在STM32F4上面SPI2 DMA 接受不到数据
xiaowang11 提问时间:2018-12-3 16:26 /
大家好,我最近遇到一个问题,SPI2 DMA 接受不到数据,不知道哪里遇到了问题,向大神们请教一下。比较急,谢谢!
下面是我的代码:
DCMI 通过DMA给 SPI发数据,DCMI有数据发出,且数据正确。但是SPI没有接受到数据,且LCD没有显示摄像头端的数据(spi2驱动LCD是ok的)。
DCMI端代码:这是ok的通过FSMC验证过。
        DMA_InitTypeDef  DMA_InitStructure;
        //spi tx -> DMA_Channel_3
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2,ENABLE);
        DMA_DeInit(DMA2_Stream1);//µÈ´ýDMA2_Stream1
        while (DMA_GetCmdStatus(DMA2_Stream1) != DISABLE){}
  DMA_InitStructure.DMA_Channel = DMA_Channel_1;  //ͨµÀ1 DCMIͨµÀ
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&DCMI->DR;
  DMA_InitStructure.DMA_Memory0BaseAddr = (u32)&SPI2->DR;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = DMA_BufferSize;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream1, &DMA_InitStructure);
SPI DMA端配置代码:
void SPI2_DMAInit (void)
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Stream3);
    DMA_DeInit(DMA1_Stream4);
                while (DMA_GetCmdStatus(DMA1_Stream3) != DISABLE){printf("-");}
    DMA_InitStructure.DMA_Channel  = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&(SPI2->DR));
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)SPI_RXBUFFER;
    DMA_InitStructure.DMA_BufferSize = 1;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_Init(DMA1_Stream3, &DMA_InitStructure);
//    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)SPI_TXBUFFER;       //
//    DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
//    DMA_InitStructure.DMA_BufferSize = 8;                               //
//    DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
//    DMA_Init(DMA1_Stream4, &DMA_InitStructure);
    SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
    SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE);
    DMA_ITConfig(DMA1_Stream3, DMA_IT_TC | DMA_IT_TE, ENABLE);
    DMA_ITConfig(DMA1_Stream4, DMA_IT_TC | DMA_IT_TE, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannel =ENABLE;
    DMA_Cmd(DMA1_Stream3, ENABLE);
    DMA_Cmd(DMA1_Stream4, ENABLE);
                printf("DMA 000 \n");
void DMA1_Stream3_IRQHandler (void)
    if (DMA_GetITStatus(DMA1_Stream3, DMA_IT_TCIF3) == SET)
        DMA_ClearFlag(DMA1_Stream3, DMA_IT_TC);
        DMA_ClearFlag(DMA1_Stream4, DMA_IT_TC);
        DMA_ClearITPendingBit(DMA1_Stream3, DMA_IT_TCIF3);
        DMA_ClearITPendingBit(DMA1_Stream4, DMA_IT_TCIF4);
        SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, DISABLE);
        SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, DISABLE);
                        printf("DMA 111 \n");
                printf("DMA 222 \n");
参与人数 1 ST金币 +20 收起 理由
STMCU + 20
赞 收藏 1 评论2 发布时间:2018-12-3 16:26
xiaowang11 回答时间:2018-12-3 16:37:17
第一次使用SPI DMA有点菜,希望高手能够指点指点。
cruelfox 回答时间:2018-12-13 09:50:15
这一句有问题啊,RAM地址怎么写成SPI寄存器了?
