QSPI仅接收数据异常 芯片信号:STM32H743II 测试Demo如下: void QSpiDemo(void){ uint8_t aucBuf[2]; MX_QUADSPI_Init(); /* QSPI初始化 */ aucBuf[0] = 4 << 1; aucBuf[1] = 0; QSPI_WriteRegEx(aucBuf, 2); /* 发送2字节数据 */ QSPI_ReadRegEx(aucBuf, 2); /* 接收2字节数据 */ } uint8_t QSPI_WriteRegEx(uint8_t *_pBuf, uint16_t _usWriteSize) { QSPI_CommandTypeDef sCommand = {0}; /* 基本配置 */ sCommand.DummyCycles = 0; /* 不需要空周期 */ sCommand.InstructionMode = QSPI_INSTRUCTION_NONE; /* No instruction */ sCommand.AddressMode = QSPI_ADDRESS_NONE; /* No address ;QSPI_ADDRESS_1_LINE */ sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE; /* 无交替字节 */ sCommand.DataMode = QSPI_DATA_1_LINE; /* 1线数据方式 */ sCommand.NbData = _usWriteSize; /* 写数据大小 */ sCommand.DdrMode = QSPI_DDR_MODE_DISABLE; /* 不支持DDR */ sCommand.DdrHoldHalfCycle = QSPI_DDR_HHC_ANALOG_DELAY; /* DDR模式,数据输出延迟 */ sCommand.SIOOMode = QSPI_SIOO_INST_EVERY_CMD; /* 仅发送一次命令 */ if(HAL_QSPI_Command(&hqspi, &sCommand, 5000) != HAL_OK) { return 0; } if(HAL_QSPI_Transmit(&hqspi, _pBuf, 5000) != HAL_OK) { return 0; } return 1; } uint8_t QSPI_ReadRegEx(uint8_t *_pBuf, uint16_t _usReadSize) { QSPI_CommandTypeDef sCommand = {0}; sCommand.DummyCycles = 0; /* 不需要空周期 */ sCommand.InstructionMode = QSPI_INSTRUCTION_NONE; /* No instruction */ sCommand.AddressMode = QSPI_ADDRESS_NONE; /* No address ;QSPI_ADDRESS_1_LINE */ sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE; /* 无交替字节 */ sCommand.DataMode = QSPI_DATA_1_LINE; /* 1线数据方式 */ sCommand.NbData = _usReadSize; /* 写数据大小 */ sCommand.DdrMode = QSPI_DDR_MODE_DISABLE; /* 不支持DDR */ sCommand.DdrHoldHalfCycle = QSPI_DDR_HHC_ANALOG_DELAY; /* DDR模式,数据输出延迟 */ sCommand.SIOOMode = QSPI_SIOO_INST_EVERY_CMD; /* 仅发送一次命令 */ if(HAL_QSPI_Command(&hqspi, &sCommand, 5000) != HAL_OK) { return 0; } if(HAL_QSPI_Receive(&hqspi, _pBuf, 5000) != HAL_OK) { return 0; } return 1; } 读取数据时,每次执行到HAL_QSPI_Receive函数MODIFY_REG(hqspi->Instance->CCR, QUADSPI_CCR_FMODE, QSPI_FUNCTIONAL_MODE_INDIRECT_READ)时,相关寄存器就会异常  如果将接收DummyCycles配置成2时,则可以正常接收数据,但是时序会异常导致接收数据不正确。  |
运行异常截图
修改点截图
手机端哪里可以查草稿
STM32H755生成的stm32CubeIde的TouchGFX designer生成代码出错。
TouchGFX Designer如何修改生成工程的脚本
STM32H7+SAI+DMA双缓冲配置失败.
STM32H743 LAN8720 CUBEMX配置lwIP无法ping通,分配pbuf失败
FW_H7 V1.12.1-HAL库DMA双缓冲配置
STM32H755的TouchGFX如何使能Cortex-M7
stm32Cube Visual studio code 如何设置STM32H7的下载算法
STM32H755的TouchGFX不能选择M7内核
请教SPI用LL读取的问题
Repository\STM32Cube_FW_H7_V1.11.0\Projects\STM32H743I-EVAL\Examples\QSPI
