STM32F205 的HS USB 做device使用是否要接PHY?
lqh-414236 提问时间:2016-9-29 11:33 /
赞 收藏 1 评论19 发布时间:2016-9-29 11:33
19个回答
lqh-414236 回答时间:2016-10-9 10:06:30
我用做全速,不做高速,使用了内部的PHY,竟然无法枚举?
使用demo修改的,在USB 的D+上加了一个上拉,  使用官方的HID demo修改,FS USB 接口可以识别,为啥HS接口无法识别,调试发现USB会发生复位中断,后面就没有任何中断了!代码如下:
  hpcd.Instance = USB_OTG_HS;
  hpcd.Init.dev_endpoints = 4;
  hpcd.Init.use_dedicated_ep1 = 0;
  hpcd.Init.ep0_mps = 0x40;
  /* Be aware that enabling DMA mode will result in data being sent only by
     multiple of 4 packet sizes. This is due to the fact that USB DMA does
     not allow sending data from non word-aligned addresses.
     For this specific application, it is advised to not enable this option
     unless required. */
  hpcd.Init.dma_enable = 0;
  hpcd.Init.low_power_enable = 0;
  //use inter phy!! 使用内部PHY
  hpcd.Init.phy_itface = PCD_PHY_EMBEDDED;
  hpcd.Init.Sof_enable = 0;
  hpcd.Init.speed = PCD_SPEED_FULL;
  hpcd.Init.vbus_sensing_enable = 0;
  /* Link The driver to the stack */
  hpcd.pData = pdev;
  pdev->pData = &hpcd;
  /* Initialize LL Driver */
  HAL_PCD_Init(&hpcd);
  HAL_PCDEx_SetRxFiFo(&hpcd, 0x80);
  HAL_PCDEx_SetTxFiFo(&hpcd, 0, 0x40);
  HAL_PCDEx_SetTxFiFo(&hpcd, 1, 0x80);
IO设置:
    /* Configure USB H GPIOs */
    __HAL_RCC_GPIOB_CLK_ENABLE();
         /* Configure DM DP Pins */
    GPIO_InitStruct.Pin = (GPIO_PIN_14 | GPIO_PIN_15);
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF10_OTG_HS;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    /* Enable USB HS Clocks */
        __HAL_RCC_USB_OTG_HS_CLK_ENABLE();
    //__HAL_RCC_USB_OTG_HS_ULPI_CLK_ENABLE();
    /* Set USBHS Interrupt priority */
    HAL_NVIC_SetPriority(OTG_HS_IRQn, 5, 0);
    /* Enable USBHS Interrupt */
    HAL_NVIC_EnableIRQ(OTG_HS_IRQn);
    if(hpcd->Init.low_power_enable == 1)
      /* Enable EXTI Line 20 for USB wakeup*/
      __HAL_USB_OTG_HS_WAKEUP_EXTI_CLEAR_FLAG();
      __HAL_USB_OTG_HS_WAKEUP_EXTI_ENABLE_RISING_EDGE();
      __HAL_USB_OTG_HS_WAKEUP_EXTI_ENABLE_IT();
      /* Set EXTI Wakeup Interrupt priority*/
      HAL_NVIC_SetPriority(OTG_HS_WKUP_IRQn, 0, 0);
      /* Enable EXTI Interrupt */
      HAL_NVIC_EnableIRQ(OTG_HS_WKUP_IRQn);
其他的配置和FS一样的了。难道HS配置还有什么特别要注意的地方?
Lof 回答时间:2017-2-25 20:12:16
lqh-414236 发表于 2016-12-1 09:33
全部搞定哈哈!!!还是得靠自己!双USB同时做设备!
你好!
    双USB做device时,有碰到过HS USB有的电脑无法识别的问题吗?我也和你是一样的使用方案,都可以做device,但是最近发现两种现象:
    1,HS 插入XP 32bit 和WIN7 32bit 提示无法识别USB设备,换到FS USB接口可以正常识别,装好驱动后,换回HS端,就可以正常识别了:    2,HS 插入WIN7 64bit 电脑提示无法识别USB设备,换到FS USB接口可以正常识别,装好驱动后,换回HS端,也无法识别:
    3,HS 插入WIN10 64bit 电脑可以直接识别,都没看到装驱动的过程。
    请问,有没有碰到过类似的问题,可以给些建议吗?谢谢!
cloudcn 回答时间:2016-9-29 11:59:55
如果速度要求高就要PHY 内置的只能到12M
参与人数 1ST金币 +2 收起 理由
stary666 回答时间:2016-9-29 12:06:58
肯定要加的,,,,,,,,
lqh-414236 回答时间:2016-9-29 13:59:47
我用来做 USB keyboard 设备应该不用加的吧?为什么我调试,USB竟然不中断,中断没有任何反应,FS用作keyboard都没问题!奇怪!!!!
xmshao 回答时间:2016-9-29 17:26:17
关键是工作在HS模式还是FS模式。
如果工作在HS模式就必须外加PHY, FS模式就可以用内置的PHY.
参与人数 1ST金币 +2 收起 理由
mark0668 回答时间:2016-9-29 17:35:26
用内置的全速12M 不需要外接PHY,,,如果想用高速USB就必须要外置芯PHY了,因为内置的没有高速,只有全速低速
nongxiaoming 回答时间:2016-9-29 21:52:24
不需要~~~
lqh-414236 回答时间:2016-10-9 14:47:32
实在无法理解下面的宏定义:
#define USBx_INEP(i)    ((USB_OTG_INEndpointTypeDef *)((uint32_t)USBx + USB_OTG_IN_ENDPOINT_BASE + (i)*USB_OTG_EP_REG_SIZE))
#define USBx_OUTEP(i)   ((USB_OTG_OUTEndpointTypeDef *)((uint32_t)USBx + USB_OTG_OUT_ENDPOINT_BASE + (i)*USB_OTG_EP_REG_SIZE))
USBx都没定义怎么就编译通过了呢?想不通?
lqh-414236 回答时间:2016-10-10 15:34:55
这些宏,用之前必须定义USBx这变量!!!
STM23F2xx官方demo有问题,经修改后,使用fs做键盘已经成功,还差HS!暂时还没调通。
lqh-414236 回答时间:2016-10-11 14:53:27
如果使用HS USB做device,使用内部PHY,(全速USB 外设)。原理图是怎么样连接的?是不是直接连接DP和DM到USB口,DP接上拉电阻就行了?
zero99 回答时间:2016-10-12 17:31:11
楼主下次请按【求助】发帖,谢谢~
zbber 回答时间:2016-10-12 19:10:08
肯定要加的,,,,,,,,
lqh-414236 回答时间:2016-12-1 09:33:42
lqh-414236 回答时间:2016-12-5 17:06:46
全部已经完成!!!
12下一页
