STM32F4DISCOVERY 评估板资料
废鱼 提问时间:2011-10-31 10:35 /
Description
The STM32F4DISCOVERY helps you to discover the STM32F4 high-performance features and to develop your applications easily. It includes everything required for beginners and experienced users to get started quickly.
Based on the STM32F407VGT6, it includes an ST-LINK/V2 embedded debug tool, two ST MEMS, digital accelerometer and digital microphone, one audio DAC with integrated class D speaker driver, LEDs and push buttons and an USB OTG micro-AB connector.
A large number of free ready-to-run application firmware examples are available on www.st.com/stm32f4-discovery to support quick evaluation and development.
Key Features
  • STM32F407VGT6 microcontroller featuring 32-bit ARM Cortex-M4F core, 1 MB Flash, 192 KB RAM in an LQFP100 package
  • On-board ST-LINK/V2 with selection mode switch to use the kit as a standalone ST-LINK/V2 (with SWD connector for programming and debugging)
  • Board power supply: through USB bus or from an external 5 V supply voltage
  • External application power supply: 3 V and 5 V
  • LIS302DL, ST MEMS motion sensor, 3-axis digital output accelerometer
  • MP45DT02, ST MEMS audio sensor, omni-directional digital microphone
  • CS43L22, audio DAC with integrated class D speaker driver
  • Eight LEDs:
    • LD1 (red/green) for USB communication
    • LD2 (red) for 3.3 V power on
    • Four user LEDs, LD3 (orange), LD4 (green), LD5 (red) and LD6 (blue)
    • 2 USB OTG LEDs LD7 (green) VBus and LD8 (red) over-current
  • Two push buttons (user and reset)
  • USB OTG FS with micro-AB connector
  • Extension header for all LQFP100 I/Os for quick connection to prototyping board and easy probing
http://www.stmicroelectronics.com.cn/internet/evalboard/product/252419.jsp
赞 收藏 评论8 发布时间:2011-10-31 10:35
8个回答
fxw451 回答时间:2011-10-31 11:38:56
RE:STM32F4DISCOVERY 评估板资料
哦,楼主拥有这么一套?
挺快的!
青檬 回答时间:2011-11-1 16:12:24
如何获取一套呢?????
nj_jacky 回答时间:2011-11-4 13:18:02
请问:可以操作10.4“ TFT LCD吗?
k10k10k10-19309 回答时间:2011-11-8 23:20:58
回复:STM32F4DISCOVERY 评估板资料
回复第 4 楼 于2011-11-04 05:18:02发表:
不行!
dxz_bb 回答时间:2011-12-4 10:50:45
正在研究f4,看看~
lzhpguan 回答时间:2012-1-4 11:22:02
值得研究啊!!!!!
jizhiyan 回答时间:2012-1-5 10:24:40
longerwellly 回答时间:2012-4-13 14:12:45
  正在研究
