STM32F746G-Disco开发板上带有数字麦克风和音频输出,它们组合起来就可以实现助听器的功能。只要把麦克风的输入信号进行放大,然后在通过音频接口输出。
+ c' K2 [6 U5 P/ u5 _1 J" n
1 z9 e3 m7 U+ k- I% V下面程序演示了助听器的功能,它来自Mbed例程。首先它通过数字麦克风(U21、U22)获取环境声音,将数据保存到接收缓冲区,然后将数字音频发送到音频输出(U11)。如果我们在CN10(音频输出)上接一个耳机或者扬声器,就可以清楚的听到放大后的环境声音,效果非常不错。在连接耳机时,需要注意保护耳朵,因为开发板上没有音量控制的旋钮,不能调节音量。
' o' s. }: Q% E) g, D+ I
5 D! z) r- `7 M9 ~/ ?) u- 1 C D" w; X5 e) L* ? c3 M" Z/ A0 V
- ; o7 H# }& u* V' q- U
- #include "mbed.h"
7 \) w J' v% |0 X1 }4 A! n - #include "AUDIO_DISCO_F746NG.h"
" C. |" W6 a) G: u; L& R; ^1 K, G - #include "SDRAM_DISCO_F746NG.h" " N. F! m* @' R) L
, I( z7 n. b6 i' L$ e- c - AUDIO_DISCO_F746NG audio;
/ @; X+ U/ \3 r- B7 V1 l - // audio IN_OUT buffer is stored in the SDRAM, SDRAM needs to be initialized ; H( v' K0 f) R) V( Q3 _1 Y
- // and FMC enabled
3 ~# y# p5 ]* Y* l) ?& r - SDRAM_DISCO_F746NG sdram;
1 a1 A2 n4 [ w - 9 a0 h1 M2 U7 }5 L4 W+ X+ w% Q; d
- DigitalOut led_green(LED1);
2 b2 q" @- a, K1 O) ] - DigitalOut led_red(LED2); / B1 A% @6 o6 f# P* [
- Serial pc(USBTX, USBRX);
' G. P) H0 [3 ^ - 7 x4 a: v/ ]/ D* `
- typedef enum
. t/ @1 J! A1 Q( Y7 s' ]8 i - {
, I' y1 L: W/ G" \ - BUFFER_OFFSET_NONE = 0,
) R' v8 B3 ?' D; f( W0 X z9 G - BUFFER_OFFSET_HALF = 1, 9 J# `2 N- G) R3 k3 J2 g
- BUFFER_OFFSET_FULL = 2, - Z5 c) r4 l( z
- }BUFFER_StateTypeDef; * S3 ^9 b, l% h
; v( |( k# f$ V6 K - #define AUDIO_BLOCK_SIZE ((uint32_t)512)
: z! x1 Y6 e' ~/ r& H" k* X - #define AUDIO_BUFFER_IN SDRAM_DEVICE_ADDR /* In SDRAM */
G5 Z& w! A0 J1 G% L - #define AUDIO_BUFFER_OUT (SDRAM_DEVICE_ADDR + (AUDIO_BLOCK_SIZE * 2)) /* In SDRAM */ 1 M, ]/ D7 `" y$ I: f' L6 x
- __IO uint32_t audio_rec_buffer_state = BUFFER_OFFSET_NONE;
+ A# V# C1 Y4 p! }+ j7 j - static uint8_t SetSysClock_PLL_HSE_200MHz(); 8 }, _3 S4 G3 b, w* ~9 d" U! J
- int main() ^3 {3 R* n6 l: Z7 B+ Q8 i/ @
+ N! o6 q; T3 x, V% y$ B! [ - SetSysClock_PLL_HSE_200MHz();
/ T* [- J' X2 i: \/ D" Q - pc.baud(9600); ) C; `! K( w+ V
