[md]使用最新V5版源码及SDK,分立电源。 使用STM32CubeProgrammer烧写。 smt32MP157D optee完成后没有进入u-boot,系统重启 NOTICE: CPU: STM32MP157DAA Rev.Z NOTICE: Model: 2:HDIT TF-A 1 STM32MP157D eval daughter NOTICE: get_otp_index board_id:59 NOTICE: stm32_get_otp_value 0 NOTICE: boardinfo over NOTICE: get_otp_index cfg0_otp:0 NOTICE: fixed reg init NOTICE: register fixed reg regulator-vddcore! NOTICE: register fixed reg regulator-3p3v! NOTICE: register fixed reg regulator-vdd! NOTICE: register fixed reg regulator-vdd-usb! NOTICE: get_otp_index hw2_tp:18 NOTICE: get_otp_index hw2_otp:18 NOTICE: get_otp_index hw2_otp:18 NOTICE: get_otp_index hw2_otp:18 NOTICE: get_otp_index cfg0_otp:0 INFO: Reset reason (0x15): INFO: Power-on Reset (rst_por) INFO: FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000 INFO: FCONF: Reading firmware configuration information for: stm32mp_io INFO: Using USB INFO: Instance 2 INFO: Boot used partition fsbl1 NOTICE: BL2: v2.8-stm32mp1-r1.0(debug) )NOTICE: BL2: Built : 22:20:23, Jul 21 2023 INFO: BL2: Doing platform setup INFO: RAM: DDR3-DDR3L 32bits 533000kHz INFO: Memory size = 0x40000000 (1024 MB) INFO: DFU USB START... INFO: phase ID :3, Manifestation 3 at c71577fe INFO: Send detach request INFO: Receive DFU Detach INFO: DFU USB STOP... INFO: BL2: Loading image id 1 INFO: Loading image id=1 at address 0x2ffff000 INFO: Image id=1 loaded: 0x2ffff000 - 0x2ffff1ea INFO: FCONF: Reading FW_CONFIG firmware configuration file from: 0x2ffff000 INFO: FCONF: Reading firmware configuration information for: dyn_cfg INFO: FCONF: Reading firmware configuration information for: stm32mp1_firewall INFO: BL2: Loading image id 4 INFO: Loading image id=4 at address 0xfe000000 INFO: Image id=4 loaded: 0xfe000000 - 0xfe00001c INFO: OPTEE ep=0xfe000000 INFO: OPTEE header info: INFO: magic=0x4554504f INFO: version=0x2 INFO: arch=0x0 INFO: flags=0x0 INFO: nb_images=0x1 INFO: BL2: Loading image id 8 INFO: Loading image id=8 at address 0xfe000000 INFO: Image id=8 loaded: 0xfe000000 - 0xfe03ab68 INFO: BL2: Skip loading image id 9 INFO: BL2: Loading image id 2 INFO: Loading image id=2 at address 0xc0500000 INFO: Image id=2 loaded: 0xc0500000 - 0xc051d350 INFO: BL2: Skip loading image id 16 INFO: BL2: Loading image id 5 INFO: Loading image id=5 at address 0xc0100000 INFO: Image id=5 loaded: 0xc0100000 - 0xc01ff618 NOTICE: BL2: Booting BL32 INFO: Entry point address = 0xfe000000 INFO: SPSR = 0x1d3 I/TC: Early console on UART#4 D/TC:0 add_phys_mem:662 MCUSRAM_BASE type IO_SEC 0x30000000 size 0x00060000 D/TC:0 add_phys_mem:662 RETRAM_BASE type IO_SEC 0x38000000 size 0x00010000 D/TC:0 add_phys_mem:662 TEE_RAM_START type ROM_SEC 0xfe000000 size 0x00200000 D/TC:0 add_phys_mem:662 DDR_BASE type RAM_NSEC 0xc0000000 size 0x00001000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0xa0021000ul, CORE_MMU_PGDIR_SIZE) type IO_SEC 0xa0000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x54000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x54000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x50000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x50000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x48000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x48000000 size 0x01200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x5c000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x5c000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x5a000000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x5a000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x50020000, CORE_MMU_PGDIR_SIZE) type IO_SEC 0x50000000 size 0x00200000 D/TC:0 add_phys_mem:676 Physical mem map overlaps 0x50000000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x54000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x54000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x50000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x50000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x5c000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x5c000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x5a000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x5a000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x50020000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x50000000 size 0x00200000 D/TC:0 add_phys_mem:676 Physical mem map overlaps 0x50000000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x44000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x44000000 size 0x00200000 D/TC:0 add_phys_mem:662 ROUNDDOWN(0x40000000, CORE_MMU_PGDIR_SIZE) type IO_NSEC 0x40000000 size 0x00200000 D/TC:0 add_phys_mem:662 TA_RAM_START type TA_RAM 0xfe200000 size 0x01e00000 D/TC:0 add_phys_mem:662 VCORE_UNPG_RW_PA type TEE_RAM_RW 0xfe03a000 size 0x001c6000 D/TC:0 add_phys_mem:662 VCORE_UNPG_RX_PA type TEE_RAM_RX 0xfe000000 size 0x0003a000 D/TC:0 add_va_space:702 type RES_VASPACE size 0x00a00000 D/TC:0 add_va_space:702 type SHM_VASPACE size 0x02000000 D/TC:0 dump_mmap_table:829 type TA_RAM va 0xf6400000..0xf81fffff pa 0xfe200000..0xffffffff size 0x01e00000 (pgdir) D/TC:0 dump_mmap_table:829 type ROM_SEC va 0xf8400000..0xf85fffff pa 0xfe000000..0xfe1fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_SEC va 0xf8600000..0xf87fffff pa 0xa0000000..0xa01fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_SEC va 0xf8800000..0xf89fffff pa 0x5c000000..0x5c1fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_NSEC va 0xf8a00000..0xf8bfffff pa 0x5c000000..0x5c1fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_NSEC