硬件I2C调不通啊调不通,纠结中,可是不能放弃啊,先搞通软件模拟的再说,其他的,慢慢来' |! I M+ I3 P/ R
坛子里面有没有硬件I2C用起来没问题的,我的硬件I2C发送了Start和从机Device地址后SDA和SCL线上就不出信号了,郁闷。
7 B& d1 V3 _5 G: L- j. c; X6 D- R0 V" k5 i* `8 M6 B z, U! C
分析模拟I2C代码
4 _' S. @ B2 L: B8 n2 \& U$ ?- /*******************************************************************************3 ]% G/ [- a0 m0 Y
- * Copyright(C),20149 f8 s" ~+ S: J t6 B* ~: F5 a8 D& s7 d
- * @file Name user_i2c.h
% Z9 k q6 r; ? - * @author chansane5 d/ r; {/ C4 R$ G# w+ Q
- * @version V2.0.09 K9 p+ d* v6 Y. P: O! G# C; h# j
- * @date 09-12-2014 ! @0 J2 \0 n4 P7 [# S; c
- * @brief In this file we use the ImitateI2C to read the data of UV_Ambient' Y8 U; g9 r# ?6 S d$ p
- Sensor ,after read all the data we send data using USART3.- O. {3 h5 Z7 B4 X: p
- You must known that we turn on the pinmap of USART3.6 s" m' X* d& ~& B
- * @History 6 m" Y; U* |; j( q. B* B. J) E
- *******************************************************************************/ # K3 Z; z/ W: d
- #include "stm32f4xx.h"
" N" }. s2 O/ e. { - #include "user_i2c.h"
/ M8 ~7 i* [, a - //===============================================================================
/ z4 z! s; G6 z0 B4 I - //GPIO 模拟I2C ,操作UV_Ambient sensor
8 _, q, f1 S* X0 [5 o' B2 N - + R# s3 v9 F, [6 w3 v
- P: f, r. e( w4 q8 \9 m+ Y - * @brief Initializes peripherals used by the I2C Periph driver.( _! d) l+ z+ q% T( \
- * @param None5 B& O5 O, ]) v8 p- M9 C
- * @retval None
8 m. p5 _. \. I. Z! X6 F- S; j - */
, n" e S, l% N: u2 w2 j+ { - void I2C_HighLevel_Init(void)
: }' m" @0 I3 h$ w0 ~6 e% q' K - {
% {" k/ U7 a; h2 I; _$ h - // I2C_LowLevel_DeInit();
# p4 w; X% f2 M% N A -
8 Q4 f; e7 S l! x - I2C_LowLevel_Init();
# D& \( O( d) W( A# M; l- ?1 M2 |$ ~
0 J5 |5 \ d* S% S( h; X& a. M- }
! u0 m, m3 p, c* l+ u' e - ~4 A* ]7 X6 {1 E6 |
( Q; y- I. a. l - * @brief Initializes peripherals used by the I2C Periph driver.
