STM32F207+LWIP的网络丢包问题! 【悬赏问答】
STM32F207+DP83848+RTL8019可不可以实现双网口设计
深圳市旺宝电子STM32F207开发板例程集
STM32F2 器件 -25° 上电正常 复位就挂了
STM32F229 TIMER CNT问题
哪位工程师有STM32F2xx的寄存器手册?
STM32F2xx RTC启动不了,求助!!!!
STM32F2外部按键触发中断问题
STM32F205 低功耗模式有BUG?
STM32F207 两个ADC同时采样问题
RE:STM32F207+DP83848+Lwip如何不插网线初始化,之后插入网线正常通信!
LCD_SetTextColor(Red);
LCD_DisplayStringLine(Line5, (uint8_t*)" Ethernet Init ");
LCD_DisplayStringLine(Line6, (uint8_t*)" failed ");
while(1);
* @file stm32f2x7_eth_bsp.c
* @author MCD Application Team
* @version V1.1.0
* @date 07-October-2011
* @brief STM32F2x7 Ethernet hardware configuration.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
© COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f2x7_eth.h"
#include "stm32f2x7_eth_bsp.h"
#include "main.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
__IO uint32_t EthInitStatus = 0;
__IO uint8_t EthLinkStatus = 0;
/* Private function prototypes -----------------------------------------------*/
static void ETH_GPIO_Config(void);
static void ETH_NVIC_Config(void);
static void ETH_MACDMA_Config(void);
/* Private functions ---------------------------------------------------------*/
* @brief ETH_BSP_Config
* @param None
* @retval None
void ETH_BSP_Config(void)
/* Configure the GPIO ports for ethernet pins */
ETH_GPIO_Config();
/* Config NVIC for Ethernet */
ETH_NVIC_Config();
/* Configure the Ethernet MAC/DMA */
ETH_MACDMA_Config();
if (EthInitStatus == 0)
while(1);
/* Configure the PHY to generate an interrupt on change of link status */
Eth_Link_PHYITConfig(DP83848_PHY_ADDRESS);
/* Configure the EXTI for Ethernet link status. */
Eth_Link_EXTIConfig();
* @brief Configures the Ethernet Interface
* @param None
* @retval None
ETH_InitTypeDef ETH_InitStructure;
/* Enable ETHERNET clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_ETH_MAC | RCC_AHB1Periph_ETH_MAC_Tx |
RCC_AHB1Periph_ETH_MAC_Rx, ENABLE);
/* Reset ETHERNET on AHB Bus */
ETH_DeInit();
/* Software reset */
ETH_SoftwareReset();
/* Wait for software reset */
while (ETH_GetSoftwareResetStatus() == SET);
/* ETHERNET Configuration --------------------------------------------------*/
/* Call ETH_StructInit if you don't like to configure all ETH_InitStructure parameter */
ETH_StructInit(Ð_InitStructure);
/* Fill ETH_InitStructure parametrs */
/*------------------------ MAC -----------------------------------*/
ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable;
//ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Disable;
// ETH_InitStructure.ETH_Speed = ETH_Speed_10M;
// ETH_InitStructure.ETH_Mode = ETH_Mode_FullDuplex;
ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable;
ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Disable;
ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable;
ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable;
ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable;
ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable;
ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect;
ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect;
#ifdef CHECKSUM_BY_HARDWARE
ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable;
#endif
/*------------------------ DMA -----------------------------------*/
/* When we use the Checksum offload feature, we need to enable the Store and Forward mode:
the store and forward guarantee that a whole frame is stored in the FIFO, so the MAC can insert/verify the checksum,
if the checksum is OK the DMA can handle the frame otherwise the frame is dropped */
ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable;
ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable;
ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable;
ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable;
ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable;
ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable;
ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable;
ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable;
ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat;
ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat;
ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1;
/* Configure Ethernet */
EthInitStatus = ETH_Init(Ð_InitStructure, DP83848_PHY_ADDRESS);
/* Enable the Ethernet Rx Interrupt */
ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE);
* @brief Configures the different GPIO ports.
