STM32MP157 Linux系统移植开发篇10:Linux内核网卡驱动移植
STMCU小助手 发布时间:2022-9-30 18:32
实验原理; O$ ]. H  L' _5 W4 J2 v0 d, @
STM32MP157A系列SoC集成一个千兆以太网媒体访问控制器,支持RMII和MII两种标准的PHY,FS-MP1A设备上外接了一个瑞昱的千兆以太网PHY芯片RTL8211F,原理图如下:
. D) a3 b) P9 D& [: s" i- }& j* [+ [- F  O
5 U) z1 C+ H/ n0 N* |6 V6 ~) _, K' i4 R$ Q& D: d# H
查看原理图得出RTL8211F数据管脚与STM32MP157A的管脚对应关系如下:
; y# ]/ Y* {% c7 j; K4 {  F. G8 l& |/ V! U
1.网卡设备树节点1 y' F) a* G6 C% ?* q
0 x# t( X5 S1 h% x* |& H/ F" d内核中ST对STM32MP15x系列芯片的设备树资源了做了定义,可参见:1 I' K: K) B3 E9 I, v
( Y% F1 m% N; i  ]  ~0 y! A
  1. arch/arm/boot/dts/stm32mp151.dtsi
    & g5 |, i5 W, I% y2 s% u' M
  2. + w3 r* n$ v+ s
  3. stm32mp151中ethernet定义如下:
    8 Q: k2 c+ D5 R
  4. ) k. k: d1 t4 u* u  B
  5. ethernet0: ethernet@5800a000 {
    7 U! a" u# u8 o. f7 @& K& \
  6. ' \3 b+ r& @5 u& c+ Y
  7. compatible = "st,stm32mp1-dwmac", "snps,dwmac-4.20a";
    - t& {# z4 N' t
  8. 8 N$ H) @1 ~/ M# R0 b
  9. reg = <0x5800a000 0x2000>;+ z5 |' r# a7 X
  10.   \# ?, q4 k5 s6 P
  11. reg-names = "stmmaceth";* O7 s8 C: z- M2 t
  12. 7 `# M) o) N* _/ |5 }
  13. interrupts-extended = <&intc GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>,5 z4 L# h2 u! J+ n+ {: Y' L- \
  14. 2 y" m/ g/ ^0 {7 K1 x  [
  15. <&exti 70 IRQ_TYPE_LEVEL_HIGH>;/ n9 L0 [$ v( m/ }
  16. 2 m4 `  q) N% P5 m' O% `
  17. interrupt-names = "macirq",2 ?$ g" c' X! D* I
  18. 3 G( B- D) S0 q  l# \/ V( T* |
  19. "eth_wake_irq";
    % t( o& @: N2 ^" z( n
  20. ; `9 }& ^2 ~9 \0 P
  21. clock-names = "stmmaceth",
    ) p4 o! ?$ T* G
  22. 0 h- ~$ p: Q8 Q3 T
  23. "mac-clk-tx",* _: Z$ x( C" L! ~4 J5 h) s5 [
  24. ( i; T$ W1 O3 ?: V4 a
  25. "mac-clk-rx",6 ^/ t9 @: E; x
  26. 3 V- N! F# a8 _! _5 d
  27. "ethstp";  t0 W, z. h& I3 ~3 ~7 a
  28.   i; J$ R2 d% n7 D
  29. clocks = <&rcc ETHMAC>,  q% H6 i$ I9 e$ F7 b* K) X3 t
  30. . U0 F1 d+ _2 Y# x
  31. <&rcc ETHTX>,) k4 n  t  N% `0 n) w6 \# h. z/ @
  32. 0 D$ s4 w3 R) a7 S  [
  33. <&rcc ETHRX>,
    2 f1 \2 [( M  ~
  34. & l4 ]! r+ N, @  _$ Q6 K( l
  35. <&rcc ETHSTP>;
    ! S7 `' Y( z# w  u
  36. 9 [- p9 W) g% `1 D6 A- l
  37. st,syscon = <&syscfg 0x4>;
    9 O7 M! S3 Q* d+ I4 h* G  h1 m
