例程说明
0 N5 Y+ i9 C7 H W% d1 oSTM32G0xx在对Flash操作时,有时会出现HardFault异常、或者出现擦除、写入失败的情况,故有此记录。5 s6 \. Y4 Z3 F6 ~& F
STM32G0xx LL库官方没有提供Flash相关的操作需要自己写,可借鉴HAL库。
/ y; K- X/ K8 q+ Z8 M. a8 a; ^
% N0 j$ \1 ]& v+ z. @宏定义说明
6 Q$ f3 ^8 H$ x& w
9 _% c/ {- B) h2 R* [- s- #define XMEM_ALIGN_SIZE(size , align) (((size) + (align) - 1) / (align))
7 O6 B q) ]; R3 z
; k8 {0 l, A. X& ]- /* 获取成员m在结构体t中的偏移位置 */
( Y* I$ j0 w+ Y; s - #define XOFS(t , m) ((u32)(&(((t *)0)->m)))
9 x8 @2 M6 r, a8 s - 2 ?4 Y% @6 S# N8 e$ u+ y( U
- #define SYSTEM_ARG_STORE_START_ADDRE (0x0800F800UL)0 i+ J$ |; ]% a# X4 p8 Q: O8 r
3 K5 W- z. X+ \% N0 w o5 ]" M- #define FLASH_OPT_OVERTIMER (0x1FFFF)
# \% u4 L8 }, M9 `7 V+ @* U9 s6 w - #define FLASH_OPT_TRY_COUNT (5)
复制代码 3 j: G" u! A U# t/ K
Flash解锁与加锁
6 Z" D- T: Z; H2 E- }- /* Unlock the FLASH control register access */. b9 c, \) e9 ]6 {' J
- static u8 ubFLASH_Unlock(void)' T7 v$ T5 d. u* Z% V
9 s. ~$ B* d Q) V - u8 sta = 0;
R( u% j* {5 U. t+ m! i% P - 8 k3 w& |6 Y# N& `
- if (READ_BIT(FLASH->CR, FLASH_CR_LOCK) != 0x00U)
# o' f1 U* Z( ~" D( Z1 c - {* y/ W5 D H, j; F6 x/ z+ Z
- /* Authorize the FLASH Registers access */ b+ t: g# K/ e1 i! O6 C
- WRITE_REG(FLASH->KEYR, FLASH_KEY1);
( O+ [" d+ D( N9 z! S - WRITE_REG(FLASH->KEYR, FLASH_KEY2);: G" m: o& e& i& K$ l A. P
& m5 [; y& J* j7 O3 ?- /* verify Flash is unlock */8 u9 u( E1 l! T; e& c/ M; \
- if (READ_BIT(FLASH->CR, FLASH_CR_LOCK) != 0x00U)4 S7 K, ~$ d" f7 Q
- {6 F8 d+ }; o C# V
- sta = 1;, R+ O( t1 C0 V. g
& `5 W: Z, h+ \' Z) w" ]. o# a* S - }6 r4 C1 M1 P" k6 A* G8 `/ J& I
- : C+ y( B$ I- A/ A
- return sta; # B7 j' N& g6 u& G) f3 u
- }9 v1 ]0 {. ]! s
9 z7 F; |& i- Y: g: K
2 \6 F% x7 p s2 X; U, F- /* Lock the FLASH control register access */: \: |: D; C% h& n e ]
- static u8 ubFLASH_Lock(void)
4 |$ \6 _/ \+ u! c. Q2 X/ t5 c - {
8 V. z, H3 `0 k1 v; g2 E* O& t T - u8 sta = 1;
; v. b8 R* Q9 X5 g& o9 I
j6 S& z- [8 F: t( G) w- /* Set the LOCK Bit to lock the FLASH Registers access */! S3 I, D8 v7 ?5 H/ n
- SET_BIT(FLASH->CR, FLASH_CR_LOCK);' o; x% k) y9 |& X- q: u
9 Z6 J$ ^ `3 @2 O/ H- /* verify Flash is locked */9 W% w6 g! s7 S6 X. y/ S; M
- if (READ_BIT(FLASH->CR, FLASH_CR_LOCK) != 0x00u)1 m7 \" m) ?) ?& p7 A9 u' H
- { D! F+ V2 ~ S/ `9 ~
- sta = 0;
# P2 `( F+ p' o* p( v, n/ B - }
e* P$ W; Z# p
- \; R1 ~- j# I/ G7 e9 Q- return sta;
$ R: ^; \$ B" F2 T& Q/ t A - }
8 c. Y' f/ F$ R) Q! ]: X+ ?Flash选项字节解锁与加锁* B# f8 p5 n, c& w5 h
- /* Unlock the FLASH Option Bytes Registers access */
/ d8 z' f" K. F1 d2 ^ - static u8 ubFLASH_OB_Unlock(void)
2 M) Y) ^5 G! f6 w' {1 K0 D - {# u, U4 b) \8 G: q+ n
- u8 sta = 1;
3 ]( O7 S# f" S( q1 e; [ - ) t* N$ E6 E$ g. n
- if (READ_BIT(FLASH->CR, FLASH_CR_OPTLOCK) != 0x00U)1 c( X- V5 p: {: B+ B
& ]* ` S- P! H# t# f - /* Authorizes the Option Byte register programming */
& \8 _7 o$ ^ P5 u( u - WRITE_REG(FLASH->OPTKEYR, FLASH_OPTKEY1);
- e+ n* L/ v6 ?( _ - WRITE_REG(FLASH->OPTKEYR, FLASH_OPTKEY2);
6 \, N' ]$ C* F' G$ R# V - 1 B" g4 t2 U% H! D: N0 z8 K
- /* verify option bytes are unlocked */5 ~9 L* o' ^1 b2 U5 T
