为何STM8S003F3进不了TIM1中断?
求STM8S105C6T6的安装软件完整版和安装步骤,谢谢!
STM8S003无法检测到引脚电平
STM8 @svlreg 问题
STM8AF62XX+L99PM62GXP LIN通讯的电路原理图有吗?官网提供了一套软件,没找到对应的原理图,请大家指教一下
求一个STM8S207例程
STMS005K6T6 如何采集内部参考电压。
stm8s003 adc中断和通道切换的问题
adc施密特触发器stm8
#include <math.h>
void TIM2_Init(void)
CLK_PCKENR1_PCKEN10=1;//开启定时器2外设时钟
TIM2_PSCR = 0x07;//使用内部时钟,4分频
//TIM2_CNTRH = 0x00;
//TIM2_CNTRL = 0x00;
TIM2_ARRH = 0x23;//自动重载值9000,计数到此值计数器从0开始重新计数
TIM2_ARRL = 0x28;
TIM2_CNTRH = 0x00;
TIM2_CNTRL = 0x00;
TIM2_CCR1H = 0xff;
TIM2_CCR1L = 0xff;
TIM2_CCR2H = 0xff;
TIM2_CCR2L = 0xff;
//TIM2_ARRH = 0xC0; // 自动重载寄存器,复位默认值为0xff,所以不用设置
//TIM2_ARRL = 0x00; // 计数达到该值即重头开始计数,(更新)
TIM2_IER = 0x01; // 允许更新中断
TIM2_SR1_UIF = 0;
//TIM2_CR1 = 0x81; // 开始计数
void LCD_Init(void)
CLK_PCKENR2_PCKEN22=1;//打开RTC时钟,LCD刷新频率与此时钟有关
CLK_PCKENR2_PCKEN23=1;//打开LCD时钟,读写LCD寄存器用到此时钟
LCD_CR1=0x06;//闪烁关 //8分频,//1/4duty,1/3bias
LCD_CR2=0xFE;//每像素暂停时间7clk,高驱动,高电压,内部电压
LCD_FRQ=0x08;//分频系数
LCD_PM0=0xFF;//直接向LCD_PM0寄存器的地址写入数据
LCD_PM1=0xFF;//直接向LCD_PM1寄存器的地址写入数据
LCD_PM2=0x1f;//直接向LCD_PM2寄存器的地址写入数据
LCD_CR4=0x02;//LCD_RAM页面切换,1/8duty,1/4bias
LCD_CR3=0x41;//使能LCD功能
void fuhaoxianshi(unsigned char number,unsigned char value)
switch(number)
case 1:
LCD_CR4&=0xFB;//切换寄存器0123
LCD_RAM7_S202=value;//S1 MMHG
break;
case 2:
LCD_CR4|=0x04;//切换寄存器4567
LCD_RAM0_S004=value; //S2心率百位
break;
case 3:
LCD_RAM4_S104=value;//S3心跳符号
break;
case 4:
LCD_RAM7_S205 =value;//S4心率不齐
break;
case 5:
LCD_RAM11_S309=value;//S5声音符号
break;
case 6:
LCD_RAM1_S009=value;//S6电量
break;
case 7:
LCD_RAM4_S109=value;// S7电池
break;
case 8:
LCD_RAM2_S019=value;//90
break;
case 9:
LCD_RAM12_S319=value;//120
break;
case 10:
LCD_RAM9_S219=value;//150
break;
case 11:
LCD_RAM9_S218=value;//记忆
break;
case 12:
LCD_RAM5_S118=value;//双人2
break;
case 13:
LCD_RAM2_S018=value;//双人1
break;
case 14:
LCD_RAM5_S119=value;//
break;
case 15:
LCD_RAM2_S020=value;
break;
case 16:
LCD_RAM13_S320=value;
break;
case 17:
LCD_RAM9_S220=value;
break;
case 18:
LCD_RAM6_S120=value;
break;
case 19:
break;
case 20://COL
break;
case 21:
LCD_RAM8_S214=value;
break;
case 22:
LCD_RAM5_S114=value;
break;
case 23:
LCD_RAM5_S113=value;
break;
case 24:
LCD_RAM1_S014=value;
break;
case 25:
LCD_RAM12_S316=value;
break;
case 26:
LCD_RAM12_S318=value;
break;
case 27:
break;
case 28:
break;
case 29:
LCD_RAM7_S203=value;
break;
void shuzixianshi(unsigned char number,unsigned char value)