  38. & H+ m  |5 v; m
  39. snps,mixed-burst;
    & L* a( z9 N0 z! W, C; }4 A
  40. . n0 s4 p8 Z$ M& p
  41. snps,pbl = <2>;
    + K; h/ ]$ t. o. E, g$ X0 o
  42. / {- Y5 R- x: u# ^9 b4 t# I3 w
  43. snps,en-tx-lpi-clockgating;& R: p" c' L* L
  44. # N5 t' R. B$ O% ]8 p
  45. snps,axi-config = <&stmmac_axi_config_0>;
    4 |" g9 V! W8 g- z( R1 R" F  X. J1 n
  46. % y/ {+ _6 y2 y" L- f5 ^/ t2 `
  47. snps,tso;5 W/ P. S1 x! j. O5 t( ~: u4 `
  48. 0 Q& c, v5 m+ Q6 h& F( t
  49. power-domains = <&pd_core>;
    ! n! m% I: W! T) P, g/ g
  50. , a( Y' K' F5 Y  J% N
  51. status = "disabled";! p! P1 Y7 ^1 p2 i; E0 {) G
  52. $ P' B  G. M- n5 J% L2 e
  53. };
' O; t+ h: h. w& a
上述代码只对ethernet做了基本的初始化,并没有针对不同的硬件设计做适配,所以需结合硬件补全设备树节点信息。
. e5 }/ t0 N: B2 P+ t, o" y  n, r5 `6 V2 k, u% D; S3 v; _
对照内核文档目录下相关文档添加补充相关信息,亦可参考内核中其他设备树文件中相关描述,比如stm32mp15xx-dkx.dtsi关于ethernet的描述符合我们的要求,内容如下:
. |7 l& ^$ D+ w0 X- M: |3 `# Y9 B" w
  1. ðernet0 {
    2 I; I8 H: U( n8 j& i7 I
  2. ( K( r, `* X, ?9 m, C
  3. status = "okay";& F& M( y: M2 \/ m
  4. - S# i6 G6 ?$ Y
  5. pinctrl-0 = <ðernet0_rgmii_pins_a>;
    4 B2 n* x+ \( [, b$ G, I# Z5 ~
  6. . x* c, Y" W2 J
  7. pinctrl-1 = <ðernet0_rgmii_pins_sleep_a>;- s- v6 n) `: X5 \) V$ u
  8. ! m0 O( f- u( a$ }1 M
  9. pinctrl-names = "default", "sleep";- m+ `: l) {. V+ i% I
  10. : v% ]& d1 m, o# L, N$ t7 t1 c  z
  11. phy-mode = "rgmii-id";- i5 f) n. ]$ i
  12. : B3 E; D( Z9 q8 p4 m, V
  13. max-speed = <1000>;
    2 {& P4 ~; f. F! J5 Z
  14. ) c9 S" n  K2 j7 e6 L* G
  15. phy-handle = <&phy0>;% W! p8 a/ m0 E$ P/ \, s$ A
  16. / d6 K2 i- F1 {: X  r7 M
  17. mdio0 {0 h$ _6 u; ?2 Z, U0 X
  18. : A5 H! M8 ^' \
  19. #address-cells = <1>;
    4 D9 Q1 u% S' C- C2 y
  20. ! b9 a8 w8 }8 M' A5 W2 d! W/ O
  21. #size-cells = <0>;
    # ^& z# V# d: |5 a" H
  22. # B* J  S4 }3 A% Y; P, Y" s1 h3 X
  23. compatible = "snps,dwmac-mdio";
    $ Y% s% g6 B8 [* a% ?$ k4 L
  24. ; v5 T9 ?7 t# {  _
  25. phy0: ethernet-phy@0 {
    , J, \4 e1 j: S6 L6 S' ?% r
  26. 1 ?6 i* A: B% ~; x. M. N4 ~
  27. reg = <0>;
    6 t! I3 ~" b. a" X2 Z  k2 f2 U
  28. 7 z1 l9 k5 v) d9 ~6 x3 h
  29. };4 J. ]; w: S8 R; J4 _- r+ W$ [
