《STM32+WIFI+Linux+安卓智能控制开发板应用手册》PDF
微云电子 发布时间:2014-9-11 11:13
赞 收藏 6 评论1079 发布时间:2014-9-11 11:13
1079个回答
lovemingtian 回答时间:2014-10-18 09:19:09
RE:《STM32+WIFI+Linux+安卓智能控制开发板应用手册》PDF
我的ubuntu14.04     ; 编译openwrt dreambox源码,make defconfig时出现如下的信息,很多行。。。这个提示是我装了还是没装呢?/ x5 c/ a0 j# k  W9 J2 a& P( X, \
luaexpat....................................................... LuaExpat  (PACKAGE_luaexpat) [N/m/y/?] n
6 y* m) _9 w- k) N. N) ?, hluafilesystem.............................................. LuaFileSystem (PACKAGE_luafilesystem) [N/m/y/?] n
3 N1 z; S) v. z7 b( e% k* Sluaposix........................................................ luaposix (PACKAGE_luaposix) [N/m/y/?] n+ Q) }8 D. K3 t" [  W9 m
luaprofiler................................................. Lua Profiler (PACKAGE_luaprofiler) [N/m/y/?] n# Y" T2 B' s# e* q
luasec............................................................ LuaSec (PACKAGE_luasec) [N/m/y/?] n# `9 X$ j1 D5 L4 ?& O6 K& e
luasocket...................................................... LuaSocket (PACKAGE_luasocket) [N/m/y/?] n* E9 r  A% T; T& p: G
luasql-mysql................................... Lua SQL binding for MySQL (PACKAGE_luasql-mysql) [N/m/y/?] n
" Z2 c3 `4 h2 B: `; P( Y, `" S; }/ `) q2 _luasql-sqlite3.............................. Lua SQL binding for SQLite 3 (PACKAGE_luasql-sqlite3) [N/m/y/?] n
lovemingtian 回答时间:2014-10-18 10:22:43
我的ubuntu14.04     ; 编译openwrt dreambox源码,make defconfig时出现如下的信息,很多行。。。这个提示是我装了还是没装呢?6 W, q/ o) M; e3 W7 L+ u2 m
) [! Q. Z1 W' H' bluafilesystem.............................................. LuaFileSystem (PACKAGE_luafilesystem) [N/m/y/?] n% E9 ~  _+ d8 Y7 L
luaposix........................................................ luaposix (PACKAGE_luaposix) [N/m/y/?] n- n4 O9 \$ e% E2 @
luaprofiler................................................. Lua Profiler (PACKAGE_luaprofiler) [N/m/y/?] n" F2 S8 f/ e5 {# t/ C& ]% o
luasec............................................................ LuaSec (PACKAGE_luasec) [N/m/y/?] n2 e0 }  y1 m3 L8 l
luasocket...................................................... LuaSocket (PACKAGE_luasocket) [N/m/y/?] n" O8 g' N3 `% S9 Z" W7 t
luasql-mysql................................... Lua SQL binding for MySQL (PACKAGE_luasql-mysql) [N/m/y/?] n6 C# q; S% I& P) g
lovemingtian 回答时间:2014-10-18 10:23:24
我的ubuntu14.04     ; 编译openwrt dreambox源码,make defconfig时出现如下的信息,很多行。。。这个提示是我装了还是没装呢?* e8 v  p) f3 L0 \4 u; S
: `0 @6 |  R$ n7 t0 z( G. _! uluafilesystem.............................................. LuaFileSystem (PACKAGE_luafilesystem) [N/m/y/?] n9 L* {3 M+ [- ]* J5 t
luaposix........................................................ luaposix (PACKAGE_luaposix) [N/m/y/?] n( L" ~' l! e* H" n+ f  }
luaprofiler................................................. Lua Profiler (PACKAGE_luaprofiler) [N/m/y/?] n$ `' N0 `6 x9 n% g4 g# z- v
% ]" c' q' B( j4 ?# yluasocket...................................................... LuaSocket (PACKAGE_luasocket) [N/m/y/?] n& {9 J/ E; l  `3 \  Z. {+ p3 q
luasql-mysql................................... Lua SQL binding for MySQL (PACKAGE_luasql-mysql) [N/m/y/?] n' ]6 p: }/ v9 c; z! K- f7 G
lovemingtian 回答时间:2014-10-18 11:06:29
7 v2 w* ~# D# i( i2 P1 Q, {luaexpat....................................................... LuaExpat  (PACKAGE_luaexpat) [N/m/y/?] n$ m3 w8 u2 E7 T5 F0 }
lovemingtian 回答时间:2014-10-18 11:43:13
这个体验程序是用串口的,串口和stlink仿真口公用,上电程序运行了,因为有程序占用串口,所以stlink不太容易连接上,你先用usb转串口板子下载一个led程序就是第一个led的hex用串口模式下载进去,
lovemingtian 回答时间:2014-10-18 12:24:25
lovemingtian 回答时间:2014-10-18 12:56:12
lovemingtian 回答时间:2014-10-18 17:18:38
新人请教,请大侠看看,或者出一个N13u能用的op,要能挂卡pin,可以下载的
lovemingtian 回答时间:2014-10-18 17:32:07
lovemingtian 回答时间:2014-10-18 17:37:50
lovemingtian 回答时间:2014-10-18 18:05:38
lovemingtian 回答时间:2014-10-18 18:22:06
lovemingtian 回答时间:2014-10-18 18:49:00
lovemingtian 回答时间:2014-10-18 21:30:40
lovemingtian 回答时间:2014-10-18 21:43:52
