STM32F429用定时器TRGO触发AD问题
nanjinglsw-1310 提问时间:2014-9-2 11:51 /
想使用定时器触发AD转换,但是总是触发不了,AD只触发一次,应该是软件启动的时候触发一次,在主程序里面添加不停的触发ADC_SoftwareStartConv(ADC3);才能持续的转换,看了不少帖子和资料也未能解决,主要是没有和我很像的,偶尔遇到个很相近的也是没结局的,所以想请高手们帮忙看一下,问题到底出在什么地方,或者是可能出在什么地方。
这是AD和DMA配置
static void ADC3_CH13_DMA_Config(void)
  ADC_InitTypeDef       ADC_InitStructure;
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  DMA_InitTypeDef       DMA_InitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  /* Enable ADC3, DMA2 and GPIO clocks ****************************************/
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
  /* DMA2 Stream0 channel2 configuration **************************************/
  DMA_InitStructure.DMA_Channel = DMA_Channel_2;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC3_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)uhADC3ConvertedValuex;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 5000;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  /* Configure ADC3 Channel13 pin as analog input ******************************/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* ADC Common Init **********************************************************/
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  /* ADC3 Init ****************************************************************/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T3_TRGO;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(ADC3, &ADC_InitStructure);
  /* ADC3 regular channel13 configuration *************************************/
  ADC_RegularChannelConfig(ADC3, ADC_Channel_13, 1, ADC_SampleTime_3Cycles);
 /* Enable DMA request after last transfer (Single-ADC mode) */
  ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
  /* Enable ADC3 DMA */
  ADC_DMACmd(ADC3, ENABLE);
  /* Enable ADC3 */
  ADC_Cmd(ADC3, ENABLE);
这是定时器配置
void TIM3_Config(void)
  TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        RCC_TIMCLKPresConfig(RCC_TIMPrescActivated);
  PrescalerValue = (uint16_t) (SystemCoreClock / 20000000) - 1;
  /* TIM6 Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* Time base configuration */
//  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = 2000;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_ClearFlag(TIM3,TIM_FLAG_Update);   //必须先清除配置时候产生的更新标志
  TIM_Cmd(TIM3, ENABLE);
我的想法是用TIM3的TRGO 触发AD转换,使用DMA转移数据,改变TIM3更新时间来改变采样速率,因为开发板上引脚用得太多了,剩余的引脚很珍贵,所以不想用PWM输出触发,想用TRGO触发,按说应该是没有问题的,但是实际没有持续的转换进行。DMA应该没问题,因为我改成连续转换的模式是有数据的。
求助个位,看看有没有什么看法,谢谢了!!
赞 收藏 评论4 发布时间:2014-9-2 11:51
4个回答
nanjinglsw-1310 回答时间:2014-9-2 11:52:32
回复:STM32F429用定时器TRGO触发AD问题
拜求高手指点迷津
废鱼 回答时间:2014-9-3 09:16:51
RE:STM32F429用定时器TRGO触发AD问题
你这里写的要把buffer写满才会触发。你算算是不是?你把这个值改成1试试。
nanjinglsw-1310 回答时间:2014-9-5 12:45:41
回复第 3 楼 于2014-09-03 09:16:51发表:
不行,改成1也没有用,依然没有连续的转换输出,如果能进行转换的话,满5000个数据也是非常快的,应该不是这个问题,我在定时器中断里面 添加软件启动的语句就可以试验出来了。结果也确实如此,5000个数据是很快的。
xxq100822 回答时间:2017-4-5 17:39:43
你好,请问你这问题解决了吗?