  30. # x+ I2 o* u* L. ~; ^* q3 e8 `& a
  31. };
    1 Z. X4 y( _# D  ~: o
  32. 5 |- w" M9 M% Q- s. x  U
  33. };
! E0 f2 K* k7 Q9 K+ l! R
1.管脚定义! F3 Y9 ?" D  d: q) R* z( B" A! j1 I
在内核中STM32MP1默认管脚定义在文件arch/arm/dts/stm32mp15-pinctrl.dtsi中,查看文件中是否有需要的管脚定义:
9 H' i( d' h% K' O$ J) W
8 s# l/ T. Q& W1 f查看后确认有ethernet的管脚定义,且与FS-MP1A硬件使用情况一致,定义如下:; @1 K/ J; j6 k+ y  T& U
: U+ G4 w1 ^. i( m: J
  1. ethernet0_rgmii_pins_a: rgmii-0 {
    ' g6 l- |9 W% O1 f4 K
  2. 2 O) O' F7 {* g6 d. D
  3. pins1 {
    ' ?' t5 X6 t8 C, `
  4. / Y8 w. E& u' P( _& c3 T, Z( o6 u
  5. pinmux = <STM32_PINMUX('G', 5, AF11)>, /* ETH_RGMII_CLK125 */
    ! p% R1 r6 N, s
  6. 7 Z. L& i5 u2 j+ E! u0 m
  7. <STM32_PINMUX('G', 4, AF11)>, /* ETH_RGMII_GTX_CLK */; D4 r9 B% k! p& e7 F! ]2 x: c
  8. 0 a' J5 o8 L/ X6 \+ d: W  s
  9. <STM32_PINMUX('G', 13, AF11)>, /* ETH_RGMII_TXD0 */$ \& s! P: c: i4 I' s  u
  10. * u, w: i/ ?8 o0 w" q+ T9 V
  11. <STM32_PINMUX('G', 14, AF11)>, /* ETH_RGMII_TXD1 */3 X3 f4 k# E- W3 L. A( `
  12. 2 r1 c) C6 C& k4 F, _
  13. <STM32_PINMUX('C', 2, AF11)>, /* ETH_RGMII_TXD2 */2 n! s$ {! R8 Z4 o! G; a) f9 E
  14. $ }5 f7 U% ^1 L6 I" D
  15. <STM32_PINMUX('E', 2, AF11)>, /* ETH_RGMII_TXD3 */
    ! v# l% B; E: m' ?  \  w: O! `
  16. ) g' J- K2 o5 e6 q6 ?5 t8 v
  17. <STM32_PINMUX('B', 11, AF11)>, /* ETH_RGMII_TX_CTL */5 r1 W% p/ c5 q( u% J
  18. $ x5 n/ l% J# f) x* V: c$ v
  19. <STM32_PINMUX('C', 1, AF11)>; /* ETH_MDC */
    / w% P! d; ], R+ x8 F4 O- d6 i
  20. & [) p4 v" m0 E- |1 S& q
  21. bias-disable;4 _" ~$ J& N0 s- W  G1 D; X
  22. / i, q8 l" c1 q# L# ^* o4 B
  23. drive-push-pull;, j6 L- g+ [' @' f, C
  24. / C+ S& H  s* t. K" v/ a8 A7 L* I
  25. slew-rate = <2>;
    , M+ ?7 h- Q$ z" d2 J
  26.   b6 V0 p8 |8 g7 d  e
  27. };
    8 ^8 f, p7 ^9 F5 Z
  28. ( A; R; B% X, p/ @# Y* h
  29. pins2 {. F2 }0 H9 f& _" V) O2 V
  30. + T) ?+ y  Q- K, M3 a3 ~- ^
  31. pinmux = <STM32_PINMUX('A', 2, AF11)>; /* ETH_MDIO */
    ) i% c9 o- }8 i- X
  32. 9 v& L$ M3 ^% H6 b: M  C6 V1 A
  33. bias-disable;
    / s2 @% V- H' o- O
  34. 3 i9 `7 V8 ]8 J+ T% S) Y
  35. drive-push-pull;
    . \1 u, g5 H1 ~' s/ }' Y. ?