unsigned char A=0; // A
unsigned char B=0; // F G B
unsigned char C=0; // E C
unsigned char D=0; // D
unsigned char E=0;
unsigned char F=0;
unsigned char G=0;
switch(value)
case 0:
A=1;
B=1;
C=1;
D=1;
E=1;
F=1;
break;
case 1:
B=1;
C=1;
break;
case 2:
A=1;
B=1;
D=1;
E=1;
G=1;
break;
case 3:
A=1;
B=1;
C=1;
D=1;
G=1;
break;
case 4:
B=1;
C=1;
F=1;
G=1;
break;
case 5:
A=1;
C=1;
D=1;
F=1;
G=1;
break;
case 6:
A=1;
C=1;
D=1;
E=1;
F=1;
G=1;
break;
case 7:
A=1;
B=1;
C=1;
break;
case 8:
A=1;
B=1;
C=1;
D=1;
E=1;
F=1;
G=1;
break;
case 9:
A=1;
B=1;
C=1;
D=1;
F=1;
G=1;
break;
case 10:
A=1;
D=1;
E=1;
F=1;
G=1;
break;
switch(number)
case 1:
LCD_RAM7_S200=A;
LCD_RAM10_S300=B;
LCD_RAM10_S301=F;
LCD_RAM0_S000=C;
LCD_RAM3_S100=D;
LCD_RAM3_S101=E;
LCD_RAM0_S001=G;
break;
case 2:
LCD_RAM10_S303=A;
LCD_RAM10_S302=B;
LCD_RAM11_S304=F;
LCD_RAM0_S002=C;
LCD_RAM3_S102=D;
LCD_RAM3_S103=E;
LCD_RAM0_S003=G;
break;
case 3:
LCD_RAM7_S206=A;
LCD_RAM11_S305=B;
LCD_RAM11_S306=F;
LCD_RAM4_S105=C;
LCD_RAM4_S106=D;
LCD_RAM0_S006=E;
LCD_RAM0_S005=G;
break;
case 4:
LCD_RAM7_S207=A;
LCD_RAM11_S307=B;
LCD_RAM11_S308=F;
LCD_RAM0_S007=C;
LCD_RAM4_S107 =D;
LCD_RAM4_S108=E;
LCD_RAM1_S008=G;
break;
case 5:
LCD_RAM0_S001=A;
LCD_RAM0_S000=B;
LCD_RAM3_S100=C;
LCD_RAM7_S201=D;
LCD_RAM3_S102=E;
LCD_RAM0_S002=F;
LCD_RAM3_S101=G;
break;
case 6:
LCD_RAM0_S004=A;
LCD_RAM0_S003=B;
LCD_RAM3_S103=C;
LCD_RAM7_S204=D;
LCD_RAM4_S105=E;
LCD_RAM0_S005=F;
LCD_RAM4_S104=G;
break;
case 7:
LCD_RAM0_S006=A;
LCD_RAM4_S106=B;
LCD_RAM4_S107=C;
LCD_RAM8_S208=D;
LCD_RAM4_S108=E;
LCD_RAM1_S008=F;
LCD_RAM0_S007=G;
break;
case 8:
LCD_RAM11_S311=A;
LCD_RAM1_S010=B;
LCD_RAM4_S110=C;
LCD_RAM4_S111=D;
LCD_RAM5_S112=E;
LCD_RAM1_S012=F;
LCD_RAM1_S011=G;
break;
case 9:
LCD_RAM12_S314=A;
LCD_RAM12_S313=B;
LCD_RAM1_S013=C;
LCD_RAM5_S114=D;
LCD_RAM5_S115=E;
LCD_RAM1_S015=F;
LCD_RAM1_S014=G;
break;
case 10:
LCD_RAM12_S317=A;
LCD_RAM2_S016=B;
LCD_RAM5_S116=C;
LCD_RAM5_S117=D;
LCD_RAM5_S118=E;
LCD_RAM2_S018=F;
LCD_RAM2_S017=G;
break;
case 11:
LCD_RAM1_S010=A;
LCD_RAM4_S110=B;
LCD_RAM8_S210=C;
LCD_RAM11_S310=D;
LCD_RAM8_S211=E;
LCD_RAM1_S011=F;
LCD_RAM4_S111=G;
break;
case 12:
LCD_RAM1_S012=A;
LCD_RAM5_S112=B;
LCD_RAM8_S212=C;
LCD_RAM12_S312=D;
LCD_RAM8_S213=E;
LCD_RAM1_S013=F;
LCD_RAM5_S113=G;
break;
case 13:
LCD_RAM1_S015=A;
LCD_RAM5_S115=B;
LCD_RAM8_S215=C;
LCD_RAM12_S315=D;
LCD_RAM9_S216=E;
