菜鸟求助,STM32F103RGT6位带操作不成功
简单的辉辉 提问时间:2019-5-30 17:02 /
各位大神,我是一个入门级的超级菜鸟,遇到一个问题:
为啥子我同样的位带操作在STM32F103C8T6上操作成功,但是在STM32F103RGT6位带操作不成功。搞得我很郁闷ing
求科普
赞 收藏 评论4 发布时间:2019-5-30 17:02
4个回答
edmundlee 回答时间:2019-5-30 18:23:09
怎样操作不说
是怎样得知不成功也不说
也许回答你的问题不是很困难,
但要猜到你问的问题确实很难呢
xing1954 回答时间:2019-5-31 04:42:15
检查下位带地址对不对。
STMCU + 2
简单的辉辉 回答时间:2019-5-31 11:45:55
#ifndef _system_H
#define _system_H
#include "stm32f1xx_hal.h"
#define BITBAND(addr, bitnum) ((addr & 0xF0000000)+0x2000000+((addr &0xFFFFF)<<5)+(bitnum<<2))
#define MEM_ADDR(addr)  *((volatile unsigned long  *)(addr))
#define BIT_ADDR(addr, bitnum)   MEM_ADDR(BITBAND(addr, bitnum))
#define GPIOA_ODR_Addr    (GPIOA_BASE+12) //0x4001080C
#define GPIOB_ODR_Addr    (GPIOB_BASE+12) //0x40010C0C
#define GPIOC_ODR_Addr    (GPIOC_BASE+12) //0x4001100C
#define GPIOD_ODR_Addr    (GPIOD_BASE+12) //0x4001140C
#define GPIOE_ODR_Addr    (GPIOE_BASE+12) //0x4001180C
#define GPIOF_ODR_Addr    (GPIOF_BASE+12) //0x40011A0C
#define GPIOG_ODR_Addr    (GPIOG_BASE+12) //0x40011E0C
#define GPIOA_IDR_Addr    (GPIOA_BASE+8) //0x40010808
#define GPIOB_IDR_Addr    (GPIOB_BASE+8) //0x40010C08
#define GPIOC_IDR_Addr    (GPIOC_BASE+8) //0x40011008
#define GPIOD_IDR_Addr    (GPIOD_BASE+8) //0x40011408
#define GPIOE_IDR_Addr    (GPIOE_BASE+8) //0x40011808
#define GPIOF_IDR_Addr    (GPIOF_BASE+8) //0x40011A08
#define GPIOG_IDR_Addr    (GPIOG_BASE+8) //0x40011E08
#define PAout(n)   BIT_ADDR(GPIOA_ODR_Addr,n)
#define PAin(n)    BIT_ADDR(GPIOA_IDR_Addr,n)
#define PBout(n)   BIT_ADDR(GPIOB_ODR_Addr,n)
#define PBin(n)    BIT_ADDR(GPIOB_IDR_Addr,n)
#define PCout(n)   BIT_ADDR(GPIOC_ODR_Addr,n)
#define PCin(n)    BIT_ADDR(GPIOC_IDR_Addr,n)
#define PDout(n)   BIT_ADDR(GPIOD_ODR_Addr,n)
#define PDin(n)    BIT_ADDR(GPIOD_IDR_Addr,n)
#define PEout(n)   BIT_ADDR(GPIOE_ODR_Addr,n)
#define PEin(n)    BIT_ADDR(GPIOE_IDR_Addr,n)
#define PFout(n)   BIT_ADDR(GPIOF_ODR_Addr,n)
#define PFin(n)    BIT_ADDR(GPIOF_IDR_Addr,n)
#define PGout(n)   BIT_ADDR(GPIOG_ODR_Addr,n)
#define PGin(n)    BIT_ADDR(GPIOG_IDR_Addr,n)
#endif
这是头文件
手里有两块开发板,一块是C8T6的,一块是RGT6的。
用STM32cube分别选 STM32F103C8T6和STM32F103RGT6建立不同的工程并生成代码,设置好同样的PC1端口(端口设置也一样,推挽模式,上拉、高速)输出点亮LED,LED正极直接接IO口,负极接GND。在主函数中设置Pcout(1)=1;STM32F103C8T6的板子可以点亮led,但是STM32F103RGT6的LED不亮。
edmundlee 回答时间:2019-5-31 12:47:29
这段代码没问题
你的问题应该在别的地方
参与人数 1蝴蝶豆 +1 收起 理由
STMCU + 1
