STM32F407的 DAM疑问
wang12zhe-29129 提问时间:2015-6-17 11:07 /
使用库文件的Demo程序,配合ST官方Demo板,
下载库文件的Demo程序,发送使用DMA时,DAC没有输出,
反复修改,
最后将两个DAC都配置成Stream5 Chanel7 两个通道都正常输出,
但是数据手册了上DAC2应该是Sream6 Channel7,   根据手册配置的话 DAC1和DAC2 都没有输出
这是怎么回事,
下边是我的源程序
  * @file    DAC_SignalsGeneration/main.c
  * @author  MCD Application Team
  * @version V1.0.0
  * @date    19-September-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f4_discovery.h"
/** @addtogroup STM32F4_Discovery_Peripheral_Examples
/** @addtogroup DAC_SignalsGeneration
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define DAC_DHR12R2_ADDRESS    0x40007414
#define DAC_DHR8R1_ADDRESS     0x40007410
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
DAC_InitTypeDef  DAC_InitStructure;
const uint16_t Sine12bit[32] = {
                      2047, 2447, 2831, 3185, 3498, 3750, 3939, 4056, 4095, 4056,
                      3939, 3750, 3495, 3185, 2831, 2447, 2047, 1647, 1263, 909,
                      599, 344, 155, 38, 0, 38, 155, 344, 599, 909, 1263, 1647};
const uint8_t Escalator8bit[6] = {0x0,0X11,0X22,0X33,0X44,0xFF};
__IO uint8_t SelectedWavesForm = 1;
__IO uint8_t KeyPressed = SET;
/* Private function prototypes -----------------------------------------------*/
void TIM6_Config(void);
void DAC_Ch1_EscalatorConfig(void);
void DAC_Ch2_SineWaveConfig(void);
void DAC_Ch1_NoiseConfig(void);
void DAC_Ch2_TriangleConfig(void);
/* Private functions ---------------------------------------------------------*/
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f4xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f4xx.c file
  /* Preconfiguration before using DAC----------------------------------------*/
  /* DMA1 clock and GPIOA clock enable (to be used with DAC) */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1 | RCC_AHB1Periph_GPIOA, ENABLE);
  /* DAC Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  /* DAC channel 1 & 2 (DAC_OUT1 = PA.4)(DAC_OUT2 = PA.5) configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  /* TIM6 Configuration ------------------------------------------------------*/
  TIM6_Config();
  /* Configures User Button */
  STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_EXTI);
DAC_Ch1_EscalatorConfig();
        /* Sine Wave generator -----------------------------------------------*/
  DAC_Ch2_SineWaveConfig();
  while (1)
    /* If the User Button is pressed */
    if (KeyPressed == RESET)
      DAC_DeInit();
      /* select waves forms according to the Key Button status */
      if (SelectedWavesForm == 1)    //SelectedWavesForm 已经设置成1
        /* The sine wave and the escalator wave has been selected */
       //   DAC_Ch1_EscalatorConfig();  ==========注释掉这部分,移动到while (1)前
        /* Escalator Wave generator ------------------------------------------*/
       // DAC_Ch2_SineWaveConfig();==========注释掉这部分,移动到while (1)前
      else
        /* The triangle wave and the noise wave has been selected */
        /* Noise Wave generator ----------------------------------------------*/
      //DAC_Ch1_NoiseConfig();
        /* Triangle Wave generator -------------------------------------------*/
        DAC_Ch2_TriangleConfig();
      KeyPressed = SET;
  * @brief  TIM6 Configuration
  * @note   TIM6 configuration is based on CPU @168MHz and APB1 @42MHz
  * @note   TIM6 Update event occurs each 37.5MHz/256 = 16.406 KHz
  * @param  None
  * @retval None
  TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
  /* TIM6 Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
  /* Time base configuration */
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = 0xFF;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
  /* TIM6 TRGO selection */
  TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
  /* TIM6 enable counter */
  TIM_Cmd(TIM6, ENABLE);
  * @brief  DAC  Channel2 SineWave Configuration
  * @param  None
  * @retval None
  DMA_InitTypeDef DMA_InitStructure;
  /* DAC channel2 Configuration */
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
  DAC_Init(DAC_Channel_2, &DAC_InitStructure);
//这部分注释应该有问题,手册上DAC2对应Stream6 Channel7
/* DMA1_Stream5 channel7 configuration **************************************/
  DMA_DeInit(DMA1_Stream5);
  DMA_InitStructure.DMA_Channel = DMA_Channel_7;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)DAC_DHR12R2_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&Sine12bit;
  DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  DMA_InitStructure.DMA_BufferSize = 32;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA1_Stream5, &DMA_InitStructure);
  /* Enable DMA1_Stream5 */
  DMA_Cmd(DMA1_Stream5, ENABLE);
  /* Enable DAC Channel2 */
  DAC_Cmd(DAC_Channel_2, ENABLE);
  /* Enable DMA for DAC Channel2 */
  DAC_DMACmd(DAC_Channel_2, ENABLE);
  * @brief  DAC Channel1 Escalator Configuration
  * @param  None
  * @retval None
  /* DAC channel1 Configuration */
  DAC_Init(DAC_Channel_1, &DAC_InitStructure);
//这部分注释应该有问题,手册上DAC2对应Stream5 Channel7
  /* DMA1_Stream6 channel7 configuration **************************************/
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR8R1_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&Escalator8bit;
  DMA_InitStructure.DMA_BufferSize = 6;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_Init(DMA1_Stream6, &DMA_InitStructure);
  /* Enable DMA1_Stream6 */
  DMA_Cmd(DMA1_Stream6, ENABLE);
  /* Enable DAC Channel1 */
  DAC_Cmd(DAC_Channel_1, ENABLE);
  /* Enable DMA for DAC Channel1 */
  DAC_DMACmd(DAC_Channel_1, ENABLE);
  * @brief  DAC Channel2 Triangle Configuration
  * @param  None
  * @retval None
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_Triangle;
  DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_TriangleAmplitude_1023;
  /* Set DAC channel2 DHR12RD register */
  DAC_SetChannel2Data(DAC_Align_12b_R, 0x100);
  * @brief  DAC  Channel1 Noise Configuration
  * @param  None
  * @retval None
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_Noise;
  DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_LFSRUnmask_Bits10_0;
  /* Set DAC Channel1 DHR12L register */
  DAC_SetChannel1Data(DAC_Align_12b_L, 0x7FF0);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
收藏 评论3 发布时间:2015-6-17 11:07
3个回答
creep 回答时间:2015-6-17 11:53:29
标题应该是DMA吧,
mark0668 回答时间:2015-6-17 12:27:43
creep 发表于 2015-6-17 11:53
标题应该是DMA吧,
我也这么说.
wang12zhe-29129 回答时间:2015-6-17 17:21:51
额  笔误 台粗心了,,
希望大家不要介意
