如题,我先配置GPIOPD12后配置TIM4_CH1,但是通过监测发现没有PWM 输出,不知道是不是哪儿出问题了,定时器CNT仿真看到是正常的,但是就是没有PWM输出到gpio上,看GPIO的寄存器ISTAT也没有变化,看看哪位大神指导一下,或者我是那个寄存器没配置对?:程序如下: RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD,ENABLE); GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin =GPIO_Pin_12; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_OD; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ; GPIO_Init(DI8_GPIO_PORT, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_TIM4); TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; // NVIC_InitTypeDef NVIC_InitStructure; //NVIC RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE); TIM_TimeBaseStructure.TIM_Period = 21000-1; //250us TIM_TimeBaseStructure.TIM_Prescaler =0; TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Down; TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); TIM_SelectMasterSlaveMode(TIM4, TIM_MasterSlaveMode_Enable); TIM_SelectOutputTrigger(TIM4, TIM_TRGOSource_OC1Ref); TIM_ARRPreloadConfig(TIM4, ENABLE); TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;//TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;// TIM_OCIdleState_Reset
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;// TIM_OCNIdleState_Reset
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_Pulse = 10500+30;
TIM_OC1Init(TIM4, &TIM_OCInitStructure); |
stm32 f411偶发性无法启动大神求助
STM32F407VET6,使用cubeIDE下载跑不起来
FLASH擦除轮询等待时CPU真的会轮询吗
STM32F417 RTC读取亚秒寄存器
STM32F405ZGT6 批次22+ 问下这颗料,60度烘烤12小时后,出现鼓包,是怎么回事? 原厂有标准的烘烤温度范围 跟时长范围吗?
HAL_TIM_OC_SetConfigChannel 因 override_state 参数触发断言报错
VNS3NV04DPTR-E芯片测试开启延迟时间和关断延迟时间时,IN脚和DRAIN脚的电压波形是什么样子的,求大佬提供一下?
非官方开发板第一次下载成功,之后就各种失败
在 STM32Cube 中配置正交编码器模式
不知是否跟GPIO复用或时钟配置有关。 如果可能的话,尽量使用CubeMx进行配置,
基于它做配置实现PWM输出真是分分钟的事情。
硬件上注意整个硬件板可以正常工作了、别把管脚编号弄错了。
STM32F4xx_StdPeriph_Examples\TIM\TIM_PWMOutput
另外,标准库已经是上个时代的东西了,用CUBE库非常容易,而且参考例程非常多。
粗略看上面没有GPIO端口复用功能时钟的使能(AFIO)。都2023年了,还是建议使用HAL库,CubeMX软件直接生成初始化代码,完全没有初始化代码丢三落四的烦恼。
