STM8编译问题,case label value has already appeared in this switch
lucjn 提问时间:2017-11-28 11:00 /
在STM8的标准库中做了选择,STM8S003,
/* #define STM8S208 */      /*!< STM8S High density devices with CAN */
/* #define STM8S207 */      /*!< STM8S High density devices without CAN */
/* #define STM8S007 */      /*!< STM8S Value Line High density devices */
/* #define STM8AF52Ax */    /*!< STM8A High density devices with CAN */
/* #define STM8AF62Ax */    /*!< STM8A High density devices without CAN */
/* #define STM8S105 */      /*!< STM8S Medium density devices */
/* #define STM8S005 */      /*!< STM8S Value Line Medium density devices */
/* #define STM8AF626x */    /*!< STM8A Medium density devices */
/* #define STM8AF622x */    /*!< STM8A Low density devices */
/* #define STM8S103 */      /*!< STM8S Low density devices */
#define STM8S003      /*!< STM8S Value Line Low density devices */
/* #define STM8S903 */      /*!< STM8S Low density devices */
编译出现两个错误,
Error[Pe513]: a value of type "uint8_t *" cannot be assigned to an entity of type "uint32_t *" D:\work\声眼项目\软件\声眼程序3\Libraries\STM8S_StdPeriph_Driver\src\stm8s_flash.c 624
Error[Pe1578]: case label value has already appeared in this switch at line 180 D:\work\声眼项目\软件\声眼程序3\Libraries\STM8S_StdPeriph_Driver\src\stm8s_itc.c 184
Error[Pe1578]: case label value has already appeared in this switch at line 307 D:\work\声眼项目\软件\声眼程序3\Libraries\STM8S_StdPeriph_Driver\src\stm8s_itc.c 312
请问谁遇到过这类问题,怎么解决的,谢谢
赞 收藏 评论1 发布时间:2017-11-28 11:00
七哥 回答时间:2018-3-6 11:52:44
Error[Pe513]是指针类型不一致,一个是"uint8_t *",另一个是"uint32_t *";
Error[Pe1578]是case值冲突,同一个switch中出现了两个相同的case值,看一下 180和184行,是否相同。
