stm32f030的i2c(eeprom)调试分享
alisa123 提问时间:2016-1-13 16:43 /
之前在调试stm32的i2c花了很长时间,由于项目时间催的紧,硬件的i2c没能调试好,最后项目中采用了软件模拟的方式,由于软件等待时间CPU的效率有点低,后面自己花时间最终调通了硬件i2c,调试中自己的两点注意:1,调试i2c外接的器件接好一定要核对Ok(否则,后续努力也没用);2,要弄清i2c通信原理,多参考前人的经验。现在分享代码如下:
void sReadI2C(INT8U* lubData,INT16U luwI2CAddr,INT8U lubDataLen)    //从指定地址读取指定长度的数据
INT8U i;
// 等待总线空闲
while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY));
I2C_TransferHandling(I2C1,EepromAddr,1,I2C_SoftEnd_Mode,I2C_Generate_Start_Write);
while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TXIS) == RESET);
I2C_SendData(I2C1,luwI2CAddr);
while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TC) == RESET);
I2C_TransferHandling(I2C1,EepromAddr,lubDataLen,I2C_AutoEnd_Mode,I2C_Generate_Start_Read);
for(i=0;i<lubDataLen;i++)
  while(I2C_GetFlagStatus(I2C1,I2C_FLAG_RXNE) == RESET);
  lubData[i] = I2C_ReceiveData(I2C1);
while(I2C_GetFlagStatus(I2C1,I2C_FLAG_STOPF) == RESET);
I2C_ClearFlag(I2C1, I2C_ICR_STOPCF);
//从指定地址开始写指定个数的数据
void I2C_uWriteData(INT8U *WriteBuf,INT16U WriteAddr,INT8U WriteLen)
INT8U i;
// 等待总线空闲
I2C_TransferHandling(I2C1,EepromAddr,1,I2C_Reload_Mode,I2C_Generate_Start_Write);
I2C_SendData(I2C1,WriteAddr);
while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TCR) == RESET);
I2C_TransferHandling(I2C1,EepromAddr,WriteLen,I2C_AutoEnd_Mode,I2C_No_StartStop);
for(i=0;i<WriteLen;i++)
  I2C_SendData(I2C1, WriteBuf[i]);
//eeprom不能跨页连续写数据,对跨页写的数据进行处理
void sWriteI2C(INT8U* lubData,INT16U luwI2CAddr,INT8U lubDataLen)
INT16U NumOfPage = 0,NumOfSingle = 0,Addr = 0;
INT16U count = 0;
Addr = luwI2CAddr % 16;
count = 16 - Addr;
NumOfPage = lubDataLen / 16;
NumOfSingle = lubDataLen % 16;
if(Addr == 0)
  if(NumOfPage == 0)
   I2C_uWriteData(lubData,luwI2CAddr,NumOfSingle);
   I2c_delayms(5);
  else
   while(NumOfPage--)
    I2C_uWriteData(lubData,luwI2CAddr,16);
    I2c_delayms(5);
    luwI2CAddr +=  16;
    lubData += 16;
   if(NumOfSingle!=0)
    I2c_delayms(5);
else
  if(NumOfPage== 0)
   if (lubDataLen > count)
    /* Write the data contained in same page */
    I2C_uWriteData(lubData,luwI2CAddr,count);
    I2c_delayms(5);
       /* Write the remaining data in the following page */
    I2C_uWriteData((INT8U*)(lubData + count),luwI2CAddr + count,lubDataLen - count);
    I2c_delayms(5);
   else
    I2c_delayms(5);
  else
   lubDataLen -= count;
   if(count != 0)
    I2c_delayms(5);
    luwI2CAddr += count;
    lubData += count;
   while(NumOfPage--)
    I2c_delayms(5);
    luwI2CAddr +=  16;
    lubData += 16;
   if(NumOfSingle != 0)
    I2c_delayms(5);
参与人数 1 ST金币 +20 收起 理由
沐紫 + 20 赞一个!
赞 收藏 6 评论10 发布时间:2016-1-13 16:43
10个回答
沐紫 回答时间:2016-1-14 09:22:31
谢谢楼主,i2c让很多工程师发愁
特拉法尔加.罗 回答时间:2016-10-12 11:13:30
bucuo
seven101 回答时间:2017-6-1 19:33:56
很的很详细
samhong 回答时间:2017-8-10 21:45:50
晚上好!谢谢楼主分享。
samhong 回答时间:2017-8-10 21:49:24
在i2c上花时间比读学前班的时间长,从4位MCU、8位MCU、16位MCU、32位MCU、MPU。
alisa123 回答时间:2017-8-11 10:40:17
我也花了很长时间,
yanghaixia819 回答时间:2018-2-28 09:37:26
您好楼主,我最近也在调试IIC,但是按着还是卡在 while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TXIS) == RESET);
pcb_diy 回答时间:2018-3-20 09:16:41
来试试楼主代码。多谢。
小林电路 回答时间:2020-7-30 15:04:20
非常有用的文章
另外补充一句
注意第三个参数 ‘2’
I2C_TransferHandling(I2C1, driver_Addr, 2, I2C_Reload_Mode, I2C_Generate_Start_Write);
// 发一个控制字节加上 发两个字节地址
sincomaster 回答时间:2020-8-2 16:49:06
谢谢分享