  36. 6 Z; e! C1 L6 Q2 K& k; N
  37. slew-rate = <0>;
    : V4 q+ K6 ?/ g
  38. $ X: C- }% ~" U4 J
  39. };
    - z. a! x! f: r' k
  40.   D; A3 Q; x7 e. ]8 T7 y
  41. pins3 {
    8 Q- c8 s* J3 C
  42. " y" n9 F% k8 O
  43. pinmux = <STM32_PINMUX('C', 4, AF11)>, /* ETH_RGMII_RXD0 */
    : j6 ~% j. j' z. L
  44. 1 v8 O/ Q# ]# _; D+ `" k8 |( s
  45. <STM32_PINMUX('C', 5, AF11)>, /* ETH_RGMII_RXD1 */
    6 C+ y, [' ^2 ^" X5 l9 M8 j
  46. 3 H; p2 r, A1 `. G3 Z' q" g1 O
  47. <STM32_PINMUX('B', 0, AF11)>, /* ETH_RGMII_RXD2 */& J5 o8 S; G/ r- y
  48. + b$ J! c, Z5 L/ v4 o2 R
  49. <STM32_PINMUX('B', 1, AF11)>, /* ETH_RGMII_RXD3 */
    6 h4 F& l: p' z3 t. S
  50. . G5 z% j3 `4 s% i/ ^# h! i; u. r* U
  51. <STM32_PINMUX('A', 1, AF11)>, /* ETH_RGMII_RX_CLK */! _6 |$ e+ [7 E1 m; i+ B
  52. ! g( g$ i2 m# W. @8 ?8 \. X
  53. <STM32_PINMUX('A', 7, AF11)>; /* ETH_RGMII_RX_CTL */; ]" T) z5 h; i, G
  54. # n7 b6 H: j! V1 S. o- \0 l
  55. bias-disable;
    * {) t2 a! K& X1 Q- t
  56. & D0 M% @' _1 }4 L
  57. };, {4 J, R2 K* o7 P( m4 @
  58. 4 [: Y# K  U$ X+ Y1 {
  59. };
    - k/ Z8 ]4 k0 H0 g, [9 U
  60.   ?6 w" H  Z: ]/ @' Q/ ]
  61. ethernet0_rgmii_pins_sleep_a: rgmii-sleep-0 {& Q0 ~! a& a5 C& w$ D. d7 [: M8 q
  62. ; D& T& I) [, x; l) _
  63. pins1 {2 w" O' Z6 {8 |: Q/ X  @, n7 F
  64. " l. p) H: |% o, l# c5 ]
  65. pinmux = <STM32_PINMUX('G', 5, ANALOG)>, /* ETH_RGMII_CLK125 */
    " @6 c. Y1 L% q2 W; u
  66. ) x) F' ?8 K; I( s% j2 o
  67. <STM32_PINMUX('G', 4, ANALOG)>, /* ETH_RGMII_GTX_CLK */! i# A" k9 J8 ?
  68. - r& O# |: }* }7 r
  69. <STM32_PINMUX('G', 13, ANALOG)>, /* ETH_RGMII_TXD0 */! J( J6 q% L6 M& ~
  70.   F- ]  V% V# u- k4 a; E! t
  71. <STM32_PINMUX('G', 14, ANALOG)>, /* ETH_RGMII_TXD1 */
    1 f, @. b, w7 b" d4 q7 ~
  72. # k" x, s) I+ {& }
  73. <STM32_PINMUX('C', 2, ANALOG)>, /* ETH_RGMII_TXD2 */2 I; j: D& J. |0 {4 L( |6 g
  74. 1 L) d$ ], h; w
  75. <STM32_PINMUX('E', 2, ANALOG)>, /* ETH_RGMII_TXD3 */; X  Q* m( y! O% v; e
  76. 1 a4 b* t" x0 g" H3 V5 U
  77. <STM32_PINMUX('B', 11, ANALOG)>, /* ETH_RGMII_TX_CTL */" n5 |) g/ y) C2 b
  78. + L0 R& ^" l3 `  j/ F8 e/ H. N* W
