) W, ~5 w+ d: D, H stm32mp151中rtc定义如下:2 T3 j" ]+ z. F- C 9 k: d: g& q: |0 L rtc: rtc@5c004000 {: }; a$ k; b& N+ S" L2 o 0 V& T: G3 y# D, o/ h: y compatible = "st,stm32mp1-rtc";% Z- E. ]) S3 z5 ^, B - B s8 M9 K6 M0 T reg = <0x5c004000 0x400>; ' @6 b$ v$ l) U5 c! [ V clocks = <&scmi0_clk CK_SCMI0_RTCAPB>, ( g7 `, X$ `; V% g <&scmi0_clk CK_SCMI0_RTC>; ; N0 |* G0 @% B' I6 B clock-names = "pclk", "rtc_ck";2 d' x& P7 R1 n) Y9 B2 n$ z interrupts-extended = <&exti 19 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; - A6 K. O2 }3 S };" Z# I6 N. q! g* l 上述代码只对rtc做了基本的初始化,并没有针对不同的硬件设计做适配,所以需结合硬件补全设备树节点信息。 7 n6 N2 @+ q6 z% X 参考stm32mp157c-dk2.dts对于rtc设备节点的描述,需增加内容如下:1 a( z/ @9 S( @/ A: J) m% Q # e* |( C. L; w4 p rtc {% _( x6 S1 D, V. W" v# x st,lsco = <RTC_OUT2_RMP>;6 R1 r; y" p. [' f ; }5 a. ? o: f. c; R pinctrl-0 = <&rtc_out2_rmp_pins_a>;0 \8 _/ k/ k5 [ ( ]) N. @/ X5 m/ _2 M1 g4 } pinctrl-names = "default";. u2 H. {) p) k status = "okay";. |% \4 }/ ~: d1 u5 P }; 2.实验目的 熟悉基于Linux操作系统下的WiFi设备驱动移植配置过程。7 I6 Z9 C' Z9 c% F0 c T Q, i 6 Z# E: o' Z/ G6 e: } 3.实验平台 华清远见开发环境,FS-MP1A平台; 4.实验步骤, D. Y# B1 T$ O. G 1.导入交叉编译工具链 linux@ubuntu source /opt/st/stm32mp1/3.1-openstlinux-5.4-dunfell-mp1-20-06-24/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi由于WiFi部分与蓝牙部分共用1路RTC时钟,有些操作与蓝牙要修改的内容相同,因此如果之前已经做过了蓝牙的移植,则这些部分不需要再重复修改。( }# p0 p* y* a: J ! x' X( g. G& a4 d 1.增加设备树文件/ ]1 o. N7 e+ g, J( M) I 修改arch/arm/dts/stm32mp15xx-fsmp1x.dtsi文件,在文件末尾添加如下内容:/ t0 z+ u; }1 Y. \$ Z, t% S, b &sdmmc3 { ) o" b, N; d9 {" k9 ~ arm,primecell-periphid = <0x10153180>;) S- q' ~: L C9 R" ] pinctrl-names = "default", "opendrain", "sleep";* C+ A) \* ~- e( h7 _ pinctrl-0 = <&sdmmc3_b4_wifi_pins_a>; - w$ _& m0 q3 P' v8 d) c" r pinctrl-1 = <&sdmmc3_b4_od_wifi_pins_a>;5 X- D1 D/ Z% l) X5 `7 I( k ; C4 o0 ^- _' u/ r6 | B' n pinctrl-2 = <&sdmmc3_b4_sleep_wifi_pins_a>; non-removable;$ R6 O: B; r5 g$ X0 u ' @8 K" K K# l$ ^7 T: @ st,neg-edge; bus-width = <4>; vmmc-supply = <&v3v3>; mmc-pwrseq = <&wifi_pwrseq>; #address-cells = <1>;5 M4 @" R5 Z6 r3 G #size-cells = <0>; keep-power-in-suspend; status = "okay"; brcmf: bcrmf@1 {1 {8 _# |/ W% m 3 ]* H0 s, d2 J( k% G# x reg = <1>; , d' M5 F. v- y# }7 S, I compatible = "brcm,bcm4329-fmac"; };! }% ~6 m. k9 Q * X1 w) g Y) k+ q" L };2 [4 W: J3 V" V& J6 l5 q ) y* A& `( r0 Y: D# r 添加pwrseq管脚配置, g% A* i9 D1 n, r* G! E 修改arch/arm/dts/stm32mp15xx-fsmp1x.dtsi文件,在根节点末尾下添加如下内容: / F i1 _7 ]: H7 C- O0 n! N/ e wifi_pwrseq: wifi-pwrseq {8 Q$ M9 h" l9 M3 g& ~$ i compatible = "mmc-pwrseq-simple";1 l3 f& I- I. o4 o! Q' U $ E- B& ]- g9 T" m8 L reset-gpios = <&gpiod 4 GPIO_ACTIVE_LOW>; 3 R4 Q! S2 P8 b' z+ @1 Q }; 2 q' V9 M4 ?- G# i7 Z' } 添加功能管脚配置 要添加管脚配置需要有pinctrl节点,如果之前已经做了MIPI LCD移植或者RGB LCD则在arch/arm/boot/dts/stm32mp15xx-fsmp1x.dtsi文件下找到pinctrl节点添加如下配置,如果之前没有做MIPI LCD移植或者RGB LCD那么需要新建一个pinctrl节点,然后添加如下配置。 * e" n: c. N* ~2 ] &pinctrl { . S6 G$ w8 M! T5 i$ A% h ... ... sdmmc3_b4_wifi_pins_a: sdmmc3-b4-wifi-0 { # U% a' Z4 s1 B1 { pins1 { pinmux = <STM32_PINMUX('F', 0, AF9)>, /* SDMMC3_D0 */ 2 m- N# T- ^% o6 _" d6 Q1 _% M <STM32_PINMUX('F', 4, AF9)>, /* SDMMC3_D1 */* O! \& v; j6 G! E( _1 b <STM32_PINMUX('D', 5, AF10)>, /* SDMMC3_D2 */ <STM32_PINMUX('D', 7, AF10)>, /* SDMMC3_D3 */ <STM32_PINMUX('D', 0, AF10)>; /* SDMMC3_CMD */5 @# B+ k$ t) U F) a slew-rate = <1>; . ]- E z; n& H9 R; \! g drive-push-pull; , e3 ?0 [( p3 z bias-pull-up; [3 T, t; \7 b7 ~0 n }; ~8 }1 c7 _+ V* [1 } T8 k! ]9 t7 H; Y : K$ ]; I7 f4 ?( l8 E pins2 {8 M# {* X y6 l$ ]% E" q6 B+ c % D6 w& F% D# ]: q pinmux = <STM32_PINMUX('G', 15, AF10)>; /* SDMMC3_CK */ slew-rate = <2>;4 `* P `( G: D: F" c2 B drive-push-pull; 9 x& z0 _0 Y' ?2 O4 W- {2 O9 F" _& A bias-pull-up;5 R2 ?) t9 _6 Q, r : }+ b! w7 G$ W& ]7 ?/ C };7 C, U9 a6 k1 K ; Y, G3 t9 G0 t }; T' G2 e2 l3 \ sdmmc3_b4_od_wifi_pins_a: sdmmc3-b4-od-wifi-0 { 7 u, ~% n$ I* G1 ~ pins1 {, F, w4 s. V% U$ D7 r* Q5 A* W ' \8 o' A" J* q0 ~6 k pinmux = <STM32_PINMUX('F', 0, AF9)>, /* SDMMC3_D0 */& U) \3 j( f: n o u7 L- i& U( V % t( ?, S6 H/ S0 @6 a; h* ?. N0 y. m) I <STM32_PINMUX('F', 4, AF9)>, /* SDMMC3_D1 */, x! m* d0 g. R+ A9 |& F 3 |3 p6 d2 L% F" M5 D) N7 ` <STM32_PINMUX('D', 5, AF10)>, /* SDMMC3_D2 */2 I8 \7 V3 [2 E ) |/ Q7 K! F- N, I <STM32_PINMUX('D', 7, AF10)>; /* SDMMC3_D3 */ slew-rate = <1>;/ _4 E) N+ R* ~0 A X w 5 x- H# }* P2 o8 f drive-push-pull;8 ?0 C9 n F# e, Q + h4 q$ ~7 Q: s' e! V bias-pull-up;* d" s' K! \' ]' ?" S };% G+ k( E$ g$ z! u2 H4 B$ T ; x# ?, c1 Y; n pins2 { pinmux = <STM32_PINMUX('G', 15, AF10)>; /* SDMMC3_CK */0 e* _ }* d6 \7 \0 f3 c & q, u, J+ t- \ g! q& U slew-rate = <2>; drive-push-pull; 5 J$ G0 {9 d q, p: g bias-pull-up;- y6 ]5 S+ D3 h0 E% d7 H 0 Z [+ s) o% e9 g$ i! `6 o };5 j* \0 S/ \& s) Y9 D pins3 {0 A, w1 E0 Y- y1 b) C( K ?7 Z) n6 {9 R- ?; T pinmux = <STM32_PINMUX('D', 0, AF10)>; /* SDMMC2_CMD */ slew-rate = <1>; % }4 a. i4 v1 v2 F* n8 \. R drive-open-drain; bias-pull-up; 6 h( _1 n0 g/ D9 | };8 g/ c. [: t# R# j( Z1 }1 P; E. z1 h. ^ }; sdmmc3_b4_sleep_wifi_pins_a: sdmmc3-b4-sleep-wifi-0 { 0 R4 i7 A5 C% q6 U! X. ?- j pins { ) x- r% z8 Y5 F" w, | pinmux = <STM32_PINMUX('F', 0, ANALOG)>, /* SDMMC3_D0 */2 s; o/ P! `& x8 s" U! j* w& M . d6 p1 J T% {- {/ M/ E <STM32_PINMUX('F', 4, ANALOG)>, /* SDMMC3_D1 */ <STM32_PINMUX('D', 5, ANALOG)>, /* SDMMC3_D2 */* {, U6 d2 p2 I: J$ o $ ^7 R4 K9 o% W& J <STM32_PINMUX('D', 7, ANALOG)>, /* SDMMC3_D3 */5 y* V8 s r6 R7 b , N* q" o9 H( q% o <STM32_PINMUX('G', 15, ANALOG)>, /* SDMMC3_CK */ ' J7 z O; u+ x& _& u6 X <STM32_PINMUX('D', 0, ANALOG)>; /* SDMMC3_CMD */6 V! U; h" W: w V1 t0 J5 _ ; `! u# r" V4 D8 R }; ) A6 V, K& Q5 t. Q/ x }; ... ..., L0 o, P7 x9 | };) b* l# P8 P( b' q 开启32.768KHz时钟 如果之前已经做过了蓝牙的移植,则这部分不需要再重复修改。8 Q+ r7 H: f' ?: ^/ [ ' j) D6 c1 b, N0 v 修改arch/arm/dts/stm32mp15xx-fsmp1x.dtsi文件中的rtc节点添加如下内容: rtc {* h$ Q6 E" H; q) _2 c( K& t st,lsco = <RTC_OUT2_RMP>;3 h- i* g4 `5 Y. ?( ` 2 s5 F9 E; F8 i7 @& A pinctrl-0 = <&rtc_out2_rmp_pins_a>; 3 N7 j2 E0 V7 W8 H g! X% b pinctrl-names = "default";; W9 _+ |3 W# m! b- Q status = "okay";8 y! U: O z6 o+ D, |9 j7 U }; 其中红色字体部分为要添加的内容。 添加rtc相关头文件。如果之前已经做过了蓝牙的移植,则这部分不需要再重复修改。$ k. F _9 N, R } u- l2 ~2 l6 R+ J% v #include <dt-bindings/rtc/rtc-stm32.h>; R9 t! M: w+ p' S 2 W7 J$ ?- B8 [ 修改启动选项 在系统中加入了sdmmc3的配置选项,导致系统中eMMC的设备号发生了改变,系统在启动过程中找不到原来的eMMC设备会导致启动失败。我们可以通过修改ubuntu主机中的/tftpboot/pxelinux.cfg/01-00-80-e1-42-60-17文件配置来解决这个问题。 $ A2 Y! Z1 j, ~! `) I # Generic Distro Configuration file generated by OpenEmbedded / z$ f% e- b( M4 j- S menu title Select the boot mode+ K' A6 E* ]. z% K: N9 S MENU BACKGROUND /splash.bmp" J! \# o* n% y- ~/ ~# P1 ` TIMEOUT 20 DEFAULT stm32mp157a-fsmp1a-emmc LABEL stm32mp157a-fsmp1a-emmc9 y8 @; c `/ ~. a9 V& \5 V KERNEL /uImage FDT /stm32mp157a-fsmp1a.dtb APPEND root=/dev/mmcblk2p4 rootwait rw console=ttySTM0,115200 & c- M x {. B5 S+ i LABEL stm32mp157a-fsmp1a-mipi050-emmc KERNEL /uImage% V# n/ u7 D9 J/ \ FDT /stm32mp157a-fsmp1a-mipi050.dtb 6 u+ |7 X' D5 ~# z6 T6 E$ X APPEND root=/dev/mmcblk2p4 rootwait rw console=ttySTM0,1152002 _( x4 ^- X6 e' h ' |7 C- y" W+ y2 V8 y LABEL stm32mp157a-fsmp1a-rgb070-emmc KERNEL /uImage5 x; h8 _: z, s. g7 L8 e FDT /stm32mp157a-fsmp1a-rgb070.dtb' w5 |! X( |6 U- G1 v% D APPEND root=/dev/mmcblk2p4 rootwait rw console=ttySTM0,115200 配置内核 由于内核源码默认配置以及支持AP62xx,本节列出主要选项,如下: , k6 Z( S8 c( t7 [! q linux@ubuntu make menuconfig$ J. J3 N3 z4 p, V- Q3 Y, m9 t2 o0 E$ p, a Device Drivers --->9 s8 R2 n ^3 s# F# `- s. { 5 }! D r# Z% c' \ <*> Broadcom specific AMBA ---> Support for BCMA in a SoC ChipCommon-attached serial flash support BCMA Broadcom GBIT MAC COMMON core driver BCMA GPIO driver* I5 Q- J! u1 U" ~ r" G8 S 编译内核及设备树 linux@ubuntu make -j4 uImage dtbs LOADADDR=0xC2000040+ ^( ?0 a) v" W+ y; {& L2 T/ B) o% I! C, A' T 重启测试 将编译好的设备树和内核镜像拷贝到/tftpboot目录下,通过tftp引导内核,系统启动后查看/lib/firmware/brcm目录下是否包含brcmfmac43430-sdio.bin和brcmfmac43430-sdio.st,stm32mp157a-dk1.txt两个固件,如果没有发现这两个文件可从【华清远见-FS-MP1A开发资料\02-程序源码\04-Linux系统移植\04-移植相关文件\02-Linux内核移植\AP6236固件】下拷贝到/lib/firmware/brcm目录下。: j7 n+ A E6 N# ]! }( X1 ^ 使用wpa_passphrase工具生成WiFi的配置文件。运行该命令之后需要输入wifi的连接密码。* p' ]" A, k! D3 b( y. W * f. P: n; g8 q$ ^" @8 T. t root@fsmp1a:# wpa_passphrase "你的WiFi SSID" > wifi.conf 连接WiFi+ ~, G3 h* X/ A5 U s/ p9 Y9 _ root@fsmp1a:# wpa_supplicant -B -c wifi.conf -i wlan08 _; K/ W0 {' r 8 G, W1 f8 B: c3 D8 G7 l 配置WiFi网络- m* N4 W3 |8 n: p V4 }$ p , U( t+ e; ]+ Y# {1 a$ J$ b root@fsmp1a:# udhcpc -i wlan0" D1 w' }4 ]' l5 Q6 `5 v+ j . i S: V) `$ l% M root@fsmp1a:# echo "nameserver 114.114.114.114" > /etc/resolv.conf2 R: J) a: x' z2 Z5 J& w 5 {- I2 I/ @0 z0 u# Z root@fsmp1a:# echo "nameserver 8.8.8.8" >> /etc/resolv.conf ( h- Y& b ~; b9 @
$ ~+ Z3 E1 I, L- k& u ———————————————— 版权声明:华清远见IT开放实验室8 @7 R" X) i- w- p# X+ W 7 h [$ _: a& B! L' y8 d, [ O7 H7 H* M/ ^" S; n8 [0 x9 C7 T7 J. { |
STM32MP157双A核Linux + 自研RTOS双系统镜像免费下载
扩展STM32微处理器,实现高性价比、低功耗和灵活性能
STM32MP1 自举程序编程:USB DFU/USART 协议全解析
兔哥心中的ST中文论坛
我心中的ST中文论坛
STM32 开发者指南:ST.com 全新 MCU 产品阵容视觉布局深度解析
深度拆解 STM32MP1 Boot 链路
STM32串口自动识别波特率的原理
STM32MP135 MP157 MP257 CoreMark移植&&跑分对比&&多核心负载不均衡问题排查与解决
STM32--STM32 微控制器详解
