STM32F429驱动SDRAM时,SDRAM时钟脚没有信号
liudashuang 提问时间:2016-5-25 09:46 /
在用STM32F429驱动SDRAM时,初始化代码用cubeMX生成,代码如下:
DRAM_HandleTypeDef hsdram1;
/* FMC initialization function */
void MX_FMC_Init(void)
  FMC_SDRAM_TimingTypeDef SdramTiming;
  /** Perform the SDRAM1 memory initialization sequence
  hsdram1.Instance = FMC_SDRAM_DEVICE;
  /* hsdram1.Init */
  hsdram1.Init.SDBank = FMC_SDRAM_BANK1;
  hsdram1.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_9;
  hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_12;
  hsdram1.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16;
  hsdram1.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
  hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_3;
  hsdram1.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
  hsdram1.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2;
  hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_ENABLE;
  hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_1;
  /* SdramTiming */
  SdramTiming.LoadToActiveDelay = 2;
  SdramTiming.ExitSelfRefreshDelay = 7;
  SdramTiming.SelfRefreshTime = 4;
  SdramTiming.RowCycleDelay = 7;
  SdramTiming.WriteRecoveryTime = 2;
  SdramTiming.RPDelay = 2;
  SdramTiming.RCDDelay = 2;
  if(HAL_SDRAM_Init(&hsdram1, &SdramTiming) != HAL_OK)
    /* Initialization Error */
  #ifdef DEBUG
    printf("SDRAM Initialization Error\n");
  #endif
static int FMC_Initialized = 0;
static void HAL_FMC_MspInit(void){
  /* USER CODE BEGIN FMC_MspInit 0 */
  /* USER CODE END FMC_MspInit 0 */
  GPIO_InitTypeDef GPIO_InitStruct;
  if (FMC_Initialized) {
    return;
  FMC_Initialized = 1;
  /* Peripheral clock enable */
  __HAL_RCC_FMC_CLK_ENABLE();
  /** FMC GPIO Configuration
  PF0   ------> FMC_A0
  PF1   ------> FMC_A1
  PF2   ------> FMC_A2
  PF3   ------> FMC_A3
  PF4   ------> FMC_A4
  PF5   ------> FMC_A5
  PC0   ------> FMC_SDNWE
  PC2   ------> FMC_SDNE0
  PC3   ------> FMC_SDCKE0
  PF11   ------> FMC_SDNRAS
  PF12   ------> FMC_A6
  PF13   ------> FMC_A7
  PF14   ------> FMC_A8
  PF15   ------> FMC_A9
  PG0   ------> FMC_A10
  PG1   ------> FMC_A11
  PE7   ------> FMC_D4
  PE8   ------> FMC_D5
  PE9   ------> FMC_D6
  PE10   ------> FMC_D7
  PE11   ------> FMC_D8
  PE12   ------> FMC_D9
  PE13   ------> FMC_D10
  PE14   ------> FMC_D11
  PE15   ------> FMC_D12
  PD8   ------> FMC_D13
  PD9   ------> FMC_D14
  PD10   ------> FMC_D15
  PD14   ------> FMC_D0
  PD15   ------> FMC_D1
  PG4   ------> FMC_BA0
  PG5   ------> FMC_BA1
  PG8   ------> FMC_SDCLK
  PD0   ------> FMC_D2
  PD1   ------> FMC_D3
  PG15   ------> FMC_SDNCAS
  PE0   ------> FMC_NBL0
  PE1   ------> FMC_NBL1
  /* GPIO_InitStruct */
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_11|GPIO_PIN_12
                          |GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.Alternate = GPIO_AF12_FMC;
  HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_2|GPIO_PIN_3;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5
                          |GPIO_PIN_8|GPIO_PIN_15;
  HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10
                          |GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14
                          |GPIO_PIN_15|GPIO_PIN_0|GPIO_PIN_1;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_14
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /* USER CODE BEGIN FMC_MspInit 1 */
  /* USER CODE END FMC_MspInit 1 */
void HAL_SDRAM_MspInit(SDRAM_HandleTypeDef* hsdram){
  /* USER CODE BEGIN SDRAM_MspInit 0 */
  /* USER CODE END SDRAM_MspInit 0 */
  HAL_FMC_MspInit();
  /* USER CODE BEGIN SDRAM_MspInit 1 */
  /* USER CODE END SDRAM_MspInit 1 */
static int FMC_DeInitialized = 0;
static void HAL_FMC_MspDeInit(void){
  /* USER CODE BEGIN FMC_MspDeInit 0 */
  /* USER CODE END FMC_MspDeInit 0 */
  if (FMC_DeInitialized) {
    return;
  FMC_DeInitialized = 1;
  __HAL_RCC_FMC_CLK_DISABLE();
  PF0   ------> FMC_A0
  PF1   ------> FMC_A1
  PF2   ------> FMC_A2
  PF3   ------> FMC_A3
  PF4   ------> FMC_A4
  PF5   ------> FMC_A5
  PF12   ------> FMC_A6
  PF13   ------> FMC_A7
  PF14   ------> FMC_A8
  PF15   ------> FMC_A9
  PG0   ------> FMC_A10
  PG1   ------> FMC_A11
  PE7   ------> FMC_D4
  PE8   ------> FMC_D5
  PE9   ------> FMC_D6
  PE10   ------> FMC_D7
  PE11   ------> FMC_D8
  PE12   ------> FMC_D9
  PD8   ------> FMC_D13
  PD9   ------> FMC_D14
  PD14   ------> FMC_D0
  PD15   ------> FMC_D1
  PG4   ------> FMC_BA0
  PG5   ------> FMC_BA1
  PD0   ------> FMC_D2
  PD1   ------> FMC_D3
  HAL_GPIO_DeInit(GPIOF, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15);
  HAL_GPIO_DeInit(GPIOC, GPIO_PIN_0|GPIO_PIN_2|GPIO_PIN_3);
  HAL_GPIO_DeInit(GPIOG, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5
                          |GPIO_PIN_8|GPIO_PIN_15);
  HAL_GPIO_DeInit(GPIOE, GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10
                          |GPIO_PIN_15|GPIO_PIN_0|GPIO_PIN_1);
  HAL_GPIO_DeInit(GPIOD, GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_14
  /* USER CODE BEGIN FMC_MspDeInit 1 */
  /* USER CODE END FMC_MspDeInit 1 */
void HAL_SDRAM_MspDeInit(SDRAM_HandleTypeDef* hsdram){
  /* USER CODE BEGIN SDRAM_MspDeInit 0 */
  /* USER CODE END SDRAM_MspDeInit 0 */
  HAL_FMC_MspDeInit();
  /* USER CODE BEGIN SDRAM_MspDeInit 1 */
  /* USER CODE END SDRAM_MspDeInit 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
配置代码如下:
static void SDRAM_Initialization_Sequence(SDRAM_HandleTypeDef *hsdram, FMC_SDRAM_CommandTypeDef *Command)
  __IO uint32_t tmpmrd =0;
  /* Step 3:  Configure a clock configuration enable command */
  /* ʱÖÓÅäÖÃʹÄÜ,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè3 */
  Command->CommandMode     = FMC_SDRAM_CMD_CLK_ENABLE;
  Command->CommandTarget    = FMC_SDRAM_CMD_TARGET_BANK1;