- if (READ_BIT(FLASH->CR, FLASH_CR_OPTLOCK) == 0x00U)5 E5 T$ I! E! H* K3 J
- {7 d( F h1 q/ P6 K
- sta = 0;
1 L' S, l& D$ z- n9 k! F4 r - }
( A+ E9 F- q# o* C7 E7 i" E - }
; g; E. W+ n7 q) y0 P, e/ a
; J) B" d5 A; B/ Y. l0 s- return sta;- |- n! o: a: K# b5 M3 E; W
- }0 U# o- V; v5 L* ~4 Z1 h4 h, d
- 3 X A0 `2 @1 d6 A* U0 U
; Q6 R1 r4 _& i/ |- /* Lock the FLASH Option Bytes Registers access */( l3 R( e2 u( b: z! \
- static u8 ubFLASH_OB_Lock(void)
& U3 O6 f4 |% |+ D, N0 `* D4 z - {- u0 h7 d9 i7 d; m' _9 Y; v% f, o
- u8 sta = 1;3 b, E& D6 A( v
- 8 g8 C1 G* L- U8 n& N
- /* Set the OPTLOCK Bit to lock the FLASH Option Byte Registers access */2 F$ R/ m$ H0 N9 p4 r9 V
- SET_BIT(FLASH->CR, FLASH_CR_OPTLOCK);
) U6 X; w# a4 z3 t% W- T/ x6 N
( G9 A" P0 p( ?$ |- /* verify option bytes are locked */- f# ~% o' E2 l: ]' g' Y4 R/ s
- if (READ_BIT(FLASH->CR, FLASH_CR_OPTLOCK) != 0x00u)* N# j5 k# S; Y) C9 f
% K3 e$ ^9 Z' e% S/ s& N - sta = 0;4 c8 x5 `% s: c; P* F
- }! @( A# ]( e" ]) ]; P1 A1 O0 q
# k: h3 K) r2 h- return sta;
" d2 e# I3 f0 a) q' _ |, K) i - }
复制代码 9 |1 a- o9 X* p* \3 @! d2 u( k; F
Flash擦除页$ a2 V9 L9 K3 f# j4 @
- /* Gets the page of a given address */
, C$ k# f7 t7 |( Y9 G; ?9 s - static u32 ulGetPage(u32 startAddr)- q" j0 d8 a# A
- {0 t3 ]+ R$ Q X+ @& N
- return ((startAddr - FLASH_BASE) / FLASH_PAGE_SIZE);
: j! o8 f3 j; D - }
6 k- i) k) t1 w [1 X# m: z - 3 U2 ?0 a$ o6 A$ H; m
+ d& h* U+ S- e( U3 X- /* Erase the specified FLASH memory page */
, F/ I! z' c* `3 d* E - static u8 ubFLASH_PageErase(u32 page)
1 V' H \- A i; d - {
0 }* a8 O$ b/ W1 t - u32 tmp = 0;
' {5 G! f# n' S' @+ v9 H9 M - u32 time = 0;
2 Q# ?$ ~5 A! N) ? - u8 res = 0;# R% T8 d8 |) Z+ y
- {- u- Q+ M* a. B% A- /* Get configuration register, then clear page number */6 z% f+ u0 h% E- h0 b% A+ F
- tmp = (FLASH->CR & ~FLASH_CR_PNB);
2 |5 d5 t8 u* n" N- F - % p& s1 X; U; }: M
- /* Set page number, Page Erase bit & Start bit */
- s# v$ _0 |2 S - FLASH->CR = (tmp | (FLASH_CR_STRT | (page << FLASH_CR_PNB_Pos) | FLASH_CR_PER));6 A1 L3 q0 \7 J/ d9 j! O7 [& F; r
- : z7 [) ]% a, ?. l- E0 x! [
- /* wait for BSY1 in order to be sure that flash operation is ended before allowing prefetch in flash */
, y+ j! Z6 G$ A- l7 V( r9 F) }4 r - while ((FLASH->SR & FLASH_SR_BSY1) != 0x00U)
0 k" K- a0 F. c% U) ^) e6 m, f5 m - {
% g; }4 h# n! W9 t - if ((++time) > FLASH_OPT_OVERTIMER)
1 m; ~# b; ^+ }9 [4 i F8 m - {1 k& N0 }( I g' E7 f3 \
- res = 1;
/ t1 L5 E1 N0 _' \ - break;- s/ o! I) C/ a& m6 Z# Q
8 i- s4 S0 s) N# N - }9 h! M" U! a9 m8 G' Z* y i
& v/ |/ ^+ ~% T( i/ T8 U% b- L- /* If operation is completed or interrupted, disable the Page Erase Bit */- ^( }* ^6 c$ D( L) r; U
- CLEAR_BIT(FLASH->CR, FLASH_CR_PER);
1 C7 @; T2 l/ p( x Z* p - ( i) D& B# m# j" A0 f
- return res;
4 j" C0 ^3 }0 B5 B7 g - }
复制代码 + d' j. g, N. D. A) e" H1 P5 X7 ~
Flash忙等待
5 v" p( u$ L# X/ S- p' g" {9 Y- /* Wait for a FLASH operation to complete */
4 w% a( X- Y" F3 _/ C - static u8 ubFlash_WaitFor_Operate(u32 timeOut)
