例程中没有输出变量,接下来的任务就是通过串口输出 ADC1 的值了。3 ~% G' u" Y" D
- O" c9 L7 w0 R- u
根据板子的设计,将串口输出到 USART3_PD9,USART3_PD8。通过新建立的项目完成硬件配置,主要是将 ADC 的函数拷贝到项目中。7 b/ J- e8 n' Y% N! g
: E' l2 {5 y+ v8 Y) C+ Y - + e; i7 {- @ ]$ j0 h% B+ @
- * @brief USART3 Initialization Function$ _$ p9 N$ m! I& ~/ Q( ?$ L9 X1 }7 F
- * @param None! \2 ?, N0 k! e" a1 v
- * @retval None- s6 ~0 P7 Q# q6 x! Z6 Q. B R. r
- */static void MX_USART3_UART_Init(void)1 Q5 I* L3 O3 }' |( h/ L! [# @2 v$ T
- {3 J5 f' m- J, Z& p; g
- / L9 V* }6 B% l6 m
- /* USER CODE BEGIN USART3_Init 0 */% g) [& W7 w% E/ [) p" U: y b
- 3 m; g h, M* Q8 |$ ~: C6 |/ ^
- /* USER CODE END USART3_Init 0 */9 e- A) s3 l/ W' a, w! Q
& Y! b8 R& S4 }" P5 O) Z$ O R- |- /* USER CODE BEGIN USART3_Init 1 */
+ _% [, W$ A% X; E, n5 Z$ n/ p- o
. w6 ?5 m3 Z- n, {+ ~- /* USER CODE END USART3_Init 1 */
) @: n7 L- _2 F% V - huart3.Instance = USART3;
: H+ m6 t j' X1 o% ]# s, v - huart3.Init.BaudRate = 115200;: z; f4 y: C* x$ k9 }8 D# N- Q' E2 t( I# Q
- huart3.Init.WordLength = UART_WORDLENGTH_8B;
) c' W6 K) X& ]. c% C* \; C: r - huart3.Init.StopBits = UART_STOPBITS_1;
3 Z6 X- J: L Q0 ]- O4 U# y - huart3.Init.Parity = UART_PARITY_NONE;7 s9 O9 N. ^5 U
- huart3.Init.Mode = UART_MODE_TX_RX;/ k5 T: X1 h. O5 R: g
- huart3.Init.HwFlowCtl = UART_HWCONTROL_NONE;, F6 I" T7 q; i4 Z1 P, H# b
- huart3.Init.OverSampling = UART_OVERSAMPLING_16; `- c% y/ q- s1 W6 f
- huart3.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
# m0 ?" S. Q- U1 _; r. i! ?& q9 I - huart3.Init.ClockPrescaler = UART_PRESCALER_DIV1;" k a* {0 Q$ w/ m
- huart3.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
: x! H8 [0 |- { - if (HAL_UART_Init(&huart3) != HAL_OK)
2 y* E' @# J" r" j) O7 U - {/ v# `" ?; ~, I4 }- ]! d" ^
- Error_Handler();; Y( Y; b7 c" w. u- t, A8 U
" p+ Q- B% e! S, n9 N% j - if (HAL_UARTEx_SetTxFifoThreshold(&huart3, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)+ B0 \) m1 k# p$ ~8 x9 z9 V
^5 ?( W) b g - Error_Handler();$ N" b# X# _. Y! ?4 z
- }5 Q, i# {. k. r" S9 y+ `" I
- if (HAL_UARTEx_SetRxFifoThreshold(&huart3, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK). c' }2 W" s6 f: H+ o
- {3 D/ b* H8 K" J- V" x( G* ^* u
- Error_Handler();
v7 D% a$ W6 Q& A. c# D; {! | - }
5 f% w: U% T! `, O7 C5 g, T7 x - if (HAL_UARTEx_DisableFifoMode(&huart3) != HAL_OK)" M1 v7 _5 a$ `( p" A3 O
- {: @$ ^* L. R( d( g
- Error_Handler();
4 z) c" O9 n# p - }
- C. i* ]4 Z R( l$ ? - /* USER CODE BEGIN USART3_Init 2 */8 m" F# d0 |* y6 p& H6 t6 ]# D
- 4 ]1 D% C2 {' D5 C# @- P
- /* USER CODE END USART3_Init 2 */
7 q6 j5 M) K+ c: F; R
: X7 Y" p4 V0 r( b# G- }
: _" a* W: |1 J* i$ M' W, z2 G6 d
将例程拷贝到例程中,然后是 printf 函数的设置,main.c 中包含 #include <stdio.h>. t5 V" i( |; B* _
7 _: o( g# H$ A) _& m- #if defined(__ICCARM__)
+ P& c3 m: Q) K; d: I; @ - /* New definition from EWARM V9, compatible with EWARM8 */
# c* `0 u7 a# B1 o - int iar_fputc(int ch);! Q* o4 u/ N7 h& i5 t
- #define PUTCHAR_PROTOTYPE int putchar(int ch)
: M: i0 Y& Q1 T2 R# U - #elif defined ( __CC_ARM ) || defined(__ARMCC_VERSION) m* c, G* i7 o6 _3 ^$ O* `
- /* ARM Compiler 5/6*/
9 X+ @- G8 d) v4 v! r/ m6 Y - #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
$ |' S0 E6 w3 l6 Y5 }4 Q - #elif defined(__GNUC__)2 f0 x1 D% O- x$ L+ N2 Z' C# o
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)# M: P1 m. ]1 x3 Z
- #endif /* __ICCARM__ */
复制代码 3 F- i {' q7 x& x
还有就是声明 PUTCHAR_PROTOTYPE 宏。
+ D' X+ x: [* `- /* USER CODE BEGIN 4 */
9 a$ H# E# t8 a* ^3 r4 g9 x+ Y6 J - /**
4 B( g" T2 b2 Q6 N6 ^8 N
$ C# `% z' [7 ~% R6 n- \- * @brief Retargets the C library printf function to the USART.