; v; G$ u# O1 ] - * @param None
/ G# C W! Z7 y5 G4 i - * @retval None3 q9 S& v h: P
4 ?( d6 ^9 t0 @' h, ^+ [( B; {# J - void I2C_LowLevel_Init(void)
9 k% c; Q Z3 _4 }+ X3 ^ - {+ F( ]' J6 K) _4 C- L
- GPIO_InitTypeDef GPIO_InitStructure; " I0 M$ r' n0 k9 n
/ J- a0 h4 ~$ Z) h( C - /*!< GPIO_CLK Periph clock enable */
7 E( }9 g m3 e - RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
4 ~- L3 L4 l, g: O# s! Z - " t( e% d; e, Z! b& i9 u
- /*!< GPIO configuration */ / U; q+ C$ V# L! b5 h1 t6 d; n
- /*!< Configure I2C pins: SCL */
+ {7 [- N# e) n, T - // GPIO_StructInit(&GPIO_InitStructure);; b: N0 U1 g2 A$ X
- GPIO_InitStructure.GPIO_Pin = Uv_SCL;( ~) F& ^' j' {; m E( n! H
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
- U! L( d# N7 x0 [, q; ]& S - GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;/ d# Z, L# O# K
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;# X4 a/ i5 q6 w6 h U: H; k
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
5 ~1 e9 i8 V+ C, S( z8 k: [; X - GPIO_Init(GPIOB, &GPIO_InitStructure);
% {6 w) N: u8 I5 w - GPIO_SetBits( GPIOB, Uv_SCL );
y }1 l3 ^& D9 ^! ^4 G+ I* K4 t - ' k# D' o( E' J: \. A
- /*!< Configure I2C pins: SDA */6 l0 G2 S; R% p* o
- GPIO_InitStructure.GPIO_Pin = Uv_SDA;
% s. u. g% @1 } - GPIO_Init(GPIOB, &GPIO_InitStructure);
& D! H& n% d! O( j# u9 ~' s3 ? - GPIO_SetBits( GPIOB, Uv_SDA );
7 H+ C, Z5 s G2 U - } c3 L3 S9 N _. Q" D {) P
- # H# r3 I. q Z. v+ {/ _7 ^
7 B% T) X- P6 w, |- static void DelayMs(uint8_t uc)4 o5 _' f7 j9 ^! A2 T3 @
- {! _: i+ O. m1 y6 R0 e/ R3 Q; U/ o5 ~
- uint8_t i, j;
9 h( t7 E+ r; i0 S: Y ^) W0 k+ ]
. i" W! a K' A6 k. ?/ C- for (i=0; i<uc; i++) {/ S X4 x' Y4 F2 a" F! \
- for (j=0; j<I2C_DELAY; j++);" d2 Z) C5 x1 i. b9 b
- }$ c2 L# E1 V7 S: ~; h
- }. ?$ x8 U9 O* ^, l
/ i2 _' h, Y/ v J- J+ F - *函数名称:I2CStart 5 P3 v, O) O" o3 a: Y
- *函数功能:I2C开始信号
- x! P8 d* K8 j+ b - *输入参数:
' Y: r5 n8 V! j" k& z - *输出参数:
" t# _( G$ P: I# ~1 Y9 N - *备 注:时钟线高时,数据线由高到低的跳变,表示I2C开始信号
- M' t' y% O; X, Q$ _ - **************************************************************/
6 y1 f9 @$ c7 n5 I! }% ]2 A% R: V+ R - void I2CStart( void )
/ ~+ @4 F5 o% q: @# [* y - {
7 w8 e2 h- H# `8 E# |) q4 ~# I - GPIO_SetBits( GPIOB, Uv_SDA ); * \' X* R- b1 e" o8 a' W
- DelayMs(1); 7 ~7 R/ b! E* m4 T$ U& F5 W6 C0 {0 a
- o0 p7 w' k. B, I - DelayMs(1);
5 t/ |6 B6 h7 R( D - GPIO_ResetBits( GPIOB, Uv_SDA ); 0 A8 ]) _0 t4 U2 G