  Command->AutoRefreshNumber   = 1;
  Command->ModeRegisterDefinition = 0;
  /* Send the command */
  HAL_SDRAM_SendCommand(hsdram,Command, 0x1000);
  /* Step 4: Insert 100 ms delay */
  /* µÈ´ýÖ¸¶¨ÑÓ³ÙÖÜÆÚ,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè4 */
  HAL_Delay(100);
  /* Step 5: Configure a PALL (precharge all) command */
  /* PALL£¨¡°Ô¤³äµçËùÓÐ´æ´¢ÇøÓò¡±£©ÃüÁî,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè5 */
  Command->CommandMode     = FMC_SDRAM_CMD_PALL;
  /* Step 6 : Configure a Auto-Refresh command */
  /* ×ÔË¢ÐÂÃüÁî,8¸ö×ÔË¢ÐÂÖÜÆÚ,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè6 */
  Command->CommandMode     = FMC_SDRAM_CMD_AUTOREFRESH_MODE;
  Command->AutoRefreshNumber   = 9;
  /* Step 7: Program the external memory mode register */
   /* ÅäÖÃSDRAMģʽ¼Ä´æÆ÷,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè7 */
  /* Í»·¢³¤¶È£º1
     Í»·¢´«Ê䷽ʽ£ºË³Ðò
     CASDZ·üÆÚ£º2
     ²Ù×÷ģʽ£º±ê×¼
     ²Ù×÷ģʽ£ºÍ»·¢¶Á/µ¥Ò»Ð´
  tmpmrd = (uint32_t)SDRAM_MODEREG_BURST_LENGTH_1          |
                     SDRAM_MODEREG_BURST_TYPE_SEQUENTIAL   |
                     SDRAM_MODEREG_CAS_LATENCY_2          |
                     SDRAM_MODEREG_OPERATING_MODE_STANDARD |
                     SDRAM_MODEREG_WRITEBURST_MODE_SINGLE;
  Command->CommandMode = FMC_SDRAM_CMD_LOAD_MODE;
  Command->ModeRegisterDefinition = tmpmrd;
  /* Step 8: Set the refresh rate counter */
  /* Ë¢ÐÂÂÊÉèÖÃ,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè8 */
  /* (15.62 us x Freq) - 20 */
  /* Set the device refresh counter */
  HAL_SDRAM_ProgramRefreshRate(hsdram, REFRESH_COUNT);
硬件部分已经检查了很多遍,没有连接错误,没有假焊/短路,但是SDRAM就是读写错误,用示波器测试一下,发现SDCLK没有信号输出.测量没有发现短路和开路.把SDRAM更换了也一样.请各位高手帮忙看看是否代码有问题,谢谢!!!!!!!
赞 收藏 1 评论5 发布时间:2016-5-25 09:46
5个回答
废鱼 回答时间:2016-5-25 14:36:55
看一下硬件上的资源选择是否正确,我测试407的。用的NE3操作SRAM是没有问题的。
xmshao 回答时间:2016-5-26 10:19:43
你确认SDRAM时钟使能了。
看你代码里有 __HAL_RCC_FMC_CLK_ENABLE(); 和 __HAL_RCC_FMC_CLK_DISABLE(); 你确认下到底最后哪个在起作用。
人之颠 回答时间:2016-5-26 11:17:25
应该是你FMC时钟没开启
liudashuang 回答时间:2016-5-26 15:43:50
确认FMC的时钟已经使能,在DEBUG下查看相关控制寄存器的数值都是对的,其它数据线/地址线引脚上都有信号输出,就是SDCLK和SDCKE上没有输出信号,SDRAM和STM32F429的芯片都更换过了,结果还是一样
叶孤城 回答时间:2016-9-25 11:35:33
我也遇到同样问题,读写的时候,地址,数据都有波形,clk,nwe等等都是没有信号,没有找到原因
我是用stm32cube 生成的代码,不知道哪里出错
static void MX_FMC_Init(void)
  /* hsdram1.Init */
  hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_13;
  hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_2;
  hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_DISABLE;
  hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_0;
  /* SdramTiming */
  SdramTiming.LoadToActiveDelay = 3;
  SdramTiming.ExitSelfRefreshDelay = 12;
  SdramTiming.SelfRefreshTime = 3;
  SdramTiming.RowCycleDelay = 8;
  SdramTiming.RPDelay = 3;
  SdramTiming.RCDDelay = 3;
  if (HAL_SDRAM_Init(&hsdram1, &SdramTiming) != HAL_OK)
    Error_Handler();
