STM8L151 ADC 采用DMA 8通道连续采集,通过ST_LINK仿真发现:通道数据滚动问题,比如第一通道的数据本应该在数组0通道,一会儿整组偏移到数组3通道,一会又偏移到4通道,而且是所有数据同时偏移。网上搜了一下,有很多人遇到过,但是都不说解决方法。折腾了一天无解,只能在这里求救了。ADC初始化程序如下: void ADC_DMA_Config(void) //ADC初始化,ADC连续转换模式 { // Enable ADC clock CLK_PeripheralClockConfig(CLK_Peripheral_ADC1, ENABLE); //开启ADC时钟 CLK_PeripheralClockConfig(CLK_Peripheral_DMA1, ENABLE); //DMA时钟 DMA_DeInit(DMA1_Channel0); //初始化DMA为默认值 ADC_DeInit(ADC1); //初始化ADC为默认值 ADC_Init(ADC1, ADC_ConversionMode_Continuous,ADC_Resolution_12Bit, ADC_Prescaler_1);//初始化ADC1为,连续转换模式,12位AD转换,ADC时钟预分频为1 ADC_SamplingTimeConfig(ADC1, ADC_Group_SlowChannels,ADC_SamplingTime_192Cycles);//配置ADC为慢速通道,采样时间周期为192 //ADC_SamplingTimeConfig(ADC1, ADC_Group_FastChannels,ADC_SamplingTime_24Cycles);//配置ADC为,快速通道,采样时间周期为9 ADC_Cmd(ADC1, ENABLE); //启用ADC //ADC_ChannelCmd(ADC1, ADC_Channel_Vrefint, ENABLE); //内部参考电压 ADC_ChannelCmd(ADC1, ADC_Channel_15, ENABLE); //ADC通道15使能 Vbat 总电池电压 ADC_ChannelCmd(ADC1, ADC_Channel_16, ENABLE); //ADC通道16使能 TS5 MOS温度检测 ADC_ChannelCmd(ADC1, ADC_Channel_17, ENABLE); //ADC通道17使能 TS4 电池温度检测4 ADC_ChannelCmd(ADC1, ADC_Channel_18, ENABLE); //ADC通道18使能 TS3 电池温度检测3 ADC_ChannelCmd(ADC1, ADC_Channel_19, ENABLE); //ADC通道19使能 TS2 电池温度检测2 ADC_ChannelCmd(ADC1, ADC_Channel_20, ENABLE); //ADC通道20使能 TS1 电池温度检测1 ADC_ChannelCmd(ADC1, ADC_Channel_21, ENABLE); //ADC通道21使能 Ic 充电电流检测 ADC_ChannelCmd(ADC1, ADC_Channel_22, ENABLE); //ADC通道22使能 Id 放电电流检测 SYSCFG_REMAPDMAChannelConfig(REMAP_DMA1Channel_ADC1ToChannel0); //重新映射DMA通道的具体外围(ADC或TIM4) DMA_Init(DMA1_Channel0, //通道0 (uint32_t)&ADC_Value, //缓冲区地址 (uint16_t)ADC1_DR_Address, //ADC数据寄存器地址 DMA_BUF_SIZE, //缓冲区大小 DMA_DIR_PeripheralToMemory, //外设到内存 DMA_Mode_Circular, //循环转换 DMA_MemoryIncMode_Inc, //内存地址自增 DMA_Priority_High, //优先级为高 DMA_MemoryDataSize_HalfWord); //内存数据是半字位宽 16位 // DMA_SetCurrDataCounter(DMA1_Channel0,DMA_BUF_SIZE);// // Enable DMA1 channel0 DMA_Cmd(DMA1_Channel0, ENABLE); //启用DMA使能通道0 DMA_ITConfig(DMA1_Channel0,DMA_ITx_TC, ENABLE);//使能传输完成中断 //DMA_ITConfig(DMA1_Channel0,DMA_ITx_TC, DISABLE); //是否开启DMA中断 // DMA_ITConfig(DMA1_Channel0,DMA_ITx_HT, DISABLE); DMA_GlobalCmd(ENABLE); //启用或禁用全部DMA ADC_DMACmd(ADC1,ENABLE); //启用ADC DMA请求 // a short time of delay is required after enable ADC //delay_10us(3); //延时 ADC_ITConfig(ADC1, ADC_IT_EOC,DISABLE); //开启ADC中断 // ADC_ClearFlag(ADC1, ADC_FLAG_EOC); //清除EOC标志,即:清除转换完成标志 ADC_SoftwareStartConv(ADC1); //开始ADC转换 } |
| 你用多通道连续扫描方案,建议所有通道采样速度相同。 |
| 怎样设置?我就配置了一次采样速率,8通道是要配置8次吗? |
为何STM8S003F3进不了TIM1中断?
求STM8S105C6T6的安装软件完整版和安装步骤,谢谢!
STM8S003无法检测到引脚电平
STM8 @svlreg 问题
STM8AF62XX+L99PM62GXP LIN通讯的电路原理图有吗?官网提供了一套软件,没找到对应的原理图,请大家指教一下
求一个STM8S207例程
STMS005K6T6 如何采集内部参考电压。
stm8s003 adc中断和通道切换的问题
adc施密特触发器stm8