- DelayMs(1); 8 a3 i' |' G9 V% [) D
- + n, a- ?& \2 E) ^
- GPIO_ResetBits( GPIOB, Uv_SCL ); 6 ]- D6 o* L9 \/ k6 C
" [+ y/ X# R6 t8 O7 k - 5 k5 z' [4 f% K' U: E* C
3 C8 j: Z. A h4 K. u! B, q - *函数名称:I2CStop , @1 u* p% I& M& b, M
- *函数功能:I2C停止信号
/ C% X J% U. T0 | @, ] - *输入参数:
# s9 a% p* B9 X8 s' h. e, K1 E - *输出参数:
) c- w% D- N6 T& H- K1 K - *备 注:时钟线高时,数据线由低到高的跳变,表示I2C停止信号 6 z/ J/ K2 W# w% s0 P: H) \
- **************************************************************/ " k* z( O) w4 {# r& S
- void I2CStop( void ) + R/ r3 Z: c# q( p" n. F8 D
- { 5 Q: g# c) _, T0 S2 `
7 Y8 s8 \4 k7 a. d N& H - DelayMs(1);
: z: K. ^+ [1 `. w - GPIO_SetBits( GPIOB, Uv_SCL );
) S! e: F% I, G! W4 |, Y( L# b+ f - DelayMs(1); 7 x2 q) l9 F4 d/ x
- GPIO_SetBits( GPIOB, Uv_SDA ); % v8 x1 R; R! k$ t
- DelayMs(1); 5 a' w( u* n! e: Z
$ S0 N* Q; d) ]& D% t) G) M- GPIO_ResetBits( GPIOB, Uv_SCL ); " i3 a3 H* Z O. _$ }& S- S7 K, E) G
; h' [1 s; b6 P6 s( h - 9 ?- H. E8 }* p5 _# d } L
- /************************************************************* : x. V4 S. s3 s, l: z7 f6 J+ B. o' u
- *函数名称:I2CSlaveAck
0 A/ |$ H9 @, f/ g4 L - *函数功能:I2C从机设备应答查询
7 ~3 o3 N9 [4 z% Y; z; I - *输入参数:
- P5 j/ |& ?; d" j- q. l - *输出参数:
# B% [. C8 W7 O( H' G, j( z' I - *备 注:
: M0 j0 f; l e( u4 w6 p - **************************************************************/
2 w' q1 p8 D" x& n5 M( b - unsigned char I2CSlaveAck( void )
9 A( W" u6 u" W" [- Q& i - { # X9 }/ `1 X, h
- GPIO_InitTypeDef GPIO_InitStruct; * Z( m" Y. r- c0 ~
- unsigned int TimeOut;
/ ?- V$ j2 n$ M) C1 X1 c) ` - unsigned char RetValue; + E' q6 J! q( ?2 S
- & e* J9 i) M1 m' [8 e
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN; /*这里一定要设成输入上拉,否则不能读出数据*/
; @$ G+ ~( x! P( | - GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;
- v* k9 s& q1 J - GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
c6 ]1 `, d3 j - GPIO_InitStruct.GPIO_Pin = Uv_SDA;
m/ Y: R4 o' Q0 Z, ~' u% S5 e+ O a - GPIO_Init( GPIOB, &GPIO_InitStruct ); 2 T. S9 p: Q( |0 f, f
- 7 c7 ]. p" i( C' Z' ~& G
- GPIO_SetBits( GPIOB, Uv_SCL ); h g: W3 L* U# d4 d2 ]
- TimeOut = 10000;
- g8 ?1 \1 N1 B2 O8 t) ^ - while( TimeOut-- > 0 )
! h1 p8 V8 U' a$ m) m$ W - { ! U) y8 R- G% O3 U
- if( SET == GPIO_ReadInputDataBit( GPIOB, Uv_SDA ) ) , x% {' H+ h) n7 ?$ V! D! J/ \3 t
) V- d, q# R+ \! L% ~: O/ \: {5 { - RetValue = RESET;