9 J/ Y! _) T, k* Y! X9 v - {" [5 ~5 H& Z7 ]
- u32 timer = 0;
7 i' V ^! M' L; K+ r - u32 error = 0;
; }/ D6 h, B+ s$ U/ a. K6 V
! G4 U1 B/ S% P1 ]! g- while ((FLASH->SR & FLASH_SR_BSY1) != 0x00U)
" D9 h9 H1 A S4 r; R - {
6 B9 T9 K/ ], U2 G - if ((++timer) >= timeOut)
4 b0 [6 |3 o9 p. ^ \ - {3 C. j% ]+ @% L! F
- return 1;
6 K- A. v6 G! ?$ L) G$ S - }
" \% S3 M( S8 H3 }9 P - }0 A& B# V. S0 M) J1 x1 n
4 z( r9 \" U Q3 ? A+ r5 m- #if ( USE_STM32G0_LL_LIB_ENABLE > 0)
9 g& F% Z, p L, D - /* check flash errors */2 G8 v2 N: f# G7 _' ?# J
- error = (FLASH->SR & FLASH_FLAG_SR_ERROR);9 h) b7 B1 e2 ]' Y
. l' N& S2 H) ]- M" a$ j- /* Clear SR register */
8 t) Q( Z# C4 T/ I - FLASH->SR = FLASH_FLAG_SR_CLEAR;$ e3 S$ r$ f. _; J/ R0 M q5 |
- #endif6 \8 q. I' X: O( o* m
( D; e' x1 I' M2 d% ~4 A
0 E% m1 R N1 E9 N4 M0 s- #if ( USE_STM32G0_HAL_LIB_ENABLE > 0)$ k- s# V: Z. Q- Q( g
9 L. h$ K! u w+ _! } Y+ k - error = (FLASH->SR & FLASH_SR_ERRORS);
/ W. X5 y2 @" _* s" b
! R4 ?, H- Z7 z- /* Clear SR register */
) q8 G8 ]1 P. e - FLASH->SR = FLASH_SR_CLEAR;
4 a/ K( x( O& r4 S - #endif# X, i( N3 C% H5 v8 Q! R
* n" i9 b: t1 u p) ?5 u
' b- f, t: s* U! p' @- if (error != 0x00U). Q/ ^( G$ ]2 q4 q3 l4 b
$ P, ], g4 w7 H# g% P8 [ - return 2;
& B7 w# p r" F4 ^ - }' `5 X Y5 y6 j" B9 x' ^- X
- & I: d- l/ W$ i4 W' q
- timer = 0;
/ u& k1 `1 ^: i% t; R$ g& H - while ((FLASH->SR & FLASH_SR_CFGBSY) != 0x00U)
/ L; [1 w K3 b+ s4 l: R& K - {
6 ]+ G) V* w- @) S. ^' ?: {) s - if ((++timer) > timeOut)5 T) D4 D1 B6 q& O1 Y
- {) Z, x: t1 r% Z
- return 3;( `2 H: h% V1 ^" e0 a. V# J$ O- T
- }! v3 m6 P+ E4 D$ e8 k! Z
& {* M% S+ v g( C6 U+ k- d - 6 C9 D1 T! Y7 N0 J J
- return 0;" L6 x3 G! x7 `' U* J
复制代码 3 c& P5 _, K# h8 \" _- [5 q) c
Flash双字写入
9 ^, y. L; R# c4 @0 m- /* Program double-word (64-bit) at a specified address */
7 Q* J0 t" h9 Y2 C/ K9 J, s - /* Must EN PG bit before and DIS PG bit after */+ S& g3 O* U. d( L% V
- static u8 ubFLASH_Program_DoubleWord(u32 addr, u64 data)7 b- u3 K; z9 `, E
% k; ] s+ W F8 t4 |" n7 l D: { - u32 time = 0;
5 [0 c. p8 H' r3 H- U8 ^# f - - I+ m5 G# f" ^9 ^1 q$ }
- ! E2 {' ?- ~$ H
- /* Wait for last operation to be completed */6 S2 g c( R! o
% J" d6 @; r/ @5 Z! o" H& j- _ - {! b% ~* f( N$ N( x! p/ C; a- z
% _* Q7 Y W" q! r2 ^: G - {
3 ?+ o+ ^" ?9 R7 W - return 1;& z) z- n8 I \; f
- }" s: [& t* d4 Q5 I
- }) u1 T; t' F/ M% f
, z& U4 X- f+ e$ \1 b9 P; o2 m - /* Set PG bit */
Q9 e2 `; G3 } x- H - SET_BIT(FLASH->CR, FLASH_CR_PG);7 \5 E, r8 u6 D7 W: X- M0 q
- % H; v: U4 r' i6 [2 y% P* H
- /* Program first word */
6 k% U3 v2 T% ^ t& U+ m - *(u32 *)addr = (u32)data;
8 d5 Q" _2 T8 g' `6 k
1 u& l9 X# t, }2 C& w1 f- /* Barrier to ensure programming is performed in 2 steps, in right order
% T+ y6 ]5 ^: L; b& x - (independently of compiler optimization behavior) */
4 Z; u2 [" r g9 t - __ISB();
1 ]' @1 c) E0 a
' H3 n3 T5 G. @! r& _: s- /* Program second word */
* G6 q1 l( z& C8 \: I9 E8 t, S - *(u32 *)(addr + 4U) = (u32)(data >> 32U);5 p' s# z! K% N2 h5 K
