【MCU实战经验】STM32F429I-DISO探索第一篇 --GPIO LCD显示状态
ffeige1984 提问时间:2014-4-4 13:45 /
上一篇写了GPIO简单的流水灯测试,看着有点单调,习惯了串口调试,板子上没有串口 那就另想办法吧,看着LCD突然有了个想法,为什么不把调试信息输出到LCD上,以前在做2416 WINCE开发的时候就经常这样干非常直观,那说干就干。
STM32F429I-DISO SDK里已经把开发包做好,那就直接拿过来用吧。
[html] view plaincopy
  • #define MESSAGE1   "STM32F429I-Discoverry"   //提示信息
  • #define MESSAGE1_1 "    GPIO TEST        "
  • #define MESSAGE2   " LED3     LED4  "
  • #define MESSAGE2_1 "      ^-^       "
  • #define MESSAGE5   "   LED3 = %d"      //LED3状态  1亮 0灭
  • #define MESSAGE6   "   LED4 = %d"      //LED4状态
  • #define LINENUM            0x15        //行数
  • #define FONTSIZE         Font12x12     //字体大小
定义完了,那就该具体实现了,惯例先初始化 LCD初始化实现:
  • static void Display_Init(void)
  •   /* Initialize the LCD */
  •   LCD_Init();
  •   LCD_LayerInit();
  •   /* Eable the LTDC */
  •   LTDC_Cmd(ENABLE);
  •   /* Set LCD Background Layer  */
  •   LCD_SetLayer(LCD_BACKGROUND_LAYER);
  •   /* Clear the Background Layer */
  •   LCD_Clear(LCD_COLOR_WHITE);
  •   /* Configure the transparency for background */
  •   LCD_SetTransparency(0);
  •   /* Set LCD Foreground Layer  */
  •   LCD_SetLayer(LCD_FOREGROUND_LAYER);
  •   /* Configure the transparency for foreground */
  •   LCD_SetTransparency(200);
  •   /* Clear the Foreground Layer */
  •   /* Set the LCD Back Color and Text Color*/
  •   LCD_SetBackColor(LCD_COLOR_BLUE);
  •   LCD_SetTextColor(LCD_COLOR_WHITE);
  •     /* Set the LCD Text size */
  •   LCD_SetFont(&FONTSIZE);
  •   LCD_DisplayStringLine(LINE(LINENUM), (uint8_t*)MESSAGE1);
  •   LCD_DisplayStringLine(LINE(LINENUM + 1), (uint8_t*)MESSAGE1_1);
  •   LCD_DisplayStringLine(LINE(0x17), (uint8_t*)"                               ");
  •   LCD_SetFont(&Font16x24);
  •   LCD_DisplayStringLine(LCD_LINE_0, (uint8_t*)MESSAGE2);
  •   LCD_DisplayStringLine(LCD_LINE_1, (uint8_t*)MESSAGE2_1);
  •   LCD_SetBackColor(LCD_COLOR_WHITE);
  •   LCD_SetTextColor(LCD_COLOR_BLUE);
初始化完成了,那就改实现显示函数了
  • static void Display(void)
  •   uint8_t  led3 = 0, led4 = 0;
  •   uint8_t aTextBuffer[50];
  •   led3 = GPIO_ReadOutputDataBit(LED3_GPIO_PORT,LED3_PIN);     //读取LED3对应引脚值
  •   sprintf((char*)aTextBuffer, MESSAGE5, led3);
  •   LCD_DisplayStringLine(LCD_LINE_4, (uint8_t*)aTextBuffer);    //把LED3状态更新到屏幕上
  •   led4 = GPIO_ReadOutputDataBit(LED3_GPIO_PORT,LED4_PIN);      //读取LED4对应引脚值
  •   sprintf((char*)aTextBuffer, MESSAGE6, led4);
  •    LCD_DisplayStringLine(LCD_LINE_6, (uint8_t*)aTextBuffer);    //把LED4状态更新到屏幕上
这就是显示函数,读取LED对应的值,组成字符串,最后更新到LCD,LCD显示。
接下来就改主函数了:
  • int main(void)
  •   int i;
  •     Display_Init();
  •   LEDInit();
  •     SysTickInit();
  •   while (1)
  •         Delay(500);
  •         GPIO_SetBits(LED4_GPIO_PORT,LED4_PIN);
  •         GPIO_ResetBits(LED3_GPIO_PORT,LED3_PIN);
  •         Display();
  •         Delay(500);
  •         GPIO_SetBits(LED3_GPIO_PORT,LED3_PIN);
  •         GPIO_ResetBits(LED4_GPIO_PORT,LED4_PIN);
  •         Display();
惯例,主要函数部分实现完了,那就看最终的显示结果吧.
赞 收藏 评论1 发布时间:2014-4-4 13:45
littlelincoln 回答时间:2014-4-6 01:21:21
RE:STM32F429I-DISO探索第一篇 --GPIO LCD显示状态
用stlink调试就知道了。从前我也是用串口的。遇到这板子没串口,就改用stlink了。