* @param None
* @retval None
/* Enable GPIOs clocks */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOI |
RCC_AHB1Periph_GPIOG | RCC_AHB1Periph_GPIOH |
RCC_AHB1Periph_GPIOF, ENABLE);
/* Enable SYSCFG clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* Configure MCO (PA8) */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
/* MII/RMII Media interface selection --------------------------------------*/
#ifdef MII_MODE /* Mode MII with STM322xG-EVAL */
#ifdef PHY_CLOCK_MCO
/* Output HSE clock (25MHz) on MCO pin (PA8) to clock the PHY */
RCC_MCO1Config(RCC_MCO1Source_HSE, RCC_MCO1Div_1);
#endif /* PHY_CLOCK_MCO */
SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_MII);
#elif defined RMII_MODE /* Mode RMII with STM322xG-EVAL */
SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_RMII);
#endif
/* Ethernet pins configuration ************************************************/
ETH_MDIO -------------------------> PA2
ETH_MDC --------------------------> PC1
ETH_PPS_OUT ----------------------> PB5
ETH_MII_CRS ----------------------> PH2
ETH_MII_COL ----------------------> PH3
ETH_MII_RX_ER --------------------> PI10
ETH_MII_RXD2 ---------------------> PH6
ETH_MII_RXD3 ---------------------> PH7
ETH_MII_TX_CLK -------------------> PC3
ETH_MII_TXD2 ---------------------> PC2
ETH_MII_TXD3 ---------------------> PB8
ETH_MII_RX_CLK/ETH_RMII_REF_CLK---> PA1
ETH_MII_RX_DV/ETH_RMII_CRS_DV ----> PA7
ETH_MII_RXD0/ETH_RMII_RXD0 -------> PC4
ETH_MII_RXD1/ETH_RMII_RXD1 -------> PC5
ETH_MII_TX_EN/ETH_RMII_TX_EN -----> PG11
ETH_MII_TXD0/ETH_RMII_TXD0 -------> PG13
ETH_MII_TXD1/ETH_RMII_TXD1 -------> PG14
/* Configure PA1, PA2 and PA7 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_7;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_ETH);
/* Configure PB5 and PB8 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_8;
GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_ETH);
/* Configure PC1, PC2, PC3, PC4 and PC5 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource3, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_ETH);
/* Configure PG11, PG14 and PG13 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_13 | GPIO_Pin_14;
GPIO_Init(GPIOG, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOG, GPIO_PinSource11, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOG, GPIO_PinSource13, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOG, GPIO_PinSource14, GPIO_AF_ETH);
/* Configure PH2, PH3, PH6, PH7 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_6 | GPIO_Pin_7;
GPIO_Init(GPIOH, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOH, GPIO_PinSource2, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOH, GPIO_PinSource3, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOH, GPIO_PinSource6, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOH, GPIO_PinSource7, GPIO_AF_ETH);
/* Configure PI10 */
GPIO_Init(GPIOI, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOI, GPIO_PinSource10, GPIO_AF_ETH);
* @brief Configures and enable the Ethernet global interrupt.
* @param None
* @retval None
/* 2 bit for pre-emption priority, 2 bits for subpriority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/* Enable the Ethernet global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = ETH_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
* @brief Configure the PHY to generate an interrupt on change of link status.
* @param PHYAddress: external PHY address
* @retval None
uint32_t Eth_Link_PHYITConfig(uint16_t PHYAddress)
uint32_t tmpreg = 0;
/* Read MICR register */
tmpreg = ETH_ReadPHYRegister(PHYAddress, PHY_MICR);
/* Enable output interrupt events to signal via the INT pin */
tmpreg |= (uint32_t)PHY_MICR_INT_EN | PHY_MICR_INT_OE;
if(!(ETH_WritePHYRegister(PHYAddress, PHY_MICR, tmpreg)))
/* Return ERROR in case of write timeout */
return ETH_ERROR;
/* Read MISR register */
tmpreg = ETH_ReadPHYRegister(PHYAddress, PHY_MISR);
/* Enable Interrupt on change of link status */
tmpreg |= (uint32_t)PHY_MISR_LINK_INT_EN;
if(!(ETH_WritePHYRegister(PHYAddress, PHY_MISR, tmpreg)))
return ETH_ERROR;
/* Return SUCCESS */
return ETH_SUCCESS;
* @brief EXTI configuration for Ethernet link status.
* @retval None
void Eth_Link_EXTIConfig(void)
EXTI_InitTypeDef EXTI_InitStructure;
/* Enable the INT (PB14) Clock */
RCC_AHB1PeriphClockCmd(ETH_LINK_GPIO_CLK, ENABLE);
/* Configure INT pin as input */
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_Pin = ETH_LINK_PIN;
GPIO_Init(ETH_LINK_GPIO_PORT, &GPIO_InitStructure);
/* Connect EXTI Line to INT Pin */
SYSCFG_EXTILineConfig(ETH_LINK_EXTI_PORT_SOURCE, ETH_LINK_EXTI_PIN_SOURCE);
/* Configure EXTI line */
EXTI_InitStructure.EXTI_Line = ETH_LINK_EXTI_LINE;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* Enable and set the EXTI interrupt to the highest priority */
NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
* @brief This function handles Ethernet link status.
* @param None
* @retval None
void Eth_Link_ITHandler(uint16_t PHYAddress)
/* Check whether the link interrupt has occurred or not */
if(((ETH_ReadPHYRegister(PHYAddress, PHY_MISR)) & PHY_LINK_STATUS) != 0)
EthLinkStatus = ~EthLinkStatus;
#ifdef USE_LCD
/* Set the LCD Text Color */
if(EthLinkStatus != 0)
/* Display message on the LCD */
LCD_DisplayStringLine(Line5, (uint8_t*)" Network Cable is ");
LCD_DisplayStringLine(Line6, (uint8_t*)" unplugged ");
else
LCD_DisplayStringLine(Line6, (uint8_t*)" now connected ");
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
回复:STM32F207+DP83848+Lwip如何不插网线初始化,之后插入网线正常通信!
ETH_GPIO_Config();
/*此处一直等待网络连接,直到网络连接成功,且初始化通过*/
while(!EthInitStatus)
OSTimeDly(100); //调用OS函数,任务等待,释放CPU控制权
Eth_Phy_Init(); //对PHY初始化
ETH_NVIC_Config();
ETH_DeInit();
Eth_Phy_Init();
void Eth_Phy_Init(void)
#endif
/*此处增加初始化状态判断*/
if(!EthInitStatus)
return;
不知道原因?谁能解答一下。
我用万用表测试7脚的输出电压,发现只能变化一次,后来再无变化。(这个还是取决于代码Eth_Link_PHYITConfig(DP83848_PHY_ADDRESS);的定义,否则,一点都不变化)
是否我的思路有问题?谢谢。
你好,我碰到了同样的问题,先通电再插网线就不通了,你是如何解决得呢,
搞定了也没有一个具体的回复哟 ?????????
