STM32MP1 WiFi连接
; r) p' q$ Q {# S- Documentation to activate manually wireless interface. d7 A$ y% `7 e% D
- 1. generate the specific wpa_supplicant file" ?" I* G7 |% M7 ^" H! V& s
- mkdir -p /etc/wpa_supplicant/
! C8 J" [1 s" L% ~( R& d3 ?1 r - echo "ctrl_interface=/var/run/wpa_supplicant" > /etc/wpa_supplicant/wpa_supplicant-wlan0.conf$ [7 v5 B. W! s
- echo "eapol_version=1" >> /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
( D2 J* d9 S& r* } - echo "ap_scan=1" >> /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
$ _; b; y, l4 }3 I' s. J - echo "fast_reauth=1" >> /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
% P2 A4 a( X; j - echo "" >> /etc/wpa_supplicant/wpa_supplicant-wlan0.conf: @1 X+ z5 N( @( F' c
- wpa_passphrase SSID_OF_NETWORK PASSWORD_OF_NETWORK >> /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
! K" r$ f# D5 S" j( K/ S% Z7 Y - or
0 ]" Y1 J- S) g; g5 \- {- S - wpa_passphrase ssid_of_network >> /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
) M3 I3 t Y: o/ A; `* ]9 O - 2. put in place network configuration
3 G; c* m1 |! U' ], C5 S - rename file 51-wireless.network.sample to 51-wireless.network on /usr/lib/systemd/network/ or /lib/systemd/network/0 p. Z2 q- X+ Y# q- j
- 3. restart/start service( @# W0 J' R8 q9 V5 ~- i
- systemctl enable systemd-networkd.service
: A4 Y6 @; Q O6 B - + P) w$ {8 c, `/ i# _. x" {' E. j
- systemctl restart systemd-networkd.service9 l$ e; y9 N2 f4 z. }& O
* i7 [+ H& h# b) [7 F* l7 f
( g" U1 C U# M$ p* p, [' {- 8 z$ D6 Q5 l6 l- t
- info:
! |; H; o0 d* Q3 P1 x - How to list SSID available G" D; @. T$ `& q1 o1 `) G! e
- ifconfig wlan0 up7 J) U: t7 ^% @" ?' H+ [
- iw dev wlan0 scan | grep SSID. q0 a* X; d- O2 n( N
- or
7 b% r! Q3 P$ ^+ F) Z - iwlist wlan0 scanning | grep ESSID) w# n* E0 p; O' L/ ]) R* Z
- 3 r' f2 V7 o4 w
- e.g.+ o# @+ F! C& T0 a# X
- wpa_passphrase peszazurehear pass.w0rd, >> /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
, t9 B O* |& h+ y9 C5 a6 q6 I) m" {$ ~& ]6 t
a; O, p" u v$ {$ b版权声明:zhoujiazhao
# o# ]4 g9 C- t6 A
( j4 k7 |2 e0 J8 S |
ifconfig wlan0 up( I+ {! Z3 K, D
+ `% T4 W) b, T- e" E, Z1 u/ x1 J5 _
//关闭wifi: i# c0 @4 G! I- Y/ J
ifconfig wlan0 down5 ?# w9 P8 h6 L
) `5 P$ b0 t8 g, g( J4 }$ H5 n
//搜索可以连接的wifi
iw dev wlan0 scan |grep SSID
/ f" e4 b) c c- `& [) T2 H4 E
//wpa_passphrase 设置 wifi 名字和密码6 t3 t5 M& a' P2 D
wpa_passphrase name passward>> /etc/wpa_supplicant.conf! Z3 I, O# X+ O2 `/ b
//初始化 wpa_supplicant
wpa_supplicant -B -iwlan0 -c /etc/wpa_supplicant.conf* X7 J6 z4 y. Z) J$ T, x
: H* M$ R8 B4 d! e/ z* ~" _
//连接wifi; W% `$ Z8 x% {& w3 L3 ?
iw wlan0 link
//获取 WiFi IP 地址0 x3 E2 }. L9 k. o3 I! S9 h- I$ B* P$ e
udhcpc -i wlan00 D" i7 K& k. t7 D) E4 m# m" B+ O5 I
' H, R( V; R& `6 [3 T
//wifi连接后ping外网测试* K. y3 D i8 ?+ m; ^
ping -I wlan0 www.baidu.com
2 }. @' g8 }/ B0 }& Q
设置开机自启动WiFi
systemctl enable wpa_supplicant@wlan0.service9 T+ k; s/ s& ~2 X/ B! X9 o% ^
将 wpa_supplicant.conf 改成 wpa_supplicant-wlan0.conf 并拷贝到新建的目录下
/etc/wpa_supplican
去除开机自启动连接WiFi0 N5 {8 r* x2 C' t8 Q4 C+ ]: S
rm -rf /etc/systemd/system/multi-user.target.wants/wpa_supplicant@wlan0.service
这里也有官方的配置教程
https://wiki.stmicroelectronics.cn/stm32mpu/wiki/How_to_setup_a_WLAN_connection
