有没有关于STM32H750在IAR环境下,将外部Flash程序搬到内部RAM中运行的文档说明
szd00025 提问时间:2024-2-1 09:52 / 未解决
由于STM32H750的RAM是分段不连续,我只能将外部Flash程序分开搬到RAM中运行。测试只搬一两个简单函数是没有问题。程序量大后就不正常,仿真查看程序内容发现MCU跳转的地址和实际地址对不上。例如MCU调用函数地址为0x30000000,实际函数的地址可能是0x30000001或者是其他地址。
下面是RAM拷贝的程序和ICF的配置
RCC->AHB2ENR |= 0xE0000000; // 使能SRAM1、SRAM2、SRAM3
#if 1
src  = (uint8_t *) __section_begin("USER_PRG1_RBLOCK");
dst  = (uint8_t *) __section_begin("USER_PRG1_WBLOCK");
size = (uint32_t) __section_size("USER_PRG1_WBLOCK");
bsp_copy_4byte(src, dst, size);
RAM_Fault_Cnt_DW(src, dst, size);
#endif
#if 1
src  = (uint8_t *) __section_begin("USER_PRG2_RBLOCK");
dst  = (uint8_t *) __section_begin("USER_PRG2_WBLOCK");
size = (uint32_t) __section_size("USER_PRG2_RBLOCK");
//if (0 != ((uint32_t)src&0x01))
//src += 1;
#endif
#if 1
src  = (uint8_t *) __section_begin("USER_PRG3_RBLOCK");
dst  = (uint8_t *) __section_begin("USER_PRG3_WBLOCK");
size = (uint32_t) __section_size("USER_PRG3_WBLOCK");
#endif
赞 收藏 评论3 发布时间:2024-2-1 09:52
3个回答
szd00025 回答时间:2024-2-1 09:55:18
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__ = 0x90000000;
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__ = 0x90000000;
define symbol __ICFEDIT_region_ROM_end__   = 0x90047FFF;
//define symbol __ICFEDIT_region_ROM1_start__ = 0x90018000;
//define symbol __ICFEDIT_region_ROM1_end__   = 0x90027FFF;
//define symbol __ICFEDIT_region_ROM2_start__ = 0x90028000;
//define symbol __ICFEDIT_region_ROM2_end__   = 0x90037FFF;
//define symbol __ICFEDIT_region_ROM3_start__ = 0x90038000;
//define symbol __ICFEDIT_region_ROM3_end__   = 0x90047FFF;
define symbol __ICFEDIT_region_RAM_start__ = 0x20000000;
define symbol __ICFEDIT_region_RAM_end__   = 0x2001FFFF;
define symbol __ICFEDIT_region_CODERAM1_start__ = 0x24000000;
define symbol __ICFEDIT_region_CODERAM1_end__   = 0x2407FFFF;
define symbol __ICFEDIT_region_CODERAM2_start__ = 0x30000000;
define symbol __ICFEDIT_region_CODERAM2_end__   = 0x30047FFF;
define symbol __ICFEDIT_region_CODERAM3_start__ = 0x38000000;
define symbol __ICFEDIT_region_CODERAM3_end__   = 0x3800FFFF;
define symbol __ICFEDIT_region_ITCMRAM_start__ = 0x00000000;
define symbol __ICFEDIT_region_ITCMRAM_end__   = 0x0000FFFF;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = 0x4000;
define symbol __ICFEDIT_size_heap__   = 0x2000;
/**** End of ICF editor section. ###ICF###*/
define memory mem with size = 4G;
define region ROM_region      = mem:[from __ICFEDIT_region_ROM_start__   to __ICFEDIT_region_ROM_end__];
//define region CODEROM1_region = mem:[from __ICFEDIT_region_ROM1_start__   to __ICFEDIT_region_ROM1_end__];
//define region CODEROM2_region = mem:[from __ICFEDIT_region_ROM2_start__   to __ICFEDIT_region_ROM2_end__];
//define region CODEROM3_region = mem:[from __ICFEDIT_region_ROM3_start__   to __ICFEDIT_region_ROM3_end__];
define region RAM_region      = mem:[from __ICFEDIT_region_RAM_start__   to __ICFEDIT_region_RAM_end__];
define region CODERAM1_region = mem:[from __ICFEDIT_region_CODERAM1_start__   to __ICFEDIT_region_CODERAM1_end__];
define region CODERAM2_region = mem:[from __ICFEDIT_region_CODERAM2_start__   to __ICFEDIT_region_CODERAM2_end__];
define region CODERAM3_region = mem:[from __ICFEDIT_region_CODERAM3_start__   to __ICFEDIT_region_CODERAM3_end__];
define region ITCMRAM_region  = mem:[from __ICFEDIT_region_ITCMRAM_start__ to __ICFEDIT_region_ITCMRAM_end__];
define block CSTACK    with alignment = 8, size = __ICFEDIT_size_cstack__   { };
define block HEAP      with alignment = 8, size = __ICFEDIT_size_heap__     { };
initialize by copy { readwrite,};
do not initialize  { section .noinit };
place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
initialize by copy
ro code object stm32h7xx_hal_gpio.o,
initialize by copy
ro code object delay.o,
initialize by copy
ro code object beep.o,
//section RAMCODE,
//-----------------512K AXISRAM-------------------
define block USER_PRG1_RBLOCK
//ro code object stm32h7xx_hal_gpio.o,
define block USER_PRG1_WBLOCK
rw code object delay.o,
//rw code object stm32h7xx_hal_gpio.o,
//-----------------288K SRAM1 SRAM2 SRAM3----------
define block USER_PRG2_RBLOCK
define block USER_PRG2_WBLOCK
rw code object beep.o,
//-----------------64K SRAM4------------------------
define block USER_PRG3_RBLOCK
define block USER_PRG3_WBLOCK
place in ROM_region   { readonly };
place in ROM_region   { block USER_PRG1_RBLOCK, };
place in ROM_region   { block USER_PRG2_RBLOCK, };
place in ROM_region   { block USER_PRG3_RBLOCK, };
place in RAM_region   { readwrite, block CSTACK, block HEAP,};
place in CODERAM1_region  { block USER_PRG1_WBLOCK, };
place in CODERAM2_region  { block USER_PRG2_WBLOCK, };
//place in CODERAM2_region  {section RAMCODE, };
place in CODERAM3_region  { block USER_PRG3_WBLOCK, };
xmshao 回答时间:2024-2-1 16:28:48
网上不少类似话题的分享。你搜索一篇 《IAR下如何把程序拷贝在RAM中运行》的文章参考下。
szd00025 回答时间:2024-2-1 16:49:12
xmshao 发表于 2024-2-1 16:28
网上不少类似话题的分享。你搜索一篇 《IAR下如何把程序拷贝在RAM中运行》的文章参考下。 ...
参考了很多这样的文章包括ST官方资料都是失败告终,之前用瑞萨的RZT2,小华的4A0将程序拷贝到RAM中运行是没有任何问题的。
ST官方是否在IAR环境下做过750的相关测试。