. ]/ r! m# ~$ E: ^9 d) D - break; ) j( X# d$ Q$ ~3 c! u; a6 q
3 o2 j" J! d5 V; J% F - else
7 i9 d9 Y/ |2 M6 b' } - { & Z7 Y8 X* m1 y% P. J
- RetValue = SET;
( t5 R# K, `9 l - } , G9 T' U3 u1 ~+ @* a! F
- } + [/ F. ^ o/ K; z9 z6 f4 ]- S
A% t2 z4 p+ N' H- c - " I' N s2 Q! m T
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;
3 N! W6 u( T1 N) d! Z - GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;+ {$ e6 b# h) j3 ^; J/ i! G
- 5 X% G( {! p& x+ _6 K2 ?3 U
W4 h R. p- f4 A7 [- {( C' _ - return RetValue; ; j1 E3 G( T5 P5 w: Q- J
" O ]9 S% L+ Z2 y$ i1 G! ^$ r
& f- Y! S) {, z: w$ A, R- /*************************************************************
8 }, H! ^2 b' D: o - *函数名称:I2CWriteByte " G' s3 @& n# u; b
- *函数功能:I2C写一字节数据 4 H) G) c4 }7 Q+ r# z
- *输入参数:
4 t4 q+ G. j9 f& y, Z% { - *输出参数:
' ?5 L1 n% ]& i# Z( p* \9 c - *备 注:
- S( V/ Z* O0 P x. }, M - **************************************************************/
9 @" z9 f w6 L8 O: b0 q0 J3 g' g! D - void I2CWriteByte( unsigned char byte )
4 N' U) x4 \! W4 Y5 I - {
; ~; r4 Q2 k! ]/ N - unsigned char i; 1 h' W' y1 z& |3 {1 N2 H0 o8 h
7 S( I1 I+ z* o9 _- G: `, D- for( i=0; i<8; i++ ) ! [" s+ V& j3 A; C2 ~7 o" ~% }7 e
- { ( `& d$ {& c3 p8 o
- if( 0X80 & byte ) # k& e+ K1 \5 p- Q: Q4 m% E
- GPIO_SetBits( GPIOB, Uv_SDA ); " B% H$ C. I3 {& l7 @( {6 U* X# K
- else
/ h1 o, g, O6 r% f4 t# D4 z - GPIO_ResetBits( GPIOB, Uv_SDA );
D. G7 H0 b' Z8 D! N! n5 c* L, \ - byte <<= 1;
$ i3 ?: s6 E+ {( ~% Q6 s - DelayMs(1);
0 \7 \" r; L2 y" O3 p9 I - 8 d1 n3 l2 [; h8 e- m
- GPIO_SetBits( GPIOB, Uv_SCL ); + r! N% M2 Q4 s$ ~# H+ C
- DelayMs(1);
, }* M8 i. ^2 B7 D7 [ - GPIO_ResetBits( GPIOB, Uv_SCL ); + g& V, _2 P2 g6 v! M
- DelayMs(1); 5 A. t1 U2 e- F; Q8 `( g
4 z, G* E6 }& q3 s3 `4 Z - } # i: q h/ P0 e* N( ], d" T+ M
- + V4 P' s7 j: q
$ G4 ?' J: `; x" | - *函数名称:I2CReadByte 5 H+ H7 s: q7 ~
- *函数功能:I2C读一字节数据 {" Z# G3 l, N4 O; e6 W
- *输入参数:
' Q4 o/ v9 Z4 O$ D. Z u% p - *输出参数: + o$ {, e! n/ q; }2 U; G
- *备 注:
4 V+ p$ U" \8 L* M+ G; D! Q - **************************************************************/
+ I2 m& U; P1 [. V8 a - unsigned char I2CReadByte( void )
! ?: G7 i$ P& J5 Q F7 f5 h2 W0 g; ] - { , Z2 z _: ?" ^7 M
- unsigned char i;
' { i! G! T+ d+ A' r' A0 p - unsigned char ReadValue = 0;
) X! x, {& {9 E! M5 r3 o) `! x/ t - GPIO_InitTypeDef GPIO_InitStruct;
# e N' k! o; G4 w- B - unsigned char bit;
' C4 ]: D W% {3 g - Y) D* b$ Y6 `8 S6 m5 O2 R
