STM32MP157 Linux系统移植开发篇15:Linux内核7寸触摸屏驱动移植
STMCU小助手 发布时间:2022-9-30 15:51
1.实验目的
6 P) }6 s0 G- F5 M' l2 O9 @熟悉基于Linux操作系统下的触摸屏设备驱动移植配置过程。
+ g  ~5 l* a2 A- S! g" [3 m3 ?0 k, A( A2 d, f$ f! S/ m8 D8 O
2.实验平台
! s8 Y7 Y% _- Z7 M: Y. s- B华清远见开发环境,FS-MP1A平台;
- k" M& b4 u+ Q4 f$ ~5 E/ D* n" f; v. ^3 _& W( [# b
3.实验目的
& b5 A, y" u: e/ v6 A1 x; v熟悉基于Linux操作系统下的块设备驱动移植配置过程。7 Q! K2 e: }4 b" O6 M
7 r& f9 L! K7 c% U" D
4.实验步骤
, q/ ]1 E) c8 x8 M3 E1.导入交叉编译工具链
* r) V( k# e9 k* E
  1. linux@ubuntu:$ source /opt/st/stm32mp1/3.1-openstlinux-5.4-dunfell-mp1-20-06-24/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
( k7 E: }+ b5 o# B( I6 _. c/ G% [过程与5寸触摸屏移植过程相同,如果步骤重复请跳过。( k2 ?* [* H6 @' @! A) Q
# Z/ z" \" p; j2 K- B) |+ J
2.修改设备树$ |/ {; r' K; }
修改arch/arm/boot/dts/stm32mp157a-fsmp1a-rgb070.dts文件,在文件末尾增加如下内容:7 e3 t& p3 W& ~6 y
+ y$ G) W2 X' {) S
  1. &i2c2 {0 I- |, h5 P+ k0 s+ ^+ {; j
  2. - D6 J" L4 v& P
  3. pinctrl-names = "default", "sleep";# f( k0 k, F  T) m* O* x$ O
  4. ) O( O2 r; W) R* I
  5. pinctrl-0 = <&i2c2_pins_a>;
    * v6 n3 y! B5 e% `
  6. - V5 }) Q: P9 |, ?) y2 e* U
  7. pinctrl-1 = <&i2c2_pins_sleep_a>;2 \4 a& }6 k% I7 G/ Y
  8.   E8 B) z" }$ p
  9. i2c-scl-rising-time-ns = <100>;- H5 A  B  J- E  O' M
  10. 5 n& p3 i' r/ `" _
  11. i2c-scl-falling-time-ns = <7>;5 w7 M- ?/ t  A: _, j( F# E4 \
  12. ! s) n0 u. U* |7 O/ n' B5 D1 m4 D
  13. status = "okay";
    ! U; p- _2 v1 q/ F. o  ~4 p) t
  14. 7 o4 G; {8 N/ e. o2 D
  15. /delete-property/dmas;
    9 }$ Z0 y4 n7 ^5 X) V
  16. 2 b2 c9 y; s& E; n8 R
  17. /delete-property/dma-names;
    ) O8 ~% w/ A& m, W6 a$ b4 b
  18. 9 _1 L/ G+ E3 h  P4 q
  19. touchscreen@5d {) x2 P4 V& A, h
  20. ( V9 i: P* n; w) E3 I3 r
  21. compatible = "goodix,gt911";/ t* s' P/ L+ Y0 {: S! Z* |
  22. , t- f' h* _$ Q, v8 d9 [# N
  23. reg = <0x5d>;8 F1 G9 J4 Z2 F- m+ A% C6 a
  24. 9 p0 n& t( _7 B4 x4 Y
  25. irq-gpios = <&gpiog 7 (GPIO_ACTIVE_HIGH | GPIO_PULL_UP)>;
    4 n! D( \4 s' D9 ^
  26. 1 C+ R$ ]1 z, E# e( A: Y% \8 ~* s
  27. reset-gpios = <&gpiog 8 GPIO_ACTIVE_HIGH>;
    , s' ~0 @8 d" W* W$ L9 Z
