STM32F103 SPI时钟初始化后与理论值不一致
wh2104 提问时间:2016-8-6 19:24 /
大家好,我是新手,最近在研究stm32f103c8t6的spi功能,我自己编程写了一段从rcc开始一直到spi初始化的程序。由于设备有限,我用示波器测量了spi sck管脚的输出波形,的确是时钟信号,但是频率和我rcc设置的有出入,底了很多,上网找了一下原因没有一个合适的。所以请问一下我的程序到底哪里出错了,谢谢。
  1. <div class="blockcode"><blockquote> RCC_DeInit();
  2.         RCC_HSEConfig(RCC_HSE_ON);
  3.         Errsts = RCC_WaitForHSEStartUp();
  4.         if (Errsts == SUCCESS)
  5.         {
  6.                 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
  7.                 RCC_PLLConfig(RCC_PLLSource_HSE_Div2, RCC_PLLMul_9);
  8.                 RCC_PLLCmd(ENABLE);
  9.                 while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY == RESET))
  10.                 {
  11.                 }
  12.                 FLASH_SetLatency(FLASH_Latency_1);
  13.                 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  14.                 RCC_HCLKConfig(RCC_SYSCLK_Div1);
  15.                 RCC_PCLK1Config(RCC_HCLK_Div2);
  16.                 RCC_PCLK2Config(RCC_HCLK_Div1);
  17.                 while (RCC_GetSYSCLKSource() != 0x08)
  18.                 {
  19.                 }
  20.         }
上面是rcc的初始设置,我用的hse作为芯片的时钟信号,根据上面的code可以算出apb2(pclk2)的时钟信号是36mhz,所以我的spi也应该是36mhz。
下面是我的spi初始化设置:
  1. <div class="blockcode"><blockquote>{
  2.         SPI_InitTypeDef SPI_InitStructure;
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.
  5.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  6.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  7.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  8.
  9.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5| GPIO_Pin_6| GPIO_Pin_7;
  10.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  11.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  12.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  13.
  14.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  15.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  16.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  17.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  18.
  19.         GPIO_WriteBit(GPIOA, GPIO_Pin_4,Bit_SET);
  20.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  21.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  22.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  23.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  24.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  25.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  26.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  27.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  28.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  29.         SPI_Init(SPI1, &SPI_InitStructure);
  30.         /* Enable SPI2 */
  31.         SPI_Cmd(SPI1, ENABLE);
  32. }
这里SPI_BaudRatePrescaler_4将spi 时钟信号分频了4,理论上spi现在应该是36mhz/4=9mhz。但是我用示波器观测sck管脚,只有200khz左右,而且我不断改变SPI_BaudRatePrescaler的值,发现结果也不是线性的,很奇怪。所以想问一下这个到底是什么原因。
提前谢谢大家。
收藏 评论1 发布时间:2016-8-6 19:24
宏沉一笑 回答时间:2016-8-6 23:14:03
支持一下!
