STM32F4 使用HSI通过PLL提供SYSTEMCLOCK,程序跑飞
vlinda5150 提问时间:2015-10-30 16:25 /
使用HSI通过PLL提供SYSTEMCLOCK,下面代码每次执行到RCC->CFGR |= RCC_CFGR_SW_PLL;  程序就执行不下去了。求各位牛人帮忙看看问题出在哪里?
void SystemInit(void)
   uint32_t tmp = 0;
  /* Reset the RCC clock configuration to the default reset state ------------*/
  /* Set HSION bit */
  RCC->CR |= (uint32_t)0x00000001;
  /* Reset CFGR register */
  RCC->CFGR = 0x00000000;
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= (uint32_t)0xFEF6FFFF;
  /* Reset PLLCFGR register */
  RCC->PLLCFGR = 0x24003010;
  /* Reset HSEBYP bit */
  RCC->CR &= (uint32_t)0xFFFBFFFF;
  /* Disable all interrupts */
  RCC->CIR = 0x00000000;
#ifdef DATA_IN_ExtSRAM
  SystemInit_ExtMemCtl();
#endif /* DATA_IN_ExtSRAM */
#ifdef PLL_SOURCE_HSI
  /* At this stage the HSI is already enabled */
    /* Configure the main PLL */
    RCC->PLLCFGR = PLL_M | (PLL_N << 6) | (((PLL_P >> 1) -1) << 16) |
                   (RCC_PLLCFGR_PLLSRC_HSI) | (PLL_Q << 24);
    /* HCLK = SYSCLK / 1*/
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK / 2*/
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;
    /* PCLK1 = HCLK / 4*/
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV4;
    /* Enable the main PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till the main PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Configure Flash prefetch, Instruction cache, Data cache and wait state */
    FLASH->ACR = FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS;
    /* Select the main PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    tmp = (RCC->CFGR) & (uint32_t)RCC_CFGR_SWS;
    /* Wait till the main PLL is used as system clock source */
    while (tmp != RCC_CFGR_SWS_PLL)
#else
  /* Configure the System clock source, PLL Multiplier and Divider factors,
     AHB/APBx prescalers and Flash settings ----------------------------------*/
  SetSysClock();
#endif /* PLL_SOURCE_HSI */
  /* Configure the Vector Table location add offset address ------------------*/
#ifdef VECT_TAB_SRAM
  SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
#else
  SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
#endif
赞 收藏 评论4 发布时间:2015-10-30 16:25
4个回答
vlinda5150 回答时间:2015-10-30 16:54:04
已解决,字数字数字数
埃斯提爱慕 回答时间:2015-10-30 22:11:14
你好我好大家好! 回答时间:2015-10-31 09:34:27
学习学习
mcuyangyifan 回答时间:2015-10-31 10:36:53
分享一下解决办法吧,F4的PLL时钟源能选外部时钟?