  28. 6 s1 U) d% a0 r: p& I* h
  29. interrupt-parent = <&gpiog>;
    & c5 x9 v7 F2 b4 o* {' z
  30. # ^& J( I2 x: |" d2 M
  31. interrupts = <7 IRQ_TYPE_EDGE_FALLING>;6 q' `/ r6 ?% r
  32. ( T* X4 g, y! M4 o# \- @0 s) y
  33. status = "okay";
    : }$ y: A0 l; y' G" b! k6 ]
  34. / ^8 l5 V; R8 h9 S6 K
  35. // touchscreen-inverted-x;
    1 J7 _1 d) Q8 {3 c% V+ d: f
  36. # t1 l% l4 R; D: r' Q& H1 R
  37. touchscreen-inverted-y;
    & X: ]  D# @% t) q
  38. 8 y# ^; m: n; z, S0 @3 m
  39. touchscreen-swapped-x-y;( W9 @$ K# V/ c5 a
  40.   R5 d7 C$ m1 t0 o& `1 L
  41. };2 G3 @2 {4 j' q6 ^8 s
  42. 1 {/ b" w* Z9 I& U& a3 V% |
  43. };
      t+ c( I1 z2 M+ s9 a: ^
  t, [( r9 `5 r1 [2 y% B+ w+ H3.配置内核1 V1 p. W# m+ b& `
由于内核源码默认配置以及支持sii902x,本节列出主要选项,如下:
. ]- }5 N( m- {8 Y1 B0 u0 I, K5 e8 J2 p5 ?% v
  1. linux@ubuntu:$ make menuconfig: |& F4 F  |0 |0 P
  2. & _3 T' y8 ]0 f) e3 Q3 L, D9 }1 s
  3. Device Drivers --->
    ; w; L7 W- B$ h
  4. - C$ y9 _" R$ R4 e$ U' F/ G
  5. Graphics support --->% ~7 `7 C% P8 j+ ]; Z9 g
  6. & P4 _! f, W6 H
  7. <*> Direct Rendering Manager (XFree86 4.1.0 and higher DRI support) --->5 p9 j4 }6 F/ _- ^- O; G+ b
  8. 2 ]5 @4 m' W& H# C
  9. <*> DRM Support for STMicroelectronics SoC Series0 \5 [0 J$ b& i0 c
  10. " |, ]' |, s% g0 F, X  x
  11. Display Interface Bridges --->) Q* @* l. [, l! N: W' F
  12.   I8 R8 H! U- [, Y7 n! s- q
  13. <*> Silicon Image sii902x RGB/HDMI bridge
( M( Q! K4 G( Z0 x0 y
4.编译内核级设备树:
: R) y" d  b5 J# r0 Plinux@ubuntu make -j4 uImage dtbs LOADADDR=0xC2000040
+ y  T6 g) @- o$ p5 W: q. u7 p  D' v( ~! G, ]7 ^$ \8 Y
5.重启测试: `1 m' t! q% f! T# j/ \6 |8 H
将编译好的设备树和内核镜像拷贝到/tftpboot目录下,通过tftp引导内核,设备连接七寸屏,重启设备后查看/dev会多出event0的信息,这是点击屏幕会的到反馈。
- V* _) @+ J. O
& L% d7 A5 l& jroot@fsmp1a:# ls /dev/input
7 H0 z4 @5 x! M) m* ~
( N3 I/ b9 s# l- L 30bb5596ca3a6155b667790f7e3002fa.png
& A& ?6 y/ f' v4 S+ C# o  c- t% }; Y# F9 e# Q5 f0 @
————————————————0 W/ Q$ _$ p: I& |2 d* C
版权声明:华清远见IT开放实验室; ~% A, S9 r0 m
7 k; e2 ?( \" y1 X2 L' K  P0 s& z
赞 收藏 评论0 发布时间:2022-9-30 15:51
