关于STM32F030的串口发送不能中断,请大侠们帮忙看看
yinlian 提问时间:2015-7-26 00:11 /
    最近在开发的一个案子,使用STM32F030C8T6 主芯片,需要用到STM32F030C8T6的串口与外设完成通讯和控制,现在遇到的问题是:接收没有问题,单独发送也没有问题,但是将接收到的信息转化为控制命令发送回去的时候,发现出程序不能产生中断,程序死在发送函数了:下面是源码,请大侠们帮忙看看问题出在哪里:
    static          void          USART1_Init_config()
                   GPIO_InitTypeDef      GPIO_Init_Struct;
                   NVIC_InitTypeDef      NVIC_Init_Struct;
                   USART_InitTypeDef      USART_Init_Struct;
                    //¶¨ÒåGPIO¡¢USART ³õʼ»¯½á¹¹Ìå
                   RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
                   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
                   //´ò¿ªUSART1¡¢GPIOB(USART1 TX/RX ¸´ÓÃÒý½Å)ʱÖÓ
                   USART1_DMA_config();
                   //ÅäÖÃUSART1 µÄDMAͨµÀ£»
                   GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_0);
                   GPIO_PinAFConfig(GPIOB,GPIO_PinSource7,GPIO_AF_0);
                   GPIO_Init_Struct.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
                   GPIO_Init_Struct.GPIO_Mode = GPIO_Mode_AF;
                   GPIO_Init_Struct.GPIO_Speed = GPIO_Speed_Level_3 ;
                   GPIO_Init_Struct.GPIO_OType = GPIO_OType_PP;
                   GPIO_Init_Struct.GPIO_PuPd = GPIO_PuPd_NOPULL;
                   GPIO_Init(GPIOB,&GPIO_Init_Struct);
                   //ÅäÖÃPB6 ¡¢PB7ΪUSART1 TX ¡¢RX£¨ÍÆÃâÊä³öģʽ£©
                   NVIC_Init_Struct.NVIC_IRQChannel = USART1_IRQn;
            NVIC_Init_Struct.NVIC_IRQChannelPriority = 0x01;
            NVIC_Init_Struct.NVIC_IRQChannelCmd = ENABLE;
            NVIC_Init(&NVIC_Init_Struct);
           //ÅäÖÃNVICÖжÏUSART1 ÖжÏ
                   USART_Init_Struct.USART_BaudRate = 57600;
                   USART_Init_Struct.USART_WordLength = USART_WordLength_8b;
                   USART_Init_Struct.USART_StopBits = USART_StopBits_1;
                   USART_Init_Struct.USART_Parity = USART_Parity_No;
          USART_Init_Struct.USART_Mode = USART_Mode_Rx|USART_Mode_Tx;
          USART_Init_Struct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
          USART_Init(USART1, &USART_Init_Struct);
          USART_ITConfig(USART1, USART_IT_RXNE,ENABLE);
          USART_ITConfig(USART1, USART_IT_TXE,DISABLE);
          USART_Cmd(USART1, ENABLE);
          //ÅäÖÃUSART1 Ϊ57600¡¢8¡¢1¡¢ÎÞ È«Ë«¹¤Ò첽ͨѶ£»
    上面的代码是,打开串口1中断,配置串口1为全双工异步通讯模式,(配置:57600、8、无、无、1)
          void      USART1_IRQHandler(void)
          if  (USART_GetITStatus(USART1,USART_IT_RXNE) == ENABLE)
         USART1_RxData_buffer[USART1_ReadData_count] = USART_ReceiveData(USART1);
         USART1_ReadData_count++;
         if (USART1_ReadData_count == 1 && \
           USART1_RxData_buffer[0] != 'A')
           USART1_ReadData_count = 0;
        else if (USART1_ReadData_count == 2 && \
                 USART1_RxData_buffer[1] != 'X')
        else if (USART1_ReadData_count == 3 && \
                 USART1_RxData_buffer[2] != 'X')
         if (USART1_ReadData_count >= 11)
           USART1_Rx_Status = SET;
           USART1_RxData_buffer[USART1_ReadData_count] = '\n';
           USART1_RxData_buffer[USART1_ReadData_count+1] = '\0';
      //串口接收
      if  (USART_GetITStatus(USART1,USART_IT_TXE) == ENABLE)
             USART_ITConfig(USART1,USART_IT_TXE,DISABLE);
             USART1_Busy  =  RESET;
      上面的代码是串口中断应用函数,当发送寄存器为空时产生中断,清除串口忙标志,以便发送函数判断发送是否完成。
      void            USART1_Printf(uint8_t*   String)
         while  (*String  !=  '\0')
                   USART_SendData(USART1, (uint16_t)*String);
                    USART_ITConfig(USART1,USART_IT_TXE,ENABLE);
                    USART1_Busy  =  SET;
               while (USART1_Busy  ==  SET)
                   Char_LED(ON);
                String++;
         上面是串口发送函数,发送完成时由中断函数清除串口忙标志;
         下载程序后出现的现象是:程序启动时串口能够发送数据,比如我在主程序写这样一行代码:
              USART1_Printf("power on\n");
          串口助手能够看到打印信息;说明发送中断是可以工作的;但是当收到串口发来的字符串,再将字符串原样返回的时候 ,程序进入死循环了。在串口助手上只能看到第一个字符,其他字符打印不出来;说明程序发送第一个字符后进入死循环;分析程序,应该是死在这句:
                                  Char_LED(ON);
         这个标志位是在串口中断函数中,清除的;难道没有产生串口中断????但是为什么这句:USART1_Printf("power on\n");能够打印出信息呢?
