求助各位大神,小弟在用STM32F4 进行SPI通讯,SPI 动作时,软件片选信号被拉高,IO口程序逻辑失控,请问是为啥? 如下图:CS本来都拉低了,SPI一动作,CS就被拉高了,我用的软件模拟CS信号,单独配置的GPIO口,且配置GPIO的函数与初始化SPI函数独立开了。 ![]() 上图中绿色为CLK,蓝色为MOSI,红色为CS,我配置希望他前8个clk是要拉低的。 我这段波形运行的代码为: void SendDatatoSSD(u8 addr,u16 dat) { u8 a=addr; u8 b=((dat >> 8) & 0xFF); u8 c=(dat & 0xFF); SSD2828_SDC=0; delay_ms(20); SSD2828_SDC=0; SPI1_ReadWriteByte(a); SSD2828_SDC=1; SPI1_ReadWriteByte(c); SPI1_ReadWriteByte(b); } 其中SPI读写函数就是特别常用的如下: u8 SPI1_ReadWriteByte(u8 TxData) { while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) != RESET); while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); SPI_I2S_SendData(SPI1, TxData); // while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); // return SPI_I2S_ReceiveData(SPI1); // } SPI 初始化函数和CS GPIO口配置都很常规 void SPI1_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);// RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);// GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_SPI1); //PB3?′ó??a SPI1 PG SPI SCLK GPIO_PinAFConfig(GPIOA,GPIO_PinSource6,GPIO_AF_SPI1); //PB4?′ó??a SPI1 PG SPI MISO GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_SPI1); //PB5?′ó??a SPI1 PG SPI MOSI GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;// GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;// GPIO_Init(GPIOA, &GPIO_InitStructure);// // RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//?′??SPI1 RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//í£?1?′??SPI1 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //éè??SPIμ¥?ò?ò?????òμ?êy?Y?£ê?:SPIéè???a???????òè???1¤ SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //éè??SPI1¤×÷?£ê?:éè???a?÷SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //éè??SPIμ?êy?Y′óD?:SPI·¢?í?óê?8?????á11 //SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //′?DDí?2?ê±?óμ????D×′ì??a??μ??? SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //′?DDí?2?ê±?óμ????D×′ì??aμíμ??? //SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //′?DDí?2?ê±?óμ?μú?t??ì?±???£¨é?éy?ò???μ£?êy?Y±?2é?ù SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //′?DDí?2?ê±?óμ?μú?t??ì?±???£¨é?éy?ò???μ£?êy?Y±?2é?ù SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSSD?o?óéó2?t£¨NSS1ü??£??1ê?èí?t£¨ê1ó?SSI??£?1üàí:?ú2?NSSD?o?óDSSI?????? SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128; //?¨ò?2¨ì??ê?¤·??μμ??μ:2¨ì??ê?¤·??μ?μ?a256 ?÷?μ84M??DD·??μ SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //???¨êy?Y′?ê?′óMSB???1ê?LSB???aê?:êy?Y′?ê?′óMSB???aê? SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC?μ????μ??à??ê? SPI_Init(SPI1, &SPI_InitStructure); //?ù?YSPI_InitStruct?D???¨μ?2?êy3?ê??ˉíaéèSPIx??′??÷ SPI_Cmd(SPI1, ENABLE); SPI1_ReadWriteByte(0xff); } 我后来为了验证是不是SPI动作就把CS拉高,还在CS置0后Delay了一段时间,发现确认SPI移动,CS就被拉高了。波形如下: ![]() 这个我就奇了怪了!!!!! 这个问题困扰我3天3夜了,后来我都想不用硬件SPI了,直接用纯软件模拟SPI的各个信号和逻辑。 但来论坛搜了好久,我发现SPI读写函数有好多种,我就换了一种,发现了神奇的事情: u8 SPI1_ReadWriteByte(u8 TxData) { u16 u16Temp; /* Loop while DR register in not emplty */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); if (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == SET) { SPI_I2S_ReceiveData(SPI1); } /* Send byte through the SPIx peripheral */ SPI_I2S_SendData(SPI1, TxData); /* Wait to receive a byte */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); u16Temp = SPI_I2S_ReceiveData(SPI1); while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == SET); /* Return the byte read from the SPI bus */ return (u8)(u16Temp); } ![]() 问题解决了,我刚开始学ARM,用的STM32F4系列,两端代码差别怎么就那么大呢,第一段SPI的读写很常规啊?为啥就出那个问题呢? 我把这个遭遇分享给大家,向大家求教。 最后,经验不足想问问大家: return (u8)(u16Temp); 这种表述是啥意思?一般不是return (u16Temp);就好了吗? 哎,真实苦了我了,求老师啊,我企鹅475437231,求大家批评啊。 |
盘古UE-STM32F407工控板原理图
STM32F407 定时器触发DMA 求助大神
【MCU实战经验】基于STM32F407的音频播放器设计
【STM32F429心得\疑问】+STM32F4之FSMC和FMC
STM32F429读取IO口传输的数据速率
STM32F407ZGT6 手摸芯片背部重启
STM32F401RE NUCLEO求助,串口一直不能进中断
读取STM32F407内部温度传感器值错误
STM32F429多路内部ADC独立采集的办法
STM32F407 的1588问题(已解决)
我记得这个是数据类型转换。
SPI 的时候,CS一直是拉低的,按说不应该出现 波动的。难道是因为F4的原因吗?
我的这个CS是软件模拟的,所以我是刻意先拉低后再在1个byte后拉高的,可是就是不清楚为啥像图1一样SPI一动作就给拉高了。。。
我意思是,按照SPI协议来说,CS拉高后就停止通信了。所以,你这个刻意拉高 我就理解 不了了
嗯嗯,我现在是比较纠结像我图1抓的波形那样,SPI一动作,我本来拉低的GPIO pin ,居然瞬间被拉高,但我换了另一个函数后就变好,很是奇怪。
在程序运行中需要这个变量的高八位做存储之类的运算,但是最后需要的结果是这个变量的低八位,所以定义了一个个16位的变量,最后返回的时候只取了低八位。
希望能帮到楼主理解
点评
然后想问问,SPI1_Init里面,
最后到底启用RCC没有呢?
RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);是复位SPI1
RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);是停止复位SPI1
我这样理解没错吧,
确实是换了读写函数就好了,是不是第一次用的读写函数没有先收SPI 导致某个标志位溢出导致的异常呢?
