我用了3个AD,用外部定时器中断触发采样,AD1用PA6引脚,AD2用PC2引脚,AD3用PF7引脚,发现AD1的采样很不准,误差比较大,其他两个还可以接受,下面是我关于AD部分的设置,请问有什么问题吗 ADC_InitTypeDef ADC_InitStructure; ADC_CommonInitTypeDef ADC_CommonInitStructure; /*使能ADC1,2,3的时钟*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1|RCC_APB2Periph_ADC2|RCC_APB2Periph_ADC3, ENABLE); /*ADC公共初始化配置*/ ADC_CommonInitStructure.ADC_Mode = ADC_TripleMode_RegSimult; //配置ADC模式为3通道规则组 ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div8; //配置ADC时钟分频为8分频 ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1; //DMA mode 1 enabled (2 / 3 half-words one by one - 1 then 2 then 3) ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles; //配置两次采样的间隔时间 ADC_CommonInit(&ADC_CommonInitStructure); //初始化ADC公共配置 /*ADC1初始化配置*/ ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; //配置ADC分辨率为12位 ADC_InitStructure.ADC_ScanConvMode = ENABLE; //使能多通道扫描转换模式 ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; //注意不要使用持续转换模式,否则只要触发一次, //后续的转换就会永不停歇(除非CONT清0),这样第一次以后的ADC,就不是由TIM2_CC2来触发了 ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising; //外部上升沿触发转换 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_CC2; //配置TIM2_CC2为触发源 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //配置数据对齐方式为右对齐 ADC_InitStructure.ADC_NbrOfConversion = 1; //指定ADC的转换次数 ADC_Init(ADC1, &ADC_InitStructure); //初始化配置ADC1 /*PA6->ADC12的通道6,采用频率为3个周期*/ ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 1, ADC_SampleTime_15Cycles); ADC_Init(ADC2, &ADC_InitStructure); /*PC2-> ADC12的通道12,采用频率为3个周期*/ ADC_RegularChannelConfig(ADC2, ADC_Channel_12, 1, ADC_SampleTime_15Cycles); ADC_Init(ADC3, &ADC_InitStructure); /*PF7->ADC3的通道5*/ ADC_RegularChannelConfig(ADC3, ADC_Channel_5, 1, ADC_SampleTime_15Cycles); /* Enable DMA request after last transfer (Multi-ADC mode) */ ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE); // ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE); //开启ADC转换结束中断 /* 使能ADC1,ADC2,ADC3*/ ADC_Cmd(ADC1, ENABLE); ADC_Cmd(ADC2, ENABLE); ADC_Cmd(ADC3, ENABLE); |
STM32F476NG使用CAN2通信无法接收数据
盘古UE-STM32F407工控板原理图
STM32F407 定时器触发DMA 求助大神
【MCU实战经验】基于STM32F407的音频播放器设计
【STM32F429心得\疑问】+STM32F4之FSMC和FMC
STM32F429读取IO口传输的数据速率
STM32F407ZGT6 手摸芯片背部重启
STM32F401RE NUCLEO求助,串口一直不能进中断
读取STM32F407内部温度传感器值错误
STM32F407 的1588问题(已解决)
