写了一个串口通信实验,接的蓝牙,发送指令后,正确的话应该能收到OK,但是现在就是没有返回。 void USART_Config(void) { GPIO_Init(GPIOC,GPIO_Pin_6,GPIO_Mode_In_PU_No_IT); GPIO_Init(GPIOC,GPIO_Pin_5,GPIO_Mode_Out_PP_Low_Fast); CLK_PeripheralClockConfig(CLK_Peripheral_USART1, ENABLE); USART_DeInit(USART1); USART_Init(USART1, (u32)9600, USART_WordLength_8b, USART_StopBits_1, USART_Parity_No, (USART_Mode_TypeDef)(USART_Mode_Tx |USART_Mode_Rx )); USART_Cmd(USART1,ENABLE); } PUTCHAR_PROTOTYPE { if(ch =='\n') { while(!(USART1->SR & USART_FLAG_TC )); USART_SendData8(USART1,'\r'); while(!(USART1->SR & USART_FLAG_TC )); } while(!(USART1->SR & USART_FLAG_TXE )); USART_SendData8(USART1,ch); while(!(USART1->SR & USART_FLAG_TXE )); return (ch); } //主函数 void main(void) { char zsh[]="AT+CB\n"; // disableInterrupts(); // enableInterrupts(); CLK_Config(); USART_Config(); /* GPIO_Init(GPIOB, GPIO_Pin_0, (GPIO_Mode_TypeDef)GPIO_Mode_Out_PP_High_Slow);//BT_RESET/ */ while(1){ // scan_key(); /* GPIOB ->ODR =~GPIOB ->ODR; DelayMS(1000); GPIOB ->ODR =~GPIOB ->ODR; */ cnt = 0; printf("AT+CA\r\n"); while(temp !=' \n'){ while(!(USART_FLAG_RXNE & USART1_SR) ); temp = USART_ReceiveData8(USART1); buf[cnt++]=temp; } DelayMS(100); } } |
求STM8S105C6T6的安装软件完整版和安装步骤,谢谢!
STM8S003无法检测到引脚电平
STM8 @svlreg 问题
STM8AF62XX+L99PM62GXP LIN通讯的电路原理图有吗?官网提供了一套软件,没找到对应的原理图,请大家指教一下
求一个STM8S207例程
STMS005K6T6 如何采集内部参考电压。
stm8s003 adc中断和通道切换的问题
adc施密特触发器stm8
stm8l051f3 TSSOP20 封装,待机模式下,2天后,电流突然增加到140UA
放假了,没用示波器测,用万用表测是通的
等先用示波器测测看看