# W, r( {" C6 M2 N7 @9 }: U - * @param None
. b1 p; {6 `( z/ q4 e: ~) f& d - * @retval None
2 D C: J8 z% G3 k: Z, ? - */& e/ w! {$ y$ z9 `& j; _7 K
- PUTCHAR_PROTOTYPE/ | O0 E2 [9 b* Q# z% n/ K
- {% ^( _( B: e! s% U6 q2 q+ g& c
- /* Place your implementation of fputc here *// G( s( {9 G' e) a
- /* e.g. write a character to the USART1 and Loop until the end of transmission */
6 N5 I! X+ a5 P2 Y. u ^! S - HAL_UART_Transmit(&huart3, (uint8_t *)&ch, 1, 0xFFFF);
u% c4 S& \& n, L# e; J - % b' y( m3 C+ E9 {. x# y
- return ch;/ `- L! X7 E6 T) ?4 b0 x9 M M
: a1 Q/ |! n! I n9 ?4 D0 L% p7 I( R - /* USER CODE END 4 */+ `! r" \6 u$ e
复制代码 还需要一个 keil 的设置 MicroLib。) B2 N2 |. V3 Q0 n
% O, j# Z. O/ h& Q3 L
% P/ k/ ~+ Z2 A6 E' s/ |) m
3 K& [* i! j& A
& R5 Y; u: i7 w* F1 I# R& y% g2 {( I
- while (1) p4 ]; C+ c* Y+ ~9 c s A' H' j
+ w$ c" Y v5 l' H& Z2 D - /* USER CODE END WHILE */5 u% _2 l5 ^5 f1 n. e
- /* Start ADC group regular conversion */3 p* r! J& f! K
- if (HAL_ADC_Start_IT(&hadc1) != HAL_OK)
" i7 V7 V4 e) K9 t - {; y; F' H/ ]( [/ u2 a- Q
- /* Error: ADC conversion start could not be performed */
/ M3 l u9 X7 {0 p8 o3 P - Error_Handler();2 _0 T+ i. i% ~$ p) T- w/ n
" v- n, B) {) F, w2 {/ Q
1 f" P# ?* M3 b' B) Z- /* For this example purpose, wait until conversion is done */$ C+ s8 Y% u- x( s9 y( {
- while (ubAdcGrpRegularUnitaryConvStatus != 1);
' g% x, x& n7 A; _7 R: e - printf("mVolt=%d \n",uhADCxConvertedData_Voltage_mVolt);
, p4 }) o' `7 J, Q( X2 J - /* Reset status variable of ADC group regular unitary conversion */
3 k! ?* G% ~, z1 ~# y7 h* r6 ` - ubAdcGrpRegularUnitaryConvStatus = 0;
+ V. m/ D9 f2 l$ C+ J8 i% b0 ` - HAL_Delay(500);
; b6 b! ]9 P: C& |% h- s$ G0 F - /* USER CODE BEGIN 3 */
+ ^- W; X; Y' e. j - }
复制代码 ' m1 }. s) W5 f$ i+ X
下面是输出的结果
# q; I* k7 ^! [; R% C
+ H |3 v, J4 ?' v0 B- I! h
测试中我使用了我的一个宝贝,信号发生器。ADC 的性能和以往的ST差不多。
( G% ~( ^2 G* v9 S
( `1 O6 b$ N8 X* r+ I. s! T% b; L来源:EEWORLD论坛网友 bigbat 版权归原作者所有- z; P1 A8 i3 h1 p0 Q( n, R
, P0 E* ~/ O: X4 y4 E1 ]' |
9 k5 h$ F: i5 t6 e$ V8 N0 G$ A |