/ ?# y8 L+ p3 r4 ?- /* Wait for last operation to be completed */5 ^& `1 I8 Y8 j3 ?) F
- while ((FLASH->SR & FLASH_SR_BSY1) != 0x00U)1 A3 K: U5 |+ N" }3 }: x* b
! D5 z; M8 V! Q7 P - if ((++time) > FLASH_OPT_OVERTIMER)
0 M$ u2 e) ^: \, c6 D - {; w' L- u# e" @" @$ c4 e+ w" S
- return 2;
# q' g3 P, l" ^% F& ] - }
# |3 c! L! r0 n" F1 Y `7 @ - }
! T" W& E8 ]' { R
( O0 N/ ~7 p7 y3 m9 O' i% S- G1 P- return 0;! n9 V6 E) P6 O; s5 B+ ]. r
复制代码 ( [, b+ \! v- Q, Z8 M
Flash LL库双字写
) E! ^# H: J9 r% `' W+ ]$ c- /* Program double-word(64-bit) at a specified address */
! C$ {0 B" Q1 o - u8 ubFlash_Write_DoubleWord(u32 startAddr, u64 * pDat, u16 len)5 t: m) S! J# C9 h
' y: u# ]- v9 j - u32 page = 0, time = 0;
) |2 v8 M; M8 g% F - u8 tryCount = 0, res = 0;
1 q3 U/ ?( y; Q' l; C8 C- ?: [. { - u16 i = 0;% d7 c& `/ X3 I/ f& v
- $ ~" M* Q, r7 f2 {4 G+ y
- ; R" ?/ A# _0 x* |4 k- u
- FLASH_UNLOCK:
8 d2 \. a' P" K - if (ubFLASH_Unlock())9 f% V4 ]! B6 o* U# V
$ P4 y/ t C) n/ B( `& g - if ((++tryCount) < FLASH_OPT_TRY_COUNT)
- ~; \) K8 f5 k# k& p, z& B- g2 N - {; [" c- I X' M, L' Z* I
- res = ubFlash_WaitFor_Operate(FLASH_OPT_OVERTIMER);
) m+ |0 O8 D! l - dprintf("Wait For Operate %s...%d\r\n", (res ? "Fail" : "OK"), res);
2 `% ^, t0 i8 s$ E$ p ^1 v% H - goto FLASH_UNLOCK;3 D3 s1 i. y7 l6 D# E# R
( ~. {9 d7 {8 d; A0 C1 D0 T x - else& U8 b5 V: Z3 N/ E- g
- {, A. c2 F: y9 d4 `! A! G) r
- dprintf("Flash Unlock Fail...\r\n");
5 ~" [. G! o: I; K - return 1;8 J2 c- K I' j* b7 a4 w( }! }' F6 v J
- } % Q5 n& C) [; |5 b! ?( Y: j) F
- }! ?, e; x" \' G4 j" c# @+ r
2 d, ]& U& }# i& [% I- page = ulGetPage(startAddr);" ~: A6 s6 @2 [& A6 k; k) b2 e Q
- tryCount = 0;
" |- x) z' P' y3 R4 B
" A! }8 [5 v0 e6 b/ i% [! {3 z
( Y. b2 r3 x2 h) z- FLASH_ERASE:( o/ V: q0 n8 m) u- `
- if(ubFLASH_PageErase(page))
. X4 f3 n% h- n8 I4 j - {5 Z* r5 | S" x' ~3 R
- if ((++tryCount) < FLASH_OPT_TRY_COUNT)- a) {: B0 W0 _3 _; H8 d6 e. _
: q2 M9 Q) k K- a' M" u7 B - res = ubFlash_WaitFor_Operate(FLASH_OPT_OVERTIMER);
" R; l f3 k( v% Q0 C: c - dprintf("Wait For Operate %s...%d\r\n", (res ? "Fail" : "OK"), res);
9 i9 i% J- d3 |& w0 {: l - goto FLASH_ERASE;
" j s: h U& @$ W - }. n. y* i# W0 X- A! ?
- else ]! w/ L v9 a( F
- {6 D9 J, D, B5 l2 V0 i) e) w
- ubFLASH_Lock();' Q! [% C C1 i7 w! l
- dprintf("Flash Erase Fail...\r\n");
% D; M7 a$ f- w7 I - return 2;
9 [9 f7 Q* i' P - } 5 j& N1 E- g m4 e+ [& R
5 m5 m2 k4 i7 |; I" }& n - 4 N- u. T/ H% o* ?6 l
- , T6 W* J& {6 J$ [! \ T0 ^
- tryCount = 0;# q" h, u" k3 N' b) ^
- for (i = 0; i < len; ++i)( n' h3 s/ d$ q2 d$ m
- A4 N9 F' d( ~" s% d, { - while(tryCount < FLASH_OPT_TRY_COUNT)1 B! v# j- [: N$ \ {7 U
1 T% i2 @7 _' I ^- {' S) O4 ?. J8 W7 h - if(ubFLASH_Program_DoubleWord(startAddr , pDat<i>))# _* y- C7 m% |
- {6 u3 d7 q" I' F1 l" D5 C; f0 Y
* K' I6 |# D* \( \: p1 }, j - dprintf("Wait For Operate %s...%d\r\n", (res ? "Fail" : "OK"), res);/ X b! o8 P9 O& z
- tryCount++;: P, ~4 b2 C- g+ Z5 j
8 {9 a5 Q4 B" e - else9 I( D; {% J: q# V$ C/ Z
- {6 y4 a( k: T5 \3 \8 M l2 x
- startAddr += 8;