将发送改到串口2发送,收到的字符串能够原样返回。调试了两天,实在百思不得其解!!!难道STM32的串口不能同时使用发送和接收中断吗?
         还望那位大侠能给小弟指点一二,不胜感激!!!!
STM32F0 project.rar
4.94 MB, 下载次数: 136, 下载积分: ST金币 -1
完整工程文件
赞 收藏 评论17 发布时间:2015-7-26 00:11
17个回答
yinlian 回答时间:2015-8-1 23:25:26
     结贴,虽然不是你说的这个原因。但是还是非常感谢你的指点
   解决问题后的代码如下:
                    uint8_t  Rx_Data_Buf  =  0;
                           if  (USART_GetFlagStatus(USART1, USART_FLAG_TC) ==  SET)    //发送中断被触发
        USART_ClearFlag(USART1, USART_FLAG_TC);
        USART2_String("T\n");
                                                        if   (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) ==  SET)  //接收中断被触发
        Rx_Data_Buf  =  USART_ReceiveData(USART1);
        if   (Rx_Data_Buf  !=  '\n')
        USART1_RxData_buffer[Rx_count] = Rx_Data_Buf;
        Rx_count++;
        if   (Rx_count  ==  1  &&  USART1_RxData_buffer[0]   !=  'A')
        Rx_count  =  0;
        if   (Rx_count  ==  2  &&  USART1_RxData_buffer[1]   !=  'X' )
        if  (USART1_RxData_buffer[1]   ==  'A' )
        Rx_count  =  1;
        else
        Rx_count  =  0;
        if   (Rx_count  ==  3  &&  USART1_RxData_buffer[2]   !=  'X' )
        if  (USART1_RxData_buffer[2]   ==  'A' )
        Rx_count  =  1;
        else
        Rx_count  =  0;
        //以上过滤无效打印信息,只有AXX开头的字符串才认为是需要接收的模块命令;
        if   (Rx_Data_Buf  ==  '\n'   &&   Rx_count  > 10)
        USART1_RxData_buffer[Rx_count+1]   =  '\0';
        Rx_count = 0;
        Rx_ReadData_Over  =  SET;
                                                  if (USART_GetFlagStatus(USART1, USART_FLAG_ORE) ==  SET)   //接收溢出中断被触发
        USART_ClearFlag(USART1, USART_FLAG_ORE);
        USART2_Printf("USART1 ISR(ORE)  = %b\n",USART1->ISR);
                                                  //USART2_Printf("USART1 ISR  = %b\n",USART1->ISR);
    就是把之前的 :USART_GetITStatus(USART1,USART_IT_RXNE) 修改为:USART_GetFlagStatus(USART1,USART_FLAG_RXNE);
    根本原因就是对这两个库函数的功能没有搞清楚;USART_GetITStatus(USART1,USART_IT_RXNE)这个函数的功能是获取你设置了那些中断,因为函数返回的是CR1/CR2/CR3的相应标志位;而中断函数中需要查询的是当前是哪个中断产生,所以必须使用USART_GetFlagStatus(USART1,USART_FLAG_RXNE);因为所有的中断请求都是在ISR寄存器中;查看库函数,只有这个函数返回的是ISR寄存器的值。
  新手接触STM32,走了很多弯路!!!并且STM32F030系列的编程参考手册没有中文的,我们这些英文不太好的新手 ,学起来相当费力啊!!!希望以后不要再走这样的弯路!!!!
yinlian 回答时间:2015-7-26 11:05:30
00-405686 发表于 2015-7-26 02:17
USART_ITConfig(USART1, USART_IT_TXE,DISABLE);这里把发送中断关了;
if  (USART_GetITStatus(USART1,US ...