va 0xf8c00000..0xf8dfffff pa 0x5a000000..0x5a1fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_SEC va 0xf8e00000..0xf8ffffff pa 0x5a000000..0x5a1fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_SEC va 0xf9000000..0xf91fffff pa 0x54000000..0x541fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_NSEC va 0xf9200000..0xf93fffff pa 0x54000000..0x541fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_NSEC va 0xf9400000..0xf95fffff pa 0x50000000..0x501fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_SEC va 0xf9600000..0xf97fffff pa 0x50000000..0x501fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_SEC va 0xf9800000..0xfa9fffff pa 0x48000000..0x491fffff size 0x01200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_NSEC va 0xfac00000..0xfadfffff pa 0x44000000..0x441fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type IO_NSEC va 0xfae00000..0xfaffffff pa 0x40000000..0x401fffff size 0x00200000 (pgdir) D/TC:0 dump_mmap_table:829 type RES_VASPACE va 0xfb000000..0xfb9fffff pa 0x00000000..0x009fffff size 0x00a00000 (pgdir) D/TC:0 dump_mmap_table:829 type SHM_VASPACE va 0xfbc00000..0xfdbfffff pa 0x00000000..0x01ffffff size 0x02000000 (pgdir) D/TC:0 dump_mmap_table:829 type RAM_NSEC va 0xfdf8f000..0xfdf8ffff pa 0xc0000000..0xc0000fff size 0x00001000 (smallpg) D/TC:0 dump_mmap_table:829 type IO_SEC va 0xfdf90000..0xfdf9ffff pa 0x38000000..0x3800ffff size 0x00010000 (smallpg) D/TC:0 dump_mmap_table:829 type IO_SEC va 0xfdfa0000..0xfdffffff pa 0x30000000..0x3005ffff size 0x00060000 (smallpg) D/TC:0 dump_mmap_table:829 type TEE_RAM_RX va 0xfe000000..0xfe039fff pa 0xfe000000..0xfe039fff size 0x0003a000 (smallpg) D/TC:0 dump_mmap_table:829 type TEE_RAM_RW va 0xfe03a000..0xfe1fffff pa 0xfe03a000..0xfe1fffff size 0x001c6000 (smallpg) D/TC:0 core_mmu_xlat_table_alloc:526 xlat tables used 1 / 10 D/TC:0 core_mmu_xlat_table_alloc:526 xlat tables used 2 / 10 D/TC:0 core_mmu_xlat_table_alloc:526 xlat tables used 3 / 10 I/TC: I/TC: Embedded DTB found I/TC: OP-TEE version: Unknown_3.19 () #19 Tue Jul 25 06:34:18 UTC 2023 arm I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/ ... ing_guidelines.html I/TC: Primary CPU initializing I/TC: main_init_gic over I/TC: init_vfp_nsec over D/TC:0 0 call_preinitcalls:21 level 2 mobj_mapped_shm_init() D/TC:0 0 mobj_mapped_shm_init:463 Shared memory address range: fbc00000, fdc00000 D/TC:0 0 call_initcalls:40 level 1 register_time_source() D/TC:0 0 call_initcalls:40 level 1 initialize_bsec() D/TC:0 0 save_dt_nvmem_layout:900 nvmem[1] = cfg0_otp 0bit offset: 0, length: 8 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[2] = part_number_otp 1bit offset: 0, length: 8 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[3] = monotonic_otp 4bit offset: 0, length: 32 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[4] = nand_otp 9bit offset: 0, length: 32 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[5] = uid_otp 13bit offset: 0, length: 96 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[6] = package_otp 16bit offset: 0, length: 32 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[7] = hw2_otp 18bit offset: 0, length: 32 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[8] = calib 23bit offset: 0, length: 16 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[9] = calib 23bit offset: 16, length: 16 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[10] = pkh_otp 24bit offset: 0, length: 256 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[11] = mac 57bit offset: 0, length: 64 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[12] = board_id 59bit offset: 0, length: 32 D/TC:0 0 save_dt_nvmem_layout:900 nvmem[13] = huk-otp 60bit offset: 0, length: 128 D/TC:0 0 call_initcalls:40 level 1 clk_dt_probe() D/TC:0 0 clk_dt_probe:202 Probing clocks from devicetree F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-hse D/TC:0 0 clk_register:126 Registered clock clk-hse, freq 24000000 D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-hse initialized F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-hsi D/TC:0 0 clk_register:126 Registered clock clk-hsi, freq 64000000 D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-hsi initialized F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-lse D/TC:0 0 clk_register:126 Registered clock clk-lse, freq 32768 D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-lse initialized F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-lsi D/TC:0 0 clk_register:126 Registered clock clk-lsi, freq 32000 D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-lsi initialized F/TC:0 0 probe_driver_node:391 Probing fixed_clock on node clk-csi D/TC:0 0 clk_register:126 Registered clock clk-csi, freq 4000000 D/TC:0 0 probe_driver_node:398 element: fixed_clock on node clk-csi initialized F/TC:0 0 probe_driver_node:391 Probing stm32mp1_clock on node rcc@50000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 533000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 533000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 133250000 D/TC:0 0 clk_register:126 Registered clock (null), freq 133250000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 133250000 D/TC:0 0 clk_register:126 Registered clock (null), freq 133250000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 66625000 D/TC:0 0 clk_register:126 Registered clock (null), freq 66625000 D/TC:0 0 clk_register:126 Registered