Write the STM32U545 DAC register (12-bit, right-justified) = 2048, and the measured output voltage is 2.8V. 1 How many volts is the internal reference output? 2 No external reference input definition is found in the pin definition. How to connect the external reference? thank you. |
STM32U585对应CRA合规的安全功能方案咨询
STM32U575 TrustZone 工程中断异常
请问一下STM32U575VGT6在mx里怎么配置DCMI的DMA setting啊,我点那个页面只有GPDMA1,跳转过去也没有什么DCMI的选项
STM32U575的LPTIM中断问题
STM32U575低功耗问题
stm32u5g9j-dk1, 设置tzen1,之后关闭变砖
STM32u575 USART 用GPDMA接收,DMA中断,usart 中断正常来,ROR数据正确,接收缓冲却不变
stm32u575 gpdma burst length=1 配置其他数值不工作
STM32U5进入standby模式时,待机电流有时候大的离谱,有时候却正常
如果从外部引进参考电压,当芯片有VREF脚时就通过该脚过来,如没有该管脚,VDDA就是此时DAC的外部参考电压,即VREF+跟VDDA是硬件绑定在一起的。
如果通过内部VERFBUF引进参考电压,此时芯片有专门的有VERF+脚。VREFBUF的输出可以配置选择:
此时VREFBUF输出与VREF+内部相通,还可以通过VREF+对外提供参考。
当芯片没有专门VREF脚,即VDDA与VREF+内部绑定在一起时,不能通过VREFBUF给DAC提供参考电压。
参考电压只能通过VDDA提供。
VREF+ can be provided either by an external reference of by an internal buffered voltage
reference (VREFBUF). The internal voltage reference can output a configurable voltage:
1.5 V, 1.8 V, 2.048 V or 2.4 V.
VREF- and VREF+ pins are not available on all packages. When not available, they are
bonded to VSSA and VDDA, respectively.
When the VREF+ is double-bonded with VDDA in a package, the internal voltage
reference buffer is not available and must be kept disabled.
VREF- must always be equal to VSSA.