# f4 x% g# V2 r: E - tryCount = 0;
9 d) ]6 M; K; J - break;- V# H1 K0 s6 ^ }, y9 N! ]
" V- ^ a+ @; @6 F, M ^ - }7 n% W8 A7 v+ }, R
/ p" P3 F3 H) o* a9 F- if (tryCount)1 k; g- r/ [! N( e* o1 z5 n
& \2 s8 G1 L& F5 Z* b. H9 m - ubFLASH_Lock();5 O- S4 V" ^7 G$ }4 X
- dprintf("Write Flash Fail...\r\n");" E+ I& D8 U! n7 N# |' O
- return 3;# j2 G0 O: L9 Q3 t' Z
; _6 _ ?: }) G$ M* D - }! ? H5 t) Z" D' w
- 7 C# q$ ]2 O* m* O
, G5 E9 i4 z, h- [7 Y; {+ i- ubFLASH_Lock();
L3 Y. l* _; m( @6 T6 g( H/ d - dprintf("Write Flash OK...\r\n");$ Q$ P; T8 B) K1 G) n
- return 0;" b$ m' F" {( G
- }</i>
0 O# R' f' y6 Q+ h0 R ]+ V9 \4 GFlash HAL库双字写. U5 @! G: S" | N0 B1 W) ^: H! y1 Z7 C
- /* Program double-word(64-bit) at a specified address */- u$ K8 F9 L, f, D1 |& y# Z
- u8 ubHAL_Flash_Write_DoubleWord(u32 startAddr, u64 * pDat, u16 len)* @( z" O4 {* }
- {4 X7 J: [ v! A6 O7 S
- FLASH_EraseInitTypeDef EraseInitStruct = {0};0 O- z7 p8 ]5 J5 ^$ n
- u32 pageError = 0;
8 H- j$ e% @9 j" T+ u - u8 i = 0, tryCount = 0;
) D5 k$ h4 C: N
3 r! Y: i8 U, u* \# P) o q
4 {6 w( g3 h7 m) T$ T- 2 u4 |4 y" K& o" u/ V- |7 l
- EraseInitStruct.TypeErase = FLASH_TYPEERASE_PAGES;4 G5 U: M$ }. j9 m
- EraseInitStruct.Page = ulGetPage(startAddr);
5 h& y7 l2 F+ ^. L+ Y) U/ h3 W - EraseInitStruct.NbPages = 1 ;- p3 N# g& z1 V6 \8 {; R
- EraseInitStruct.Banks = FLASH_BANK_1 ;0 b0 B0 _7 w s: |, i' q) \+ A
8 [/ Q8 n* d" N8 M& K- ! C6 y; H% y3 v" o/ X9 M$ q
- FLASH_UNLOCK_TRY:/ c( E d: |+ C! B/ s7 n( Y; o
- if(__HAL_FLASH_GET_FLAG(FLASH_FLAG_CFGBSY) != 0x00U)
- h" D* @/ H. f, T. A - {
% Z6 m9 I5 ?6 b, Y. [3 P - *(u32 *)(startAddr + 600) = 0x123123; P, H O5 A$ A0 r
- FLASH->SR = FLASH_SR_CLEAR;5 K) S5 ~2 @+ V' h1 i. P
# E! q0 n( V5 }8 \4 A8 e- a
1 x8 O6 P; x; ~$ t8 q8 o3 b- if(HAL_FLASH_Unlock() != HAL_OK)' E) j: w' \7 ?
3 a& o _ m6 c; a) N9 b - if ((++tryCount) < FLASH_OPT_TRY_COUNT)
5 `3 T4 r: T p6 Q$ X" N$ T( s - {
' @% o0 n' a/ p" V7 B' { - FLASH_WaitForLastOperation(50);9 r5 x& e2 h: r: u
- goto FLASH_UNLOCK_TRY;" U* J, C# l: u }* ]
- }$ i; R! A# O0 R
- else; U) e( u+ d; W
- {: [% Y a; _+ T
, P& t+ Z% G, J - return 1;4 l+ s- T; u3 V I- f3 r9 X5 s
( V. L8 _+ E& o* r% V5 [5 N: s1 b, v - }
5 y5 {( l, W( N' J' Y) U" d - $ X6 l, |. W" V2 G% h. n
- tryCount = 0;
) t) u/ m3 y; Y+ j - ; o+ W9 ~: p1 q% M' f. K( _0 i/ Y
- & O+ o Q5 ~, b7 p$ C# b
( |, s. B$ C& o$ v* O
& C3 p- b% a. u% w4 M) Q- FLASH_ERASE_TRY:7 U9 v$ _8 v9 s, \& C
- HAL_FLASHEx_Erase(&EraseInitStruct, &pageError);3 g+ u- _4 u( F6 _" s3 m7 }
- if(pageError != 0xFFFFFFFF)
. u. L1 W. L! Q- ]5 g! ~# A1 j4 l - {) R- `) z5 f) I% a7 }
- if ((++tryCount) < FLASH_OPT_TRY_COUNT)( Z" A; q! K6 b* }5 o7 I4 f; E) A
. j! N0 R5 l: ] - FLASH_WaitForLastOperation(50);
2 C5 _- H! D% s7 k( \. H: r, x - goto FLASH_ERASE_TRY;* |3 i5 v$ z- r3 ]' g. c4 |4 n8 L
- }/ v% X2 S; F; i5 n' K! O, x
- else. l9 n: q. a+ \5 P
$ {6 }" d4 A: G - HAL_FLASH_Lock();
4 _! F/ D6 d( g* t6 Z1 x4 W - dprintf("Flash Erase Fail...\r\n");$ a. g) v" m( j% v: g4 R1 Q3 ^, T" C
- return 2;
, K% O; o* o3 U4 g, Z - }