      已经验证,不会是这个原因,程序中有两个地方关闭发送寄存器为空中断,一个在中断函数里、一个是当所有字符发送完成,遇到“\0”结束发送循环后,关闭发送寄存器为空中断,因为发送寄存器为空中断标志位必须通过写发送寄存器来清除,我的程序不上在中断函数写发送寄存器的,所以必须在响应中断后关闭中断请求;在发送函数里先写发送寄存器清除标志位,在开发送寄存器空中断请求:如下代码:
                     USART1_Busy  =  SET;
                    Char_LED(ON);
                 String++;
         不然的话,程序会一直在响应中断,不能处理发送函数,造成程序死循环;
      我在主循环中写这样一句:USART1_Printf("main  run is  ok\n");在没有通过串口助手发送字符串之前,一直可以看到程序不断打印出这个消息;如果通过串口发送一个字符串,程序返回我发送的字符串的第一个字符,然后就进入死循环了。
     还是请再帮忙看看,是什么原因发送寄存器空中断没有响应?
294479435@qq.co 回答时间:2015-7-27 11:45:14
                USART_ITConfig(USART1,USART_IT_TC,ENABLE);
                 while(USART_GetITStatus(USART1,USART_IT_TC)==RESET)
                         Char_LED(ON);
//                USART1_Busy  =  SET;
//                while (USART1_Busy  ==  SET)
//                   Char_LED(ON);
                String++;
//         USART_ITConfig(USART1,USART_IT_TXE,DISABLE);
        USART_ITConfig(USART1,USART_IT_TC,DISABLE);
                //¹Ø±Õ·¢ËÍÖжÏ
我不太懂你这里为什么用TXE不用TC,如果可以你改成这样试试
294479435@qq.co 回答时间:2015-7-26 02:17:44
这个条件应该一直不会执行;
所以Busy一直为1吧
Paderboy 回答时间:2015-7-26 11:29:34
帮顶。。。
294479435@qq.co 回答时间:2015-7-26 11:30:44
yinlian 发表于 2015-7-26 11:05
已经验证,不会是这个原因,程序中有两个地方关闭发送寄存器为空中断,一个在中断函数里、一个是当 ...
这样还是不好看,能把你的工程文件加上来吗
moyanming2013 回答时间:2015-7-26 13:47:27
yinlian 回答时间:2015-7-26 22:36:04
怎么上传附件呢?
第一次在论坛发帖,请多指教!!!
294479435@qq.co 回答时间:2015-7-26 23:23:20
yinlian 发表于 2015-7-26 22:36
怎么上传附件呢?
第一次在论坛发帖,请多指教!!!
压缩包,添加附件
yinlian 回答时间:2015-7-27 00:07:43
00-405686 发表于 2015-7-26 23:23
压缩包,添加附件
     完整的工程文件已经附上, 请帮忙看看是什么问题造成一旦接收中断产生后,就不能产生发送中断了????在没有产生接收中断前,发送中断是可以正常工作的!!!
yinlian 回答时间:2015-7-27 00:10:06
   需要帮忙看看程序出现了什么问题,顶贴不能解决什么问题,反而有借机赚分的嫌疑
moyanming2013 回答时间:2015-7-27 11:42:28
yinlian 发表于 2015-7-27 00:10
需要帮忙看看程序出现了什么问题,顶贴不能解决什么问题,反而有借机赚分的嫌疑 ...
不懂的情况下,帮顶当然是赚分的!
不帮你顶,你的帖子2天就沉了,没人看了!
294479435@qq.co 回答时间:2015-7-27 11:44:30
                         Char_LED(ON);
//                   Char_LED(ON);
                String++;
                //¹Ø±Õ·¢ËÍÖжÏ
stary666 回答时间:2015-7-27 12:16:31
帮顶,,,,,,,,,,,,,
yinlian 回答时间:2015-8-1 23:06:33
     非常感谢你的帮助,问题已经解决!!!
12下一页
