【STM32F429开发日志】(0)+示波器
stentor 提问时间:2014-7-10 22:43 /
 自己之前做的一个示波器,只用了LCD的底层驱动,没用系统及GUI
将C文件替换到固件包的STM32F429I-Discovery_FW_V1.0.1\Projects\Template下,运行即可
代码贴上看看:
  * @file    ADC_TripleModeInterleaved/main.c
  * @author  MCD Application Team
  * @version V1.0.1
  * @date    11-November-2013
  * @brief   This example provides a short description of how to use the ADC
  *          peripheral to convert a regular channel in Triple interleaved mode
  *          using DMA in mode 2 with 8.4Msps .
  * @attention
  * © COPYRIGHT 2013 STMicroelectronics
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include
/** @addtogroup STM32F429I_DISCOVERY_Examples
/** @addtogroup ADC_TripleModeInterleaved
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
  #define MESSAGE1   "  Triple ADC Interleaved      "
  #define MESSAGE1_1 "  DMA mode2 example           "
  #define MESSAGE2   " ADC Ch13 Conv "
  #define MESSAGE2_1 "    8.4Msps      "
  #define MESSAGE3   "Connect voltage "
  #define MESSAGE4   "to ADC Ch13   "
  #define MESSAGE5   " ADC1 = %d,%d V"
  #define MESSAGE6   " ADC2 = %d,%d V"
  #define MESSAGE7   " ADC3 = %d,%d V"
  #define LINENUM            0x15
  #define FONTSIZE         Font8x12
uint8_t aTextBuffer[50];
int ADC_Value[4096];
int ADC_ValueSec[4096];
int i=0;
int Zero[8] = {0,0,0,0,0,0,0,0};
int ZeroFlag = 1;
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
__IO uint32_t uhADCTripleConvertedValue[3];
/* Private function prototypes -----------------------------------------------*/
#ifdef USE_LCD
static void Display_Init(void);
static void Display(void);
void gridon(void);
#endif /* USE_LCD */
void DAC_Ch1_Config(void)
        GPIO_InitTypeDef  GPIO_InitStructure;//
        DAC_InitTypeDef DAC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE); //?? DCA ??
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //DAC_OUT1=PA.4
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; //??? AN ??
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //??????
        GPIO_Init(GPIOA, &GPIO_InitStructure); // ? ? ? ? ? ?GPIOA
        DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software ; //????
        DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None; //?????
        DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude= DAC_TriangleAmplitude_2047;//???
        DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable; //????
        DAC_Init(DAC_Channel_2, &DAC_InitStructure); // ?????? DAC1
        DAC_Cmd(DAC_Channel_2, ENABLE); // ?? DAC1 ??
        DAC_SetChannel2Data(DAC_Align_12b_R, 1000); //????? 0
        DAC_SoftwareTriggerCmd(DAC_Channel_2, ENABLE); ///??????
void DAC1_SET(unsigned int date)
        DAC_SetChannel2Data(DAC_Align_12b_R, date ); //????
        DAC_SoftwareTriggerCmd(DAC_Channel_2, ENABLE); //??????
/* Private functions ---------------------------------------------------------*/
  * @brief   Main program
  * @param  None
  * @retval None
  * @brief  ADC configuration
  * @note   This function Configure the ADC peripheral
            1) Enable peripheral clocks
            2) Configure ADC Channel 13 pin as analog input
            3) DMA2_Stream0 channel0 configuration
            4) Configure ADC1 Channel 13
            5) Configure ADC2 Channel 13
            6) Configure ADC3 Channel 13
  * @param  None
  * @retval None
static void GPIO_Configuration(void)
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
void Gyro_ADC_Configuration(uint8_t ADC_SampleTime_Cycles)
          ADC_InitTypeDef       ADC_InitStructure;
          ADC_CommonInitTypeDef ADC_CommonInitStructure;
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
        /* ADC Common Init **********************************************************/
          ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
          ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
          ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
          ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
          ADC_CommonInit(&ADC_CommonInitStructure);
        /* ADC2 Init ****************************************************************/
          ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
          ADC_InitStructure.ADC_ScanConvMode = ENABLE;
          ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
          ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
          ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
          ADC_InitStructure.ADC_NbrOfConversion = 1;
          ADC_Init(ADC2, &ADC_InitStructure);
          ADC_ITConfig(ADC2, ADC_IT_EOC, ENABLE);
        ADC_RegularChannelConfig(ADC2, ADC_Channel_13, 1, ADC_SampleTime_Cycles);
        /* Enable ADC2 */
          ADC_Cmd(ADC2, ENABLE);
          /* Start ADC2 Software Conversion */
        ADC_SoftwareStartConv(ADC2);
/* Functions --------------------------------------------------------------------------------*/
void ADC_Config(uint8_t ADC_SampleTime_Cycles)
  GPIO_Configuration();
        Gyro_ADC_Configuration(ADC_SampleTime_Cycles);
uint16_t Get_ADC_Data(void)
   while(!(ADC_GetFlagStatus(ADC2, ADC_FLAG_EOC)==SET));
         return(ADC_GetConversionValue(ADC2));
#ifdef USE_LCD
  * @brief  Display ADCs converted values on LCD
  * @param  None
  * @retval None
        int delay = 20000,a=1000000000;
        int i=0,j=0;
        float ff = 150*4096/255;
        int tmpMax,tmpMin,cha,div,tmpMaxNum,tmpMinNum,offset,trigger,triggerflag = 0,temp1 = 0,temp2 = 0;
        int temp1flag = 0,temp2flag = 0;
        float Vpp;
                for(i=0;i
赞 收藏 1 评论5 发布时间:2014-7-10 22:43
5个回答
sssxs 回答时间:2015-6-23 10:59:25
源码没贴完整啊  请详细贴出源码 和操作方法 谢谢了
秋水时至 回答时间:2015-8-25 00:12:31
对啊,代码要贴完整才好嘛。。
JackieLaura 回答时间:2015-8-26 09:23:11
F429 discovery的示波器不错
bigvan2012 回答时间:2015-8-27 10:07:58
顶一个,Good!
胤幻1988 回答时间:2018-11-1 12:39:47
就是个坑啊~