) G+ w4 v" [# j- y i& V; a - }& P0 Q+ J t I
$ M% ~% m/ T' n9 O) I- Z$ b- - ^/ p" }) Z$ \: m/ _
- tryCount = 0;
1 Y' A; J* J6 s+ m! s - for (i = 0; i < len; ++i)
& ~& @6 U' ^0 ~, z/ R! D4 F& J9 I( w - {
) A. f2 F( m) Z+ K/ W! h0 r( D - while(tryCount < FLASH_OPT_TRY_COUNT)
, G5 [$ L* n7 h - {
0 I. U. {( Q( k - if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_DOUBLEWORD, startAddr, pDat) == HAL_OK)/ K/ ?9 C, @. I! l+ W' G. Y
/ s1 f/ V( R4 `- s - startAddr += 8;
/ r7 S1 Y. P5 V. s- j0 j' p6 ]% D - tryCount = 0;
" s4 M2 Y" J* X9 x1 `4 C* B# F - break;
% Y! w! T# l+ B) @$ {2 T! U/ @+ k - }
* c; t# _& x: ` l$ M$ E" R! S - else
- |5 i, i9 I! p( k: l - {
! y# z t' s- g - FLASH_WaitForLastOperation(50); L/ V" G4 E% b2 Y2 P
- tryCount++;
& \: B+ c; _. E+ U7 A. S - }7 Y" j) ?9 I M# @) H+ r$ D3 ^
" A6 b9 m9 i( O- Q1 b* Y# q
+ k+ m, Y" k; q* J. H- if (tryCount)
( Y: Z9 I" m- u+ B) ]# k - {4 B& l1 i$ A: C/ x6 U5 q
- HAL_FLASH_Lock();
- x% m# m# ~6 `0 q - dprintf("Write Flash Fail...\r\n");5 }) x1 g# X2 M; z. `$ P
- return 3;
/ a, N+ F% r; b4 M7 Q9 S. \6 u1 a - }
3 y3 r `5 k8 k - }
/ Z0 x/ _0 t' c$ h" ]6 s* ? - # f( X; a8 a- e
+ d, w2 I% J5 P/ O1 v0 R' Q- dprintf("Write Flash OK...\r\n");+ j' @1 U2 {+ i
- HAL_FLASH_Lock();1 ]# Q4 H# Y8 z5 w2 z
- return 0;* M) @6 W7 a: }! X3 ?
$ q/ U$ g( }9 g. A- }
; `( k" Z- S8 p+ @6 C# Z& q% ~
6 y. u! ]% f( W' V" W1 i0 @% |Flash双字读
. |8 W0 ]9 ]# ]4 n+ \/ v$ j- /* Read double-word (64-bit) at a specified address */1 Y' n, N5 v+ m2 t0 P$ h- t
- void vFlash_Read_DoubleWord(u32 startAddr, u64 * pDat, u16 len)
4 ~- R* W. ~2 h" C" u; o, D( [+ V - {6 s `; w, R( n9 m
- u16 i = 0; G( [! ]6 p9 u! I( X2 X! U: {
- ' X1 Y" G* p6 _
- for(i = 0; i < len; ++i)* d: {# v1 W5 ?
2 c0 j& |- F* S% ^# e - *pDat++ = *(volatile u64 *)(startAddr + (i << 3));
% a# g/ R+ E' w& R8 I - }
+ v& m0 ^3 K% ?' O: h* P( a/ ` - }
复制代码 ; W6 W+ }$ g( p9 `
Flash读写擦除测试
7 I L4 X' K. n- E- typedef struct
+ K7 W* U" O( ~: z1 h5 f- } - {
% j6 d' x( K* l - eBatteryCap eBatCap; /* 电池容量 */' p3 P- [% A1 f
- eMeasUnit eUnit; /* 测量单位 */$ p( L! x/ O7 }& w
$ C3 p5 u8 B8 z9 |- u8 LowBatFlg; /* 电池低电标志 */
1 j. O2 h0 B2 m: z- O# V - u8 MeasType; /* 测量类型 */0 \. _9 N3 l8 y
- u16 MeasMaxRange; /* 测量最大量程 */- ^) j" }1 C7 z2 _2 r
6 N# h7 ^2 @, f! x, X- }GlobalParamStore, * GlobalParamStore_t;
/ `) r/ G; V! m: W4 f k
7 o& s/ m6 H `4 X- ~: V3 O) o0 G- s4 [
- typedef struct
2 n/ P1 Q& Q& N; F - {: e6 F' ?: [# A( B
- u8 AngleDemarFlg; /* 角度标定标志 */
K' l$ B' e6 U - s16 AngleDemarVal; /* 角度标定值 */
8 ~. j0 k9 h" r3 Y- e. T
! m7 i% j1 @% e W- 6 P4 O1 g4 U' A L
- u8 GyroCaliFlg; /* 陀螺仪校准标志 */
: ]! P* Z# d$ k- ^* g3 Y - s16 xGyroCaliVal; /* x轴陀螺仪校准值 */$ ?" E+ Q8 T# |4 a) H2 k9 |
- s16 yGyroCaliVal; /* y轴陀螺仪校准值 */
/ S- c/ [! x5 g" ], V, y - s16 zGyroCaliVal; /* z轴陀螺仪校准值 */, _6 z T4 s7 U
- $ L: L) ~+ K" N0 S
. M, w" {0 G9 a+ I4 d: }5 {4 r- u8 DistDemarFlg; /* 距离标定标志 */, x$ Q7 o. ]6 e: H1 c1 i% K
- u8 ZeroDistDemarVal; /* 零距离标定值 */
% r& k( e& @ R - u16 FarDistDemarVal; /* 远距离标定值 */3 l. N7 }0 |7 u6 k7 s# u
