关于STM32F746使用LwIP_TCP_Echo_Client进行tcp/ip 客户端开发的问题
xiaoxiao0932 提问时间:2017-5-1 19:53 /
最近在使用STM32F746做网络开发,移植LwIP_TCP_Echo_Client客户端的程序,电脑端使用TCP/IP调试助手建立服务器,客户端板子上电初始化配置后,在调试助手能够看到客户端已经连上服务器,并收到字符串sending11111 tcp client message 0,但是在主函数中调用 tcp_echoclient_send函数,电脑端的调试助手收不到发送的数据,这中间出现了什么问题啊?还请搞过的朋友们指点啊,先谢谢了啊!~~~~~~~~客户端配置程序如下:
void tcp_echoclient_connect(void)
  struct ip_addr DestIPaddr;
  /* create new tcp pcb */
  echoclient_pcb = tcp_new();
  if (echoclient_pcb != NULL)
    IP4_ADDR( &DestIPaddr, DEST_IP_ADDR0, DEST_IP_ADDR1, DEST_IP_ADDR2, DEST_IP_ADDR3 );
    /* connect to destination address/port */
    tcp_connect(echoclient_pcb,&DestIPaddr,DEST_PORT,tcp_echoclient_connected);
  else
    /* deallocate the pcb */
    memp_free(MEMP_TCP_PCB, echoclient_pcb);
#ifdef SERIAL_DEBUG
    printf("\n\r can not create tcp pcb");
#endif
static err_t tcp_echoclient_connected(void *arg, struct tcp_pcb *tpcb, err_t err)
  struct echoclient *es = NULL;
  if (err == ERR_OK)
    /* allocate structure es to maintain tcp connection informations */
    es = (struct echoclient *)mem_malloc(sizeof(struct echoclient));
    if (es != NULL)
      es->state = ES_CONNECTED;
      es->pcb = tpcb;
      sprintf((char*)data, "sending11111 tcp client message %d", (int)message_count);
      /* allocate pbuf */
      es->p_tx = pbuf_alloc(PBUF_TRANSPORT, strlen((char*)data) , PBUF_POOL);
      if (es->p_tx)
        /* copy data to pbuf */
        pbuf_take(es->p_tx, (char*)data, strlen((char*)data));
        /* pass newly allocated es structure as argument to tpcb */
        tcp_arg(tpcb, es);
        /* initialize LwIP tcp_recv callback function */
        tcp_recv(tpcb, tcp_echoclient_recv);
        /* initialize LwIP tcp_sent callback function */
        tcp_sent(tpcb, tcp_echoclient_sent);
        /* initialize LwIP tcp_poll callback function */
        tcp_poll(tpcb, tcp_echoclient_poll, 1);
        /* send data */
        tcp_echoclient_send(tpcb,es);
        return ERR_OK;
    else
      /* close connection */
      tcp_echoclient_connection_close(tpcb, es);
      /* return memory allocation error */
      return ERR_MEM;
  else
  return err;
赞 收藏 2 评论6 发布时间:2017-5-1 19:53
6个回答
xiaoxiao0932 回答时间:2017-5-2 09:58:51
顶一下,大家怎么使用lWIP的TCP客户端啊?
xiaoxiao0932 回答时间:2017-5-3 09:03:51
大家有用F746作为客户端开发的吗?
jcx0324 回答时间:2017-8-4 09:38:01
可以跟踪看下当前的状态,例程估计客户端自动关闭的
参与人数 1ST金币 +2 收起 理由
tgwfcc 回答时间:2017-8-4 10:57:36
搞过F107的,也仅仅是调通了,收不到,一定是哪里不对,帮顶!
gujiamao 回答时间:2017-8-4 11:03:33
帮顶!!
无薪税绵 回答时间:2017-8-4 12:37:47
估计是回应的IP和MAC不对。
建议使用网络抓包工具,看看发出的数据哪错了。
参与人数 1ST金币 +2 收起 理由
