stm32cubeide更新后启动 发生了错误,请参阅日志文件
丹东 提问时间:2024-5-17 09:41 / 未解决
!SESSION 2024-05-17 08:59:24.447 ----------------------------------------------- eclipse.buildId=Version 1.15.1 java.version=17.0.8.1 java.vendor=Eclipse Adoptium BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2024-05-17 09:00:56.776 !MESSAGE 应用程序错误 !STACK 1 java.lang.LinkageError: loader constraint violation: when resolving method 'void org.eclipse.e4.ui.bindings.internal.BindingTable.addBinding(org.eclipse.jface.bindings.Binding)' the class loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @69f69078 of the current class, org/eclipse/e4/ui/workbench/swt/util/BindingProcessingAddon, and the class loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @430aae8e for the method's defining class, org/eclipse/e4/ui/bindings/internal/BindingTable, have different Class objects for the type org/eclipse/jface/bindings/Binding used in the signature (org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @69f69078, parent loader 'platform'; org.eclipse.e4.ui.bindings.internal.BindingTable is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @430aae8e, parent loader 'platform') at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.defineBinding(BindingProcessingAddon.java:181) at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.defineBindingTable(BindingProcessingAddon.java:168) at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.defineBindingTables(BindingProcessingAddon.java:148) at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.init(BindingProcessingAddon.java:96) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:568) at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:976) at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:138) at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:385) at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:325) at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:228) at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:94) at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60) at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:37) at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:276) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:577) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:342) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:555) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:173) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:208) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:568) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:651) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:588) at org.eclipse.equinox.launcher.Main.run(Main.java:1459)
赞 收藏 评论1 发布时间:2024-5-17 09:41
Stamets 回答时间:2024-9-15 20:08:08
我也是这样,从1.4更新到1.6之后就打不开,workspace报错