- }DemarParamStore, * DemarParamStore_t, * pDemarParamStore;' ]/ }3 m+ X' f2 K: n) A: `$ F" V d
- , ?9 I) U# E+ Y: i1 f4 I
- typedef struct y4 \! \$ T1 Q* V2 t
: @2 x* q. _) l3 y - xSuperProductInfo ProInfo; /* 产品信息 */
4 P1 l7 ^' N+ Y* V2 L+ K* [, K - GlobalParamStore SysPar; /* 系统参数 */
% w' E! d9 m% m" s7 |2 Q+ x- E - DemarParamStore DemarPar; /* 标定参数 */4 k# L- c3 V3 ~# L$ P: z0 |
- & f% }: m$ Y- I& N) R8 D1 o
( I5 Y4 p/ s1 y$ p- u8 ubRes[1]; /* 预留 */, ^: e' H v5 m) T: o' y4 |# q
- u8 ubCRC8; /* 校验 */ Y( F$ N; _$ x$ w
- }SystemParamStore, * SystemParamStore_t;" f5 s4 E2 [0 o0 ]. F% w
/ l+ Y1 Z8 g% P0 |+ ~- m0 ]
" l, r1 h' \" B3 q( f8 c- 6 R' V$ s0 q* k5 I6 `
- " t" ]8 M1 O& g
- - V. j* E$ W" f! ~$ o8 `; p
- SystemParamStore SystemParam = {0};
8 B" p# Z+ W+ T - ! y8 D* G' G [ B
- /* 保存系统参数 */3 T$ E0 H$ j' o$ k' |
- void vSave_System_Parameter(void)
, k0 q- W6 B0 T- o& ~ - {7 c& L. Z! X/ c* ]
- u16 len = 0;
. m! J" k- r z6 z" } - ( a5 L2 o7 U$ ~- k9 Z$ B
- : {% n) j* z: P5 K; G
- len = XMEM_ALIGN_SIZE(sizeof(SystemParamStore) , 8); }5 k1 a7 U$ e8 D8 t; T
- if (len > (FLASH_PAGE_SIZE >> 3))
b. y( {' t/ M% W4 i5 k - {8 y5 I& H! j2 W$ L1 X9 ]/ e# S ~
- dprintf("System Param Over Flash Page Size...\r\n");
' Y0 V( [& k& O L8 m7 _ - }
; D- @# y/ S& }% `: A& w- E& p - else+ S& [& N7 [# o
- {. _$ e* I& }# t& m4 ]# o
- vSynWrite_System_Parameter();
2 O4 b+ g1 B2 S; w7 V' k - SystemParam.ubCRC8 = ubCheckSum_CRC8((void *)(&SystemParam), XOFS(SystemParamStore , ubCRC8));/ I# ]0 N; v& u$ Z- B" R# O
- dprintf("SystemParam CRC8...%X\r\n", SystemParam.ubCRC8);& @1 m' @, c4 w! s1 Y1 P
- if (ubFlash_Write_DoubleWord(SYSTEM_ARG_STORE_START_ADDRE, (u64 *)&SystemParam, len) != 0x00U) Z9 v% A" ^9 d }' p6 ]
- // if (ubHAL_Flash_Write_DoubleWord(SYSTEM_ARG_STORE_START_ADDRE, (u64 *)&SystemParam, len) != 0x00U)0 I+ P' K r+ S9 N1 K& p* ?, Y
- {+ c. Z' h( l# J5 M1 h
- dprintf("Save Param Fail...\r\n");
. R" z* V4 R. D# Z- @ - }8 [0 Y( Z7 [! n* H; O( _
- else
7 ~0 `8 I+ |9 @% `6 ?0 U7 v' X& X' m - {
0 P# s$ o( r5 a1 y9 _ - dprintf("Save Param OK...\r\n");1 n% _; G( p2 R" ~
- }2 D3 \7 E# l2 y
- }1 R: }$ Z4 N: b) A5 a. x
2 u# j% D' k" T# y
2 b! P; j+ C% V7 U# K' X) k; G- ( @1 _3 ~+ u% G* z0 T3 o! F
* f/ q( ~$ O+ X
- \; o1 _ J; {
! i* g# W* M" y- /* 读取系统参数 */
! I( N$ V1 f' C; z& p' _ r6 @: ` v - void vRead_System_Parameter(void)+ E% Q& x7 r0 k2 u; I
, u# ~" Y% R2 r+ B; v9 u* b - u16 len = 0;
/ I; d6 D0 Y; M/ F - u8 crc8 = 0;
: Q6 }* K4 f8 M% e5 l - 7 W, @0 H( ^; C% K9 S
- ( c" f4 {" ~$ ?2 e- C7 L% z2 W
- AppProInfo = &SystemParam.ProInfo;
# c! G! }6 X+ u$ k# w, s [6 [ - len = XMEM_ALIGN_SIZE(sizeof(SystemParamStore) , 8);
: B4 f0 ]0 c- H5 n - dprintf("SystemParamStore Size:%d %d\r\n", sizeof(SystemParamStore), len);- z2 ]/ M- t4 y1 h" S% B
8 i7 B) v5 l4 S9 M- if (len > (FLASH_PAGE_SIZE >> 3)), Y9 z- j1 F ?: T: l5 M" n- J
; e8 Y6 U( e" N9 v6 @5 P( F) _ - len = (FLASH_PAGE_SIZE >> 3);) X' q/ g' A# h& f
- dprintf("System Param Over Flash Page Size...\r\n");( s! P( c7 P" _4 \) K5 j
- } B: A6 \! m/ f: H! R7 ?
