大家好! 首次使用stm32f407芯片,在串口使用过程中,发现如下问题,请各位告诉帮忙解决,谢谢! 目的:串口4使用DMA收发数据 IO口:接收PC11, 发送PC10 问题:使用下列串口初始化,接收和发送的中断都可以正常产生,串口4可以接收数据,但无法发送数据,PC10端口示波器上无法捕捉到数据(发送0xaa数据) 串口配置如下所示: 初始化: void UART4_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; DMA_InitTypeDef DMA_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* Enable the UART4 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream2_IRQn; // UART4接收 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream4_IRQn; // UART4发送 NVIC_Init(&NVIC_InitStructure); // 串口缓冲区初始化 memset(UART4_DMA_Rx, 0xaa, sizeof(UART4_DMA_Rx)); memset(UART4_DMA_Tx, 0xaa, sizeof(UART4_DMA_Tx)); // 时钟配置 /* Peripheral Clock Enable -------------------------------------------------*/ /* Enable GPIO clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC , ENABLE); /* Enable USART clock */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE); /* Enable the DMA clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE); // 串口IO口配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOC, GPIO_PinSource10 | GPIO_PinSource11, GPIO_AF_UART4); // 串口设置 USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; USART_Init(UART4, &USART_InitStructure); DMA_DeInit(DMA1_Stream2); DMA_DeInit(DMA1_Stream4); DMA_StructInit(&DMA_InitStructure); // DMA设置 /* Configure DMA Initialization Structure */ DMA_InitStructure.DMA_BufferSize = UART_DMA_BUF_NUM ; DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable ; DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull ; DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single ; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralBaseAddr =(UINT32) (&(UART4->DR)) ; DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_Priority = DMA_Priority_High; /* Configure TX DMA */ DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;// 发送DMA设计为正常模式,需要发送时再开启 DMA_InitStructure.DMA_Channel = DMA_Channel_4 ; DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral; DMA_InitStructure.DMA_Memory0BaseAddr = (UINT32)UART4_DMA_Tx; DMA_Init(DMA1_Stream4, &DMA_InitStructure); /* Configure RX DMA */ DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;// 接收DMA设计为循环收,否则接收一次后,无法正常接收到数据 DMA_InitStructure.DMA_Channel = DMA_Channel_4 ; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory ; DMA_InitStructure.DMA_Memory0BaseAddr =(UINT32)UART4_DMA_Rx; DMA_Init(DMA1_Stream2,&DMA_InitStructure); // 使能串口 USART_Cmd(UART4, ENABLE); /* Enable DMA USART TX Stream */ DMA_Cmd(DMA1_Stream2, ENABLE); // RX DMA_Cmd(DMA1_Stream4, ENABLE); // TX USART_DMACmd(UART4,USART_DMAReq_Tx,ENABLE); USART_DMACmd(UART4,USART_DMAReq_Rx,ENABLE); // 使能DMA中断 DMA_ITConfig(DMA1_Stream2, DMA_IT_TC, ENABLE); //使能DMA1通道2发送完成中断 DMA_ITConfig(DMA1_Stream4, DMA_IT_TC, ENABLE); //使能DMA1通道4传输完成中断 } 中断函数: // UART4的DMA接收中断入口 void DMA1_Stream2_IRQHandler(void) { if(DMA_GetITStatus(DMA1_Stream2, DMA_IT_TCIF2) == SET ) { //DMA_ClearFlag(DMA1_Stream2, DMA_FLAG_TCIF2); DMA_ClearITPendingBit(DMA1_Stream2, DMA_IT_TCIF2); DMA_Cmd(DMA1_Stream2, ENABLE); // 将数据放入缓冲区队列中 // .... } } // UART4的DMA发送中断入口 void DMA1_Stream4_IRQHandler(void) { if(DMA_GetITStatus(DMA1_Stream4, DMA_IT_TCIF4) == SET ) { //DMA_ClearFlag(DMA1_Stream4, DMA_FLAG_TCIF4); DMA_Cmd(DMA1_Stream4, ENABLE); DMA_ClearITPendingBit(DMA1_Stream4, DMA_IT_TCIF4); TestIO(); DMA_Cmd(DMA1_Stream4, ENABLE); } } |
STM32F476NG使用CAN2通信无法接收数据
盘古UE-STM32F407工控板原理图
STM32F407 定时器触发DMA 求助大神
【MCU实战经验】基于STM32F407的音频播放器设计
【STM32F429心得\疑问】+STM32F4之FSMC和FMC
STM32F429读取IO口传输的数据速率
STM32F407ZGT6 手摸芯片背部重启
STM32F401RE NUCLEO求助,串口一直不能进中断
读取STM32F407内部温度传感器值错误
STM32F407 的1588问题(已解决)
莫非UART4不能使用DMA发送?
已解决。
该问题是由于IO口初始化造成的,将IO口初始变更为如下情况,就可以解决:
// 串口IO口配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_UART4);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_UART4);
F103 上合起来初始化也是可以的,F407的USART1合起来也可以,但不知道为什么这个不行。
为了防止类似情况发生,以后还是一步步来吧。
楼主用的407的,设置方法和103的有点区别,你可以试试407