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN; /*这里一定要设成输入上拉,否则不能读出数据*/ ; p9 o" s S. R& j5 x% z
- GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;1 A0 L# N9 u/ G' e" r _( T
- , Z3 ~+ C, C; X" c
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; a* `6 E* o! H. X( t
w+ g: E, N! U& N - GPIO_Init( GPIOB, &GPIO_InitStruct );
( `9 i3 N+ A6 `! U9 y8 k: M: M9 ^ - for( i=0; i<8; i++ )
5 u: {+ B( f7 |2 c( x. @) D7 F8 A. e - {
# B2 p. o5 z+ R4 B+ z( ~ - GPIO_SetBits( GPIOB, Uv_SCL ); j% ^+ d- m) V
- DelayMs(1);
8 O1 `& R3 G6 G - if( SET == GPIO_ReadInputDataBit( GPIOB, Uv_SDA ) ) 8 ?; i( I- M$ U1 r# y) D% A+ N
- bit = 0X01; ; r% x$ A4 S+ R. m' |
- else 7 C1 n2 b$ t! x2 V/ o3 L8 l
- bit = 0x00;
- c& h6 B! C8 T6 b! x+ H& i% e: q - & I) N* G( T4 e/ Y6 [: i' G
- ReadValue = (ReadValue<<1)|bit;
0 I, w( K. q, W - GPIO_ResetBits( GPIOB, Uv_SCL ); 1 j7 |# C- {/ v; M1 _
- DelayMs(1); ) Q- U' t9 |# |* d
- } $ ^$ `- B R* Y6 T/ \8 {
) B+ J; h) o, _& Z3 H1 P& Y- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;, C2 e6 s4 e* m1 f6 |% Y$ `
- GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;8 v/ J# {0 R8 L3 h R8 r( y; a* a
- o0 G3 x9 j' I7 F* Z y
- GPIO_Init( GPIOB, &GPIO_InitStruct ); : ?5 X% Z5 c9 q7 w; t7 I+ V
- return ReadValue;
' p3 q3 I3 A6 h* p2 N - }
$ @" G6 v; R- g$ u0 `/ |( G4 t - " B7 ^6 }: l B+ D. c& b
- /************************************************************* 2 a: B" H. @* ~1 O6 D
- *函数名称:UvWriteByte
: L" I9 m& ~( a2 Q: s5 f0 @ - *函数功能:Uv指定地址写一字节数据
* _/ o6 X: X# ?9 `; y3 W - *输入参数:addr Uv地址 +Reg地址) Y: i! Q. J& Q$ k; S
- data 写入的数据 , o- ]9 Y2 T1 N2 B+ S0 A
- *输出参数:SET: 写入正常;RESET:写入错误 3 G; E" V; [7 Z
- *备 注:
4 x B) B+ S, Q+ [ - **************************************************************/ 8 T) l2 G3 J# T' V# Y
- uint8_t UvWriteByte( uint16_t addr, uint8_t data )
3 G5 n8 }2 Q- w, i( T" J9 E; f/ i - { : D, R: @" y6 \; L8 X* W
- //asm("CPSID I"); //关中断 : {& F6 Q' J9 t( t; ^
- I2CStart(); ! l7 s8 g4 f: ]
9 a5 X% z2 K& t$ z1 w- I2CWriteByte( Uv_ADD_WRITE );
9 l. u% v/ ~' i7 F1 z$ W5 r - if( RESET == I2CSlaveAck() ) 2 ]% s3 Y: F8 v B2 ^( }
- { 4 T5 w' A/ b& Y0 V- Q
- return RESET; 1 @" O; q: m; S6 r! j5 t6 x0 t+ }& c
# J2 r4 l& E+ [8 ~/ X - I2CWriteByte( (addr >> 8) & 0xFF );
7 a$ `8 v5 p. l" P( G - if( RESET == I2CSlaveAck() ) 9 o7 b0 @1 |: x- b) D3 m
- { # J: S# v+ e* Q+ f, C$ G
