未接网线先上电,再接网线也不工作
patch1582 提问时间:2026-8-27 16:05 / 未解决
我用 STM32CubeMX 生成了工程,板子上的以太网通信在网线预先插好的情况下可以正常工作。
但存在一个问题:只有在开机时网线已经接好,以太网才能正常工作。如果板子上电时没有插网线,以太网就无法正常工作,即便之后再插上网线也始终无法恢复。
为了解决这个问题,我在 LWIP 初始化完成后添加了如下函数:
netif_set_link_callback(&gnetif, ethernetif_update_config);
其中ethernetif_update_config函数是 CubeMX 自动生成的,作用是重启以太网自动协商。
void
ethernetif_update_config(
struct
netif *netif)
__IO uint32_t tickstart = 0;
uint32_t regvalue = 0;
if
(netif_is_link_up(netif))
/ Restart the auto-negotiation /
if
(heth.Init.AutoNegotiation != ETH_AUTONEGOTIATION_DISABLE)
/ Enable Auto-Negotiation /
HAL_ETH_WritePHYRegister(&heth, PHY_BCR, PHY_AUTONEGOTIATION);
/ Get tick /
tickstart = HAL_GetTick();
/ Wait until the auto-negotiation will be completed /
do
HAL_ETH_ReadPHYRegister(&heth, PHY_BSR, ®value);
/ Check for the Timeout ( 1s ) /
if
((HAL_GetTick() - tickstart ) > 1000)
/ In case of timeout /
goto
error;
while
(((regvalue & PHY_AUTONEGO_COMPLETE) != PHY_AUTONEGO_COMPLETE));
/ Read the result of the auto-negotiation /
HAL_ETH_ReadPHYRegister(&heth, PHY_SR, ®value);
/ Configure the MAC with the Duplex Mode fixed by the auto-negotiation process /
if
((regvalue & PHY_DUPLEX_STATUS) != (uint32_t)RESET)
/ Set Ethernet duplex mode to Full-duplex following the auto-negotiation /
heth.Init.DuplexMode = ETH_MODE_FULLDUPLEX;
else
/ Set Ethernet duplex mode to Half-duplex following the auto-negotiation /
heth.Init.DuplexMode = ETH_MODE_HALFDUPLEX;
/ Configure the MAC with the speed fixed by the auto-negotiation process /
if
(regvalue & PHY_SPEED_STATUS)
/ Set Ethernet speed to 10M following the auto-negotiation /
heth.Init.Speed = ETH_SPEED_10M;
else
/ Set Ethernet speed to 100M following the auto-negotiation /
heth.Init.Speed = ETH_SPEED_100M;
else
/ AutoNegotiation Disable /
error :
/ Check parameters /
assert_param(IS_ETH_SPEED(heth.Init.Speed));
assert_param(IS_ETH_DUPLEX_MODE(heth.Init.DuplexMode));
/ Set MAC Speed and Duplex Mode to PHY /
HAL_ETH_WritePHYRegister(&heth, PHY_BCR, ((uint16_t)(heth.Init.DuplexMode >> 3) |
(uint16_t)(heth.Init.Speed >> 1)));
/ ETHERNET MAC Re-Configuration /
HAL_ETH_ConfigMAC(&heth, (ETH_MACInitTypeDef *) NULL);
/ Restart MAC interface /
HAL_ETH_Start(&heth);
else
/ Stop MAC interface /
HAL_ETH_Stop(&heth);
ethernetif_notify_conn_changed(netif);
我在插上网线后通过调用netif_set_link_up(&gnetif)手动触发该回调函数时,以太网依旧无法正常工作。有没有人知道在这种场景下该如何让以太网正常运行?
赞 收藏 评论1 发布时间:2026-8-27 16:05
fafa1 回答时间:2026-8-28 11:13:40
我是完全从头来过!