clock (null), freq 66625000 D/TC:0 0 clk_register:126 Registered clock (null), freq 66625000 D/TC:0 0 clk_register:126 Registered clock (null), freq 66625000 D/TC:0 0 clk_register:126 Registered clock (null), freq 66625000 D/TC:0 0 clk_register:126 Registered clock (null), freq 24000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 4000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 32768 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 208877928 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 208877928 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 0 D/TC:0 0 clk_register:126 Registered clock (null), freq 24000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 4000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 32000 D/TC:0 0 clk_register:126 Registered clock (null), freq 32768 D/TC:0 0 clk_register:126 Registered clock (null), freq 64000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 12000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 650000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 650000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 650000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 533000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 533000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 208877929 D/TC:0 0 clk_register:126 Registered clock (null), freq 24573874 D/TC:0 0 clk_register:126 Registered clock (null), freq 11290698 D/TC:0 0 clk_register:126 Registered clock (null), freq 266500000 D/TC:0 0 clk_register:126 Registered clock (null), freq 650000000 D/TC:0 0 clk_register:126 Registered clock (null), freq 208877929 F/TC:0 0 __clk_enable:1174 Clock 220 has been enabled F/TC:0 0 __clk_enable:1174 Clock 221 has been enabled F/TC:0 0 __clk_enable:1174 Clock 222 has been enabled F/TC:0 0 __clk_enable:1174 Clock 223 has been enabled F/TC:0 0 __clk_enable:1174 Clock 224 has been enabled F/TC:0 0 __clk_enable:1174 Clock 225 has been enabled F/TC:0 0 __clk_enable:1174 Clock 226 has been enabled F/TC:0 0 __clk_enable:1174 Clock 228 has been enabled F/TC:0 0 __clk_enable:1174 Clock 229 has been enabled F/TC:0 0 __clk_enable:1174 Clock 230 has been enabled F/TC:0 0 __clk_enable:1174 Clock 67 has been enabled F/TC:0 0 __clk_enable:1174 Clock 66 has been enabled F/TC:0 0 __clk_enable:1174 Clock 113 has been enabled F/TC:0 0 __clk_enable:1174 Clock 128 has been enabled F/TC:0 0 __clk_enable:1174 Clock 69 has been enabled F/TC:0 0 __clk_enable:1174 Clock 65 has been enabled D/TC:0 0 probe_driver_node:398 element: stm32mp1_clock on node rcc@50000000 initialized D/TC:0 0 call_initcalls:40 level 2 probe_dt_drivers_early() D/TC:0 0 add_node_to_probe:596 element: cpu0-opp-table on node stm32mp1-cpu-opp D/TC:0 0 print_probe_list:352 Probe list: 1 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: soc on node simple-bus D/TC:0 0 print_probe_list:352 Probe list: 2 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node soc D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: ahb on node simple-bus D/TC:0 0 print_probe_list:352 Probe list: 3 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node soc D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node ahb D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: regulator-vddcore on node fixed-regulator D/TC:0 0 print_probe_list:352 Probe list: 4 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node soc D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node ahb D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vddcore D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: regulator-3p3v on node fixed-regulator D/TC:0 0 print_probe_list:352 Probe list: 5 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node soc D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node ahb D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vddcore D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-3p3v D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: regulator-vdd on node fixed-regulator D/TC:0 0 print_probe_list:352 Probe list: 6 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node soc D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node ahb D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vddcore D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-3p3v D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vdd D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: regulator-vdd-usb on node fixed-regulator D/TC:0 0 print_probe_list:352 Probe list: 7 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node soc D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node ahb D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vddcore D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-3p3v D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vdd D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vdd-usb D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end F/TC:0 0 process_probe_list:505 Probe loop 1 after 0 for deferral(s) D/TC:0 0 print_probe_list:352 Probe list: 7 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node soc D/TC:0 0 print_probe_list:354 |- Driver simple-bus probes on node ahb D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vddcore D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-3p3v D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vdd D/TC:0 0 print_probe_list:354 |- Driver fixed-regulator probes on node regulator-vdd-usb