2.芯片特性:
• Core: ARM® 32-bit Cortex®-M4 CPU with FPU, Adaptive real-time accelerator (ART Accelerator™) allowing 0-wait state execution from Flash memory, frequency up to 168 MHz, memory protection unit, 210 DMIPS/1.25 DMIPS/MHz (Dhrystone 2.1), and DSP instructions
• Memories
– Up to 1 Mbyte of Flash memory
– Up to 192+4 Kbytes of SRAM including 64-Kbyte of CCM (core coupled memory) data RAM
– Flexible static memory controller supporting Compact Flash, SRAM, PSRAM, NOR and NAND memories DM00037051.pdf(5.6 MB, 下载次数: 0)
Stm32L152 discovery系列~初次使用的st的低功耗系列MCU
之前是用Stm32F103系列入门学习的
2、Stm32L152的特点
Features
■ Ultra-low-power platform
– 1.65 V to 3.6 V power supply
– -40°C to 85°C/105°C temperature range
– 0.3 μA Standby mode (3 wakeup pins)
– 0.9 μA Standby mode + RTC
– 0.57 μA Stop mode (16 wakeup lines)
– 1.2 μA Stop mode + RTC
– 9 μA Low-power Run mode
– 214 μA/MHz Run mode
– 10 nA ultra-low I/O leakage
– < 8 μs wakeup time
■ Core: ARM 32-bit Cortex™-M3 CPU
– From 32 kHz up to 32 MHz max
– 33.3 DMIPS peak (Dhrystone 2.1)
– Memory protection unit
■ Reset and supply management
– Ultra-safe, low-power BOR (brownout
reset) with 5 selectable thresholds
– Ultra-low-power POR/PDR
– Programmable voltage detector (PVD)
■ Clock sources
– 1 to 24 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– High Speed Internal 16 MHz factorytrimmed
RC (+/- 1%)
– Internal Low Power 37 kHz RC
– Internal multispeed low power 65 kHz to
4.2 MHz
– PLL for CPU clock and USB (48 MHz)
■ Pre-programmed bootloader
– USART supported
■ Development support
– Serial wire debug supported
– JTAG and trace supported
■ Up to 83 fast I/Os (73 I/Os 5V tolerant), all
mappable on 16 external interrupt vectors
■ Memories
– Up to 128 KB Flash with ECC
– Up to 16 KB RAM
– Up to 4 KB of true EEPROM with ECC
– 80 Byte Backup Register
■ LCD Driver for up to 8x40 segments
– Support contrast adjustment
– Support blinking mode
– Step-up converter on board
■ Rich analog peripherals (down to 1.8 V)
– 12-bit ADC 1 Msps up to 24 channels
– 12-bit DAC 2 channels with output buffers
– 2x Ultra-low-power-comparators
(window mode and wake up capability)
■ DMA controller 7x channels
■ 8x peripherals communication interface
– 1x USB 2.0 (internal 48 MHz PLL)
– 3x USART (ISO 7816, IrDA)
– 2x SPI 16 Mbits/s
– 2x I2C (SMBus/PMBus)
■ 10x timers: 6x 16-bit with up to 4 IC/OC/PWM
channels, 2x 16-bit basic timer, 2x watchdog
timers (independent and window)
■ Up to 20 capacitive sensing channels
supporting touchkey, linear and rotary touch
sensors
■ CRC calculation unit, 96-bit unique ID
STM32L15.pdf(1.93 MB, 下载次数: 0)
特性
1、先说一下103的吧,最早就是玩STM32f103的,这个比较早,最开始用它纯属于因为它资源多,并且中文资料很多,学习起来也方便,上面集成了各种想要的外设。到公司之后,大量接触彩屏,上面集成了FSMC总线,可以直接和RA8875的彩屏驱动芯片对接。以及NANDFLASH和NORFlash等
2、107系列属于互联型,上面有很多的外设接口,多个UART口,以及网络接口,集成USBOTG接口。
3、407和429以及302属于M4的内核,支持硬件浮点运算。主频更是达到180MHz,429集成LCD接口,可以直接驱动LCD。不需要额外的驱动芯片。
项目:
1.空气净化器
2.智能家居控制中心
3.平衡机器人
STM32F10x å æ ¸ååºç¡å¤è®¾.pdf
2016-1-26 13:41 上传
点击文件名下载附件
下载积分: ST金币 -14.7 MB, 下载次数: 0, 下载积分: ST金币 -1
stm32f030f4p6
stm32f030f4p6
2、 说明该STM32产品型号,列举其一项或者多项特性,同时附件上传一篇该型号产品的资料(官方文档或者网络上的文章分享均可,点击立刻下载官方文档)
stm32f030f4p6真是便宜又大碗,¥3能买到的带串口SPI大内存大flash还要是32位MCU,厉害的没得顶。然后我就从arduino转到stm32了。
特别提一下cubeMX实在是业余爱好者的一大利器。
f030æå
3、 基于STM32你做过哪些设计?(如没有则不写)
stm32结合nRf24L01+和ESP8266的智能门磁。爱好者的第一个大项目都能轻松实现800mah小电池供电20天。
éçå¼åæ¿
2 stm32f107有很多UART有双CAN,USBOTG等
3.
