ST25R3911B-DISCO开发板上的LC滤波电路为啥配置的截止频率是11.75MHZ?我们的NFC频率是13.56MHZ,是不是设置的比较低?
Flyder 提问时间:2023-7-11 15:13 / 未解决
赞 收藏 评论3 发布时间:2023-7-11 15:13
3个回答
Hallstatt 回答时间:2023-7-11 18:21:08
请参考AN5276的3.3章节EMC Filter部分。
Antenna design for ST25R3916/16B, ST25R3917/17B, ST25R3918, ST25R3919B, and ST25R3920/20B devices - Application note
Filter cutoff frequency (filter resonance frequency): – If the filter cutoff frequency is too close to the carrier frequency (13.56 MHz), the system Q factor is strongly decreased. The reason is the combination of the antenna and the filter Q factor. For this reason, the EMC cutoff frequency must not be comprised between 13 and 14 MHz.
Flyder 回答时间:2023-7-11 18:43:01
那再请问一下,如果LC滤波电路的截止频率设置的更低一点,如10MHZ,或者更高一点,如17MHZ,是否可行?对于NFC的识别存在什么影响呢?
Flyder 回答时间:2023-7-11 19:31:50