D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end F/TC:0 0 probe_driver_node:391 Probing fixed-regulator on node regulator-vdd-usb F/TC:0 0 regulator_register:739 register regulator-vdd-usb F/TC:0 0 parse_dt:664 regulator-vdd-usb: parse embedded DTB F/TC:0 0 parse_dt:677 regulator-vdd-usb: min_mv=3300 F/TC:0 0 parse_dt:691 regulator-vdd-usb: max_mv=3300 F/TC:0 0 parse_properties:552 regulator-vdd-usb: 0x1 D/TC:0 0 probe_driver_node:398 element: fixed-regulator on node regulator-vdd-usb initialized F/TC:0 0 probe_driver_node:391 Probing fixed-regulator on node regulator-vdd F/TC:0 0 regulator_register:739 register regulator-vdd F/TC:0 0 parse_dt:664 regulator-vdd: parse embedded DTB F/TC:0 0 parse_dt:677 regulator-vdd: min_mv=3300 F/TC:0 0 parse_dt:691 regulator-vdd: max_mv=3300 F/TC:0 0 parse_properties:552 regulator-vdd: 0x1 D/TC:0 0 probe_driver_node:398 element: fixed-regulator on node regulator-vdd initialized F/TC:0 0 probe_driver_node:391 Probing fixed-regulator on node regulator-3p3v F/TC:0 0 regulator_register:739 register regulator-3p3v F/TC:0 0 parse_dt:664 regulator-3p3v: parse embedded DTB F/TC:0 0 parse_dt:677 regulator-3p3v: min_mv=3300 F/TC:0 0 parse_dt:691 regulator-3p3v: max_mv=3300 F/TC:0 0 parse_properties:552 regulator-3p3v: 0x1 D/TC:0 0 probe_driver_node:398 element: fixed-regulator on node regulator-3p3v initialized F/TC:0 0 probe_driver_node:391 Probing fixed-regulator on node regulator-vddcore F/TC:0 0 regulator_register:739 register regulator-vddcore F/TC:0 0 parse_dt:664 regulator-vddcore: parse embedded DTB F/TC:0 0 parse_dt:677 regulator-vddcore: min_mv=1200 F/TC:0 0 parse_dt:691 regulator-vddcore: max_mv=1350 F/TC:0 0 parse_properties:552 regulator-vddcore: 0x1 D/TC:0 0 probe_driver_node:398 element: fixed-regulator on node regulator-vddcore initialized F/TC:0 0 probe_driver_node:391 Probing simple-bus on node ahb D/TC:0 0 probe_driver_node:398 element: simple-bus on node ahb initialized F/TC:0 0 probe_driver_node:391 Probing simple-bus on node soc D/TC:0 0 add_node_to_probe:596 element: timer@44006000 on node stm32-timer D/TC:0 0 print_probe_list:352 Probe list: 2 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: rcc@50000000 on node stm32mp15_rstctrl D/TC:0 0 print_probe_list:352 Probe list: 3 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: pwr@50001000 on node stm32mp1-pwr-regu D/TC:0 0 print_probe_list:352 Probe list: 4 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: rtc@5c004000 on node stm32-rtc D/TC:0 0 print_probe_list:352 Probe list: 5 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: tzc@5c006000 on node stm32mp1-tzc400 D/TC:0 0 print_probe_list:352 Probe list: 6 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: tamp@5c00a000 on node stm32-tamp D/TC:0 0 print_probe_list:352 Probe list: 7 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: pin-controller@50002000 on node stm32_gpio D/TC:0 0 print_probe_list:352 Probe list: 8 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller@50002000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: pin-controller-z@54004000 on node stm32_gpio D/TC:0 0 print_probe_list:352 Probe list: 9 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller@50002000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller-z@54004000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 add_node_to_probe:596 element: etzpc@5c007000 on node stm32-etzpc D/TC:0 0 print_probe_list:352 Probe list: 10 elements D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-cpu-opp probes on node cpu0-opp-table D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller@50002000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller-z@54004000 D/TC:0 0 print_probe_list:354 |- Driver stm32-etzpc probes on node etzpc@5c007000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 0 elements D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 probe_driver_node:398 element: simple-bus on node soc initialized F/TC:0 0 probe_driver_node:391 Probing stm32mp1-cpu-opp on node cpu0-opp-table F/TC:0 0 get_supply_phandle:114 cpu: supplied by 4 E/TC:0 0 stm32mp1_cpu_opp_init:363 stm32mp1_cpu_opp_init 0 D/TC:0 0 stm32_bsec_find_otp_in_nvmem_layout:644 nvmem part_number_otp = 1: 1 bit offset: 0, length: 8 D/TC:0 0 stm32mp1_cpu_opp_get_dt_subnode:292 Found OPP 0 (800000kHz/1350mV) from DT F/TC:0 0 regulator_set_voltage:299 regulator-vddcore 1350mV E/TC:0 0 opp_set_voltage:68 opp_set_voltage 1350mV rst 4294901769 E/TC:0 0 opp_set_voltage:80 get voltage 1200mV D/TC:0 0 stm32mp1_cpu_opp_get_dt_subnode:304 clk_cpu 650000000 Hz,res 4294901760 E/TC:0 0 stm32mp1_cpu_opp_init:377 stm32mp1_cpu_opp_get_dt_subnode 4294901760 E/TC:0 0 probe_driver_node:413 Failed to probe stm32mp1-cpu-opp on node cpu0-opp-table: 0xffff0000 F/TC:0 0 process_probe_list:505 Probe loop 2 after 0 for deferral(s) D/TC:0 0 print_probe_list:352 Probe list: 9 elements D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller@50002000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller-z@54004000 D/TC:0 0 print_probe_list:354 |- Driver stm32-etzpc probes on node etzpc@5c007000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end F/TC:0 0 probe_driver_node:391 Probing stm32-etzpc on node etzpc@5c007000 D/TC:0 0 stm32_etzpc_set_driverdata:517 ETZPC revision 0x32, per_sec 96, ahb_sec 0, tzma 2 F/TC:0 0 etzpc_configure_decprot:148 ID : 3, CONF 3 F/TC:0 0 etzpc_configure_decprot:148 ID : 4, CONF 3 F/TC:0 0 