请教一个关于STM32F407脉宽测量问题
longfei_3 提问时间:2016-11-14 17:41 /
我打算用TIM9测量波形的脉宽长度,但是读取的置始终为0,请各位大牛帮我看看原因:
初始化:
void TIM9Capture1Init()
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_ICInitTypeDef TIM_ICInitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM9,ENABLE);  //ENABLE TIM9 of RCC
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE); //enable GPIOE of RCC
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
    GPIO_Init(GPIOE,&GPIO_InitStructure);
    GPIO_PinAFConfig(GPIOE,GPIO_PinSource5,GPIO_AF_TIM9);
    TIM_TimeBaseStructure.TIM_Prescaler=0xFFFF;
    TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
    TIM_TimeBaseStructure.TIM_Period=20;//4Mh
    TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
    TIM_TimeBaseInit(TIM9,&TIM_TimeBaseStructure);
    TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
    TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_BothEdge;
    TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
    TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
    TIM_ICInitStructure.TIM_ICFilter = 0x0;
    TIM_ICInit(TIM9, &TIM_ICInitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = TIM1_BRK_TIM9_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    TIM_ITConfig(TIM9,TIM_IT_Update|TIM_IT_CC1,ENABLE);
    TIM_Cmd(TIM9,ENABLE);
    TIM_SetCounter(TIM9,0);
中断服务函数:
void TIM1_BRK_TIM9_IRQHandler(void)
static uint8_t test=0;
    uint8_t tdat;
    if(TIM_GetITStatus(TIM9, TIM_IT_Update) != RESET)//超时处理
          TIM_ClearITPendingBit(TIM9,TIM_IT_Update);
    if(TIM_GetITStatus(TIM9, TIM_IT_CC1) != RESET)
            if(test%2==0) IO0_SET();//IO口翻转测试,该处波形与输入波形一致,周期约24us
            else IO0_CLR();
            test++;
        tdat=TIM_GetCapture1(TIM9);
        my.buf[my.wpos++] = tdat;
        TIM_SetCounter(TIM9,0); //重新计算超时
        TIM_ClearITPendingBit(TIM9, TIM_IT_CC1);
赞 收藏 1 评论6 发布时间:2016-11-14 17:41
6个回答
wenyangzeng 回答时间:2016-11-15 09:40:24
longfei_3 发表于 2016-11-15 08:58
OCx不是输出控制吗?我这是输入捕获啊
捕捉应该用到的,官方例程很多,可以参考。
InputCapture.rar
12.46 KB, 下载次数: 16, 下载积分: ST金币 -1
参与人数 1ST金币 +2 收起 理由
weigr 回答时间:2016-11-14 19:51:24
期待高手解答……
wenyangzeng 回答时间:2016-11-14 20:03:59
楼主你貌似未对IM_OCx进行初始化配置。
参与人数 1ST金币 +2 收起 理由
longfei_3 回答时间:2016-11-15 08:58:36
OCx不是输出控制吗?我这是输入捕获啊
longfei_3 回答时间:2016-11-15 10:15:38
谢谢,但是我用的TIM9还是一样,捕获的全是0
mydy 回答时间:2017-6-28 14:30:07
有没有完整正确代码,分享,学习下,谢谢!