- return RESET;
, n C. G" @9 {8 S' O - } */1 I9 q' k' i/ j0 z6 T# K
- I2CWriteByte( addr & 0xFF); b1 `- N2 z2 p( a# d8 y
% t/ i5 L5 N" Y7 Z# p; R- u1 x - {
5 T$ u3 n. ]3 T+ \! s5 k/ ]$ f2 Y: u1 @ - return RESET; & Z* {# c" t3 T- r& {% S k0 [
- } : n. d+ S# c7 j2 U- k
- I2CWriteByte( data );
$ n3 _: Y0 ]* L$ G! R* I1 P* ? - if( RESET == I2CSlaveAck() ) ' g, n7 r8 ?6 B" Z$ x3 ~1 S
4 z7 Q. y* G3 p5 W* o. \' n, h - return RESET; $ u# K/ C. K2 \6 E3 ^6 g$ H
- } 3 `" [, }- ^, |6 d# E" }
- I2CStop(); ! k( {1 l' B3 i0 G' g L
- //asm("CPSIE I"); //关中断
% r3 [- r! R' ?! |$ U- m - + g' Q; O4 J! K: R/ Y U
- return SET;
% @( ~+ S# C8 S7 E6 d5 x1 ~ - }
3 N. g8 A, l% ?9 S4 ~2 {
- K$ w2 R- R) d, D1 e- /*************************************************************
5 \1 f/ R$ z& g% N2 y; X4 O; c& S" ~ - *函数名称:UvReadByte
( y: Y2 | Q* z3 S5 D; { - *函数功能:Uv指定地址读一字节数据
2 l# W7 ] V$ a( c: H - *输入参数:addr Uv地址
# K4 ~* ]5 I) j& J9 I& B - *输出参数:返回读出的数据 H# |. V X. W! F6 W
- *备 注: # G- b* o+ Z9 E' O6 x. Q
- **************************************************************/ : A6 [* \3 X" _+ t3 R. b
- uint8_t UvReadByte( unsigned short int addr )
' K0 i- G8 n | - {
( U( A; c0 a# c' i; V' [) a4 O - unsigned char ReadValue;
. f" U/ I5 l: n# W: T- b" k4 i - 1 ?+ k: I+ o9 i' k
- I2CStart(); " z# f- ]6 R7 Z; z( j- V% q
7 c7 {7 q0 R% g! @ z% |1 ^9 o- I2CWriteByte( Uv_ADD_WRITE ); " S Y! F6 h7 X+ V; I: E* K0 q
; x9 [4 W4 u: q. p3 D - { ( ^4 |6 q- M9 h% D% m# s; J+ h8 |
- return RESET;
* x' C0 H. D6 o8 P, } - }/*4 t5 N4 X8 u# k8 f
- I2CWriteByte( (addr >> 8) & 0xFF ); % K+ W! C* U% e' d& C: w
' L+ Q7 l. C' U* V - {
! s; |" \" X4 o5 l9 n - return RESET; % S. R( Y! c. W% y. y
4 @( h, d- A% U6 q7 c% U# N0 ? - I2CWriteByte( addr & 0xFF );
; u7 w9 u1 j* S - if( RESET == I2CSlaveAck() ) 7 S L m8 e5 F: C/ v" T
- { $ I( P z) s3 A% |0 m
- return RESET;
5 V0 |9 l& `$ t1 W5 G7 | - } , s, h6 {5 Q) `' n1 l0 p8 q) r1 X
- I2CStart();
@! u1 L2 V8 n- t - I2CWriteByte( Uv_ADD_READ );
6 ^# @1 _9 |4 s9 V8 A - if( RESET == I2CSlaveAck() ) 7 I0 E/ T5 B5 r0 K! R% ]1 y
- { 5 T% t2 ?1 r+ d6 Z f1 @. s
- return RESET; + n& n3 G# P! ~+ f7 `. t8 {" Q6 `
u, \% g$ U; C& S* B - ReadValue = I2CReadByte();
' T. T% O2 S: r b - I2CStop(); ! H& R! ~5 t) E6 ^) J1 J2 o
- 2 X- I# W( D8 j1 [8 ?
- return ReadValue; ) h: j4 X D$ P6 ~. Q$ p* `( f
2 [# `$ A8 K8 c, y& U: I
& X8 J/ U. ?% w$ b5 K& b( y |