etzpc_configure_decprot:148 ID : 5, CONF 3 F/TC:0 0 etzpc_configure_decprot:148 ID : 12, CONF 3 F/TC:0 0 etzpc_configure_decprot:148 ID : 7, CONF 0 F/TC:0 0 etzpc_configure_decprot:148 ID : 8, CONF 3 F/TC:0 0 etzpc_configure_decprot:148 ID : 10, CONF 1 F/TC:0 0 etzpc_configure_decprot:148 ID : 11, CONF 1 F/TC:0 0 etzpc_configure_decprot:148 ID : 0, CONF 0 F/TC:0 0 etzpc_configure_decprot:148 ID : 1, CONF 0 F/TC:0 0 etzpc_configure_decprot:148 ID : 2, CONF 0 F/TC:0 0 stm32_etzpc_has_access:393 Check Access 7 - attr 0 - requested 0 D/TC:0 0 add_node_to_probe:596 element: rng@54003000 on node stm32_rng D/TC:0 0 print_probe_list:352 Probe list: 9 elements D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller@50002000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller-z@54004000 D/TC:0 0 print_probe_list:354 |- Driver stm32_rng probes on node rng@54003000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end F/TC:0 0 stm32_etzpc_has_access:393 Check Access 5 - attr 3 - requested 0 F/TC:0 0 stm32_etzpc_has_access:393 Check Access 5 - attr 3 - requested 3 D/TC:0 0 add_node_to_probe:596 element: i2c@5c002000 on node stm32_i2c D/TC:0 0 print_probe_list:352 Probe list: 10 elements D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller@50002000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller-z@54004000 D/TC:0 0 print_probe_list:354 |- Driver stm32_rng probes on node rng@54003000 D/TC:0 0 print_probe_list:354 |- Driver stm32_i2c probes on node i2c@5c002000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end F/TC:0 0 stm32_etzpc_has_access:393 Check Access 2 - attr 0 - requested 0 D/TC:0 0 add_node_to_probe:596 element: watchdog@5c003000 on node stm32-iwdg D/TC:0 0 print_probe_list:352 Probe list: 11 elements D/TC:0 0 print_probe_list:354 |- Driver stm32-timer probes on node timer@44006000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp15_rstctrl probes on node rcc@50000000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-pwr-regu probes on node pwr@50001000 D/TC:0 0 print_probe_list:354 |- Driver stm32-rtc probes on node rtc@5c004000 D/TC:0 0 print_probe_list:354 |- Driver stm32mp1-tzc400 probes on node tzc@5c006000 D/TC:0 0 print_probe_list:354 |- Driver stm32-tamp probes on node tamp@5c00a000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller@50002000 D/TC:0 0 print_probe_list:354 |- Driver stm32_gpio probes on node pin-controller-z@54004000 D/TC:0 0 print_probe_list:354 |- Driver stm32_rng probes on node rng@54003000 D/TC:0 0 print_probe_list:354 |- Driver stm32_i2c probes on node i2c@5c002000 D/TC:0 0 print_probe_list:354 |- Driver stm32-iwdg probes on node watchdog@5c003000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end F/TC:0 0 stm32_etzpc_has_access:393 Check Access 0 - attr 0 - requested 0 D/TC:0 0 probe_driver_node:398 element: stm32-etzpc on node etzpc@5c007000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32_gpio on node pin-controller-z@54004000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@54004000 D/TC:0 0 _fdt_stm32_gpio_controller:721 GPIO bank Z assigned to non-secure F/TC:0 0 __clk_enable:1174 Clock 95 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank Z (8 pins) @f9004000 D/TC:0 0 probe_driver_node:398 element: stm32_gpio on node pin-controller-z@54004000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32_gpio on node pin-controller@50002000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50002000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50003000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50004000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50005000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50006000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50007000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50008000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@50009000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@5000a000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@5000b000 D/TC:0 0 _fdt_stm32_gpio_controller:701 Bank name gpio@5000c000 D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank Z (8 pins) @f9004000 F/TC:0 0 __clk_enable:1174 Clock 84 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank A (16 pins) @f9402000 F/TC:0 0 __clk_enable:1174 Clock 85 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank B (16 pins) @f9403000 F/TC:0 0 __clk_enable:1174 Clock 86 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank C (16 pins) @f9404000 F/TC:0 0 __clk_enable:1174 Clock 87 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank D (16 pins) @f9405000 F/TC:0 0 __clk_enable:1174 Clock 88 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank E (16 pins) @f9406000 F/TC:0 0 __clk_enable:1174 Clock 89 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank F (16 pins) @f9407000 F/TC:0 0 __clk_enable:1174 Clock 90 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank G (16 pins) @f9408000 F/TC:0 0 __clk_enable:1174 Clock 91 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank H (16 pins) @f9409000 F/TC:0 0 __clk_enable:1174 Clock 92 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank I (16 pins) @f940a000 F/TC:0 0 __clk_enable:1174 Clock 93 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank J (16 pins) @f940b000 F/TC:0 0 __clk_enable:1174 Clock 94 has been enabled D/TC:0 0 stm32_gpio_probe:907 Registered GPIO bank K (8 pins) @f940c000 D/TC:0 0 probe_driver_node:398 element: stm32_gpio