  79. <STM32_PINMUX('A', 2, ANALOG)>, /* ETH_MDIO */
    " `" n: C' w5 o/ N! L
  80. 7 G) |/ l! D1 e. b+ `7 ~
  81. <STM32_PINMUX('C', 1, ANALOG)>, /* ETH_MDC */: x7 j( m* J6 N3 q" b
  82. ) E5 r2 G# d7 @1 F1 ~/ J; q- T* Z
  83. <STM32_PINMUX('C', 4, ANALOG)>, /* ETH_RGMII_RXD0 */
    $ d' f5 A9 O8 G1 y
  84.   E: ^# w& `! }  H, O6 Q3 N- e1 A
  85. <STM32_PINMUX('C', 5, ANALOG)>, /* ETH_RGMII_RXD1 */
    & C7 O$ Z. p0 t/ y
  86. ) d7 q8 {" u( d7 N
  87. <STM32_PINMUX('B', 0, ANALOG)>, /* ETH_RGMII_RXD2 */0 v' f1 G& j/ k
  88. ' q3 C- ~4 G. \  ?8 L
  89. <STM32_PINMUX('B', 1, ANALOG)>, /* ETH_RGMII_RXD3 */3 f* J6 A+ v5 l# q
  90. 9 @/ j8 x6 M% D6 X& q9 g
  91. <STM32_PINMUX('A', 1, ANALOG)>, /* ETH_RGMII_RX_CLK */1 B  a. n3 h( B# q: K7 t; V
  92. ; W# ^% c& f  T$ c: `
  93. <STM32_PINMUX('A', 7, ANALOG)>; /* ETH_RGMII_RX_CTL */
    0 r7 w! v4 I& H
  94. 3 f  ~2 J* \9 {+ R7 h
  95. };
    + n' S- p, i# W3 N* f0 r) q: h) p
  96. : ]3 o6 A" G) I4 e/ \/ t, M
  97. };
: \( f$ `; o  o实验目的
+ U. q2 t  p! i熟悉基于Linux操作系统下的网卡驱动移植配置过程。) l* C. ^: T5 _3 d% c+ }1 O5 B
+ B: X0 R( G. f* d* o* @6 Y- j
实验平台
5 U; W! @9 z1 `FS-MP1A平台;
' F8 A) p! U8 O6 j0 y8 a, j; t5 Z& s5 ~1 L4 T5 m3 N+ g& l2 z
实验步骤; E, Q+ Q% O; y# g% J% `3 ^
1.导入交叉编译工具链! L4 @+ \  `- W
linux@ubuntu source /opt/st/stm32mp1/3.1-openstlinux-5.4-dunfell-mp1-20-06-24/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
( O/ U! P6 p! S8 Y
2 H4 H0 I' W4 a% y6 O2.添加网卡设备树配置。
( y. S5 A+ P* R5 ~修改arch/arm/boot/dts/stm32mp15xx-fsmp1x.dtsi文件
" F" z+ D" @/ R; {
; m  B9 y% i% V' V6 F, V3 L. A在文件末尾添加如下内容:
3 d* F/ r1 P+ X
  T' u! O  B) o1 Y- v3 u* R" X
  1. ðernet0 {
    " D- R7 J9 a$ s  x
  2. ' j" h4 H+ w2 Z9 c+ y$ o' ]
  3. status = "okay";4 j$ A& y. T: n4 W
  4. 2 G4 ^+ a. a: S- \8 m1 |' ^' h
  5. pinctrl-0 = <ðernet0_rgmii_pins_a>;' O" y4 F. W* u' p- ?- z$ b6 D
  6. / k+ j2 f$ i7 C7 n
  7. pinctrl-1 = <ðernet0_rgmii_pins_sleep_a>;5 O  }. Z( s3 F# j* J# J
  8. 8 h% L$ R9 N2 v/ g2 ~! [; D" U
    6 F# A% @6 B4 {5 F7 O3 k$ N
  10. 0 q9 D5 m. H  G* `) P0 V+ U: x/ n
    8 r4 W7 K( L7 N9 T
  12. ! K- e( T5 E5 H5 [5 T9 R
    5 }: _- B& z4 }0 |$ B, ?
