各位大神好 如题,STM32F105,DMA方式采集ADC数据,其中两路,IO口电压一样,但采集数据不一样。数据相差较大,且差值不固定。 请大神指导。 void SysInit_ADC(void) { ADC_InitTypeDef ADC_InitStructure; RCC_ADCCLKConfig(RCC_PCLK2_Div2); /* Enable ADC1*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); ADC_DeInit(ADC1); /* Initialize the ADCx according to the ADC_InitStructure members */ ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 7; ADC_Init(ADC1,&ADC_InitStructure); ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_41Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_41Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_41Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_41Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_41Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 6, ADC_SampleTime_41Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 7, ADC_SampleTime_41Cycles5); /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); /* Enable ADC1 */ ADC_Cmd(ADC1,ENABLE); /* Enable ADC1 reset calibration register */ ADC_ResetCalibration(ADC1); /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); /* Start ADC1 calibration */ ADC_StartCalibration(ADC1); /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); ADC_SoftwareStartConvCmd(ADC1, ENABLE); } void SysInit_DMA(void) { DMA_InitTypeDef DMA_InitStructure; /* Enable DMA1 clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); /* DMA1 channel1 configuration ----------------------------------------------*/ DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADCConvertedValue; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = 7; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); /* Enable DMA1 channel1 */ DMA_Cmd(DMA1_Channel1, ENABLE); } //****************************************************************************************** //AD采集 //每10MS调用 //****************************************************************************************** void ADC_Scan(void) { Filter_Buf00[Filter_Pointer] = (u16)(ADCConvertedValue[0]>>2); Filter_Buf01[Filter_Pointer] = (u16)(ADCConvertedValue[1]>>2); Filter_Buf02[Filter_Pointer] = (u16)(ADCConvertedValue[2]>>2); Filter_Buf03[Filter_Pointer] = (u16)(ADCConvertedValue[3]>>2); Filter_Buf05[Filter_Pointer] = (u16)(ADCConvertedValue[4]>>2); Filter_Buf04[Filter_Pointer] = (u16)(ADCConvertedValue[5]>>2); Filter_Buf06[Filter_Pointer] = (u16)(ADCConvertedValue[6]>>2); Filter_Pointer++; if(Filter_Pointer >= 10) //去极值求平均 Filter_Remove_Extremum { Filter_Pointer = 0; Aircondition.S_InTemp = Avr_Filter(Filter_Buf0,Filter_Remove_Extremum(Filter_Buf00)); // Aircondition.S_OutTemp = Avr_Filter(Filter_Buf1,Filter_Remove_Extremum(Filter_Buf01)); Aircondition.S_Def0Temp = Avr_Filter(Filter_Buf2,Filter_Remove_Extremum(Filter_Buf02)); // Aircondition.S_LNTemp = Avr_Filter(Filter_Buf3,Filter_Remove_Extremum(Filter_Buf03)); Aircondition.S_VOL = Avr_Filter(Filter_Buf4,Filter_Remove_Extremum(Filter_Buf04)); // Aircondition.S_PTC1Temp = Avr_Filter(Filter_Buf5,Filter_Remove_Extremum(Filter_Buf05)); // Aircondition.S_PTC2Temp = Avr_Filter(Filter_Buf6,Filter_Remove_Extremum(Filter_Buf06)); // ADC_AnalogToDigtal(); } } |
pwm关闭输出
VL53L5CX无法使用
请教STM32F103的DMA空闲接收问题
3.3v单片机能刷写1.8v的spi flash吗?
STM32CubeMX配置STM32F103C8T6 RTC分频器问题
STM32F103RCT6断电以后,ADC会漏电
STM32F103VCT6通过串口1烧录程序问题
F103的IIC支持高速400K频率吗?
为什么用cubemax生成f103c8t6的freertos在编译时会报错
CUBEIDE打开一个工程,怎么改变主控芯片的同系列型号?
板子换过,电位器也换过,都有这个问题。引脚电压一样,应该是软件问题。但是ADC采集数据的程序都一样的,所以有点困惑