on node pin-controller@50002000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32-tamp on node tamp@5c00a000 D/TC:0 0 stm32_tamp_parse_passive_conf:1088 Passive conf from dt: precharge=0, nb_sample=0, clk_div=32768 D/TC:0 0 stm32_tamp_parse_active_conf:1204 Active conf from dt: no filter clk_div=1 F/TC:0 0 stm32_tamp_probe:1350 STM32 TAMPER V1.2 D/TC:0 0 gic_it_set_cpu_mask:350 cpu_mask: writing 0xff00 to 0xf86218e4 D/TC:0 0 gic_it_set_cpu_mask:352 cpu_mask: 0x300 D/TC:0 0 gic_it_set_prio:361 prio: writing 0x1 to 0xf86214e5 D/TC:0 0 probe_driver_node:398 element: stm32-tamp on node tamp@5c00a000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32mp1-tzc400 on node tzc@5c006000 D/TC:0 0 tzc_set_driverdata:124 TZC400 Filters 2 Regions 8 D/TC:0 0 add_carved_out_nsec:382 0xc0000000 - 0xfdffffff : Sec access 0 NS access 0x87fb87fb D/TC:0 0 tzc_dump_state:473 region 0 D/TC:0 0 tzc_dump_state:476 region_base: 0x0000000000000000 D/TC:0 0 tzc_dump_state:479 region_top: 0x00000000ffffffff D/TC:0 0 tzc_dump_state:481 secure rw: TZC_REGION_S_NONE D/TC:0 0 tzc_dump_state:486 filter 0 enable D/TC:0 0 tzc_dump_state:486 filter 1 enable D/TC:0 0 tzc_dump_state:473 region 1 D/TC:0 0 tzc_dump_state:476 region_base: 0x00000000fe000000 D/TC:0 0 tzc_dump_state:479 region_top: 0x00000000ffffffff D/TC:0 0 tzc_dump_state:481 secure rw: TZC_REGION_S_RDWR D/TC:0 0 tzc_dump_state:486 filter 0 enable D/TC:0 0 tzc_dump_state:486 filter 1 enable D/TC:0 0 tzc_dump_state:473 region 2 D/TC:0 0 tzc_dump_state:476 region_base: 0x00000000c0000000 D/TC:0 0 tzc_dump_state:479 region_top: 0x00000000fdffffff D/TC:0 0 tzc_dump_state:481 secure rw: TZC_REGION_S_NONE D/TC:0 0 tzc_dump_state:486 filter 0 enable D/TC:0 0 tzc_dump_state:486 filter 1 enable D/TC:0 0 gic_it_set_cpu_mask:350 cpu_mask: writing 0xff to 0xf8621824 D/TC:0 0 gic_it_set_cpu_mask:352 cpu_mask: 0x3 D/TC:0 0 gic_it_set_prio:361 prio: writing 0x1 to 0xf8621424 D/TC:0 0 probe_driver_node:398 element: stm32mp1-tzc400 on node tzc@5c006000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32-rtc on node rtc@5c004000 F/TC:0 0 __clk_enable:1174 Clock 192 has been enabled D/TC:0 0 probe_driver_node:398 element: stm32-rtc on node rtc@5c004000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32mp1-pwr-regu on node pwr@50001000 F/TC:0 0 regulator_register:739 register reg11 F/TC:0 0 parse_dt:664 reg11: parse embedded DTB F/TC:0 0 parse_dt:677 reg11: min_mv=1100 F/TC:0 0 parse_dt:691 reg11: max_mv=1100 F/TC:0 0 regulator_list_voltages:440 min_mv=1100 max_mv=1100 F/TC:0 0 get_supply_phandle:114 vdd: supplied by 25 F/TC:0 0 regulator_register:739 register reg18 F/TC:0 0 parse_dt:664 reg18: parse embedded DTB F/TC:0 0 parse_dt:677 reg18: min_mv=1800 F/TC:0 0 parse_dt:691 reg18: max_mv=1800 F/TC:0 0 regulator_list_voltages:440 min_mv=1800 max_mv=1800 F/TC:0 0 get_supply_phandle:114 vdd: supplied by 25 F/TC:0 0 regulator_register:739 register usb33 F/TC:0 0 parse_dt:664 usb33: parse embedded DTB F/TC:0 0 parse_dt:677 usb33: min_mv=3300 F/TC:0 0 parse_dt:691 usb33: max_mv=3300 F/TC:0 0 regulator_list_voltages:440 min_mv=3300 max_mv=3300 F/TC:0 0 get_supply_phandle:114 vdd_3v3_usbfs: supplied by 26 D/TC:0 0 probe_driver_node:398 element: stm32mp1-pwr-regu on node pwr@50001000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32mp15_rstctrl on node rcc@50000000 D/TC:0 0 probe_driver_node:398 element: stm32mp15_rstctrl on node rcc@50000000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32-timer on node timer@44006000 D/TC:0 0 probe_driver_node:398 element: stm32-timer on node timer@44006000 initialized F/TC:0 0 process_probe_list:505 Probe loop 3 after 0 for deferral(s) D/TC:0 0 print_probe_list:352 Probe list: 3 elements D/TC:0 0 print_probe_list:354 |- Driver stm32_rng probes on node rng@54003000 D/TC:0 0 print_probe_list:354 |- Driver stm32_i2c probes on node i2c@5c002000 D/TC:0 0 print_probe_list:354 |- Driver stm32-iwdg probes on node watchdog@5c003000 D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end F/TC:0 0 probe_driver_node:391 Probing stm32-iwdg on node watchdog@5c003000 F/TC:0 0 __clk_enable:1174 Clock 68 has been enabled F/TC:0 0 __clk_disable:1187 Clock 68 has been disabled D/TC:0 0 register_periph:104 Register IWDG1 as secure D/TC:0 0 probe_driver_node:398 element: stm32-iwdg on node watchdog@5c003000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32_i2c on node i2c@5c002000 D/TC:0 0 i2c_compute_timing:454 I2C SDADEL(min/max): 18/519, SCLDEL(Min): 285 D/TC:0 0 i2c_compute_timing:552 I2C TIMINGR (PRESC/SCLDEL/SDADEL): 1/8/1 D/TC:0 0 i2c_compute_timing:554 I2C TIMINGR (SCLH/SCLL): 27/38 D/TC:0 0 i2c_compute_timing:556 I2C TIMINGR: 0x10811b26 D/TC:0 0 i2c_setup_timing:643 I2C Freq(400000Hz), Clk Source(64000000) D/TC:0 0 i2c_setup_timing:645 I2C Rise(185) and Fall(20) Time D/TC:0 0 i2c_setup_timing:647 I2C Analog Filter(On), DNF(0) F/TC:0 0 __clk_enable:1174 Clock 140 has been enabled F/TC:0 0 __clk_disable:1187 Clock 140 has been disabled D/TC:0 0 probe_driver_node:398 element: stm32_i2c on node i2c@5c002000 initialized F/TC:0 0 probe_driver_node:391 Probing stm32_rng on node rng@54003000 F/TC:0 0 __clk_enable:1174 Clock 124 has been enabled F/TC:0 0 __clk_disable:1187 Clock 124 has been disabled D/TC:0 0 register_periph:104 Register RNG1 as secure D/TC:0 0 probe_driver_node:398 element: stm32_rng on node rng@54003000 initialized F/TC:0 0 process_probe_list:505 Probe loop 4 after 0 for deferral(s) D/TC:0 