  14. " x- ]' c$ ?& R* L3 Y' e2 I( G6 M
  15. phy-handle = <&phy0>;8 O0 ^8 N: @( d! m; V1 _
  16. 5 Y7 L; |- p9 i  i. k
  17. mdio0 {( L" O5 d; z5 ~- m  E
  18. - Z# b3 \3 Z! k+ `; r# A- {1 b! r; t
    9 e( o! M2 b! j, {$ E, G' p5 v
  20. ( Z6 g9 e/ N) d! k* i6 P
  21. #size-cells = <0>;6 U; a" n/ |& u1 R* J" U
  22. 9 V! N- H' u& ]6 \+ X
    ' `6 Q, N' E" ]  q
  24. ! [+ R' O  ?: I+ {4 D8 [
  25. phy0: ethernet-phy@0 {: Y1 f7 v7 q9 E8 ]# _% {
  26. 9 M3 S# ?* c) S8 i% A) s3 P& m0 e
  27. reg = <0>;/ g- a  {- @& G5 ~- i2 O
  28. 7 G+ T4 t3 ~4 W/ r4 R% n
  29. };# P4 F8 {# k4 N0 G8 x+ m
  30. 5 i4 x% f7 k) t9 [/ Q  I" a) [- A
  31. };' k% l: }2 U& [. ^1 U. p: V- Z" c4 N
  32. ' u/ o, X0 O( w- K- c' P, v( r
  33. };
% \& E+ O: ^( H/ R/ Z, D3 Q3.配置内核
" s! ]3 l; [, ?  k1 V由于内核源码默认配置以及支持网卡,本节列出主要选项,如下:1 Q% K/ u, x+ z; L2 w' j
2 q) g6 S3 W9 S3 r6 R$ R
linux@ubuntu make menuconfig1 X4 g! o) B3 ]8 I" X9 O( L
6 H! e6 B  n! u" {( z
Device Drivers --->
& ?. O( p3 j) ^3 Y8 [  U7 t9 a Network device support --->
0 Q/ c! g6 T( `8 y% m Ethernet driver support --->
; ~( I) w7 K- ]' r
" `5 ]; }% ^( e0 {  n; f<*> STMicroelectronics Multi-Gigabit Ethernet driver) j1 O7 y) x) @0 @
, b! l0 {0 K3 p. A4 T9 n<*> STMMAC Platform bus support. d- ?, X6 [' E
8 ^9 b$ E8 T* T  n
<*> Support for snps,dwc-qos-ethernet.txt DT binding.
# @9 f$ I/ m# a, B: T' w0 ]7 V7 O- c5 p0 ^
<*> Generic driver for DWMAC0 J1 S( c1 y7 o
4 ~9 B. S  v, ?' _3 p6 W" |
<*> STM32 DWMAC support8 d8 t" b  c* X' W
; H1 a6 L1 T4 A" p/ W4 A3.编译内核及设备树:& ~3 n  K1 \1 u, T! [. W% h+ c
linux@ubuntu make -j4 uImage dtbs LOADADDR=0xC2000040
  Z7 ^: V& ]) F4 l& k! g" r7 _  S  ?/ n3 J9 V) x
4.重启测试5 G9 M# W: N* |3 g
将编译好的设备树和内核镜像拷贝到/tftpboot目录下,通过tftp引导内核,重启设备后可以看到如下启动信息:) e9 k! K6 t3 d- l1 m  b4 s
' R. A2 d6 b+ W4 C+ P fe313fb6f3db573dc16e24195050eeb0.png 2 m# y1 {( H6 ^4 Y, b3 \. p3 J: {
5 O/ o6 J3 Q- t) e' t. F
b7c59f193686ab0c3636c67f18a87bef.png . [, ?# l6 b2 x0 t; s4 Y
% s2 x* e: a/ e( H  p
通过Ping 测试网卡& ?2 k. u2 M# u1 G
  ?* a$ z  T0 F* q 0a8eef4b7b15a8e10806b5be32019be7.png + d* J5 n9 u" [2 g" U4 G
/ q: ]% w. n9 E/ `如果设备不能接入以太网,可以ping主机5 v& N) c3 Q4 e. W; M. X2 z, i1 ?
. t4 m3 f1 {2 ~+ }版权声明:华清远见IT开放实验室
7 D8 k- i1 j6 e$ z6 i  x& Y8 A5 A0 W! G
7 C6 ?/ H2 ^$ M. S
赞 收藏 评论0 发布时间:2022-9-30 18:32