- 2 W+ {' \% u# o2 \- l: q
8 T( N$ a3 y' Q% r9 Y( |) a - #if 1
+ s+ S' B& u& f4 x - vFlash_Read_DoubleWord(SYSTEM_ARG_STORE_START_ADDRE, (u64 *)&SystemParam, len);+ Q. m0 O- P, _! t# m# W U; [& ^
- crc8 = ubCheckSum_CRC8((void *)(&SystemParam), XOFS(SystemParamStore , ubCRC8));, q8 w) f A' Y: ?! I
- if(crc8 != SystemParam.ubCRC8)
& C9 O5 F H6 L# m4 I, h - {
- n% D5 r7 Z9 F' H - Restore_Default_SystemParam();6 t+ @$ ^! L2 x6 l- h) A
- dprintf("Restore Default Param...%X %X\r\n", crc8, SystemParam.ubCRC8); x- B) U' l, m0 |& K
; R9 z" w% l+ h" ~) Q+ A4 y - else- l& [9 |+ [: B3 g) B$ ^5 i) A
0 q! O0 A+ b% u4 M - dprintf("Read System Param OK...\r\n");
; P- |# v y2 ?0 w( v2 i - }/ h7 |1 H G# {8 O9 N
- #endif
3 y4 N6 G/ V, a- m) B' | - - W, B- x- R7 A6 D) z$ j
- % l& c+ j$ m7 Z' N
- AppProInfo->DevInfo.SWVer.MajorVer = DEV_INFO_SOFT_MAJOR_VER;
( c8 L2 t! l/ x2 i; g- [# h - AppProInfo->DevInfo.SWVer.MinorVer = DEV_INFO_SOFT_MINOR_VER;: E6 V0 l. M) `& W5 z0 L! f
, N N% [' d1 L+ L0 C; T/ F, Z/ }) ]# d
9 s; L9 l6 _; a* X: i5 |- vSynRead_System_Parameter();2 P6 Y; i. j8 P% E
" F( }. U8 j/ @ - // vShow_ProductInfo();! C! B2 E( _: t: H$ \" ^* W6 ?
, m' S- a+ e& ^+ H测试情况$ q3 Y* Z/ v" ~
- Init UART OK..3 i. d- C( g# J* q- v
- Vref: 3298mV
& D4 O6 g5 x% w& L9 |2 d- n - SystemParamStore Size:88 11
; F$ [0 ?' L5 A! Q0 W - Read System Param OK...- B* X1 H1 o7 S y
- ******************** System Parameter ********************5 Z& k+ g4 |& a/ D! Y
- Meas Masx Range: 20000dm
6 d Y9 [: O; }- I! O - Angle Demar : 0 ==> 0$ J; n/ ]& w8 ^7 C
- Dist Demar : 0 ==> 00 R! A* q1 V% R: b/ Q* t$ O
- Meas Type : 6" y5 j6 g( P) f' j! o# f6 J
- Meas Unit : 1; k& ^! d3 Z" k# y; p9 z
- Gryo Cali : 0 ==> 0 0 0
. A9 y1 ]7 S' G/ ]) x; U1 F - **********************************************************
) Z' m9 `0 r, K1 Z# u3 e k7 I - Gyro Type MPU6887 ID 0x0F6 ]+ {, u |4 a* d! E
- Set Meas Type: 6
% P: W9 Q9 F1 R7 B% _ - Shutdown OverTime: 20s
& O) h7 E& I. s) |: S) A - Bat Sat : 0
& k4 {0 l8 w, E - Set Meas Type: 2
* Q8 z! \* \0 m' I - Set Meas Type: 9
4 z; A0 A/ y# S1 q0 I, ?4 i - Set Meas Type: 3# i1 }! I2 j K l9 M _, z
- Set Meas Type: 5' e1 o3 N; |/ q9 M4 Z# E! F
- Set Meas Type: 7) B1 q9 T4 F6 q5 R( o
- Set Meas Type: 82 C6 e T4 p7 @% \6 P( y6 {
- SystemParam CRC8...E7, J! q( D# Y% W) ]6 D2 Q2 v
- Write Flash OK...
" H# j9 L0 t; ?2 Z* v4 Q# T% ^ - Save Param OK...4 ]2 L+ E+ o4 N; U0 X5 T
- Overtime Shutdown...7 }% n! i9 F1 T" f3 g; `
- ' A% y) n1 S# A3 a7 ^) |- c
- Init UART OK..0 J0 Z. p; S& G+ _" y
- Vref: 3302mV
; j4 S! o) |: k - SystemParamStore Size:88 11. G* I) q x o( m! q" Q
- Read System Param OK...1 I2 X: ^5 S. t4 O* j
3 L: I# @+ j: g- C - Meas Max Range: 20000dm% J& h- ?5 R1 P; }. W' c, [
- Angle Demar : 0 ==> 09 [4 E- _6 P* v% \4 U X
- Dist Demar : 0 ==> 0: H2 B9 y! s( J3 }6 |4 X
- Meas Type : 8( K' N/ q! J9 r
- Meas Unit : 1' x+ g; T" G6 C+ S6 Q) [9 d
4 z/ P L4 C! j3 t) `# A' A - **********************************************************+ B5 P( |/ u- ~
- Gyro Type MPU6887 ID 0x0F9 R9 J& ^" T/ f, F0 V
- Set Meas Type: 8
+ p& M9 c \; X - Shutdown OverTime: 20s9 L3 Z2 Y) Q% J
- Bat Sat : 0. [0 G; M. x" Y0 d2 `7 g
6 a! x' w) A' E) l% {* x( j. m( d1 i e - Write Flash OK...
6 G3 R; N$ w7 v/ s - Save Param OK...
2 k) ?4 u! r! ^1 |+ t- z- E2 Q - Overtime Shutdown...
复制代码 " D* v7 K* n9 v+ [
/ S7 V" T& Z5 @6 Q& y2 E; e9 V版权声明:凌盛羽; ^# K, C' Z& T; y
7 {! R6 x# b9 a/ {6 U' X7 a3 _4 A7 y* F. m0 L
2 K" F0 A, D+ P4 w% _1 j |