6 n; T) I! `) u - pc.printf("\n\nAUDIO LOOPBACK EXAMPLE START:\n");
. o* I5 v) j: l - led_red = 0; 0 H' o$ A0 b3 s" W. c8 C
9 K! p! G. D: [/ I& l - pc.printf("\nAUDIO RECORD INIT OK\n");
. C/ |" C! X' N$ Z d - pc.printf("Microphones sound streamed to headphones\n"); 2 s/ x- d$ Q2 [( ~: {- f2 t
- % W: F+ l! j% n! k4 r; i, d& N
- /* Initialize SDRAM buffers */
; W# Q1 b5 E; Y& ^ - memset((uint16_t*)AUDIO_BUFFER_IN, 0, AUDIO_BLOCK_SIZE*2); & [9 u0 f" F5 I, s7 G
- memset((uint16_t*)AUDIO_BUFFER_OUT, 0, AUDIO_BLOCK_SIZE*2); + q" K0 S3 w% |& W8 T% h+ B
- audio_rec_buffer_state = BUFFER_OFFSET_NONE;
) I# P! y' X, h. @6 r9 N - 9 x$ A; A- K+ V. ~
- /* Start Recording */
+ D' q- [" R0 K+ h. s z - audio.IN_Record((uint16_t*)AUDIO_BUFFER_IN, AUDIO_BLOCK_SIZE);
. N! l; g% p3 X! b! t5 F" z9 _ -
( n! V4 N8 H! z8 L6 ?- R$ m - /* Start Playback */ 0 D# x: J, ~! _* {
- audio.OUT_SetAudioFrameSlot(CODEC_AUDIOFRAME_SLOT_02);
/ g9 s4 G% j5 H7 s: O: l' r+ U - audio.OUT_Play((uint16_t*)AUDIO_BUFFER_OUT, AUDIO_BLOCK_SIZE * 2); + T& S+ M6 g4 u, A
/ w5 C# G- G, t; G( R - while (1) { $ ]2 ]1 j1 c& L' G8 i
- /* Wait end of half block recording */
6 I7 x( s2 K2 F; g! W" \ - while(audio_rec_buffer_state == BUFFER_OFFSET_HALF) {
/ ]- D8 z' X4 e) k! z - } 6 D* b, `6 ~2 g$ W; q
- audio_rec_buffer_state = BUFFER_OFFSET_NONE; % O V, I1 T* `2 b' b9 S1 u) ?
- /* Copy recorded 1st half block */ : ~4 p* g/ |, I; I- L8 s n
- memcpy((uint16_t *)(AUDIO_BUFFER_OUT), (uint16_t *)(AUDIO_BUFFER_IN), AUDIO_BLOCK_SIZE);
* P' A# J/ I4 h7 R - /* Wait end of one block recording */
7 C! w' g& q% r% ? - while(audio_rec_buffer_state == BUFFER_OFFSET_FULL) { * F: D' I) M. E6 p
- } " s3 x+ Z8 j% f" F
- audio_rec_buffer_state = BUFFER_OFFSET_NONE; 6 w, X ?, z5 K
- /* Copy recorded 2nd half block */ ! g1 _* G' C, Y% l& U3 S& a
- memcpy((uint16_t *)(AUDIO_BUFFER_OUT + (AUDIO_BLOCK_SIZE)), (uint16_t *)(AUDIO_BUFFER_IN 4 n' O' D7 k' P
