有哪位 可以发一份 RTC唤醒的 STOP模式的 代码给我吗?我调试的代码始终有问题,唤醒后 串口打印是始终有问题;/*************************************************************/ void RTC_Config(void) { /* Enable the PWR clock */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE); /* Allow access to RTC */ PWR_BackupAccessCmd(ENABLE); RCC_LSICmd( ENABLE); //Æô¶¯LSI while (RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET) { } /* Wait till LSi is ready */ /* Select the RTC Clock Source */ RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);//Ñ¡ÔñLSI×÷ΪRTCʱÖÓÔ´ /* Enable the RTC Clock */ RCC_RTCCLKCmd(ENABLE);//Æô¶¯RTC RTC_WakeUpCmd(DISABLE); //¹Ø±ÕRTC »½ÐѶ¨Ê±Æ÷!!! /* µÈ´ýRTC¼Ä´æÆ÷ͬ²½ µÈ´ýдRTC¼Ä´æÆ÷Íê³É */ RTC_WaitForSynchro(); RTC_WakeUpClockConfig(RTC_WakeUpClock_RTCCLK_Div16);//»½ÐѶ¨Ê±Æ÷ʱÖÓ RTC_SetWakeUpCounter( 0x9c4); //¸øRTC WAKE UP TIMER¸³ÖØ×°Öµ RTC_WakeUpCmd( ENABLE); //Æô¶¯RTC »½ÐѶ¨Ê±Æ÷ } /********RTC wake up interrupt NVIC ********/ void WKUP_NVIC_Config(void) { EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* Configure EXTI line 20 (connected to the RTC wakeup event) */ EXTI_ClearITPendingBit(EXTI_Line20); EXTI_InitStructure.EXTI_Line = EXTI_Line20; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); /* NVIC configuration */ NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn; NVIC_InitStructure.NVIC_IRQChannelPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); /* Enable peirodic wakeup interrupt */ RTC_ITConfig(RTC_IT_WUT, ENABLE); // /* Clear the wakeup Pending Bit */ RTC_ClearITPendingBit(RTC_IT_WUT); } /****** RTC periodic wake up interrupt service routine*******/ void RTC_IRQHandler(void) { //printf("R "); if (RTC_GetITStatus(RTC_IT_WUT) != RESET) { /* Clear RTC wake up interrupt pending bit */ RTC_ClearITPendingBit(RTC_IT_WUT); /* Clear EXTI line20 pending bit */ EXTI_ClearITPendingBit(EXTI_Line20); } if (PWR_GetFlagStatus(PWR_FLAG_WU) != RESET) { PWR_ClearFlag(PWR_FLAG_WU); } } /** * @brief Main program * @param None * @retval None */ int main(void) { u32 cnt=0; u32 i=0; USART_Config(); for(i=0;i<10;i++) { printf("\r\n OS Æô¶¯ ¿ªÊ¼ \r\n"); delay_ms(500); } printf("\r\n ¿ªÊ¼ÅäÖà \r\n"); RTC_Config(); /* RTC Configuration */ WKUP_NVIC_Config(); /* EXTI LINE 20 CONFIG */ printf("\r\n RTC STOP ģʽ ÅäÖÃÍê³É \r\n"); while(1) { PWR_EnterSTOPMode(PWR_Regulator_LowPower, PWR_STOPEntry_WFI); SystemInit(); printf("d "); } for(;;); } |
谁能解释一下STM32F0的RTC_IRQHandler中断中EXTI_Line17的作用?
【STM32F0开发日志/评测/笔记】+互补PWM波的产生
STM32F030 PB14和PB15无法输出PWM求助
【STM32F030探索套件】序列之五 外部中断
【STM32F0开发日志---二】+ucosii.2.92移植在STM32F030
上传个STM32F0+5110+内部温度传感器的菜鸟实例
【STM32F030探索套件使用问题】STM32F030 SPI方式驱动ST7565LCD失败
求一份STM32F051 I2C驱动LCD 12864的例程
STM32F0 M0 向结构体赋值进入HardFault异常
STM32F0 ADC-DMA方式采集2路数据时出现问题
你好,感谢回复! 唤醒后我是重新配置了时钟的,但是串口我觉得不应该再次配置了,对应的寄存器都是内容保存的; 最后的我也没有找见问题具体出在哪里! 解决方案是:采用 CUBE软件自动生成的代码,然后按照一样的方法 添加 低功耗代码,然后就可以了,估计是 FREERTOS哪里有移植问题导致的吧