SRAM : 64kB
Flash : 512KB
FSMC : 1 Flexible Static Memory Controller for SRAM, PSRAM, NOR and NAND Flash,
PLL : 1 PLL,
RCC : Embedded Internal RC 8MHz and 32kHz,
RTC : 1 Real-Time Clock,
NVIC : 1 Nested Interrupt Controller, Power Saving Modes, JTAG and SWD,
TIM : 4 Synch. 16-bit Timers with Input Capture, Output Compare and PWM,
TIM : 2 16-bit Advanced Timer, 2 16-bit Basic Timer, 2 16-bit Watchdog Timers,
2 个16位带死区控制和 2 个16位基本定时器 独立型和窗口型
紧急刹车,用于电机控 用于驱动DAC
制的PWM高级控制定时器
SysTick : 1 SysTick Timer, 系统时间定时器,24位自减型计数器
SPI/I2S : 3 SPI/I2S, 有两个可复用为 I2S
I2C : 2 I2C,
USART : 5 USART,
USB : 1 USB 2.0 Full Speed Interface,
CAN : 1 CAN 2.0B Active,
A/D : 3 12-bit 16-ch A/D Converter,
D/A : 2 12-bit D/A Converter,
SDIO : 1 SDIO,
DMA : 12 通道 DMA 控制器
支持的外设:定时器、ADC、DAC、SDIO、
I2S、SPI、I2C 和 USAR
STM32F40x and STM32F41x å误表ï¼2012-08 Rev 3ï¼
STM32F405xx STM32F407xx æ°æ®æåï¼2012-05 Rev 3ï¼
STM32F415xx STM32F417xx æ°æ®æåï¼2012-05 Rev 3ï¼
2.芯片特性:
• Memories
3.我乃新手,只用STM32做过跑马灯。
1、 晒出你使用过的STM32开发板/芯片图片(如果还未使用过,可从官网寻找);
电路调试
2、 STM32F103ZET6
■ 内核:ARM 32位的Cortex™-M3 CPU − 最高72MHz工作频率,在存储器的0等待周期访问时可达1.25DMips/MHz(Dhrystone 2.1) − 单周期乘法和硬件除法
■ 存储器 − 从256K至512K字节的闪存程序存储器 − 高达64K字节的SRAM − 带4个片选的静态存储器控制器。支持CF卡、SRAM、PSRAM、NOR和NAND存储器 − 并行LCD接口,兼容8080/6800模式
■ 时钟、复位和电源管理 − 2.0~3.6伏供电和I/O引脚 − 上电/断电复位(POR/PDR)、可编程电压监测器(PVD) − 4~16MHz晶体振荡器 − 内嵌经出厂调校的8MHz的RC振荡器 − 内嵌带校准的40kHz的RC振荡器 − 带校准功能的32kHz RTC振荡器
■ 低功耗 − 睡眠、停机和待机模式 − VBAT为RTC和后备寄存器供电
■ 3个12位模数转换器,1μs转换时间(多达21个输入通道) − 转换范围:0至3.6V − 三倍采样和保持功能 − 温度传感器
■ 2通道12位D/A转换器 ■ DMA:12通道DMA控制器 − 支持的外设:定时器、ADC、DAC、SDIO、I2S、SPI、I2C和USART
3、 基于STM32设计过的作品
基于stm32的智能水族箱系统
基于stm32的四旋翼
STM32F103ZET6(䏿)(é 读ç¬è®°).pdf
2016-1-26 22:38 上传
点击文件名下载附件
下载积分: ST金币 -12.48 MB, 下载次数: 0, 下载积分: ST金币 -1
支持LTDC功能,频率高达180M
主要使用在继电器保护装置上!
2、 说明该STM32产品型号:NUCLEO-F030R8
列举其一项或者多项特性:支持mbed\Arduino
同时附件上传一篇该型号产品的资料:
3、 基于STM32你做过哪些设计?
运动控制器的开发、传感器模块的控制IC
1、 晒出使用过的STM32开发板/芯片图片
Stm32L152 discoveryç³»å
2、Stm32L152的特点
Features
■ Clock sources
RC (+/- 1%)
4.2 MHz
– USART supported
■ Memories
– Up to 16 KB RAM
– 2x SPI 16 Mbits/s
sensors
3、 基于STM32你做过哪些设计?
a.用STM32F103CBT6做过门禁IO拓展版的主控 和 RFID相关读卡端的主控
b.STM32L系列做过智能门锁
• 配备ST-LINK/V2调试和编程器
• 128KB Flash,16KB SRAM
• 配备ST MEMS陀螺仪
STM32 Nucleo 核心板是ST为用户全新设计的开放式开发平台,为用户提供了经济、灵活的途径,用于快速验证创意,制作产品样机。用户可以灵活选择带有目标单片机的多种核心板。此核心板配有两种扩展接口,一个是兼容Arduino标准的接口,用于连接符合Arduino标准的外设,另一种接口引出了全部通用I/O端口,用户评估芯片功能。
STM32 Nucleo 核心板集成了ST-LINK/V2-1,提供调试和编程的用途。
STM32 Nucleo 核心板还配套了完整的STM32软件库和各种例程,同时可以直接享用embed在线的多种资源。
打算用来设计四轴飞行器
