The hardware platform STM32U5 QSPI interface is connected to MX25L25645, and the chip ID is normally read after power-on. HAL_OSPI_Command () function is called to send the write enable command FLASH_CMD_WREN and OSPI_ERROR is returned. Please analyze the reasons. The configuration is as follows:
The code is as follows:
Expect to implement a large amount of data caching in flash, can you provide similar routines? thank you。 |
请问一下STM32U575VGT6在mx里怎么配置DCMI的DMA setting啊,我点那个页面只有GPDMA1,跳转过去也没有什么DCMI的选项
STM32U575的LPTIM中断问题
STM32U575低功耗问题
stm32u5g9j-dk1, 设置tzen1,之后关闭变砖
STM32u575 USART 用GPDMA接收,DMA中断,usart 中断正常来,ROR数据正确,接收缓冲却不变
stm32u575 gpdma burst length=1 配置其他数值不工作
STM32U5进入standby模式时,待机电流有时候大的离谱,有时候却正常
STM32U5系列上电时序
STM32U585进入shutdown模式后偶发无法被唤醒引脚唤醒