0 print_probe_list:352 Probe list: 0 elements D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 call_initcalls:40 level 3 platform_banner() I/TC: Platform stm32mp1: flavor PLATFORM_FLAVOR - DT stm32mp157d-hdit.dts D/TC:0 0 call_initcalls:40 level 3 verify_pseudo_tas_conformance() D/TC:0 0 call_initcalls:40 level 3 mobj_init() D/TC:0 0 call_initcalls:40 level 3 default_mobj_init() D/TC:0 0 call_initcalls:40 level 3 tee_cryp_init() D/TC:0 0 call_initcalls:40 level 4 init_console_from_dt() F/TC:0 0 __clk_enable:1174 Clock 151 has been enabled D/TC:0 0 register_periph_iomem:203 IO for non-secure resource 0x40010000 I/TC: DTB enables console (non-secure) D/TC:0 0 call_initcalls:40 level 4 tee_fs_init_key_manager() D/TC:0 0 call_initcalls:40 level 5 stm32mp_syscfg_enable_io_compensation() F/TC:0 0 __clk_enable:1174 Clock 51 has been enabled D/TC:0 0 call_initcalls:40 level 5 init_pm_support() F/TC:0 0 __clk_enable:1174 Clock 99 has been enabled F/TC:0 0 __clk_disable:1187 Clock 99 has been disabled F/TC:0 0 __clk_enable:1174 Clock 99 has been enabled F/TC:0 0 __clk_disable:1187 Clock 99 has been disabled D/TC:0 0 call_initcalls:40 level 5 probe_dt_drivers() F/TC:0 0 process_probe_list:505 Probe loop 5 after 0 for deferral(s) D/TC:0 0 print_probe_list:352 Probe list: 0 elements D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end E/TC:0 0 probe_dt_drivers:750 Probe sequence result: 0 D/TC:0 0 print_probe_list:352 Probe list: 0 elements D/TC:0 0 print_probe_list:358 `- Probe list end D/TC:0 0 print_probe_list:364 Failed list: 1 elements E/TC:0 0 print_probe_list:366 |- Driver stm32mp1-cpu-opp on node cpu0-opp-table failed D/TC:0 0 print_probe_list:369 `- Failed list end D/TC:0 0 call_initcalls:40 level 6 stm32_configure_tamp() D/TC:0 0 stm32_tamp_set_int_config:412 INT_TAMP1 enabled as a full tamper D/TC:0 0 stm32_tamp_set_int_config:412 INT_TAMP2 enabled as a full tamper D/TC:0 0 stm32_tamp_set_int_config:412 INT_TAMP3 enabled as a full tamper D/TC:0 0 stm32_tamp_set_int_config:412 INT_TAMP4 enabled as a full tamper F/TC:0 0 stm32_tamp_set_int_config:398 INT_TAMP5 disabled F/TC:0 0 stm32_tamp_set_int_config:398 INT_TAMP8 disabled F/TC:0 0 stm32_tamp_set_ext_config:447 EXT_TAMP1 disabled F/TC:0 0 stm32_tamp_set_ext_config:447 EXT_TAMP2 disabled F/TC:0 0 stm32_tamp_set_ext_config:447 EXT_TAMP3 disabled F/TC:0 0 stm32_tamp_set_config:659 Set passive conf 00000080 F/TC:0 0 stm32_tamp_set_config:664 Set active conf1 00000000 D/TC:0 0 call_initcalls:40 level 6 init_stm32mp1_drivers() D/TC:0 0 gic_it_set_cpu_mask:350 cpu_mask: writing 0x101ff01 to 0xf8621808 D/TC:0 0 gic_it_set_cpu_mask:352 cpu_mask: 0x1010101 D/TC:0 0 gic_it_set_prio:361 prio: writing 0x1 to 0xf8621409 D/TC:0 0 call_initcalls:40 level 6 stm32mp1_init_scmi_server() D/TC:0 0 call_initcalls:40 level 6 stm32mp1_init_final_shres() D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp IWDG1 ( 0): secure D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp USART1 ( 1): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp SPI6 ( 2): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp I2C4 ( 3): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp RNG1 ( 4): secure D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp HASH1 ( 5): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp CRYP1 ( 6): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp I2C6 ( 7): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp RTC ( 8): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp MCU ( 9): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp PLL3 (10): unregistered D/TC:0 0 stm32mp1_init_final_shres:438 stm32mp MDMA (11): unregistered D/TC:0 0 stm32_bsec_find_otp_in_nvmem_layout:644 nvmem cfg0_otp = 0: 0 bit offset: 0, length: 8 D/TC:0 0 check_rcc_secure_configuration:347 RCC/PWR secure hardening: TZEN enable, MCKPROT enable F/TC:0 0 stm32_etzpc_has_access:393 Check Access 2 - attr 0 - requested 3 F/TC:0 0 stm32_etzpc_has_access:393 Check Access 7 - attr 0 - requested 3 D/TC:0 0 call_initcalls:40 level 6 init_stm32mp1_calib() D/TC:0 0 init_stm32mp1_calib:536 Calibration csi-calibration enabled F/TC:0 0 set_cal_counter:441 Counter freq is 208877928 F/TC:0 0 __clk_enable:1174 Clock 208 has been enabled F/TC:0 0 get_freq:192 csi-calibration Freq is 4076800 F/TC:0 0 get_freq:192 csi-calibration Freq is 4111360 F/TC:0 0 get_freq:192 csi-calibration Freq is 4096256 F/TC:0 0 get_freq:192 csi-calibration Freq is 4081792 F/TC:0 0 get_freq:192 csi-calibration Freq is 4065664 F/TC:0 0 get_freq:192 csi-calibration Freq is 3889408 F/TC:0 0 get_freq:192 csi-calibration Freq is 3873152 F/TC:0 0 __clk_disable:1187 Clock 208 has been disabled D/TC:0 0 init_stm32mp1_calib:536 Calibration hsi-calibration enabled F/TC:0 0 set_cal_counter:441 Counter freq is 208877928F/TC:0 0 __clk_disable:1187 Clock 208 has been disabled F/TC:0 0 __clk_enable:1174 Clock 208 has been enabled F/TC:0 0 get_freq:192 hsi-calibration Freq is 63847424 F/TC:0 0 get_freq:192 hsi-calibration Freq is 63847424 F/TC:0 0 get_freq:192 hsi-calibration Freq is 64135168 F/TC:0 0 get_freq:192 hsi-calibration Freq is 64000000 F/TC:0 0 get_freq:192 hsi-calibration Freq is 63847424 D/TC:0 0 osc_calibration:300 Calibration : Freq 63847424 , trim 292 F/TC:0 0 get_freq:192 hsi-calibration Freq is 64000000 F/TC:0 0 __clk_disable:1187 Clock 208 has been disabled F/TC:0 0 __clk_enable:1174 Clock 208 has been enabled F/TC:0 0 get_freq:192 