- + (AUDIO_BLOCK_SIZE)), AUDIO_BLOCK_SIZE); / i3 u3 W" O' ^4 f9 d# W$ t! j& \
6 S+ j/ l1 G3 L5 u - } 3 {( a! N0 I ^2 j$ I
1 Y0 o( S5 a6 s- @ - Callbacks implementation: p4 _3 T6 u! M5 x9 h2 p# k. Z
- the callbacks API are defined __weak in the stm32746g_discovery_audio.c file
9 Z$ e- Z3 x& ^9 g - and their implementation should be done in the user code if they are needed.
* s& ^0 X- p2 E - Below some examples of callback implementations. 3 [7 P6 Y: s3 @/ ^6 n& g! F$ W
- -------------------------------------------------------------------------------------*/ ( [0 v# H+ `/ ~/ ] H
- /** : j* F& B" h3 G9 _" _$ Y% r
- * @brief Manages the DMA Transfer complete interrupt. - t8 q# A$ h$ P; W
- * @param None + C$ a" [5 u: c, j4 G
- * @retval None
$ |/ [; b, l! L. ~5 ]7 R - */ ) y( l+ Q" p+ x7 j
- void BSP_AUDIO_IN_TransferComplete_CallBack(void) 0 c3 N5 f/ G9 \. {
- { % M( G# o j7 s
- audio_rec_buffer_state = BUFFER_OFFSET_FULL;
9 {+ a- }0 d- [ I - return;
* w3 N2 ?0 B) L/ S% L# b C - } . Z: X8 d+ S; w4 P! m" z
! _/ ~8 J1 _) A6 L) N+ ^ - /**
; O5 F" r# b3 z+ t( L( b, [ - * @brief Manages the DMA Half Transfer complete interrupt. 5 D0 @% S, L4 y0 Y3 }* }) A0 X k
- * @param None ; g9 z; H) A4 {& I; H1 Y; K
- * @retval None
) t3 B1 Z* r3 ^' T" P q* e. W2 t - */ & g7 b# I1 K8 {* C5 e2 M
- void BSP_AUDIO_IN_HalfTransfer_CallBack(void) % O" ?# T9 F5 p2 G- t) j6 ?4 D
' ]- x6 t8 K; C9 @ - audio_rec_buffer_state = BUFFER_OFFSET_HALF; ' F; A- u) o/ |
- return;
/ k/ {8 x# e1 v3 `" w+ k R! Z8 S - }
% Y# p' V- b$ {' k7 f: t& w( ^+ p
复制代码 3 o, d: [' E7 g0 U% i0 ^ j7 J
程序分析:
% X+ A$ `& T0 \ [9 M4 m7 h, O- 首先定义缓冲区大小和音频输入输出缓冲区
% x- x) k" X l' [+ F( |; g7 ]+ X4 t8 z/ Z$ C& q; X: M" f. `
#define AUDIO_BLOCK_SIZE ((uint32_t)512)3 x: H8 g( E" N: ?
#define AUDIO_BUFFER_IN SDRAM_DEVICE_ADDR /* In SDRAM */ S t5 m F X+ d" s$ r; W& [
#define AUDIO_BUFFER_OUT (SDRAM_DEVICE_ADDR + (AUDIO_BLOCK_SIZE * 2)) /* In SDRAM */ - 然后进行初始化,初始化部分完成下面几个功能:5 Y+ y# ^% T' |1 i- @- r9 u
- 分配缓冲区" w ^0 z s& q5 R0 L
3 _$ Q0 V' e# e, Q# a2 ?; z memset((uint16_t*)AUDIO_BUFFER_IN, 0, AUDIO_BLOCK_SIZE*2);
5 N. H9 Q# t. u% }' J$ {0 T8 r; F memset((uint16_t*)AUDIO_BUFFER_OUT, 0, AUDIO_BLOCK_SIZE*2); - 启用录音功能,将音频输入保存到输入缓冲区3 K& X$ Z4 N3 j
4 _) S" E6 P4 T, ?' P5 A audio.IN_Record((uint16_t*)AUDIO_BUFFER_IN, AUDIO_BLOCK_SIZE); - 设置音频回放7 }# y* i3 [ W- e0 [
audio.OUT_SetAudioFrameSlot(CODEC_AUDIOFRAME_SLOT_02);2 m9 Q: P1 ~. p2 h
audio.OUT_Play((uint16_t*)AUDIO_BUFFER_OUT, AUDIO_BLOCK_SIZE * 2);7 T* G9 p6 A: ]$ \2 ]& D4 [4 s# A
- 在主循环中,等待音频输入完成,然后将输入缓冲区(AUDIO_BUFFER_IN)的数据复制到输出(AUDIO_BUFFER_OUT)缓冲区。音频输入的录音和回放,都是使用DMA方式自动完成的,所以无需CPU处理。
$ v4 N; M6 B' K" Z+ d1 F
0 L; r# f$ P3 s4 i" R完整参考程序:
/ k: o' H1 t7 A/ B2 \% M! @0 ~
DISCO-F746NG_AUDIO_demo_uvision_disco_f746ng.zip
(1.47 MB, 下载次数: 73)
这个例子主要是通过音频进行测试,不方便视频。有板子的网友试试就知道了,效果很棒。
不是的,那个芯片支持2w的喇叭,是软件里面设置了静音
需要有源音箱吧,不然带不动