LCD_RAM2_S016=F;
LCD_RAM5_S116=G;
break;
case 14:
LCD_RAM5_S117=A;
LCD_RAM2_S017=B;
LCD_RAM9_S217=C;
break;
void port_init(void)
PC_DDR=0x00;//引脚全为输入,带32k管脚和I2C,PC2双人控制,PC3 ON/OFF,PC4记忆,PC7设置
PC_CR1=0xff;//输入上拉
PC_CR2=0x08;//PC3电平中断允许,ON/OFF
PD_ODR=0x00;//数据输出寄存器,对应输出端口电平
PD_DDR=0x80;//PD7位电机驱动,其他引脚全为输入,PD4,PD5为COM4,COM5,其他引脚悬空
PD_CR1=0xff;//推挽输出,输入上拉
PD_CR2=0x00;//禁止外部中断
PE_ODR=0x00;//数据输出寄存器,对应输出端口电平
PE_DDR=0x40;//PE6为输出驱动电磁阀,其他引脚全为输入
PE_CR1=0xff;//推挽输出,输入上拉
PE_CR2=0x00;//输出模式最大2MHZ
PF_DDR=0x00;//输引脚全为输入,PD4,PD5为COM4,COM5,其他引脚悬空
PF_CR1=0xff;//输入上拉
PF_CR2=0x00;//禁止外部中断
PG_DDR=0x00;//输引脚全为输入,PD4,PD5为COM4,COM5,其他引脚悬空
PG_CR1=0xff;//输入上拉
PG_CR1=0x00;//禁止外部中断
void CLOCK_Init(unsigned char i)
if(i==1)//高频运行
CLK_ICKCR|=0x04;//开启内部低速时钟
CLK_CRTCR=0x10;//RTC时钟,采用外部低速时钟,不分频
CLK_SWR=0x04;//选择外部高速晶振为主时钟
CLK_SWCR|=0x02;//切换时钟源
CLK_CKDIVR=0x00; //12MHZ不分频
else //低频运行
CLK_CRTCR=0x04;//RTC时钟,采用内部低速时钟,不分频
CLK_SWR=0x08;//选择外部低速振荡器为主时钟
CLK_CKDIVR=0x00; //32k不分频
#pragma vector = TIM2_OVR_UIF_vector
__interrupt void EXIT_TIM2_OVR(void) //中断服务函数
TIM2_SR1_UIF =0;//清除中断标志
TIM2_CR1 = 0x00; //停止计数器1
TIM2_CNTRH =0x11;//计数器赋值4500,从4500开始计数
TIM2_CNTRL =0x94;
TIM2_CR1 = 0x81;//开始计数
PD_ODR^=0x80;//外部电机驱动端口,高电平驱动
void main(void)
unsigned int j=0;
asm("sim");//关全局中断
CLOCK_Init(0);//低频,内部低速时钟
port_init();//初始化IO口
LCD_Init();//初始化LCD
TIM2_Init();//初始化tim2
j=TIM2_SR1&0xC7;//读TIM2中断标志寄存器
shuzixianshi(10,1);//显示序号1
shuzixianshi(3,j/100);//显示TIM中断寄存器值
shuzixianshi(2,j%100/10);
shuzixianshi(1,j%10);
j=TIM2_CNTRH;//读TIM计数器值
j=(j<<8)+TIM2_CNTRL;
shuzixianshi(8,j%10000/1000);//显示计数器值
shuzixianshi(7,j%1000/100);
shuzixianshi(6,j%100/10);
shuzixianshi(5,j%10);
asm("rim");//开全局中断
shuzixianshi(10,2);//显示序号2
shuzixianshi(3,j/100);//显示中断标志寄存器值
j=TIM2_CNTRH;//读计数器值
while(1)//循环读取计数器中断标志寄存器和计数值并显示
shuzixianshi(10,3);
j=TIM2_SR1&0xC7;
j=TIM2_CNTRH;
上面是完整程序
单步调试,序号1,2,3段都正常,计数器从0开始计数,计数到9000,产生溢出中断(更新),
PD7口输出高电平,电机运转。
分段调试也运行正常,
但是如果让单片机自己运行,计数器到序号3段时中断寄存器的值就是0x07,表明两个比较中断和溢出中断标志都置位了,计数器进入中断程序,然后计数器从4500开始计数,PD7直接输出高电平,电机运转,计数到9000后电机停止,然后从4500再开始计数,再次计数到9000,电机停止,从现象开,程序在定时器溢出时能正常进入中断,但是还是老问题,为啥一起动定时器即进入定时器溢出中断,然后后续才能正常运行,调整了开始计数命令和全局中断命令位置也是同样的情况,
TIM2_ARRL = 0x28;
TIM2_CNTRH = 0x00;
TIM2_CNTRL = 0x00;
TIM2_CCR1H = 0xff;
TIM2_CCR1L = 0xff;
TIM2_CCR2H = 0xff;
TIM2_CCR2L = 0xff;
TIM2_SR1_UIF = 0;
在这段程序的末尾加一个强制更新命令即可,
TIM2_EGR_UG =1;
到这程序运行就全部正常了。
意法的定时器功能太多了