csi-calibration Freq is 4001792 F/TC:0 0 get_freq:192 csi-calibration Freq is 3984512 F/TC:0 0 get_freq:192 csi-calibration Freq is 4001792 F/TC:0 0 get_freq:192 csi-calibration Freq is 3985664 D/TC:0 0 osc_calibration:300 Calibration : Freq 3985664 , trim 120 F/TC:0 0 get_freq:192 csi-calibration Freq is 4002432 F/TC:0 0 __clk_disable:1187 Clock 208 has been disabled D/TC:0 0 call_initcalls:40 level 6 stm32mp_syscfg_set_hslv() D/TC:0 0 stm32_bsec_find_otp_in_nvmem_layout:644 nvmem hw2_otp = 6: 18 bit offset: 0, length: 32 D/TC:0 0 call_initcalls:40 level 6 init_low_power() D/TC:0 0 gic_it_set_cpu_mask:350 cpu_mask: writing 0xff00 to 0xf86218b0 D/TC:0 0 gic_it_set_cpu_mask:352 cpu_mask: 0x300 D/TC:0 0 gic_it_set_prio:361 prio: writing 0x1 to 0xf86214b1 D/TC:0 0 call_initcalls:40 level 6 stm32mp1_init_lp_states() D/TC:0 0 stm32mp1_init_lp_states:236 Power configuration: shutdown to 6, suspend to 2 D/TC:0 0 call_initcalls:40 level 6 regulator_core_init() F/TC:0 0 regulator_core_config:957 F/TC:0 0 regulator_core_config:963 usb33: connect supply F/TC:0 0 regulator_core_config:963 reg18: connect supply F/TC:0 0 regulator_core_config:963 reg11: connect supply F/TC:0 0 _regulator_enable:150 regulator-vddcore F/TC:0 0 _regulator_enable:188 regulator-vddcore refcount: 1 F/TC:0 0 _regulator_enable:150 regulator-3p3v F/TC:0 0 _regulator_enable:188 regulator-3p3v refcount: 1 F/TC:0 0 _regulator_enable:150 regulator-vdd F/TC:0 0 _regulator_enable:188 regulator-vdd refcount: 1 F/TC:0 0 _regulator_enable:150 regulator-vdd-usb F/TC:0 0 _regulator_enable:188 regulator-vdd-usb refcount: 1 F/TC:0 0 regulator_core_dump:920 Dump Regulators F/TC:0 0 regulator_core_dump:921 reg name use en mV min max flags supply F/TC:0 0 regulator_core_dump:941 usb33 usb33 0 0 3300 3300 3300 0 regulator-vdd-usb F/TC:0 0 regulator_core_dump:941 reg18 reg18 0 1 1800 1800 1800 0 regulator-vdd F/TC:0 0 regulator_core_dump:941 reg11 reg11 0 1 1100 1100 1100 0 regulator-vdd F/TC:0 0 regulator_core_dump:941 vddcore regulato 1 1 1200 1200 1350 0x1 F/TC:0 0 regulator_core_dump:941 v3v3 regulato 1 1 3300 3300 3300 0x1 F/TC:0 0 regulator_core_dump:941 vdd regulato 1 1 3300 3300 3300 0x1 F/TC:0 0 regulator_core_dump:941 vdd_usb regulato 1 1 3300 3300 3300 0x1 D/TC:0 0 call_initcalls:40 level 7 stm32_rng_release() D/TC:0 0 call_initcalls:40 level 7 regulator_core_cleanup() F/TC:0 0 regulator_core_cleanup:1008 D/TC:0 0 regulator_core_cleanup:1012 disable usb33 D/TC:0 0 regulator_core_cleanup:1012 disable reg18 D/TC:0 0 regulator_core_cleanup:1012 disable reg11 D/TC:0 0 call_initcalls:40 level 7 release_probe_lists() I/TC: init_tee_runtime over D/TC:0 0 call_finalcalls:59 level 1 release_external_dt() I/TC: Primary CPU switching to normal world boot D/TC:0 tee_entry_exchange_capabilities:101 Asynchronous notifications are disabled D/TC:0 tee_entry_exchange_capabilities:110 Dynamic shared memory is enabled D/TC:0 0 core_mmu_xlat_table_alloc:526 xlat tables used 4 / 10 D/TC:? 0 tee_ta_init_pseudo_ta_session:296 Lookup pseudo TA 7011a688-ddde-4053-a5a9-7b3c4ddf13b8 D/TC:? 0 tee_ta_init_pseudo_ta_session:309 Open device.pta D/TC:? 0 tee_ta_init_pseudo_ta_session:326 device.pta : 7011a688-ddde-4053-a5a9-7b3c4ddf13b8 F/TC:? 0 plat_prng_add_jitter_entropy:72 0xAB02 D/TC:0 tee_entry_exchange_capabilities:101 Asynchronous notifications are disabled D/TC:0 tee_entry_exchange_capabilities:110 Dynamic shared memory is enabled D/TC:0 tee_entry_exchange_capabilities:101 Asynchronous notifications are disabled D/TC:0 tee_entry_exchange_capabilities:110 Dynamic shared memory is enabled D/TC:0 tee_entry_exchange_capabilities:101 Asynchronous notifications are disabled D/TC:0 tee_entry_exchange_capabilities:110 Dynamic shared memory is enabled D/TC:0 tee_entry_exchange_capabilities:101 Asynchronous notifications are disabled D/TC:0 tee_entry_exchange_capabilities:110 Dynamic shared memory is enabled NOTICE: get_otp_index part_number_otp:1 NOTICE: get_otp_index package_otp:16 NOTICE: CPU: STM32MP157DAA Rev.Z NOTICE: Model: 2:HDIT TF-A 1 STM32MP157D eval daughter NOTICE: get_otp_index board_id:59 NOTICE: stm32_get_otp_value 0 NOTICE: boardinfo over NOTICE: get_otp_index cfg0_otp:0 NOTICE: fixed reg init NOTICE: register fixed reg regulator-vddcore! NOTICE: register fixed reg regulator-3p3v! NOTICE: register fixed reg regulator-vdd! NOTICE: register fixed reg regulator-vdd-usb! NOTICE: get_otp_index hw2_otp:18 NOTICE: get_otp_index hw2_otp:18 NOTICE: get_otp_index hw2_otp:18 NOTICE: get_otp_index hw2_otp:18 NOTICE: get_otp_index cfg0_otp:0 INFO: Reset reason (0x54): INFO: System reset generated by MPU (MPSYSRST) INFO: FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000 INFO: FCONF: Reading firmware configuration information for: stm32mp_io INFO: Using USB INFO: Instance 2 INFO: Boot used partition fsbl1 NOTICE: BL2: v2.8-stm32mp1-r1.0(debug) )NOTICE: BL2: Built : 22:20:23, Jul 21 2023 INFO: BL2: Doing platform setup INFO: RAM: DDR3-DDR3L 32bits 533000kHz INFO: Memory size = 0x40000000 (1024 MB) INFO: DFU USB START... |
在stm32mp135f-dk上搭建编译环境,应该需要怎么做,有哪个大佬能解答一下
社区无法登录
STM32CubeID V1.19.0 无法识别串口设备
STM32MP135D的TIM2使用ETR作为外部时钟时,无法使用PE15作为输入
实际ECG和有创压生理信号模拟器
STM32CubeIDE 报错 编译STM32MP135(Projects\STM32MP135C-DK\External_Loader)
STM32MP157D调试M4内核的问题
STM32MP135移植lvgl build fatal error: drm.h: No such file or directory
STM32MP135无法用NFS开机挂载文件系统启动,报错root '/dev/nfs' doesn't exist
repo 拉取创库老是失败,有什么方法直接下载
你好,
tf-a/optee/u-boot的设备树可以提供一下吗
